AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Local HDTV Info and Reception (http://www.avsforum.com/forum/45-local-hdtv-info-reception/)
-   -   Louisville, KY - HDTV (http://www.avsforum.com/forum/45-local-hdtv-info-reception/209737-louisville-ky-hdtv.html)
NightowlKY 05-09-2002 04:21 PM
Well, the WHAS-DT thread has lived its life, I think, and it's time for a general thread given the news now that Insight might be offering HD over cable by EOY.
I'll start off by saying I think my phone call to WHAS worked! Watching their 6pm newscast on the digital channel in 4:3! No more stretched image! This is a good step forward. Now we'll see how they handle Stuart Little tonight as I see TitanTV showing WCPO-DT (Cincinnati) with Stuart Little in HD. Oh, the audio seems improved, too. Not quite equal to the analog yet but better. Now if we can just get them to lose that huge-a$$ logo bug in the lower-right corner!
And, I'll end with a general query to Woowoo and Willam Smith. Is WKPC-DT going to be showing the scheduled HD programs in HD or continued multi-casting? I see a few shows coming up next week that, according to the DTV schedule at www.ket.org, show them to be in HD.
Things are starting to pick up here in the Derby city!
UPDATE: Per an actual thought I had, here's a list of technical contacts to report problems. (Thanks to all who contribute!):
WHAS 582-7840
WHAS NEWS (for nights and weekends)582-7223
WAVE 585-2201
WAVE NEWS (for nights and weekends)561-4150
WLKY 893-3671
WLKY NEWS (for nights and weekends)891-4932
Chief Engineer Jim Mercer [email]jmercer@hearst.com
NightowlKY 05-09-2002 06:32 PM
I just spoke w/Neal re:the audio issue with Stuart Little tonight (just static on the national feed and commercials, local commercials sounded ok). They're all still recovering from the Derby production of Thunder and are fleshing things out.
He said, for one, they are reading this forum now so they can see our feedback. Also, they just pass the HD signal from ABC through and cannot do any processing on that signal. I mentioned if they are actually receiving a 16:9 signal tonight, it appears to be zoomed and cropped in all dimensions (esp. noticeable to the left and right edges of the frame compared to the analog version).
I did thank him for getting rid of the stretched 4:3 image.
Sooo...I will gladly give WHAS a bit more time before making any more judgments and just hope for the best.
I was also hoping that front moving through would provide some tropo enhancment to Cincinnati (I could catch WCPO-DT and compare) but that's not happening.
bruggles 05-09-2002 07:38 PM
Hey all,
I have a Zenith DTV1080 being fed by a ChannelMaster 4221 4-bowtie antenna. I live in Prospect (just into Oldham County). Here's my problem - when I do an EZ-scan, the only digital channels I get are 15-(1-4) (KPC?). I can't get WHAS (55/11-1). This is even though the signal strength meter is in the "Good" range (I would estimate 80-90 out of 100 if there were numbers on the meter). Even 15-(1-4) has a choppy signal. I've got my antenna in one of my upstairs rooms (very near the location I will mount it on my house) facing SW. Any ideas on what my problem is?
NightowlKY 05-09-2002 07:50 PM
Hey, bruggles.
Do you mean to mount that on the roof? That should definitely help reception.
But, pointing SW? I would think you'd want to point pretty much due West. I'm just in Jeff. County from PeWee Valley and the WHAS tower is about 12 degrees North of West for me. I've found significant dropoff to the SW but better to the NW of the tower.
And, what's the tree/building situation around you? And what type of cabling, the distance, splitters in use, etc.?
bruggles 05-09-2002 08:00 PM
It will be mounted on the side of the house at roof level. It is actually pointing about due West (maybe just a little south of due west). There is about 70' of quad-shield RG6 in between, with no splitters. Do you think that the signal meter on the DTV1080 is misleading?
NightowlKY 05-09-2002 08:15 PM
Well, it's more of a signal over noise measurement. I've had locks on Indy digitals or Cincy digitals during tropo enhancement and the signal % has shown 50-51% and had no dropouts as it was a rather clean signal, but weak.
If you get a lot of fluctuation in strength I believe that's a sign of a lot of multipath interference (trees/buildings/hills).
You may need to switch to a more directional-type antenna like the Channel Master 3022 instead of the bowtie. But, get it on the roof, if you can. Use an eave-mount and a small mast (Radio Shack has a 5' steel mast you could use for about $10) or a chimney mount and, say, a 10' mast. Height is your friend.
PCS 05-09-2002 08:24 PM
Just caught the news on the Insight HD plan. I'm psyched! This would be so much easier and really help HD catch on more quickly. It seems like there is finally more movement all over the country on Hidef. I hope within 6 months we see CBS and NBC go HD here in Louisville.
William Smith 05-09-2002 08:34 PM
We lost the sat receiver we use to pickup the HD feeds, I hope to have another receiver online for the weekend. Check the digital section of our web site to check for programming. or send email to the address on the digital page. Programming reads the emails.
William
woowoo 05-10-2002 05:19 AM
Originally posted by William Smith
programming reads the emails.
William
So write them S L O W L Y
Woo
BTW
The plan to carry PBS on Insight is a National Level deal.
It was not something that happend localy.
Us bottom feeders are waiting to find out the Details
bruggles 05-10-2002 05:45 AM
Jerry,
I'll give that a shot. Do I understand that you're getting Cincy and Indy HD feeds? That's great - I didn't realize that was a possibility (although right now I'll be happy to get the Louisville feeds).
