Santa Barbara, CA; Santa Maria, CA; San Luis Obispo, CA - HDTV - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 07-03-2014, 10:04 AM
giant25's Avatar
Quoted: 12 Post(s)
Originally Posted by rc05 View Post
Is anyone else getting pixellation on KSBY lately? The news was blocky and Hannibal last night was almost unwatchable. It's not happening on other channels...wondering if anyone else is seeing anything?
I'm in Arroyo Grande and am seeing pixelation on KSBY and CW as well. I just hooked my OTA antenna back up to my HDHomerun Dual, which is used by Windows Media Center to feed an XBMC frontend. The pixelation looks similar to the screen shots a few posts above. The signal strength is pretty much 100% at all times for KSBY. I also get KEYT from the SLO/Cuesta Ridge repeater (31) and KCOY/KKFX from SM as well. Those channels look perfect even though their signal strength is weaker. I'd say the pixelation occurs once or twice a minute, just enough to be annoying. I have my antenna in the attic, which isn't ideal, but didn't want to mount it outside unless I was pretty confident that I needed to. Anyone else still seeing occasional pixelation on KSBY?
giant25 is offline
Old 07-03-2014, 01:39 PM
baja7475's Avatar
Quoted: 39 Post(s)
Liked: 55
I'm still getting pixelation on ksby, not as bad as last month. I have charter.
baja7475 is offline
Old 07-22-2014, 09:26 AM
baja7475's Avatar
Quoted: 39 Post(s)
Liked: 55
san luis obispo county (charter)
Digital transition happened last night on schedule. The only errors i saw was on series recordings on broadcast channels. Easy fix, change the channel option to hd only on the series manager.
baja7475 is offline
Old 07-29-2014, 10:52 PM
giant25's Avatar
Quoted: 12 Post(s)
Did the digital transition complete in AG/Grover Beach today as scheduled? I only have Charter Internet, so I can't tell for sure. I've been getting slow internet speeds during peak hours (2 to 3 Mbps down at 8-11pm) and Charter said this should be resolved when the digital transition completes. I've been patient (slow speeds in pm since May).......
giant25 is offline
Old 07-30-2014, 09:02 AM
baja7475's Avatar
Quoted: 39 Post(s)
Liked: 55
I heard it takes a while. Faster speeds by Sept or Oct. I know they are testing it, because i have gotten 60 a couple of times in the last week or so.
baja7475 is offline
Old 07-31-2014, 08:36 AM
karrank%'s Avatar
We have noticed slower speeds in the early evening/after dinner hours. I live in Grover, and the transition happened right on schedule, 29th I think it was.
We'd stopped bothering with subscription TV until that happened.
We had to rescan, and lost everything except strictly OTA stuff. Back to screwing with antennas again, going to experiment with our little monoprice, (an exterior placement). Any current advice on that subject would be appreciated.
karrank% is offline
Old 07-31-2014, 10:42 AM
giant25's Avatar
Quoted: 12 Post(s)
I'm on Charter node GB209 if you wanted to compare. I'm very disappointed that I'm still getting 3 Mbps download speeds at night even after the transition. I know baja mentioned it might take a while, but that wasn't what I was told by Charter. They've been stringing me along for a few months now avoiding slow speeds in our area with no compensation yet for these issues.
So are you looking to go strictly OTA? That's where I'm headed. You should consider a directional external antenna pointed at Cuesta ridge where KSBY and KEYT (repeater) are located, and you'll likely get KCOY/KKFX from Santa Maria as well. I think KCET is available as well, but haven't yet looked into it. You can check out antennaweb.org or tvfool.com for more info.
giant25 is offline
Old 07-31-2014, 10:58 AM
karrank%'s Avatar
Yeah, I'm considering the antenna thingy, just not very enthusiastically. Seems like a lot of work for maybe four channels. Three of them come in well enough with the indoor. No KEYT, and KSBY spotty enough to bother the wife. Me, all those stations could disappear tomorrow & I wouldn't notice, much less care.
I mean, can you imagine waiting for some clown to shout at you what the weather's going to be before the day starts and after it's done? Senseless.
Regarding the speeds, I haven't measured anything recently, just seemed to slow down a bit around dinnertime (Streaming MLB on our Roku can get a little funky), nothing disastrous.
karrank% is offline
Old 07-31-2014, 10:59 AM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Hey! Dave Hovde is the best!
rc05 is offline
Old 07-31-2014, 11:25 AM
karrank%'s Avatar
More of a grouse about others waiting for info to be received via squawkbox instead of just retrieving it at their convenience.
But if the shoe fits...
And interesting that you figured I was talking about Hovde!
karrank% is offline
Old 08-12-2014, 11:55 AM
baja7475's Avatar
Quoted: 39 Post(s)
Liked: 55
Charter (San Luis Obispo county)
The SEC and the SEC alternate channel just showed up on my guide. Channels 867 and 868.
baja7475 is offline
Old 09-05-2014, 11:29 PM
giant25's Avatar
Quoted: 12 Post(s)
I was finally able to speak to a local tech in the Arroyo Grande/Grover Beach area and they mentioned that they recently migrated to 16-channel bonding to alleviate congestion on the node here. I have seen a huge difference, with download speeds now staying at 30 Mbps all evening. No 60 Meg Spectrum sightings yet, but no worries here.
