Rockford, IL - HDTV - Page 41 - AVS Forum | Home Theater Discussions And Reviews
post #1201 of 1210 Old 02-02-2015, 08:59 AM
mudd123's Avatar
Originally Posted by MJA28 View Post
1st time I open the attic since we bought the house 7 years ago.not easy to get to .plus we have no use for it.
I wire on the left for dish network I think. the previous owner lift .we use Comcast now .
Ok cool looks like you have good access up there. I use a RCA antenna I bought at Menards, I think it was model ANT3636 or something like that. Unless you want to order online, Menards has a pretty good selection of antenna supplies. You could hang a 2x4 from the joists up there (ant. would hang from ceiling) and mount on that or put it on a tripod from Menards. ($25) I would go with the tripod, easier to rotate for adjustment. If you go with a RCA antenna from there, get the biggest one that will fit up there - Remember if you want to get Chicago stations you need to point the skinny end of the antenna east - so measure accordingly. If you want Rockford (may be easier to receive), you need to point northwest - again measure accordingly. Measuring up there will let you know how big of an antenna you can get up there, mine is huge when unfolded!
As for the Rats nest of wires you have up there, bypass all of it and run a single cable out of your attic to your TV (temporary) Then you can point your antenna for the best signal, lock in place and then "hardwire" it using those cables up there. Remember, the more you cable length you run and the more you split it, the signal degrades.
If you want to order online, I was looking at his antenna : http://dennysantennaservice.com/hd_s...enna-html.html
That antenna was the one my friend is using in Tilton Park (off of North 1st street) I KNOW it works good.
The RCA antennas at Menards are cheaper, mine was $70 they have a smaller that was $50
You might want to consider a amplifier. I am using a cheap RCA single output 12db amplifier, it really helped the signal. You can get that at Menards too. I think Wal-mart has it also.
Good Luck and post back with your results!
Mike
mudd123 is offline
post #1202 of 1210 Old 02-02-2015, 10:55 AM
MJA28's Avatar
Mike
Thanks for the help. if the attic option doesn't work the 2ed option is going to cost me a lot with labor($200 and up just for labor?) .here goes my savings for the cz 75 .lol
MJA28 is offline
post #1203 of 1210 Old 02-04-2015, 11:49 PM
sebenste's Avatar
Quoted: 21 Post(s)
Hey MJA28,
I'm on the north side of DeKalb. I can't put an antenna outside due to restrictions in our subdivision. In the attic of a one-story, I have a ChannelMaster 4228 and a large, VHF-only, channel 2-13 antenna to pick up WBBM. I get everything clear, except WBBM comes in a little choppy at times. All the Rockford stations except WREX come in off the side of the antenna with no problem. I am using the ChannelMaster 7777 preamplifier. And although I need to slightly adjust my VHF antenna, everything but WBBM comes in glitch-free.
A ChannelMaster 4228HD should do the trick for all except WBBM, and with a ChannelMaster 7777, as long as you have a good east view with no major buildings blocking you, I say you have a good shot at getting everything you want.
Gilbert
sebenste is offline
post #1204 of 1210 Old 02-05-2015, 03:21 PM
MJA28's Avatar
Originally Posted by sebenste View Post
Hey MJA28,
WooW.I talked to you years ago.lol
U live in the River mist subdivision?
MJA28 is offline
post #1205 of 1210 Old 02-05-2015, 03:23 PM
MJA28's Avatar
By the way. My attic is facing First st
MJA28 is offline
post #1206 of 1210 Old 02-05-2015, 07:52 PM
sebenste's Avatar
Quoted: 21 Post(s)
Yep, I am near there! If you can get the antenna in the attic and point it east, you've got a good shot at getting at least most of the stations.
sebenste is offline
post #1207 of 1210 Old 02-15-2016, 07:52 PM
aclerok's Avatar
Anyone else noticed with live musical performances on CBS the audio mix is wrong? With both the Super Bowl halftime and the granny's performances I get the mix only out of my left front channel. However the rest of the show comes through fine in all channels. Do I have something weird going on or is everyone getting the same thing?
aclerok is offline
post #1208 of 1210 Old 06-13-2016, 02:09 PM
Roadboss's Avatar
Is there some sort of issue with the transmission towers of WIFR (23) & WQRF (39) from Rockford? I’m in Beloit, WI with a rooftop antenna, I get 13 & 17 from Rockford & all the Madison channels. 23 pixelates a lot and 39 hardly wants to come in at all. I’m just wondering if it’s me or them? I’m hoping they’re involved in an upgrade and soon their signal will improve.
Roadboss is offline
post #1209 of 1210 Old 06-14-2016, 06:20 AM
sebenste's Avatar
Quoted: 21 Post(s)
Hey Roadboss,
They are at full power. If you don't point your antenna at their Rockford towers, even from Beloit, you'll have issues. 39 is at high power, but is low on their tower. 23 is at 100,000 watts...enough to cover the metro if you have a decent antenna pointed at it.
Gilbert
sebenste is offline
post #1210 of 1210 Old 06-14-2016, 09:20 AM
Roadboss's Avatar
Thanks Sebenste,
Height must be my problem then. I’m in the turtle creek bottoms and my antenna is only about 20’ high. It’s frustrating that I get 13 & 17 so well and have problems with 39 especially.
Roadboss is offline
