Albany, NY - HDTV - Page 170 - AVS | Home Theater Discussions And Reviews
 4Likes
post #5071 of 5100 Old 01-15-2015, 08:01 AM
NYota1's Avatar
Quoted: 13 Post(s)
Originally Posted by ebo View Post
You're not likely to get the Windham station (WYBN, RF 14) no matter what antenna you use unless you happen to be in a sweet spot not blocked by mountains. I've tried from a hilltop near Berne using a 4-bay bowtie (Channel Master CM-4221) and a Zenith Silver Sensor. Not a glimmer that any station was there. The only place I've been able to receive WYBN was the parking lot of the Valero station in Windham. They claim to cover the Capital Region but that's wishful thinking.
I had been trying to get WYBN ever since they signed on. But gave up a long time ago. I tried no less than 4 different outdoor antennas, and exchanged emails with the WYBN engineer. He saw no reason why I SHOULDN'T get it! ... which only aggravated me more. But TVFool has had it right all along, putting me in the "GREY" for WYBN, even though the station's contours have me within the acceptable pick up range. Frustrating. I too even took an antenna to an area south of the Heldebergs...and STILL couldn't get it! All I DID get was every sub-channel from Poughkeepsie! (ch. 48 I think?)
NYota1 is offline
post #5072 of 5100 Old 01-15-2015, 08:15 AM
NYota1's Avatar
Quoted: 13 Post(s)
Originally Posted by IN2tvClassics View Post
How come I receive 45.3 CBS / WRGB and don't receive THIStv?
You'd think that CBS6 would be coming in on 6.1
WRGB only has ThisTV on 6.2
CBS 6 IS on 6.1 .... and 45.3 as you already know.
FYI: Channel 15 was analog, (ex; Antenna TV) ... then went with AMGTV programming. Used to be on the Heldeberg tower, then moved to Coxsackie. Word was, that they had a CP to go digital and move to RF 22. Don't know if that ever happened.
NYota1 is offline
post #5073 of 5100 Old 01-15-2015, 08:41 AM
NYota1's Avatar
Quoted: 13 Post(s)
Originally Posted by The Hound View Post
I live less then 6 miles from amsterdam but unless I aim my rooftop at the station I don't get Ion. it is 2 edge just like yours. This means it reflects twice before reaching your antenna.
Never knew what "2 edge" meant. But I guess that's why your path is challenged? I'm twice as far from them as you are...(they're north/northwest), and I can get them fine even when pointing at the Heldebergs...in the opposite direction.
NYota1 is offline
post #5074 of 5100 Old 01-15-2015, 10:04 AM
ebo
ebo's Avatar
Quoted: 22 Post(s)
I found these two antennas. Would either of these work for me?Is one better than the other, how so?Solid Signal HD-BLADE Amplified Indoor Digital Flat Indoor TV Antenna w/ 15FT Cable (HDBLADE100-15FT)
Model: HDBLADE100A-15FT
http://www.solidsignal.com/pview.asp...15FT&ss=421549
Winegard FL5500A FlatWave Amped Indoor HDTV Antenna (FL-5500A)
Model: FL5500A
http://www.solidsignal.com/pview.asp...500A&ss=421687
You're obviously determined to get a panel antenna, even though neither of these is well suited to the channels in our area. Neither will do well on channel 6--they're just not big enough--so you probably won't get This TV or WRGB in HD, at least not reliably (you already get WRGB in SD from WCWN's transmission). Both panels claim high VHF capability so you might get 7, 12 and 13 (WXXA, WNYT and WNYA respectively). Both have amplifiers but only the Winegard claims a low noise figure: 1 dB, which is exceptional and almost certainly better than your tuner's NF. Assuming it won't be overloaded by strong signals, that would be the better choice. It appears from the picture that the amp can't be removed from the cable as the Solid Signal's amp can and I don't know if there's a way to bypass it to compare reception with and without it.
dbc333 likes this.
ebo is offline
post #5075 of 5100 Old 01-16-2015, 02:39 AM
IN2tvClassics's Avatar
Quoted: 31 Post(s)
Not really, I just want to find an eye pleasing antenna. The family would prefer not to have a metal monstrosity in the living room.