With regards to the pixilation on KSBY: I am only seeing the dropouts/pixilation on my HDHomerun box. It does appear something within the signal is causing it, as I just received a newer version of the HDHomerun box from the vendor and I see the same signal quality drops. However, with this new model, the error handling is much better and the pixilation is less noticeable. I also hooked this antenna straight into my Samsung TV tuner and do not see any dropouts, suggesting that the error correction is superior on the TV. Anyone else have an HDHomerun or other TV tuner that can check out KSBY?
giant25 is offline
Old 09-22-2014, 03:00 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Ok, I just got settled back in SLO and I'm loving the new channels! I'll check one more time tonight, but it looks like the pixelation on KSBY was resolved over the summer! Unfortunately, I just noticed that KEYT, KSBY, KCOY, and KKFX are all marked as copy-once (meaning I can't mark commercials or move the files to different computers). I don't think it's on the station ends, since it's all of them. I'm trying to reach out to Charter, but I'm not expecting much from them.
rc05 is offline
Old 09-28-2014, 11:43 PM
giant25's Avatar
Quoted: 12 Post(s)
Does anyone have a CableCARD with Charter? I currently only have Charter internet and was considering getting an HDHomerun Prime with a CableCARD for just the local channels if it's cheap enough (using XBMC/Kodi). I'm wondering how much it costs for just the locals or if that is even possible (I don't want the $26/mo basic package, was hoping under $10/mo or so). Anyone?
giant25 is offline
Old 09-29-2014, 10:49 PM
karrank%'s Avatar
There's a $26 basic package? I've just been looking and can't find that anywhere!
-and sorry, no cable card.Just the internet service right now. Thinking of adding TV service to catch the playoffs, but looks like they want to charge extra monthly fee for a set top box.
Grrr.
karrank% is offline
Old 09-30-2014, 09:39 AM
Terry78's Avatar
Try free OTA for your needs
Charter doesn't have anything close to that price, I think the best you could do is about $59 for the basic package.
Depending on your location, you should try free over-the-air TV. All the major networks and PBS (KCET) are available in SLO and reception is excellent (depending on your specific location). Using a Terk indoor antenna in a kitchen cabinet, we get ABC, RetroTV, NBC, CW, CBS, Fox, 4 KCET channels, and 8 to 10 Spanish channels.
A couple years ago, we used to have a simple old rabbit-ears antenna in another room and received all the majors with it. Maybe you could borrow one, or a different antenna, from someone to test reception at your location. Until then, check out tvfool.com for a map of your stations. It's good, but I just noticed that they don't have a couple of our stations listed.
Good luck! Be aware that some indoor antennas are very sensitive to positioning -- so even a slight direction rotation may result in a distant station coming in or not.
Terry78 is offline
Old 09-30-2014, 10:16 PM
giant25's Avatar
Quoted: 12 Post(s)
Thanks for the reply. I have an outdoor antenna (omni) in my attic that I was thinking of moving outdoors to improve my signal. I've been using OTA feeding an HDHomerun Dual that plays nicely with XBMC and the server.wmc/pvr.wmc plugins. The signal here in Arroyo Grande can be tricky, so I thought I'd ask about cheap cable and get an HDHomerun Prime with CableCARD, but looks like there's no cheap monthly plan. With the antenna I get ABC, CBS, NBC, FOX, and CW, but I notice pixilation sometimes. I might even get a directional antenna since a neighbor is doing that with success right now, where he also gets PBS in addition to the networks above.
I have Dish Network but am looking to cut the cord with XBMC on a Raspberry Pi. The video quality on the Pi is perfect, I just wish the Pi had a bit more horsepower. I tried XBMC on the Amazon Fire TV and it is blazing fast. It doesn't deinterlace mpeg-2 properly, though, which makes sports look terrible and is a deal breaker for now. Maybe the upcoming Android TV will finally be the answer, as the Pi is decent but limited.
giant25 is offline
Old 01-10-2015, 09:23 AM
Freezer75's Avatar
New local CBS and Fox repeater
Last night I was scanning for channels when two new channels appeared. Fox (KKFX) has finally replaced the analog signal from Cuesta peak with a digital repeater. This signal also includes Fox's sister station CBS (KCOY).
So if you use an antenna pointed at Cuesta peak, scan for new channels and enjoy!
The exact details are:
Virtual channel: 24.1: Fox (KKFX) 480 16:9
Virtual channel 24.2: CBS (KCOY) 1080 16:9
Freezer75 is offline
Old 01-10-2015, 10:30 AM
mvcg66b3r's Avatar
Quoted: 102 Post(s)
They could upgrade the FOX subchannel to 720p HD on 24.1/12.2 (an HD feed is carried on cable). KSBY has their CW subchannel in HD.
http://www.rabbitears.info/market.ph...=33870#station
http://www.rabbitears.info/market.ph...=63165#station
http://www.rabbitears.info/market.ph...=19654#station
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is offline
Old 01-11-2015, 09:16 PM
Freezer75's Avatar
Technically they can, but will they? Their main transmitter for KCOY in Santa Maria I believe is the same way, 1080 for CBS and 480 for Fox. Hopefully they will upgrade both signals.
