Tri-Cities, TN-VA - HDTV - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #361 of 537 Old 05-20-2009, 04:12 PM
brian1269's Avatar
Ok I was right. WKPT e-mailed me back and said Sunday morning its HD encoder went out. It's fixed now.
brian1269 is offline
post #362 of 537 Old 05-20-2009, 06:35 PM
tommyp007's Avatar
Good to know. I really missed the HD feed for the finale of DWTS. We don't watch ABC on Wednesday, but glad it's back in HD.
tommyp007 is offline
post #363 of 537 Old 06-02-2009, 08:18 PM
unrealman's Avatar
Charter just add MLBHD to the lineup
unrealman is offline
post #364 of 537 Old 06-03-2009, 03:56 PM
brian1269's Avatar
Now all we need is Fox Sports, FX, Travel Channel, SPEED, VERSUS, Spike, Sci-Fi, etc., etc. Charter is still lagging way behind. I am very close to just going to a dish.
post #365 of 537 Old 06-12-2009, 07:13 AM
eacalhoun's Avatar
Quoted: 58 Post(s)
How did the DTV switches go today?
Eric Calhoun
"If it was simple, anyone could do it" - Roy Clark from Hee Haw
eacalhoun is offline
post #366 of 537 Old 06-12-2009, 07:18 AM
LMUBill's Avatar
They don't start until 12:30 when WJHL turns off their analog and moves the digital from 58 to 11. WKPT, WEMT and WCYB won't stop analog until 11:59 pm. The PBS stations have been digital only since February.
LMUBill is offline
post #367 of 537 Old 06-17-2009, 03:46 PM
scarpenter's Avatar
I use to live in Bristol and worked for WCYB. Are they HD with their local news yet?
scarpenter is offline
post #368 of 537 Old 06-17-2009, 06:25 PM
LMUBill's Avatar
That will be the day.
I have a feeling they won't do HD News until WJHL does. And vice versa. And neither one will want to go first.
LMUBill is offline
post #369 of 537 Old 06-22-2009, 11:53 AM
BANGHEAD11's Avatar
Speaking of WCYB I lost the signal, anybody else? I haven't had the antenna hooked up in about 2 months and even did a rescan but no luck.
BANGHEAD11 is offline
post #370 of 537 Old 06-22-2009, 01:59 PM
cpcat's Avatar
WCYB switched back to VHF 5 in case you weren't aware. This will require an antenna for low band VHF. Rabbit ears might work if you are close in.
cpcat is offline
post #371 of 537 Old 06-22-2009, 02:24 PM
BANGHEAD11's Avatar
I was afraid that's what it was, thanks for the reply. Did any of the knoxville stations change?
post #372 of 537 Old 06-22-2009, 03:33 PM
LMUBill's Avatar
WBIR (10) and WBXX (20) went back to their old numbers.
Can you get WJHL on 11?
LMUBill is offline
post #373 of 537 Old 06-22-2009, 07:18 PM
cpcat's Avatar
I can. It's better at night but still with dropouts. I get a better signal now with DT11 than I did with DT58.
cpcat is offline
post #374 of 537 Old 06-23-2009, 09:11 AM
BANGHEAD11's Avatar
I can get 11 WJHL and 19 WKPT no problems, just not 5.
The Tropo must have been crazy high last night as I could get 39 WEMT in almost any direction.
I got 10.2 and 10.3, and idea why no 10.1?
post #375 of 537 Old 06-23-2009, 10:47 AM
LMUBill's Avatar
Maybe WCYB set up jammers just outside Morristown to make sure you can only watch NBC programming on their station?
And there is no 10.3 unless they added it this morning and didn't advertise.
LMUBill is offline
post #376 of 537 Old 06-23-2009, 11:33 AM
BANGHEAD11's Avatar
I don't live outside of Morristown I was hoping I would still get 5 after the change but I guess not.
I didn't think there was a 10.3 either but that's how my TV is showing it now! 10.2 is the weather and 10.3 seems to be regular NBC, for now.
Is channel 6 WATE VHF now? That's the only Knoxville channel I couldn't get last night that I wanted.
post #377 of 537 Old 06-23-2009, 01:35 PM
cpcat's Avatar
WATE is DT26.
cpcat is offline
post #378 of 537 Old 06-23-2009, 03:28 PM
LMUBill's Avatar
WATE is on UHF. I know it could be picked up in Kingsport before June 12 and they've been at that channel (26) since they turned on the DT signal.