It has to be an HDTV indoor antenna (VHF/UHF) with a range of 40-50+ miles.
I know I'm asking a lot of questions. But I would like to know what my options are.
IN2tvClassics is online now
post #5076 of 5100 Old 01-16-2015, 07:44 PM
NYota1's Avatar
Quoted: 13 Post(s)
You know, a lot of folks have had pretty good luck with the Clearstream 2 from Antenna's Direct. I own one, but am not actively using it at the moment. Although it's essentially an outdoor unit, it's small enough that many folks have it hanging indoors. The primary unit (that I have) is for UHF...but there's also a UHF/VHF version that comes with a VHF dipole. My niece and her husband have the 2-band version on their roof. When I was using it, (with UHF only) --- I could STILL get all the VHF stations...including CBS 6 (on 6) and ThisTV on 6.2 I actually did a review of the antenna on my blog site, http://lightsngear.com/review-clears...-hdtv-antenna/ I'd consider it if I were you.
NYota1 is offline
post #5077 of 5100 Old 01-16-2015, 07:55 PM
NYota1's Avatar
Quoted: 13 Post(s)
There is no longer a channel 15 it was analog before it went away, so your digital tuner wouldn't pick it up anyway.
Channel 15 is still analog... and still on the air! Just saw it this evening.
NYota1 is offline
post #5078 of 5100 Old 01-17-2015, 11:04 AM
Quoted: 31 Post(s)
Which one of these antenna should work best for me? Is the combo packs worth there costs?
Could any of these be mounted on a plywood base and placed behind a HDTV? Would a wall mount be better?
SMARTenna 35/50
http://www.channelmasterstore.com/SM.../cm-3000hd.htm
ClearStream™ 2V Long Range UHF/VHF Antenna Complete Combo Pack
https://www.antennasdirect.com/store...-Complete.html
ClearStream™ 2 Long Range Indoor UHF Antenna with Mount, Base Cover and 50 ft. Low Loss RG6 Coaxial Cable (MBS)
https://www.antennasdirect.com/store...V-Antenna.html
ClearStream™ 2 Long Range UHF TV Antenna
https://www.antennasdirect.com/store...V-antenna.html
ClearStream™ 2 Indoor/Outdoor DTV Antenna Combo Pack
https://www.antennasdirect.com/store...ith-Mount.html
Should I go with a UHF only antenna and hope it picks up the VHF stations? Would I be better off with a UHF/VHF antenna?
Below you see my current tv signal possibilities care of Anntennaweb, TVfool, AntennaPoint.
Antennaweb.org
Stations:
WCWN-DT 45.1 CW
RF Channel: 43
17 miles at 252°
Yellow
WMHT-DT 17.1 PBS
RF Channel: 34
17 miles at 252°
Yellow
WNYA-DT 51.1 MNT
RF Channel: 13
16 miles at 254°
Yellow
WNYT-DT 13.1 NBC
RF Channel: 12
17 miles at 252°
Yellow
WRGB-DT 6.1 CBS
RF Channel: 6
17 miles at 252°
Yellow
WTEN-DT 10.1 ABC
RF Channel: 26
17 miles at 252°
Yellow
WXXA-DT 23.1 FOX
RF Channel: 7
17 miles at 252°
Yellow
W44CT-D 44.1 3AB
RF Channel: 44
16 miles at 255°
Green
WNYT-LD 13.1 NBC
RF Channel: 18
7 miles at 29°
Green
