Sioux City, IA / Sioux Falls, SD - HDTV - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 1500 Old 08-02-2005, 04:08 PM
BVfan's Avatar
Originally Posted by rmullin View Post
I don't think that KDLT at 75% in the Sioux Falls metro area will do me any good in Sioux City.
Yeah, I'm only 5 miles away so I should notice the jump. Part of my problem is I am so close, if I point right at KELO tower, my signal strength goes down, as I must be getting reflective signals.
FOX here is the real bugger. Even the analog signal is weak. I have huge trees in direction of the transmiter. I can pick up your Fox44 almost as good as 17.
BVfan is offline
post #452 of 1500 Old 08-02-2005, 09:36 PM
COLAVSFANINNWIA's Avatar
I dunno what happened to Analog Fox17, but over in Larchwood, it is nearly to usually unwatchable. good thing for dish i can get it in clear. and also in Larchwood Fox44 comes in almost perfect. Wasnt that long ago when i was able to get both in about the same.
I am guessing that no one knows the time frame for KTTW-DT full power? Must be the July 2006 deadline they are waiting for to stick out any more $$.~ColAvsFan
In case you didn't know, I am a Colorado Avalanche fan!
COLAVSFANINNWIA is offline
post #453 of 1500 Old 08-07-2005, 06:48 PM
Ben L C's Avatar
Does anyone here living in Sioux Falls and subscribes to Directv, get the national Fox HD feed? I have a friend who is asking and I don't know the answer. He has a problem getting the local fox HD feed which is rather weak. I know here in NW Iowa we are able to pick it up over the sat.
Ben
Ben L C is offline
post #454 of 1500 Old 08-07-2005, 07:04 PM
BVfan's Avatar
Ben
KTTW's offical coverage map shows they presently cover a 15 mi radius from their tower. We all know here that is not a fact. He would have to get a waiver and if you live in SF, that may be hard to do. You may have him call DirecTV to see what the exact process is as I am sure they would not just turn the nat feed on for him.
BVfan is offline
post #455 of 1500 Old 08-07-2005, 07:44 PM
Ben L C's Avatar
Thats what I thought. Thanks. I will pass the info on.
Ben L C is offline
post #456 of 1500 Old 08-10-2005, 04:28 AM
hiltsy855's Avatar
Hello all. Below is some info on digital/HD status of the Omaha stations - I received from the KETV chief engineer. With my home being in Morningside (Sioux City) I have been very surprised with the reception I can get from Omaha. I watched the MNF game on KETV (I believe they are transmitting at 700Kw) and my signal strength was 100%. I also get almost 100% signal from WOWT so it looks like 1000Kw will easily get the job done here if you have a decent antenna & amp (my reception from KMTV is hit & miss). Here's the Omaha station info:
KMTV-DT (CBS) is still running 700Kw ERP, will go up to 1000Kw here when the FCC grants their license which should be any day now.
WOWT-DT (NBC) on channel 22 is running 1000Kw ERP.
KPTM (Fox) channel 43 is changing out their antenna this month, and will run 1000Kw ERP, look for them by the end of the month.
WB (KXVO) will not be passing HD initially.
Mark
hiltsy855 is offline
post #457 of 1500 Old 08-15-2005, 08:35 AM
mhaider's Avatar
Does KWSD WB broadcast any HD shows in HD?
mhaider is offline
post #458 of 1500 Old 08-15-2005, 09:07 PM
Unfortunatly they are SD only.
post #459 of 1500 Old 08-15-2005, 09:09 PM
Feddie's Avatar
Can someone tell me how long Midcontinent has had TNT-HD and FSN HD?
Feddie is offline
post #460 of 1500 Old 08-16-2005, 06:19 AM
mhaider's Avatar
Couple of weeks.
mhaider is offline
post #461 of 1500 Old 08-16-2005, 06:21 AM
mhaider's Avatar
Bummer....DirecTV is having fall previews of the various channels this month, and this week they're highlighting the WB and it looks like there's going to be some good shows this fall in HD.
mhaider is offline
post #462 of 1500 Old 08-18-2005, 03:36 PM
ScottyRambo's Avatar
KDLT appears to have upped their power. I can get 80% signal strength from Chancellor,SD
ScottyRambo is offline
post #463 of 1500 Old 08-18-2005, 05:06 PM
Husker's Avatar
Yup. You beat me to it. KDLT-DT is pegging the meter here at 100%. HD and 5.1 and looking good. NBC in HD...finally!
Husker is offline
post #464 of 1500 Old 08-19-2005, 06:14 AM
rmullin's Avatar
Life is strange...
I now receive KDLT's digital signal in Sioux City (that's 70+ miles from the tower) at 95% signal strength. Dolby digital sound, too.
My local NBC affiliate (KTIV) also broadcasts a digital HD signal from a tower about 10 miles from my home, and I can't receive anything.
Guess it proves that you need to have a signal powered by more than a couple Duracell batteries and a hamster wheel.
THANK YOU to the folks at KDLT and their advertisers.
In theory there is no difference between theory and practice. But in practice there is.
rmullin is offline
post #465 of 1500 Old 08-19-2005, 12:18 PM
Mendu's Avatar
Yahoo!
