Albany, NY - HDTV - Page 174 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #5191 of 5210 Old 06-26-2015, 04:57 PM
wkomorow's Avatar
I have tried a second antenna with the same result.
wkomorow is online now
post #5192 of 5210 Old 06-27-2015, 06:00 AM
wkomorow's Avatar
Hmm - within the last hour (Sat 9 AM) it just came back to normal. Wonder what the issue was?
post #5193 of 5210 Old 06-28-2015, 03:29 PM
wkomorow's Avatar
Really odd - it is off again. The signal has always been steady 73, never goes above 75, or below 72, but mostly completely steady at 73. I wonder if there is an issue with the transmitter,
post #5194 of 5210 Old 06-29-2015, 08:41 AM
NYota1's Avatar
Quoted: 34 Post(s)
Are you talking about a WNYT translator?
NYota1 is online now
post #5195 of 5210 Old 06-29-2015, 11:24 AM
wkomorow's Avatar
Yes it is the one located at south mountain in pittsfield a couple of miles from me. I have never had an issue with it before - it has never fluctuated. I am getting no signal whatsoever from it. I can not get rf 12 WNYT because of interference from my solar arrays, but they only block 7-13 during the day and do an affect UHF or signals at night.
post #5196 of 5210 Old 06-29-2015, 11:30 AM
NYota1's Avatar
Quoted: 34 Post(s)
You can't get WNYT on 18.1 I guess either huh?
post #5197 of 5210 Old 06-29-2015, 01:35 PM
wkomorow's Avatar
No way to far away. On a good day I can get it on 38 (on Greylock), but I set up DVRs and I can not be fooling around changing things every few hours. I had the same problem with rf 19(45) a while ago and it turned out to be a transmitter unit. Unfortunately, there was a ton of snow on the ground and the engineer could not easily get to the transmitter to get it fixed. All my other UHF stations on that antenna remain fine, so I do not think it an antenna issue. I think there is a problem on South Mountain. Interestingly, there is a lot of construction (road construction) happening in that area.
post #5198 of 5210 Old 07-01-2015, 06:08 AM
Scott_J's Avatar
Sinclair announced recently that they're starting a diginet featuring science-fiction shows and movies that is expected to launch in the fall. Since it's owned by Sinclair, i would expect it to be on a feed of either WRGB or WCWN at or shortly after launch. Maybe it'll replace ThisTV if/when WRGB gets rid of that.
http://www.broadcastingcable.com/new...diginet/142220
Scott_J is offline
post #5199 of 5210 Old 07-01-2015, 07:51 AM
NYota1's Avatar
Quoted: 34 Post(s)
Interesting. We'll see what happens.
In the meantime... still waiting for developments on 10.3
post #5200 of 5210 Old 07-01-2015, 04:12 PM
wkomorow's Avatar
Well I got that wrong - COZI did not appear today. In fact all of the Media General stations subchannels (formerly owned by Young) that had LWN are dark. Some talk of BUZZR
post #5201 of 5210 Old 07-05-2015, 08:32 PM
mikepier's Avatar
Quoted: 14 Post(s)
Originally Posted by mikepier View Post
Still having slight issues with WNYT -13 (VHF 12), occasionally get dropouts, nothing major, but it is an annoyance. I do not have an amp, but figured one might help, also to maybe get WNYA-51 that I cannot get a blip of.
I ordered an RCA TVpramp1R from Walmart online for $20. I 'll post back to report results.
Nice that 45-3 is now in 720P for those who only have a UHF antenna, or have trouble getting 6-1. My Radio Shack VU-210XR survived another winter ( 20 years old now) , but would like to replace eventually.
Well, finally got around to installing the amp this weekend, and although it did improve signal strength, still no signs of WNYA-51.1. I was really hoping to get it, but what I saw instead was 14.1 out of Hunter, but it was very weak with a lot of dropouts.
