Kansas City, MO - HDTV - Page 166 - AVS Forum
post #4951 of 8913 Old 07-07-2006, 09:02 AM
LiveLite's Avatar
KSMO-DT-47 will not automatically scan into my STB, but if I manually add the channel, it accepts it. It takes 6 or 7 seconds for my STB to acknowledge that there is a valid signal there. The automatic scanning function times out before the tuner detects a valid signal. I have seen this behavior on the other stations in the 'early days' from time to time. STB = Samsung SIRT-151.
LiveLite is offline
post #4952 of 8913 Old 07-07-2006, 11:00 AM
Colonia9's Avatar
Further my 07-04-06 posting. Thanks KSMO. My LTV-32w6 now locks in 47-1 with resulting brilliant video and sound!
Colonia9 is offline
post #4953 of 8913 Old 07-07-2006, 01:34 PM
jeffdbs's Avatar
I was able to get a hold of KSMO DT-47 (62-1) engineering. Yes they are aware of the problem and are working hard to solve the problem. Hopefully we all will be able to receive DT-47 again very soon.
jeffdbs is offline
post #4954 of 8913 Old 07-07-2006, 06:12 PM
Colonia9's Avatar
Apparently my congrats earlier today to KSMO were premature. The DT-47 signal was recognized by a Westinghouse LTV-32w6 scan several hours ago and viewed for a short period. It must be a work in progress because this evening signal is again a no show.
Colonia9 is offline
post #4955 of 8913 Old 07-08-2006, 07:30 AM
mcj2a's Avatar
It started showing up for me this morning as channel 47.62. Getting closer...
mcj2a is offline
post #4956 of 8913 Old 07-10-2006, 05:20 PM
rrostie's Avatar
Originally Posted by DogOfMadness View Post
KSMO-DT (RF Ch 47) on with 1 MW power at about 12:30 today! Reception reports would be appreciated.
Any updates? I am currently watching KSMO-DT on 47.62
rrostie is offline
post #4957 of 8913 Old 07-10-2006, 07:05 PM
dlnester's Avatar
Mine switched back from 47.62 to 47.3 today.
dlnester is offline
post #4958 of 8913 Old 07-11-2006, 08:07 PM
dlnester's Avatar
DAMN YOU FOX 4 FOR SWITCHING TO SD! I'm trying to watch the ALL-STAR game!
BTW: I now get KSMO-DT at 62-1
dlnester is offline
post #4959 of 8913 Old 07-13-2006, 12:07 PM
Eyedox's Avatar
This just in today ...
The Federal Communications Commission voted 3-2 Thursday to approve the $16.9 billion acquisition of Adelphia Communications by Time Warner Inc. and Comcast, removing the last regulatory hurdle facing the deal.
http://www.multichannel.com/article/...=Breaking+News
Eyedox is offline
post #4960 of 8913 Old 07-13-2006, 04:11 PM
kcjefff's Avatar
That will make moving out of KC that much easier for TWC.
kcjefff is offline
post #4961 of 8913 Old 07-14-2006, 05:32 PM
Colonia9's Avatar
Using an Accurian 16-3499 HDTV receiver because of advantageous built in signal reception tools, the following strength comparisons were obtained today at Weatherby Lake. Antenna is a chimney mounted Winegard PR-8800 with rotation capability but fixed and directed at mid cluster of the KC stations for purpose of exercise.
STRENGTH METER SNR
4-1 86 28.5
5-1 92 32.0
9-1 94 33.4
16-1 90 31.3
19-1 91 31.9
29-1 94 33.5
38-1 82 26.6
41-1 86 29.1
50-1 89 30.9
62-1 85 29.0
Note all readouts jump around so logging numbers above has to be a judgment call. Regarding much discussed KSMO(62-1), tweaking ant. direction to optimize signal strength gave 93 and an SNR of 33.0. Similarly rotating ant. for best KTWU Topeka (11-1) gave 79 and 25.0 respectively, for very acceptable viewing
Colonia9 is offline
post #4962 of 8913 Old 07-17-2006, 12:34 PM
Bradtothebone's Avatar
I hadn't checked for awhile, but over the weekend I was once again able to load KSMO into my Dish 622. It's showing as 62.1 and coming in at 95%. Thanks, Dog-of-Madness!
Brad
"I can't complain, but sometimes I still do!"