WNGN-LP 38 FMN
RF Channel: 38
7 miles at 29°
Red
WYPX-DT 55.1 ION
RF Channel: 50
32 miles at 309°
Violet
TVFOOL:
Callsign Network Virtual Channel Band
Channel: 6 (RF 6) Strong Signal WRGB CBS 6-1 Lo-V
Channel: 10 (RF 26) Strong Signal WTEN ABC 10-1 UHF
Channel: 45 (RF 43) Strong Signal WCWN CW 45-1 UHF
Channel: 17 (RF 34) Strong Signal WMHT PBS 17-1 UHF
Channel: 13 (RF 12) Strong Signal WNYT NBC 13-1 Hi-V
Channel: 23 (RF 7) Strong Signal WXXA FOX 23-1 Hi-V
Channel: 51 (RF 13) Strong Signal WNYA MYTV 51-1 Hi-V
Channel: 55 (RF 50) Moderate Signal WYPX ION 55-1 UHF
Channel: 19 (RF 36) Weak Signal WCDC ABC 19-1 UHF
Channel: 2 (RF 29) No Signal WKTV NBC 2-1 UHF
Channel: 54 (RF 27) No Signal WTBY TBN 54-1 UHF
Channel: 28 (RF 9) No Signal WVER PBS 28-1 Hi-V
Digital:
WRGB 6 (6.1) CBS 16.8 LOS 66.2
WTEN-DT 26 (10.1) ABC 16.8 LOS 62.5
WCWN 43 (45.1) CW 16.8 LOS 61.2
WMHT-DT 34 (17.1) PBS 16.8 LOS 59.3
WNYT 12 NBC 16.8 LOS 58.2
WXXA-TV 7 (23.1) Fox 16.8 LOS 56.6
WNYT 18 NBC 6.9 LOS 55.4
WNYA-DT 13 (51.1) MyN 15.8 LOS 54.7
WNGN-LP 23 (38.1) 6.9 LOS 50.1
WVBG-LP 41 (41.1) 15.9 LOS 45.4
W44CT-D 44 16.1 LOS 42.3
WNCE-CD 31 40.8 LOS 29.8
WYPX-DT 50 (55.1) ION 31.6 2Edge 25.9
WNGX-LD 25 6.9 LOS 23.7
WCDC-DT 36 (19.1) ABC 27.2 1Edge 14.9
WYBN-LD 14 40.7 1Edge 13.1
WNYT 45 NBC 41.9 2Edge 10.7
WEPT-CD -- 22 (15.1) 47.2 1Edge 10.6
WKTV-DT 29 (2.1) NBC 69.0 2Edge -2.6
WVER-DT 9 (28.1) PBS 72.6 2Edge -3.0
WRNN-DT 48 (48.1) Ind 84.6 2Edge -4.7
WTBY-TV 27 (54.1) Ind 84.5 2Edge -5.7
W47CM 47 (47.1) 20.3 1Edge -6.0
W38DL-D 38 27.2 1Edge -6.0
W21CP-D 21 41.4 2Edge -6.2
W46EW-D 46 26.2 1Edge -7.1
W30DM-D 30 43.7 1Edge -7.8
WFNY-CD 48 44.1 2Edge -8.7
WRGB 24 CBS 53.7 2Edge -13.3
Analog:
WEPT-CD 15 20.7 LOS 40.2
WNGN-LP 38 6.9 LOS 38.0
W21CQ 21 23.8 LOS 26.1
W47CM 47 41.9 LOS 15.5
WVBG-LP 41 18.0 LOS -13.8
http://www.antennapoint.com/
WRGB CBS 6 6.1 VHF 4.46 kW Schenectady 16.79 mi 252.43°
WXXA-TV FOX 7 23.1 VHF 10.0 kW Albany 16.79 mi 252.43°
WNYT NBC 12 13.1 VHF 9.1 kW Albany 16.79 mi 252.43°
WNYA MYNTV 13 51.1 VHF 12.6 kW Pittsfield 16.79 mi 252.43°
WCWN CW 43 45.1 UHF 676.0 kW Schenectady 16.79 mi 252.43°
WMHT PBS 34 17.1 UHF 325.0 kW Schenectady 16.79 mi 252.43°
WTEN ABC 26 10.1 UHF 700.0 kW Albany 16.79 mi 252.43°
WCDC-TV ABC 36 19.1 UHF 48.0 kW Adams 27.15 mi 98.88°
WYPX ION 50 55.1 UHF 450.0 kW Amsterdam 31.58 mi 308.85°
So, where do I stand antenna wise?
UHF, VHF, UHF/VHF antenna? Stand or wall mount? Are there any other possible indoor antennas I could try?
Thx,
post #5079 of 5100 Old 01-17-2015, 09:44 PM
NYota1's Avatar
Quoted: 13 Post(s)
Thx,
I would think among the Clearstreams, that the U/VHF would be the best. I think your plywood idea would work. Although I've seen where users have hung the antenna on an interior wall close to the ceiling. Yes, I would imagine a wall mount would be better.
