Montgomery, AL - HDTV - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #3871 of 6733 Old 09-19-2008, 10:28 AM
Quoted: 1393 Post(s)
Liked: 587
I think a lot of us are curious as to how much money we're really talking about. If its a few cents to carry WCOV-DT, who gives a happy hoot. But if we're talking about $5.00 per month(times 4) for each of the 4 locals, then I can see that subscribers might not go for a $20 bump in their monthly bill.
Can you shed more light on this?
JimP is online now
post #3872 of 6733 Old 09-20-2008, 10:37 AM
shoncb's Avatar
Originally Posted by Eddie L. View Post
Channel 14 now comes through, as well as every digital channel that they provide in the Expanded Basic package (ESPNHD, ESPN2HD, locals in HD with subchannels, digital music channels, etc).
Eddie, Have you found any Charter QAM channels in HD (other than those you listed, i.e., ESPNHD, ESPN2HD, and the four locals?) I re-scanned and found those you mentioned. I also found Peachtree HD on 65-1, but it only seems to be on during the Braves games...that might be all they broadcast anyway.
shoncb is offline
post #3873 of 6733 Old 09-20-2008, 11:59 PM
Crisis_Core's Avatar
Hey guys. I don't know if any of you remember me but it's okay if you don't! I have a quick question in regards to cable boxes and Bright House Networks in Elmore County. Basically I get all of the HD channels (including premium ones) from BHN. I have a bedroom HDTV that has a cable box connected to it but my girlfriend is giving me hell about the fact that it looks really bad in the current setup. I don't disagree with her on it so I'm wondering if there's any option to get all of the HD channels on that TV without the cable box itself. The TV says it has a tuner built into it for digital HDTV channels but I can't seem to get it to find any. Any suggestions?
Crisis_Core is offline
post #3874 of 6733 Old 09-21-2008, 12:30 AM
Liked: 587
.....get a new girlfriend? just kidding.
If the set can't find any HD channels during a channel scan, then it probably doesn't have a QAM tuner.
If what you're trying to do is not see the digital box, you could put it into a drawer and run an IR relay so the remote can continue to change channels or get another TV with a built in QAM tuner.
JimP is online now
post #3875 of 6733 Old 09-21-2008, 12:43 AM
See that's what I thought at first. But I just searched for the product information from the manufacturer and it specifically mentions a QAM tuner.
the VXW20L offers HD formats and an integrated standard and high definition NTSC/ATSC/clear QAM digital tuner including 1080i and 720P. This will give you the full ability to enjoy the high definition content offered by your satellite and cable providers.
Any other ideas?
post #3876 of 6733 Old 09-21-2008, 01:00 AM
Liked: 587
To go over some of the basics,
1. Be sure that you have the cable company coaxial cable (the one with the threaded connector) screwed into the RF input on the back of the display.
2. Verify that when you do the channel scan, that you've selected cable rather than antenna.
3. Be sure that you're on the right input when trying to find the in the clear qam channels.
Also, are you finding any channels? even analog?
JimP is online now
post #3877 of 6733 Old 09-21-2008, 01:07 AM
That's a check on all three points. I've found some channels on the cable, including some digital cable ones. However the problem I'm having is that it isn't picking up any of the HD channels - even the ones that should be in HD. I'm watching channels that say they're broadcasting in 1080i (some of the WSFA and APT HD ones I suppose). My problem is that the channels clearly are not in HD at all. And I'm not getting any of the cable channels like ESPN HD, Discovery HD, Mojo HD, or anything.
post #3878 of 6733 Old 09-21-2008, 01:27 AM
Liked: 587
What are the channel numbers for the ones that say that they're in HD but obviously aren't.
Also, and this might not be the case here, there are times during the day that standard definition is broadcast over channels that are listed as HD. Its not uncommon to be on one of the local affiliates and find that they're broadcasting SD.
JimP is online now
post #3879 of 6733 Old 09-21-2008, 01:39 AM
Alotting for the SD programming that's probably on at this hour 93-1 (The WSFA weather channel) should fill the entire screen yet doesn't. 77-3 (APT HD) usually at least stretches out their content if it isn't actually HD and this isn't even doing that.
post #3880 of 6733 Old 09-21-2008, 09:53 AM
sarasdad's Avatar
Mine does. Check and see if you have a pic size or format on remote or tv
sarasdad is offline
post #3881 of 6733 Old 09-21-2008, 01:56 PM
Scott Smith's Avatar
If your talking about the Golf game on WSFA yes it HD
If your talking about 12-1 WSFA Weather Plus it has never been HD.
