time related reception issue - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bobby94928
post #1 of 3 Old 06-06-2016, 05:19 PM - Thread Starter
Liked: 0
Winegard FlatWave Air VHF/UHF Outdoor Amplified Antenna (60 Mile Range)
50ft RG-6 cable with inline amp (near the TV) included with the antenna
I installed this antenna on the roof of my family member's house with flat face of antenna facing at about 330 degrees (North by Northwest). All the standard VHF channels pull in (2, 4, 5, 7, 9, 11 - virtual stn number). The problem is that Ch 7 starts to breakup after watching for 5-10 min beginning around 4pm. The other channels aren't affected.
Winegard customer service said antenna not built to receive low-VHF. Do not think KGO-TV is Lo-VHF. TV receiver scan produces two 7.1 channels. Tried both, but pixilation and loss of sound occurs sporadically. They suggest calling station or Coit tower (35 miles away), because problem seems to be subject to certain time frame not antenna.
What can I do to get channel 7 better and still keep other channels? Is this the wrong antenna for the job?
mcgruzoo is offline
post #2 of 3 Old 06-06-2016, 05:29 PM
bobby94928's Avatar
Liked: 369
The first thing you want to do is torepeat your post in the proper area and you will get some good answers.
San Francisco, CA - OTA
ejb1980 likes this.
Bobby
bobby94928 is offline
post #3 of 3 Old 06-07-2016, 07:01 AM
Super Moderator
DrDon's Avatar
Quoted: 877 Post(s)
Liked: 1734
Always read threads that say Mandatory read *** before *** posting ..before posting. Saves you time by directing you to the place that'll give you the fastest answers.
Also, including a LINK to your TVFool.com report is highly recommended. If you don't have enough posts to put in a link, PM me and I'll edit it in for you.
Thanks and welcome to AVS.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