NYota1 is offline
post #5080 of 5100 Old 01-18-2015, 02:28 PM
Quoted: 31 Post(s)
So the Clearstream UHF/VHF would be better. Should I go with the combos and pay extra to have the cables included?
Can it be placed close to the HDTV, or will that cause interference? Would I need any type of antenna amplifier?
________________________________________
I'm getting closer to a selection. Thx all for the help so far.
post #5081 of 5100 Old 01-18-2015, 07:39 PM
NYota1's Avatar
Quoted: 13 Post(s)
Well, only because the Clearstream has a smaller profile, and a decent pickup range, is why I'm suggesting that it might work for you. There's also a version (which I believe is only for indoor use) that has only one loop...but it might be UHF only I'm not sure.
Only you would know what other accessories you might need, depending on how you envision setting it up. I wouldn't pay for too many extras, in case you're just going to stick it in the same room as the TV. I certainly wouldn't imagine that you'd need a amplifier. The only thing that could get tricky with an antenna like this, is where you said an adjustment is needed to get 55 from Amsterdam. Once you have it up somewhere, there might not be much room for additional tweaking! But if the locals are strong enough, you might be able to point it towards Amsterdam while STILL picking up 6,10,13, 17 etc......... That's what I'm able to do with mine.
NYota1 is offline
post #5082 of 5100 Old 01-19-2015, 11:42 AM
Quoted: 31 Post(s)
Hmm, I'm leaning towards getting a ClearStream™ 2V Long Range UHF/VHF Antenna Complete Combo Pack.
After some price matching, I ran across a few other antennas. Each has a 50+ miles range. All three of them can be found at RadioShack.com
Winegard FL6550A Flat Wave Air Outdoor Antenna
Winegard FL5000 Flat Wave HDTV Indoor Flat Antenna
RCA ANT1650F Flat Multi-Directional Antenna
Are any of these worth considering?
post #5083 of 5100 Old 01-19-2015, 06:26 PM
NYota1's Avatar
Quoted: 13 Post(s)
I don't know where you saw that the RCA has a 50 mile range! More like 20, if that. I had one of those once... I don't remember the model # but it looks the same. It was a DISASTER! A piece of junk. And I'm only 10 miles from the Heldebergs. I don't think they're any good on VHF, and I'd be really surprised if you could get ION (ch. 55) on it.
I can't comment on the Winegard.
Also remember, those flat antennas need to be PLUGGED IN to work. A big disadvantage.
NYota1 is offline
post #5084 of 5100 Old 01-19-2015, 11:03 PM
Quoted: 31 Post(s)
http://www.radioshack.com/rca-ant165...l#.VL3t0abW0SU
RCA's ANT1650F Flat-Panel Antenna incorporates a patented design specifically for 360° digital TV reception that eliminates adjustments. It receives local HD and DTV broadcasts and supports 1080 resolution.
  • Patented, 360° multi-directional design eliminates need for constant adjustments
  • SmartBoost amplifier enhances reception by amplifying weak signals
  • Supports up to 1080i HDTV broadcasts for high-quality picture and sound
  • Receives local HD and Digital TV broadcasts for free
  • Slim profile disappears into surroundings
  • Range: 60 miles*
  • Cable type: Integrated 6-ft coaxial
I'm checking all the possibilities before I commit to one antenna. I'd like to do enough research online, then head to stores to see some up close.
My goal is to make one purchase, not multiple attempts.
post #5085 of 5100 Old 01-20-2015, 12:35 AM
The Hound's Avatar
"My goal is to make one purchase, not multiple attempts."
Well the antenna's that are predicted to give you the best chance at the channels you want you have rejected.
If we give up on channel 6, RF6, all together, then my sugestion to you would be to find somewhere that has a good return policy and try out the VHF hi, UHF combo antennas that you listed in your previous post.
Get alot of cable so you can walk around the house in search of the best reception. Using a compass find the direction of the antenna farm from your location. Try to get the antenna as high as possible and a clear unobstucted line of sight to the tower. ie, if your TV is in the back room of your house and the antenna farm is straight out the front. Then you are going to want to run cable from the TV in the back to an antenna in the second story front window. Less obstruction, walls, trees, other buildings, the better your chances. Keep your antenna away from PC's, microwaves, anything with an electric motor, all these can cause interference.
