Help! Analog cable (no box) wont work on my Panasonic TH-40a400s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-30-2015, 02:26 AM - Thread Starter
Liked: 0
Unhappy Help! Analog cable (no box) wont work on my Panasonic TH-40a400s
Hi, just bought my 1st led tv and my cable wont seem to work on it. The model is panasonic th-40a400s. Our provider only provides analog cable without any box or whatsoever. how can i fix it please do help. thanks a bunch.
Leslie Miguel Rafael is offline
post #2 of 2 Old 09-30-2015, 11:21 AM
Liked: 1
That tv doesn't have a cable tuner built in. To receive cable channels you will need a cable set-top box with a QAM tuner. If you can't get one from your cable provider, they can be found on amazon for around $30. Can you tell me what country your in and the name of your cable provider?
avsacc122 is offline
