Louisville, KY - HDTV - Page 134 - AVS Forum | Home Theater Discussions And Reviews
post #3991 of 4019 Old 06-12-2013, 02:49 AM
HDTVChallenged's Avatar
Liked: 213
Originally Posted by donp326 View Post
Not withstanding weather conditions Ch 32 as of June 1 at my best estimate began having a significant issue with artifacts. Never noticed them before All other channels come in full to moderate power. 32 will "burst" up to 75% then drop to 58% go out then come back and burst again then it's lost. This channel used to be perfect winter or summer it always came in no it seems to be toast.
FWIW, I spun my UHF back around to the 'Ville, and did a quick check of the Louisville stations around 7:30pm (ish) yesterday (6/11/13.) Everything appeared "nominal" and consistent with RF strength and RS quality readings I've gotten in the past.
What you've described is consistent with what you'd expect with interference from a distant station ... then again it could just be a bad coax connector that's going intermittent with warmer temps ...
HDTVChallenged is offline
post #3992 of 4019 Old 06-12-2013, 08:18 AM
donp326's Avatar
Thank you for fir your insight on my issue I will check my connectors but I have two Tv's hooked up with a splitter one is input directly from the antenna. it has a watchable picture with artifacts. The other TV comes through the Dish DVR It looses the transmission entirely. I don't know how to determine if another channel is causing this issue. So for the moment I have added the Lexington channel 27 to get CBS.
donp326 is offline
post #3993 of 4019 Old 06-13-2013, 05:22 AM
donp326's Avatar
Great news WLKY 32 straightened itself out last night coming in at the old 75% it was doing before June 1.
donp326 is offline
post #3994 of 4019 Old 06-13-2013, 08:39 AM
csworldwide1's Avatar
WHAS 11's parent company, Belo has agreed to be bought out by Gannett for $1.5 million.
More info on WHAS's webpage.
csworldwide1 is offline
post #3995 of 4019 Old 06-13-2013, 11:05 PM
Liked: 213
Humm ... that should be interesting ... isn't WLKY a Gannett property.
On the plus side, perhaps WHAS will finally broadcast at 720p.
post #3996 of 4019 Old 06-13-2013, 11:51 PM
WLKY is owned by Hearst. WAVE 3 is owned by Raycom. & WDRB is owned by Block Communications.
post #3997 of 4019 Old 06-14-2013, 05:27 AM
George Molnar's Avatar
Shouldn't that be $1.5 billion ??
George Molnar is offline
post #3998 of 4019 Old 06-14-2013, 10:44 PM
Liked: 213
Right then ... Apparently, I was thinking about "The Courier-Journal" who was quick to publish a story, yesterday, about how this won't violate the media ownership rules.
post #3999 of 4019 Old 06-18-2013, 07:06 PM
jb_ky1's Avatar
Should be a nice upgrade with their news. True HD and maybe a new set.
Also WKYT has made 27.2 (CW Lexington) in HD again.
jb_ky1 is offline
post #4000 of 4019 Old 06-18-2013, 10:03 PM
You was right. It was $1.5 Billion.
WLKY use to be owned by Gannett from 1979 to 1983. In '79, it was owned by Combined Communications Corporation and then it was later merged with Gannett.
post #4001 of 4019 Old 06-18-2013, 10:30 PM
Liked: 213
Oh my ... I must have been having flashbacks from my college days @ UL ... Life on the rabbit-ears. biggrin.gif
That would have been before WHAS and WLKY swapped network affiliations too.
post #4002 of 4019 Old 06-18-2013, 10:32 PM
Liked: 213
Humm ... this can't be good ...
post #4003 of 4019 Old 01-22-2014, 05:18 PM
williammanda's Avatar
Hello all!
I'm cutting comcast cable in elizabethtown and looking to get setup with OTA stations out of Louisville. Here is my tv fool info:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b94393a58a8bb
I am basically only concerned with the top 8 channels on the right hand chart. It appears that I will need two antennas:
Antenna 1
Channels 19 and 43
UHF only
Indoor Multi-Directional
Antenna 2
Channels all the rest
VHF and UHF
Rooftop Large Directional
In reviewing a couple of sites (this one included), it seems the the following two antennas should work for antenna 2:
(My northern angle is mostly covered by a couple of trees but I might be able to squeeze between them)
Winegard HD 7698P
HBU44 or HBU55
I was looking at trying this one for antenna 2 since it was at Walmart, RCA ANT700R, but the range looks to be too short. If the range is too short it could be used for antenna 1. Please give your thoughts for antenna 1 candidate. Also I wanted to inquire your opinion on the Mohu SKY.
