Dysart, PA: Antenna suggestion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-20-2015, 02:13 PM - Thread Starter
Liked: 0
Hello all, I am trying to figure out what would be the best antenna or antenna set up for my area. I live in Dysart, PA (16636) and do not have anything really around the house like trees to block the signal. I would like to have a roof mounted directional antenna with rotor and really do not care how big or ugly the antenna is. I did noticed when I ran the reports from the links below I should be able to acquire 6 UHF channels and 1 VHF channel (8 RF, 8.1V). (Not in the same direction)
Any input will be appreciated. THANKS!
ID:	952954   Click image for larger version
nzumo1 is offline
post #2 of 2 Old 09-23-2015, 09:41 PM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1764
If you don't get any response here, read and follow the instructions in the HDTV Technical section.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