Now if you can just get FOX
Mendu is offline
post #466 of 1500 Old 08-21-2005, 04:00 PM
BVfan's Avatar
rmullin ..
That is an awesome signal. My signal strength for KDLT went up from 78 to 94% so I assumed they had gotten the upgrade done. My signals are kind of screwy as I am so close to all the towers. Some days KSFY will not even come in.
I keep an antenna pointed south just to see if I can get any digital SC stations, but not a sniff.
Mendu
Thank FOX thing is irrating. I don't get FOXHD at all as I took down my big VHF/UHF antenna this summer. Am thinking about putting up a VHF only pointed at FOX as my other antenna gave me reflected signal problems. Wish they would just switch to UHF with the digital signal.
BVfan is offline
post #467 of 1500 Old 08-21-2005, 04:16 PM
bighdtvfan's Avatar
BVFAN
I put up a VHF only antenna with a channelmaster signal blocker that only allows channel 7 VHF to pass through it. No problems at all with the other antenna nor any ghosting. I bought it through Warren Electronics in case you are interested.
I have heard from KTTW. They will not be going full power until July 2006. BUMMER!!!!
bighdtvfan is offline
post #468 of 1500 Old 08-21-2005, 09:07 PM
BVfan's Avatar
Originally Posted by bighdtvfan View Post
BVFAN
Thanks for the info.... I will try that prior to NFL start.
Warren is not local ... Right? Found the web site.
BVfan is offline
post #469 of 1500 Old 08-22-2005, 03:42 AM
Ben L C's Avatar
Way to go KDLT!! Does anyone have any info if the Sioux Falls affiliate of the WB will be doing any 1080i broadcasts of their shows this season via OTA?
Ben
Ben L C is offline
post #470 of 1500 Old 08-24-2005, 01:57 PM
hiltsy855's Avatar
Hello from Sioux City. Does anyone know if KSFY-DT has upped their transmit power lately? When they first started broadcasting I could get some signal and then it went away for me. I haven't scanned for it lately though. What is the digital channel number again?
Mark
post #471 of 1500 Old 08-24-2005, 04:34 PM
Ben L C's Avatar
It is either 32 or 28 I think. SOrry i can't be more specific.
Ben L C is offline
post #472 of 1500 Old 08-24-2005, 08:33 PM
hiltsy855's Avatar
Found it - KSFY-DT is channel 29.
http://www.northpine.com/broadcast/sd/tv.html
post #473 of 1500 Old 08-25-2005, 06:59 PM
Ben L C's Avatar
Good. Glad you found it.
Ben L C is offline
post #474 of 1500 Old 09-05-2005, 07:31 PM
BVfan's Avatar
Did anyone notice during the FL St/Miami game MON Night that KSFY put a weather bug message over the top of the HD pic. Upper RH corner, and very discrete. In time for MNF.. alright. Bug said to tune to analog channel for weather alerts. Bug was there during local commericals also.
I plan to email them as this is a great way to do it. I also plan to email KELO, as they had CSI in non-HD mode with weather alerts along the bottom..... like always. KELO needs to step up to the plate on these things.
BVfan is offline
post #475 of 1500 Old 09-06-2005, 10:41 AM
Husker's Avatar
Yes, I noticed the bug too. Certainly better than losing the HD feed. I did turn over to the analog feed a few time and there was no weather messages, even though the HD bug was up. Sort of annoying in this case as it partially covered the football clock and scoreboard.
Husker is offline
post #476 of 1500 Old 09-06-2005, 07:25 PM
BVfan's Avatar
Right,
KSFY took away the alert on analog later in the game, but left the bug up on HD. I agree about the clock and the downs. I kept switching back and forth at the end of the game to see how much time was left. Did not have time to do any emailing today to the stations, but may try tonight.
Really do not understand the rhyme or reason for alerts on the screen any way as SF got hammered after midnight so why take away the alerts at 10:00. I suppose it is linked electronically to the NWS some how.
BVfan is offline
post #477 of 1500 Old 09-17-2005, 04:55 PM
cdieren's Avatar
KELO-DT 11.1 Low power?
Anyone else experiencing what seems to be low power from KELO-DT this afternoon - both 11.1 and 11.2?
This is usually my strongest local signal, but now is unwatchable while KSFY-DT and KDLT-DT (13.1 and 46.1) seem just fine.
cdieren is offline
post #478 of 1500 Old 09-17-2005, 06:32 PM
I didn't notice that. Right now (8:30) KSFY-DT seems to be at really low power, but KELO-DT
and KDLT-DT are just fine.
post #479 of 1500 Old 09-17-2005, 08:40 PM
cdieren's Avatar
This evening at about 9:30 when I checked it again, KELO-DT seems back to normal power. Maybe it was just my setup and not a transmitter power issue?
cdieren is offline
post #480 of 1500 Old 09-19-2005, 10:13 PM
BryanSD's Avatar
Found KDLT HD in the Midco Cable lineup! Now with all the current local HD channels now available on cable...I can retire the rabbit ears!
BryanSD is offline
taboola here