I'm looking to mount antenna 2 on the roof which should be about 15' minimum. I will be connecting 1 pc tv tuner to antenna 1 and 3 pc tv tuners to antenna 2. Please let me know what my expectations should be concerning the overall quality and dropouts vs average cable tv as well as on everything else including cable spec's, amp's, grounding, installation, etc...
williammanda is offline
post #4004 of 4019 Old 01-22-2014, 08:06 PM
mtallent's Avatar
I live about 6 miles north west of Cecilia and I had a VHF-UHF antenna from Radio Shack was there biggest I think rated at 150 miles range. It was on the chimney of my 2 story house about 25-30 feet high. Pointed toward Louisville stations. I got all 8 on your list with the one antenna. I used the tuner in my HDTV and it was very reliable until the wind bent the mounting pole and the bands around my chimney broke. I have not yet put up another, think I am getting a little old to be climbing on a steep roof. I did have a Channel Master 7777 pre-amp mounted at the antenna I highly recommend them if you can find one, don't think they make that model any more but it has a very low noise figure. I would try it with one antenna first I think it will work as the stations off axis are much closer to you.
Mike T
mtallent is offline
post #4005 of 4019 Old 03-27-2014, 07:14 AM
danshane's Avatar
Quoted: 55 Post(s)
Liked: 60
Does anyone else have trouble pulling WBNA channel 21 and its subs? I know its physical channel is VHF-8. I was originally able to get it (though sometimes pixelated) even with my Winegard roof antenna aimed at the New Albany tower farm, but lately I do not even pick it up when scanning. I live in Jeffersontown, so my roof antenna is at nearly 90 degrees to the Shepherdsville broadcast. I cannot get decent line-of-sight with an indoor antenna.
EDIT: I discovered the "professional" who installed my rooftop antenna had it aimed due north. Reorienting the antenna made all the local channels clear and stable.
Be seeing you...
Dan Shane
danshane is offline
post #4006 of 4019 Old 04-28-2014, 08:13 AM
Captdan1803's Avatar
I just kicked cable to the curb and put an indoor antenna in the attic. So far so good but local NBC channel is much weaker than the local CBS even though they transmit from the same area. Do some stations broadcast at a weaker HD signal than others?
Captdan1803 is offline
post #4007 of 4019 Old 04-28-2014, 08:29 AM
Does anyone know why Wave3 is so weak of a signal compared with say WHAS? Just kicked cable to the curb and have noticed how weak I am receiving Wave3 here in Crestwood. Would a pre amp help?
post #4008 of 4019 Old 04-28-2014, 11:49 AM
ADTech's Avatar
Quoted: 104 Post(s)
Liked: 57
WAVE-DT transmits at 1,000 kW, the maximum legal limit for a UHF station.
Tech support for Antennas Direct
ADTech is offline
post #4009 of 4019 Old 04-29-2014, 12:47 AM
Liked: 213
What type of antenna do you have? WHAS is on VHF-Hi (Ch11) ... WAVE is UHF (Ch47) ... All of the other major Lou. station are also on UHF as well.
post #4010 of 4019 Old 05-03-2014, 07:01 AM
Super Moderator
DrDon's Avatar
Quoted: 595 Post(s)
Liked: 1073
Moved to the Louisville thread.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4011 of 4019 Old 06-22-2014, 01:15 PM
jazzlobster's Avatar
Liked: 0
Louisville Antennas?
My apologies if this is the incorrect forum for this, but I live in Louisville, KY (St. Matthews to be more specific), and am on the cusp of cutting the cable cord.
We're not particularly far from the transmitters here (less than 15 miles, according to Antennaweb), but I get really lousy reception from rabbit ears. My guess is it's a combination of my TV on the southwest corner of a house, and the towers are mostly to the northeast, and it's an old brick house with plaster and lath walls. Can you say faraday cage?
My question here has to do with outdoor OTA antennas: I'm getting to be a little long in the tooth for climbing up on the roof, and was wondering how important antenna height is for HD reception?
I figure I can strap an antenna up to a post on my back porch and get about 20 feet up above ground without a problem. Should I expect that to work?
jazzlobster is offline
post #4012 of 4019 Old 06-22-2014, 04:46 PM
mtallent's Avatar
With antennas you don't know until you try it. Just use something a little better than "rabbit ears". There is no such thing as a "HD" antenna just get something that will work for high-VHF and UHF frequencies.
Mike T west of E-town
mtallent is offline
post #4013 of 4019 Old 07-24-2014, 10:33 AM
William Smith's Avatar
Just a quick note:
I'm retiring from KET effective August 1st, 2014 due to family health issues.