I'll keep you updated, although I won't be able to do anything for a few days.
NightowlKY 05-10-2002 06:21 AM
woowoo,
LOL!
bruggles,
Well, actually, this morning I was able to lock WKRC-DT out of Cincy at about 70-73% and WRTV-DT out of Indy at 53-54%. But, conditions were good this morning for signal propagation after that front moved through last evening.
The Hepburn Tropo Forecast is a pretty accurate indicator.
Understand about the time issue, too. There's much I'd like to do to mine but time/money is always a concern
MichaelZ 05-13-2002 09:16 PM
I wish WHAS-DT would get their sh#t together. I checked the local newcast this evening and once again there were lipsync issues. Looked like about 1/2 second out of sync. Doesn't anyone at the station look at their own telecasts?
John Nelson 05-14-2002 01:57 PM
Must have missed the announcement, can you point me to further info??
William Smith 05-14-2002 05:32 PM
The replacement sat receiver is set for HD tonight.
Happy viewing.
William
NightowlKY 05-14-2002 07:50 PM
Happy viewing.
William
Hey, William.
Well, I can tell it's 16:9 and the other three channels show black but show signal strength but the show itself, Evolution, doesn't look HD. Nowhere near the shows of Smart Travels I've seen before. Maybe these interview segments weren't in HD? Or the drama part itself wasn't in HD? Or maybe I'm just not sure what I'm seeing It looks quite soft and grainy to what I've seen on even CBS.
It looks good, though, just not the heart-stopping clarity I saw on that Smart Travels show one day several weeks ago.
NightowlKY 05-14-2002 07:52 PM
John,
Take a look at Keith's post near the end of this thread
William Smith 05-14-2002 09:43 PM
Well, its listed as HD.....
woowoo 05-15-2002 11:17 AM
Looks like we passed what was sent
http://www.avsforum.com/avs-vb/showt...hreadid=140548
Later
Woot
NightowlKY 05-15-2002 01:04 PM
Yeah...saw that, woo.
We'll see how Aleutians looks tonight at 10.
NightowlKY 05-15-2002 06:26 PM
Well, although the ABC logo is in the far right (I thought that meant they were cropping the image), I was able to compare the digital channel to the analog and there is definitely more image to the left and the right.
Soo...looks like we're on the right track for ABC-HD. I'd say the image quality is on par with, say, Everybody Loves Raymond but minus the red push CBS has. Well, the audio is still way too low.
UPDATE:
WKPC-DT showing Aleutians in HD. Oooo...this looks SWEET!!
PCS 05-16-2002 07:36 AM
Good job KET on the Aleutians. Excellent PQ. Glad you are back up and delivering.
MichaelZ 05-16-2002 11:51 AM
I see that WHAS forgot to flip the HD switch Tues. night for NYPD blue. I was checking my HiPix and saw it was broadcast in 4:3 - what a waste
Outside of WKPC, we still do not have any HD in this town. I also got a message from a friend of mine the WDRB is not planning on broadcasting anything digital until at least the first of next year
Louisville, a world class city, LOL!
NightowlKY 05-16-2002 12:15 PM
Well, Drew and According to Jim (is that the name?) were in HD on WHAS.
I wonder how far WAVE and WLKY are coming? WDRB doesn't matter much to me since FOX will probably never do HD and stations in Cincy/Dayton aren't even doing the FOX Widescreen so I doubt WDRB will either.
I wish WAVE would get moving. I caught Leno in HD last night from WLWT-DT 35 in Cincy and it looked just incredible. It's sharper than anything from CBS or ABC.
wa4ryb 05-16-2002 03:33 PM
After NYPD Blue wasn't shown in HD I called WHAS Master Control the following day. It appears that the Digital Transmitter has a separate Video Switcher and the master control personell either didn't know how to feed the transmitter or they forget. The gentleman I spoke with said that they were working on automating the process...Anyway congrats to the Master Controlers last night for 3 sit coms in hd.....
PCS 05-16-2002 09:05 PM
I feel your pain Wa4ryb! It is frustrating that WHAS forgets to hit the switch. I too was disappointed with NYPD blue. I was glad to see the sitcoms back the next day in HD. Right now I'm trying to stay cool and focus on progress for my own sanity's sake. I have to say I am getting 100% more HD than I was 6 months ago. Still not enough to satisfy hidef lovin' me (ie. not really world class yet), but it's progress.
woowoo 05-17-2002 05:08 AM
Life got better for us after william came up with a simple way to "Throw the switch"
If a station gets Lots of phone calls........
They will remember to do it.
MichaelZ 05-17-2002 06:00 AM
I usually watch all my network HD stuff on ExpressVu but I have a HiPix for time-shifting. I usually don't know whether WHAS has flipped the switch until after it been aired. I hope they get it automated. Seems like other stations have a computer do the "switch flipping".
bairda 05-17-2002 07:10 AM
Tried to catch a little of Con-Air last night on the ABC big picture show...was this supposed to be in HD? Didn't have time to take a look at HDTVgalaxy or watch much of it..but it looked to be SD and 4:3...
NightowlKY 05-17-2002 10:11 AM
Don't believe Con Air was supposed to be in HD. But, isn't there a movie coming up on Sat. on ABC that is?
bairda 05-17-2002 02:15 PM
Air Force 1 tomorrow night...hope WHAS does FTDS (flip the damn switch) and we don't have any weird audio...also Dinosaur will be on Sunday night. Should be a great weekend to test out your HDTV setup.
Now if only had my new NEC projector here to see it!
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