Actually, I know for a fact they upped their power on June 12 because my aunt just north of Surgoinsville (in Stanley Valley) can get it now and she couldn't get the digital before. And she has a small outdoor VHF/UHF antenna (with no other amplification and a near-100 foot run) outside above her house that's pointed toward Johnson City!
She just has this antenna and a converter box. Prior to June 12 show could only get WETP (2) digitally and 5,6,8 (barely),11 and 39 (barely) with this setup. I went to her house on June 13 ready to help her buy and install a new antenna and didn't need to as she now gets 2,5,6,11 and 39 easily and also 7 (WMAK) out of Knoxville but that has a lot of dropout. I told her we could try to tweak the antenna a bit to pull in 19 47 but she said she was fine with what she is getting now.
LMUBill is offline
post #379 of 537 Old 06-23-2009, 09:10 PM
BANGHEAD11's Avatar
I was just curious about WATE because everything I was getting last night from Knoxville was going straight thru my house, like I said the tropo was really high last night as I'm usually not able to do that. I've gotten WATE before, just wondered if there had been any changes to WATE.
I'm in Surgoinsville too, I hate that WCYB changed.
post #380 of 537 Old 06-26-2009, 02:19 PM
LMUBill's Avatar
Looks like WCYB is listening to the complaints as they have applied to up their power from 7.1kw to 29.9kw. If that gets approved, apart from blowing up some peoples' amplifiers because it is so strong it will also be picked up a LOT further out than now.
Current coverage map
Predicted coverage map at 29.9kw
LMUBill is offline
post #381 of 537 Old 06-26-2009, 03:11 PM
steve617's Avatar
I live in Piney Flats and my WCYB signal is 100 and my WJHL signal is ZERO.
1-Dish 622 HD DVR
1-Dish 211 HD
61.5, 110,119
Hitachi 50" Rear Proj LCD
Winegard 7080P
Onkyo Reciever
JBL E-80, EC-35,E-50
svs 10 ISD
steve617 is offline
post #382 of 537 Old 06-26-2009, 04:02 PM
cpcat's Avatar
Just a thought but I ran into issues with WJHL in that my D* receiver was "thinking" it was still on DT58. Even when I rescanned it would recognize the channel (DT11) but would not allow viewing of it. I actually had to erase everything, re-enter a different zip (other than what would be a local zip for WJHL), then rescan and finally it worked.
cpcat is offline
post #383 of 537 Old 06-27-2009, 03:23 AM
steve617's Avatar
thanks CPKAt. That worked I get around a 79 now. I am good to go. Oh my siganl strength is 100 for 5, 100 for 39 and 11 and 18 is 79. Not too bad.
1-Dish 622 HD DVR
1-Dish 211 HD
61.5, 110,119
Winegard 7080P
Onkyo Reciever
svs 10 ISD
steve617 is offline
post #384 of 537 Old 07-04-2009, 08:21 AM
cedarwood's Avatar
aunt and uncle live in church hill................ have charter.......what channels (HD) are in the clear on charter...............no box...........currently trying to get them off the charter train to go to Direct.
cedarwood is offline
post #385 of 537 Old 07-04-2009, 09:18 AM
wakeup360's Avatar
They change all the time:
http://www.silicondust.com/hdhomerun...#lineup_358548
wakeup360 is offline
post #386 of 537 Old 08-08-2009, 04:52 PM
danarn17's Avatar
WCYB increases power but still no reception in Gray since relocating at Digital Switch in June.
danarn17 is offline
post #387 of 537 Old 08-08-2009, 06:59 PM
cpcat's Avatar
Oh, I'm sure they'll have to spend more money before they finally admit to themselves they made a mistake by reverting back to low band vhf.
I emailed their CE a couple of years ago gushing about how great the uhf 28 signal was doing at the time (and how sure I was that reverting to vhf 5 would be a mistake). Not that it did any good.
cpcat is offline
post #388 of 537 Old 08-09-2009, 11:28 AM
danarn17's Avatar
Why don't they switch back to UHF?
danarn17 is offline
post #389 of 537 Old 09-13-2009, 09:29 PM
Trip in VA's Avatar
Quoted: 800 Post(s)
Liked: 239
Send a message via AIM to Trip in VA
WJHL has requested an increase in power from 25.5 kW up to 34.5 kW.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #390 of 537 Old 09-15-2009, 06:39 AM
LMUBill's Avatar
- Trip
Looks like they're still trying to play catch-up to WCYB....
LMUBill is offline