Heck try these suggestions with the antenna you're using now.
"CA's ANT1650F Flat-Panel Antenna incorporates a patented design specifically for 360° digital TV reception that eliminates adjustments."
This is the exact reason why this antenna may not work for you. The more directional the more gain, the better reception.
Last thought, I've heard of people using the base and pole from a table umbrella to mount there antenna's. This way it can be put out on the porch, balcony and taken in when not needed. If the look is an issue.
I the end getting excellent reception is not about the look but, the functionality of the antenna.
Good luck, if you find the answer post it up.
The Hound is offline
post #5086 of 5100 Old 01-30-2015, 10:31 AM
The Hound's Avatar
It appears WNYA has lost the info that corrects the channel number as well as the program info. Anyone else see this?
post #5087 of 5100 Old 01-30-2015, 02:05 PM
ebo
ebo's Avatar
Quoted: 22 Post(s)
@The Hound : Apparently fixed quickly. At 15:45, using TSReader Lite, I'm seeing WNYA-HD on 51.1 with program listings from 15:00 to 18:30, and WNYA-AT on 51.2 with listings from 15:30 to 18:30.
O.T. Rant: I've never understood why most stations broadcast such meager listings. I'm sure it must be automated; they don't have someone typing as fast as he can to keep ahead of it, and they have to have at least a couple of weeks of program info for the other guide services.
ebo is offline
post #5088 of 5100 Old 02-01-2015, 03:41 AM
ETS121's Avatar
I'm in Port Ewen, NY, and it appears WRGB/WCWN's transponder in Kingston, NY on ch 24 is down again. It was up & working perfectly since September 2013. Since Sept 2013 I've had a 100% signal for 45-1. Two weeks ago I checked the signal and it was 100% still. I noticed last week that instead of being only 45.1(WCWN HD) & 45.3(WRGB SD) now they also have 45.2(Grit SD), I am unsure when 45.2 was added here. But I checked the signals and it was down to 83% but still a perfect picture. On Wednesday night he had a snow storm pass thru and I checked 45.1 & it kept losing picture and I noticed around 1am it stopped coming back and the signal was 7%. Still today on Sunday morning it's still 7% and no picture. I wonder what happened and I hope it comes back soon. I watch Ring Of Honor Wrestling on 45.1 every Sunday night at 9pm.
I'm still able to get WTBY on ch 27(54-1) out of Poughkeepsie and it's 5 subchannels with 40% signal and good picture quality.
I also noticed that WEPT-CD on ch 22(15-1) out of Newburgh or Woodstock which I began being able to pick up this summer is no longer airing just infomercials, it's now airing AMG-TV programming. Good picture quality.
Anyone able to get ch 24 out of Kingston?
ETS121 is offline
post #5089 of 5100 Old 02-02-2015, 12:08 AM
ETS121's Avatar
I have my indoor antenna hooked up to my DirecTV AM21 so I can DVR programs off of WRGB ch 24 in Kingston. I noticed 45-1's picture came back for 5 minutes on Sunday between 1:15pm-1:20pm during the Oakland vs Youngstown College Basketball game. It has not returned since, so I'm guessing there is something wrong with the transponder in Kingston.
ETS121 is offline
post #5090 of 5100 Old 02-02-2015, 07:28 AM
NYota1's Avatar
Quoted: 13 Post(s)
I didn't realize they were actually ON ch. 22 now...especially since the analog signal on 15 is still going. AMGTV has been on 15 ever since they moved the signal to Coxsackie. I can just barely receive analog 15. Judging from the ch.22 signal contour map, and the fact that I haven't seen it in recent scans...I guess it doesn't make it up this far.
One thing I noticed, W21CQ (currently analog) Bennington, has an application for a digital signal on RF21 on a tower about 7 miles south of the Heldebergs. It's intended to cover Albany.
NYota1 is offline
post #5091 of 5100 Old 02-02-2015, 11:58 AM
WRGB EngDept's Avatar
We noticed the power at 0% on Thursday. Not sure what's going on until we can get there. How much snow is in Kingston?