Can't understand why I'm having issues getting 51.1, when I can get WKTV in Utica 53 miles away perfectly with no amp.
mikepier is offline
post #5202 of 5210 Old 07-08-2015, 04:12 PM
wkomorow's Avatar
I have written wnyt - still have not heard back, but I still can not get a signal from rf 28. I have tried 2 antennas and it is the only UHF channel I have an issue with.
post #5203 of 5210 Old 07-09-2015, 04:26 AM
RKlein13's Avatar
All,
The South Mountain site where channel 28 for WNYT has been having significant electrical power problems. Both the power company and staff have been working to resolve the problem. Hopefully this can be resolved soon, as it has been as frustrating for the station as I assume it has been for you.
Richard Klein
WNYT-TV / WNYA-TV
715 N Pearl St. | Albany, NY 12204
RKlein13 is offline
post #5204 of 5210 Old 07-09-2015, 07:06 AM
wkomorow's Avatar
Thank you for the update
Originally Posted by RKlein13 View Post
All,
I absolutely understand - there is also a ton of construction in that area (not sure it is related). I was more concerned that there was some issue with my setup or some weird interference. I tried a lot of stuff, different antennas, preamp no preamp, etc. I have a call into my solar company because interference from my inverters make hi VHF impossible during the day, no issues when the sun is down. Therefore I can not get rf 12 during the day. I probably pvr ME-TV (and at night antennatv) more than any other station. Thanks for the update. For whatever reason rf 38 on Mt Greylock is a really hit but mostly a miss for me. I think the power is just too low or rf 36 may be causing interference for me at my range.
I appreciate the update, so I don't have to worry about my setup now. Positive thoughts that the transmitter gets fixed soon.
post #5205 of 5210 Old 07-09-2015, 01:09 PM
wkomorow's Avatar
28 appears to be backed. Thank you.
post #5206 of 5210 Old 07-10-2015, 03:59 AM
RKlein13's Avatar
The power problems at the Channel 28 site in Pittsfield have been resolved. Thanks for your patience.
Richard Klein
WNYT-TV / WNYA-TV
RKlein13 is offline
post #5207 of 5210 Old 07-13-2015, 06:31 PM
wkomorow's Avatar
Media General (channel 10/23 owners) announce a new service Newson:
http://www.prnewswire.com/news-relea...300096287.html
Live streaming news from local stations across the US. Looks like it will be part of the News 10 app.
Still nothing on the LWN replacement
post #5208 of 5210 Old 07-19-2015, 04:11 PM
wkomorow's Avatar
rf 28 is down again.
post #5209 of 5210 Old 07-30-2015, 09:09 PM
NYota1's Avatar
Quoted: 34 Post(s)
I just arrived back from a few days in Newport R.I. (which is on the south coast about 40 miles from Providence)
Perhaps because I'm weird...(or would be, to non-OTA folks) I took a portable TV and an Antenna's Direct Clearstream 2 with me. I had a west facing 3rd floor hotel room just north of Newport in Middletown. I placed the antenna in the window, and would check reception during the late evening, after a day of sightseeing.
Even though I could barely move the direction of the antenna, I was amazed at some of the distant channels it picked up. They almost varied from night to night...but some channels appeared for more than just one evening.
In general, I saw New York City, Hartford & Boston. It was pretty selected though. From NYC I saw ch 4,5, & 9. From Boston...2,4 & 44. From Hartford...3, 30, 36 & 61. Also Bridgeport Ct., I believe.
The highlight with all these channels was actually seeing many of the digi-nets that we're not permitted to see around here. CoziTV, Escape, Movies!, Legends and GetTV were all represented...as well as the ones we DO get here. Among all the nets, the hotel TV only got MeTV, Grit and Escape. Plus, there was also a new network that started in June which I'd never heard of..."Buzzr". It's all classic game shows. That one was courtesy of WWOR 9. That channel is a production of FremantleMedia and so far has only been cleared on about 33 Fox stations across the nation.
It all seems kinda dull back here now.
post #5210 of 5210 Old Today, 03:04 PM
wkomorow's Avatar
Looks like rf 19 (45) from JP is now having issues. rf 28 (13) from Pittsfield came back.