Scott Smith is offline
post #3882 of 6733 Old 09-21-2008, 03:04 PM
shoncb's Avatar
Well, I have to say. So far the locals have been doing a great job broadcasting the NFL games in HD. WAKA is the first to break the streak...the JAX@IND game is in SD.
shoncb is offline
post #3883 of 6733 Old 09-21-2008, 04:43 PM
shoncb's Avatar
Now the NO@DEN game on Fox has suddenly switched to SD. . . amazing.
I suppose we got 14 more weeks of this poor service.
shoncb is offline
post #3884 of 6733 Old 09-21-2008, 05:39 PM
shoncb's Avatar
I heard the 60 Minutes announcer just say "For the first time ever 60 Minutes is in HD". I didn't hear him say "except in Montgomery, AL", but I'm sure that is what he meant.
...not that I really care about 60 Minutes in HD. I'd be happy if y'all just get the sports right.
shoncb is offline
post #3885 of 6733 Old 09-22-2008, 06:12 AM
4bama's Avatar
I get CBS via DISH network from B'ham and CBS-8.1 OTA, both had loss of HD signals that switched to SD from time to time. I switched between OTA and DISH and both sources had the problem at the same time, so I think this was a network problem, not a local channel problem....
Dish 622 DVR, B'ham locals via Dish, Montgomery locals OTA, Winegard on 70' tower + CM7777 preamp
4bama is offline
post #3886 of 6733 Old 09-22-2008, 08:06 AM
WAKA-DT 8's Avatar
CBS issue (really!---see several posts down). We returned to HD on the game when service was restored.
WAKA-DT 8 is offline
post #3887 of 6733 Old 09-22-2008, 08:10 AM
WAKA-DT 8's Avatar
Not until this coming Sunday (But The Price Is Right starts today):
CBS ENTERTAINMENT PROGRAMMING - Effective September 22, 2008
AVAILABLE IN HD AND 5.1 SURROUND SOUND
(All times listed are ET/PT unless otherwise noted)
MONDAY-FRIDAY
*THE PRICE IS RIGHT (11:00AM -12:00N ET/10:00-11:00AM PT)
*THE YOUNG AND THE RESTLESS (12:30-1:30PM & 12N-1PM ET/11AM-12N PT)
*CBS EVENING NEWS WITH KATIE COURIC (ALL FEEDS)
*LATE SHOW WITH DAVID LETTERMAN (11:35PM-12:37AM)
SUNDAY
*CBS EVENING NEWS, SUNDAY EDITION (ALL FEEDS)
60 MINUTES (7:00-8:00 PM)
COLD CASE (9:00-10:00 PM)
THE UNIT (10:00-11:00 PM)
MONDAY
THE BIG BANG THEORY (8:00-8:30 PM)
HOW I MET YOUR MOTHER (8:30-9:00 PM)
TWO AND A HALF MEN (9:00-9:30 PM)
WORST WEEK (9:30-10:00 PM)
CSI: MIAMI (10:00-11:00 PM)
TUESDAY
NCIS (8:00-9:00 PM)
THE MENTALIST (9:00-10:00 PM)
WITHOUT A TRACE (10:00-11:00 PM)
WEDNESDAY
THE NEW ADVENTURES OF OLD CHRISTINE (8:00-8:30 PM)
GARY UNMARRIED (8:30-9:00 PM)
CRIMINAL MINDS (9:00-10:00 PM)
CSI: NY (10:00-11:00 PM)
THURSDAY
SURVIVOR (8:00-9:00 PM)
CSI: CRIME SCENE INVESTIGATION (9:00-10:00 PM)
ELEVENTH HOUR (10:00-11:00 PM)
FRIDAY
GHOST WHISPERER (8:00-9:00 PM)
THE EX LIST (9:00-10:00PM)
NUMB3RS (10:00-11:00 PM)
SATURDAY
*CBS EVENING NEWS, SATURDAY EDITION (ALL FEEDS)
CRIMETIME SATURDAY (8:00-9:00 PM)
CRIMETIME SATURDAY (9:00-10:00 PM)
*NOTE: THESE PROGRAMS ARE NOT AVAILABLE IN 5.1 SURROUND SOUND.
