Hi all..
I have an issue with my Samsung TV and Panasonic DVD Blue-Ray player (Model: DRW-XW380) where i get no, or intermittent, ABC SBS on all digital channels.
The areial is connected through the Blueray player then through HDMI out to TV... This way my parents can record TV shows on the built in hard drive..
However, i have tried and conneccted the areial straight to the TV and auto-tune on TV to see what happens, STill i do not pick up these ABC and SBS channels..
however, if i take the blue ray player into another room and connect it to second wall point, i and scan via the blue ray player, i can pick up sbs and ABC just fine.
When testing at point that could pick up ABC and SBS i was usual same RF lead and HDMI cables i used at the old point, to eliminate other problems..
Would this mean its the old wall point that needs to be looked at ?
Since i can pick up ABC and SBS channels fine, even though my other TV directly connected must mean antenna is ok
However, on the channels with 'No signal' i pulled up the 'signal condition" setting on the blueray player, and saw the quality on those affected was around 2.
Any suggestions ?
Any suggestions ?