William
William Smith is offline
post #4014 of 4019 Old 08-10-2014, 02:20 PM
bnewt's Avatar
Quoted: 55 Post(s)
what has happened to 58.2........it's now broadcasting the same as 58.3
May God Guide and Guard the USA!
bnewt is offline
post #4015 of 4019 Old 09-27-2014, 11:20 AM
WaarrEagle's Avatar
Does anyone have any recommendations for OTA antenna installers in Lexington? I am trying to help some family there get better OTA HDTV reception. They already have coax cable running on the exterior of their home on the east side so i am thinking that putting an antenna up on their chimney would greatly help reception. TVFool report is here. Thanks!
WaarrEagle is offline
post #4016 of 4019 Old 10-17-2014, 07:02 PM
tripelo's Avatar
Quoted: 18 Post(s)
WBKI (RF Channel 19) Signal Strength
Does anyone know if WBKI (RF 19) has made changes to antenna or transmitter in last several months?
Haven't read of any official FCC changes, and RabbitEars usually keeps informed of such.
The reason for the inquiry is that WBKI-19 has for a few years been easily received in Russell County, KY (41 miles to southeast) . For the past several months signal strength has dropped very signifcantly. Looking back at past 2-3 years of recorded signal measurements & spectrums, they show the signal was several dB stronger than currently at this particular location. Measurements made at a neighbor's antenna, more than a quarter mile away*, indicate similar results.
WBKI-19 present signal could be considered relatively strong, compared to most other distant stations (say Lexington ~ 70 miles away), but it can no longer be casually received, such as in an antenna sidelobe.
* A signal obstruction is a possibility. The neighbor's location, relative to this particular location, is almost perpendicular to the signal path to WBKI-19. An obstruction near either receiving location would have to be very wide to affect both locations. And, if close to WBKI, must surely be a fairly tall obstruction.
tripelo is offline
post #4017 of 4019 Old 02-13-2015, 10:22 AM
Liked: 0
Louisville KY OTA & HDTV
Hello,
I just found this site and thought some of you may offer some help. I recently signed up for SlingTV as a final step to cutting my cable cord. It's really great. So now all that's left is getting my local OTA signals and I'm good to go. I have two TVs - an older (7 years or so) 42" 1080p, and a new 29" 720p smart TV. The new smaller TV has a built in antenna and I can find @10 channels or so. About 4 get a really clear, crisp HD picture. All the others (WHAS 11.1, KET, WLKY 32.1 and others) freeze immediately when I tune into them. I have not tried yet but I am assuming I'll need Mohu Leaf or something on the larger, older TV.
I'm new to this but learning more every day. If anyone can be of any assistance, it would be much appreciated.
imapirate is offline
post #4018 of 4019 Old 02-23-2015, 03:02 PM
Balloonfanatic's Avatar
Quoted: 54 Post(s)
Liked: 40
Originally Posted by imapirate View Post
Hello,
digital tv indoors can be fickle especially if you have plaster walls. the cheap antennas $10-15 are junk and not worth the money. its trial and error. if the antenna you buy is junk return it otherwise they will sell more junk.
(make sure you buy a combination antenna that receives both the vhf and uhf band) because whas ch.11 and ch.6 and ch. 21 broadcast on the vhf band while the others transmit on the uhf band.
btw (the cincinnati avs forum thread is more active). www.avsforum.com/forum/45-local-hdtv-info-reception/306883-cincinnati-oh-hdtv-483.html.
To see what actual channel frequency the louisville channels are broadcasting on go to rabbitears.info and type in a louisville channel call sign in the search box at the top of the page. example: whas, wave
ive also noticed the off brand tv's like Emerson have much weaker tv tuners than the Sony and Samsung tuners. the only way to fix that is with a better amplified antenna.
Balloonfanatic is offline
post #4019 of 4019 Old 03-16-2015, 12:46 PM
danshane's Avatar
Quoted: 55 Post(s)
Liked: 60
Hello,
Location, location, location. Precisely where do you live? TV Fool can give you a pretty accurate gauge of the sort of OTA signal you can expect. (http://www.tvfool.com/?option=com_wrapper&Itemid=29)
I am in the Jeffersontown area and use a roof-top antenna for my primary TVs, but I feed two other sets with a Homeworx indoor flat antenna taped to a wall or window above each unit. (http://www.amazon.com/Homeworx-HW110.../dp/B008KVUAGU)
In both cases moving the antenna around to find the most stable signal makes a huge difference. I have tried the Mohu Leaf and found no appreciable difference in the signal quality compared to the cheapie Homeworx. I have also tried brands from major retail stores (GE and RCA are typically found there), and they were quite poor in comparison. So you need not spend a lot, but there are differences.
Be seeing you...
Dan Shane
danshane is offline
