OTA Antenna Advice Please. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-25-2015, 01:24 PM - Thread Starter
Liked: 0
I need some help improving the reception.
I currently have a TERK Omnidirectional amplified antenna in my attic. The link is below. I also have it hooked up to a TIVO Roamio (which has four tuners and I think weakens the signal).
It works OK, but I'd like to strengthen my signals as most come in around 60 when I do an analysis- I would also like to get FOX in HD (that was my biggest motivation).
I tried to make a strong upgrade with Solid Signal Xtreme Signal HDB8X VHF/UHF Outdoor TV Antenna (HDB8X). I figured this would me much stronger- I also attached a pre-amp Winegard LNA 200- but my results were a weaker signal (I pointed it right at the tower out of Kalkaska and those signals were weaker).
I figured the much larger antenna would be a big help, but there wasn't.
Below is my TV Fool report (it was here, but since I have fewer than 5 posts I cannot put any links in.
Some final questions
Can I attach a distribution AMP to the TERK antenna I currently have to help with signal loss?
Why is this small TERK antenna doing a better job than the large one I put in?
Any antenna suggestions for some thing stronger? It must go in the attic unfortunately (and I know my location isn't great as I need to pick up stations 25-45 miles away.
Thanks in advance for your help. This has been frustrating and am running out of ideas.
orangeturtle is offline
post #2 of 4 Old Yesterday, 09:52 AM
Mr.G's Avatar
Quoted: 311 Post(s)
Liked: 170
Sometimes you get better assistance in the Technical advice area.
http://www.avsforum.com/forum/25-hdtv-technical/
Since you are unable to post links at the moment can you post your latitude and longitude?
Most smartphones will do this for you especially if you have a compass app.
Lat/Lon are obtainable by typing your address into Google Maps and clicking on the star that marks your location.
All I Really Need to Know I Learned in Movies
Mr.G is online now
post #3 of 4 Old Yesterday, 10:53 AM - Thread Starter
Liked: 0
Here's my location from Google Maps.
44.757603, -85.600433
post #4 of 4 Unread Today, 09:02 AM
Mr.G's Avatar
Quoted: 311 Post(s)
Liked: 170
Here is the link to your TV Fool report.
http://www.tvfool.com/?option=com_wr...8e03b86e16cb49
But as I mentioned it's probably best to post your problem in the Technical forum.
Mr.G is online now
