Louisville, KY - HDTV - Page 135 - AVS Forum | Home Theater Discussions And Reviews
post #4021 of 4029 Old 09-28-2016, 05:23 PM
mvcg66b3r's Avatar
Quoted: 115 Post(s)
Originally Posted by knightof502 View Post
I have contacted WBNA's station management through Facebook about W50CI-D losing its WBNA feed (as discussed previously in this post), and they are looking into finding funding for moving the VHF 8 tower to a better site, terrain-wise.
Didn't the FCC put a freeze on transmitter moves until after the spectrum auction?
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is online now
post #4022 of 4029 Old 09-28-2016, 06:01 PM
Trip in VA's Avatar
Quoted: 860 Post(s)
Liked: 255
Send a message via AIM to Trip in VA
Yes it did.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #4023 of 4029 Old 04-14-2017, 10:02 AM
Liked: 0
ION moves to WDRB 41-3
Back in March, WBNA dropped the ION lineup in favor of an independent primetime lineup. WDRB has launched channel 41-3 to carry the entire ION schedule. Previously, ION was not carried full-time on WBNA. Low powered W50CI-D dropped its WBNA simulcast on 50-1 to carry Buzzr, the classic game show network.
knightof502 is offline
post #4024 of 4029 Old 04-15-2017, 05:14 AM
jb_ky1's Avatar
Quoted: 39 Post(s)
I am guessing that WMYO will retian the CW network since WBKI is going off the air?
Check out my TV design work!
https://jasonburnettky.wordpress.com
jb_ky1 is offline
post #4025 of 4029 Old 04-17-2017, 07:21 AM
woowoo's Avatar
That is correct.
Broadcast Engineer
woowoo is offline
post #4026 of 4029 Old 07-27-2017, 10:11 AM
idntknw's Avatar
Liked: 1
Hey everyone. Just got into the whole OTA antenna thing so please bare with me.
My current setup is a Clearstream 4v about 25' on the roof going to the Channel Master DVR+ with the Channel Master Amplify. The Amplify really helped all around but even after hooking up the Amplify I still can't get WLKY.
Hopefully I'm doing this correct but here's my info from tvfool
http://www.tvfool.com/?option=com_wr...e6a462214bcb07
Any idea what's going on?
idntknw is offline
post #4027 of 4029 Old 07-27-2017, 11:30 AM
ADTech's Avatar
Quoted: 144 Post(s)
Liked: 72
The usual cause is the antenna was unknowingly placed in a frequency-specific dead spot. Such dead spots are usually due to how signals propagate around or through impairing structures (buildings, trees, terrain, etc) in or very near the signal path.
The usual cure is to move the antenna. Sometimes it takes a mere 6", sometimes 6' or 6 yards. It's always different. You might need to increase (usually) or even decrease (sometimes) the height of the antenna. The key is to see if you can identify the most open signal path back towards the towers then try that spot.
Don't drill any new holes until you've found a spot that works.
Tech support for Antennas Direct
ADTech is offline
post #4028 of 4029 Old 07-27-2017, 01:33 PM
idntknw's Avatar
Liked: 1
Thanks for the reply. I moved the antenna around 25' in a better sight path (away from a tree) and actually a little lower. With the gain on high on the Amplify the trouble channel 32 WLKY comes in now. It's at 100 signal and around 70-80 on quality. The rest of the channels I can get are 100 signal and quality.
Thanks again.
idntknw is offline
post #4029 of 4029 Old 08-22-2017, 05:43 AM
danlshane's Avatar
Quoted: 21 Post(s)
Liked: 9
Wkpc 15
Am I the only one who doesn't find WKPC 15 or its subs OTA today?
Update: Channel 15 was back on the air last night. never heard why it disappeared for a few hours.
Dan Shane
LG 65UH8500
danlshane is offline