CBS PRIMETIME PROGRAMS
NOT AVAILABLE IN HD OR 5.1 SURROUND SOUND
(All times listed are ET/PT)
SUNDAY
*THE AMAZING RACE (8:00-9:00 PM)
SATURDAY
*48 HOURS MYSTERY (10:00-11:00 PM)
*NOTE: CBS PROVIDES AN UPCONVERTED FEED OF THE ABOVE PROGRAMS.
BEST REGARDS,
NICOLE MERTINE
MANAGER, COMMUNICATIONS & OPERATIONS
CBS AFFILIATE RELATIONS
post #3888 of 6733 Old 09-22-2008, 08:18 AM
WAKA-DT 8's Avatar
I thought all weekend how to answer this. Although I am not aware of the exact terms of the other stations, I am sure we are all in the same neighborhood. We're talking CENTS per sub. But I can't think of anything you would go out and buy that would be so low. You would have to break up and buy a fracton of even the most basic commodity you use in day to day life for the same cost.
post #3889 of 6733 Old 09-22-2008, 03:23 PM
4bama's Avatar
MONDAY-FRIDAY
SUNDAY
MONDAY
TUESDAY
NCIS (8:00-9:00 PM)
WEDNESDAY
THURSDAY
FRIDAY
SATURDAY
SUNDAY
SATURDAY
BEST REGARDS,
NICOLE MERTINE
I watched 60 minutes Sunday 9/21 in HD from my DISH delivered CBS-42 in B'ham. I didn't check to see if 8.1 from Montgomery was showing HD, but it was avaliable from the network in HD.
4bama is offline
post #3890 of 6733 Old 09-22-2008, 06:21 PM
blp
blp's Avatar
I checked back and forth and it was never HD on 8.1. Maybe this Sunday.
blp is offline
post #3891 of 6733 Old 09-23-2008, 12:51 PM
brian_esq's Avatar
Has anyone tried to pick up HD signals at an Auburn tailgate with an antenna? If so what are you using? Thanks!
brian_esq is offline
post #3892 of 6733 Old 09-23-2008, 01:06 PM
brian_esq's Avatar
I just dropped in on the Columbus, GA HDTV thread. I find it hard to believe they only have 2 pages to that thread while we have 130. What's the deal? I am looking in the wrong place?
post #3893 of 6733 Old 09-23-2008, 02:12 PM
jtrippe's Avatar
We've taken a little tv and an LG tuner and used a Terk HDTVa and had pretty good success. We've picked up Columbus and Montgomery stations. Go to tvfool.com to see which direction to point the antenna.
jtrippe is offline
post #3894 of 6733 Old 09-23-2008, 06:00 PM
Liked: 587
Are all Auburn games OTA or are some on ESPN(2)?
JimP is online now
post #3895 of 6733 Old 09-23-2008, 06:15 PM
sarasdad's Avatar
some on espn cbs or sometimes 11:30 game channel 12. This week 2:30 cbs tv 8
sarasdad is offline
post #3896 of 6733 Old 09-24-2008, 06:41 AM
wirving's Avatar
For whatever reason, the folks over there use this site instead:
http://www.columbusdtv.org/
Although I don't think the forum there is quite as active as this one, it does seem to be the place they gather.
-WIrving
wirving is offline
post #3897 of 6733 Old 09-24-2008, 08:15 PM
brian_esq's Avatar
-WIrving
Thanks for the info!
post #3898 of 6733 Old 09-25-2008, 07:57 AM
brian_esq's Avatar
Thanks for your response. I have a friend who sets up a corporate tailgate. He got Direct TV, but was wondering about the locals. I was worried that a Terk (I have one) would get a lot of interference from foliage and people walking in front of it. Did you elevate the antenna much or just use it table top?
post #3899 of 6733 Old 09-25-2008, 08:00 AM
brian_esq's Avatar
I like in Wetumpka. I bought a Terk indoor antenna back in 2006 when I first went HD. I could pull in all of the HD signals, but always had a weak FOX signal. It was around 55%. Something has changed within the last six months. I can't pick up FOX for anything, and all but the PBS station fade in and out. I realize that the stations are no where near full power on their digital transmissions. Should I just wait this out? At full strength, reception should be no problem, right? Also, when will the stations go full power? Most say they are dropping analog on or about December 1st.
post #3900 of 6733 Old 09-25-2008, 08:03 AM
jtrippe's Avatar
We put it on top of my father-in-law's truck. People walking past were interfering with it and causing it to go out when we had it on a table. Elevate it the best you can.
jtrippe is offline