- Joe Walsh
Bradtothebone is offline
post #4963 of 8913 Old 07-17-2006, 05:14 PM
jeffdbs's Avatar
Brad
Me too.................. It's nice to have DT-47 (62.1) back in the lineup.
jeffdbs is offline
post #4964 of 8913 Old 07-17-2006, 07:48 PM
ekrainey's Avatar
hmmmm Not on my dish 811. still black with no sound
ekrainey is offline
post #4965 of 8913 Old 07-17-2006, 08:37 PM
jeffdbs's Avatar
Have you tried removing DT-47 (62.1) first and then rescan DT-47 for the new PSIP info? Hope this works.
jeffdbs is offline
post #4966 of 8913 Old 07-18-2006, 05:56 AM
ekrainey's Avatar
Rescaned everything and still no go. Dt-47 shows up as 62-1 but picture is still black and no sound, with a signal strength of over 80 sometimes 90. although i did pick up a couple station from omaha.
Maybe a little more work and they will get it fixed
ekrainey is offline
post #4967 of 8913 Old 07-20-2006, 11:51 AM
technicalitalian's Avatar
Just a preemptive notice that the British Open will not originate in HD. However, ABC has notified us that they are taking the PAL feed, which is being shot in 16x9 aspect ratio/SD and upconverting it to 720P. Since we're starting with 625 lines, it may not look toooo bad. We'll wait and see. Please do not adjust your sets or try to call the station.....TI
technicalitalian is offline
post #4968 of 8913 Old 07-21-2006, 06:21 AM
bongohawk's Avatar
TI,
How is the new building for Channel 9 coming along? Have they ordered any new equipment for the new studio?
bongohawk is offline
post #4969 of 8913 Old 07-21-2006, 07:55 AM
KSBugeater's Avatar
TI - Is that the same feed that TNT is using for their coverage of The Open? It's pretty good... not Masters good, but good. I'll watch about any golf in HD. Thanks again as KTKA-49 promised us Topekans ABC-HD July 1st and it's still not here. I'm glad I'm lucky enough to get your signal 95% of the time.
KSBugeater is offline
post #4970 of 8913 Old 07-21-2006, 02:43 PM
Originally Posted by bongohawk View Post
TI,
Some has yes. Final evals almost finished....TI
post #4971 of 8913 Old 07-21-2006, 02:47 PM
I can't say with 100% acuracy but since the cost of doing golf is so high, mostly due to the sheer number of cameras, I can't imagine they're using anything but the pool feed....TI
post #4972 of 8913 Old 07-21-2006, 05:22 PM
bongohawk's Avatar
Now I assume this equipment is HD compliant?
post #4973 of 8913 Old 07-22-2006, 07:18 AM
Gojhawks's Avatar
TI, just wanted to say thanks to you guys getting it right on the British Open. From reading the programming forum here a number of the ABC affiliates didn't get the message the broadcast was going to be widescreen and have been showing it in 4:3. I really appreciate KMBC went right to widescreen. It looks nice for an upconvert.
"There's gotta be some way to hook it up, it's the freakin' future" - Eric Cartman
Gojhawks is offline
post #4974 of 8913 Old 07-22-2006, 07:27 AM
rrostie's Avatar
On my Sony DVR, I can punch in channels even if the scan didn't pick them up for some reason. (Like I can get the new weather channel that way.) I can't get 62-1 but I can still get it on 47-62.
rrostie is offline
post #4975 of 8913 Old 07-22-2006, 11:27 AM
dlnester's Avatar
Is it just me or does the baseball game on FOX today just not look very crisp? It just seems compressed for some reason and I'm receiving it over the air from WDAF-DT with high signal strength.
dlnester is offline
post #4976 of 8913 Old 07-22-2006, 12:07 PM
Gojhawks's Avatar
It is not HD. It is upconverted widescreen SD. The FOX Saturday afternoon games are not HD.
Gojhawks is offline
post #4977 of 8913 Old 07-22-2006, 12:08 PM
dlnester's Avatar
Ah... that explains it! Thanks.
dlnester is offline
post #4978 of 8913 Old 07-23-2006, 12:37 PM
kurhurdler's Avatar
on KMBC (OTA), does anyone else see a flickering pixel in the middle of the screen, about an inch from the top of picture? I don't have it occur on any other channel.
kurhurdler is offline
post #4979 of 8913 Old 07-23-2006, 12:42 PM
dlnester's Avatar
I see it as well OTA... looks like it is the program they are airing.
dlnester is offline
post #4980 of 8913 Old 07-23-2006, 12:48 PM
Gojhawks's Avatar
It has been there on and off the last few days. Seems to be only on that channel. I am on Sunflower cable.
Gojhawks is offline
User Tag List