WRGB EngDept is online now
post #5092 of 5100 Old 02-02-2015, 01:05 PM
ETS121's Avatar
About a foot of snow today.
ETS121 is offline
post #5093 of 5100 Old 02-03-2015, 04:58 PM
Kingston translator back in service. A couple of fuses were blown on cooling fans for the power amplifier modules and they shut down due to overheating.
ETS121 likes this.
post #5094 of 5100 Old 02-04-2015, 11:40 AM
ETS121's Avatar
thank you
ETS121 is offline
post #5095 of 5100 Old 02-16-2015, 12:02 PM
Quoted: 31 Post(s)
Which would be the best for me to go with?
This antenna:
https://www.antennasdirect.com/store...l?cjid=6155355
or this one:
https://www.antennasdirect.com/store...-Assembly.html
Would they both work the same? From what I can see they each have a range of 50+ miles. Besides the additional base case cover, are there any other reasons to go with the MBS 50?
Thx,
post #5096 of 5100 Old 02-17-2015, 08:55 AM
NYota1's Avatar
Quoted: 13 Post(s)
This antenna:
or this one:
Thx,
Well, among those three, it's kind of a no-brainer as far as price is concerned. Chances are in your location, you probably don't need the VHF element because in my experience with that antenna, it even gets ch. 6 without a problem. But considering it's $99 for the whole kit `n kaboodle (and the j-mount isn't a bad thing to have either) it's the best deal. Plus, the VHF rod certainly can't hurt...you'll just need a bit more space to allow for the extra width.
By the way, when I got mine, BJ's was selling them at a good price. I don't think they have them anymore though.
NYota1 is offline
post #5097 of 5100 Old 02-17-2015, 01:45 PM
Quoted: 31 Post(s)
Yes price wise the combo is my best choice. The other MBS 50 is a couple inches smaller according to the AntennasDirect Rep. The stations I want are UHF & VHF so I need that element.
The MBS comes with a J-Mount cover/stand which would be great for me. I will be using this antenna indoors. Having that base would be great, but it's not available as a separate item.
I checked with AntennasDirect site & rep. I've also checked around google, amazon, ebay, etc. But I can't find it anywhere. So my choices was to either buy the C2 Combo and make my own stand for it. Or buy the MBS 50 (UHF only) plus the VHF conversion kit.
Did you mount yours? How? I was planning to mount mine on a wood block (8" x 8" x 2"). The AntennasDirect Rep told me that's what they recommend for people to do when mounting indoors.
BJ's? How is this Antennas Direct site? Should I give them a try? Or should I try finding the antenna cheaper at lets say Walmart or BestBuy?
post #5098 of 5100 Old 02-17-2015, 02:07 PM
NYota1's Avatar
Quoted: 13 Post(s)
I was only using this antenna outdoors...so I had it roof-mounted on the j-mount. Worked quite well.
The wood block sounds good. Naturally you'd want to try and get it up as high as you can in the room. I'd still get the $99 deal if I were you.
Yes, I've ordered from Antenna's Direct before. Very good service. I'm pretty certain you WON'T find this antenna at Wal-Mart (at least not in-store). Best Buy MIGHT have it. I remember now I DID see the combo unit there quite a while ago. It's worth a check...since it would be easy to return if you had to. If Best Buy had it...it wouldn't be any cheaper though.
Did you ever read my review on the antenna? http://lightsngear.com/?p=235
NYota1 is offline
post #5099 of 5100 Old 02-18-2015, 10:13 AM
ebo
ebo's Avatar
Quoted: 22 Post(s)
You could mount the antenna without the J-mount at all, replacing it with a suitable length and diameter pipe or dowel mounted in a Christmas tree stand. Even PVC pipe could work although it might be too flexible. I use a wood dowel with my 4-bay bowtie.
ebo is offline
post #5100 of 5100 Unread Today, 05:37 PM
Quoted: 31 Post(s)
I've gotten the hardware part confirmed, I think. 8" x 8" x 2" thick board, with four 1/2" or 1" wood screws (any brand recommendations).
How does that sound? That should support the ClearStream 2V Long Range UHF/VHF Antenna.