As a follow up to my post, if you rescan for channels and don't pick up the channel, move your antenna and try again. This new signal is relatively weak. This signal is .3 KW effective radiated power. Compare that to 1000 KW for KSBY, 15 KW for KEYT, and 8 KW for KCET. So this is definitely a weak signal. I have 3 TVs and antennas, only 2 of which picked up this signal. I need to move my third antenna and try again.
Old 02-05-2015, 02:57 PM
giant25's Avatar
Quoted: 12 Post(s)
The 12.2 Fox feed is now in HD, both from SM and the Cuesta Repeater. Enjoy folks.
http://www.keyt.com/news/cbs-fox-now...nties/30821494
giant25 is offline
Old 02-21-2015, 01:03 PM
fatuous's Avatar
Liked: 0
Digital QAM channel for KEYT in South SB County
In downtown Santa Barbara, we used to get HD KEYT on 114-3 but no more. Have done a complete rescan this morning, but can't find any KEYT channels, standard or HD. Also tried navigating to 114-3 directly, but no signal. Heard from an Edhat forum that the QAM channel may have changed -- suggestions were 50-2, 50-3, and 50-4, but none of those worked for us.
Is the KEYT transmitter still transmitting from Broadcast Peak, or are we going to have to try to pick up the signal from the SLO transmitter with an indoor antenna? Looking to get an HD ABC station in time for the Oscars tomorrow
Does anyone know what happened? Any suggestions?
fatuous is offline
Old 05-05-2015, 09:34 PM
karrank%'s Avatar
I suspect I may be poking the bear, but anyone here have a Tivo Roamio, and if so, does it play nice with OTA, or with Charter (needs a card I think)?
Thanks for looking.
karrank% is offline
Old 05-05-2015, 09:36 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Roamio will work with either, but the Roamio Plus/Pro will need a CableCARD from Charter
rc05 is offline
Old 05-05-2015, 09:45 PM
karrank%'s Avatar
Cool, thanks! I think I found a deal for the 4-tuner/500GB model w/lifetime sub, will report back if the deal goes down.
karrank% is offline
Old 05-05-2015, 09:48 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Sorry, to clarify, all three Roamio models will work with Charter with a CableCARD, but only regular Roamio can do OTA. I had some some initial pains with getting the CableCARD working, but Charter sent good techs who knew what to do (mostly, swap out CableCARDs until one works). Once the CableCARD is paired then you shouldn't have any trouble.
rc05 is offline
Old 05-06-2015, 01:15 PM
giant25's Avatar
Quoted: 12 Post(s)
Report back if/when you get it running. I am currently using an antenna feeding an HDHomerun to WMC/Kodi setup and it's working well, but I'm curious about a polished solution with built-in apps as well (like Amazon Instant Video).
giant25 is offline
Old 05-06-2015, 01:39 PM
karrank%'s Avatar
I couldn't resist the 300 clam offer for a Roamio OTA with lifetime service. We're dumping Dish as soon as I plug the Roamio in.
Along with our Roku we should have more than enough couch potato content to keep the peace and ensure domestic tranquility, if you know what I mean
karrank% is offline
Old 05-06-2015, 03:25 PM
giant25's Avatar
Quoted: 12 Post(s)
I figured you were talking about the Roamio OTA $300 lifetime, saw that last week. I dumped Dish earlier this year, haven't looked back. For anyone else reading, the Roamio OTA appears to be the same as the entry level Roamio DVR but without cable support. I thought about getting one of those and adding a Mini for a second room. The Kodi (formerly XBMC) solution is nice/flexible/free, but you kinda have stay on top of it sometimes to keep it all fluid (I have a Win 7 PC with WMC doing the recordings and then a Chromebox and Raspberry Pi for my frontends, along with Harmony Remotes). There are alot of moving parts, might be nice to try Roamio someday...
giant25 is offline
Old 05-14-2015, 11:49 AM
karrank%'s Avatar
Ok, box arrived Tues (after mysteriously sitting in Mesquite for almost five days) just got around to installing. Picked up our three OTAs from our indoor Monoprice no prob, seems to be working nicely on our wireless, linked our Netflix, Amazon, MLB, Pandora, Vimeo, and VUDU accounts. Thirty days to explore, become accustomed to the GUI, &c. So far, so good. Assuming it's a go for the WAF this will pay for itself in under a year. Oh, and this model will accept a CableCard. Haven't reconsidered Charter as a TV provider, but nice to know I have that option.
We'll have to get another antenna, KSBY breaking up a bit. Still, being able to pause live OTA TV without having to pay >$60 every month is just an irresistible lure.
karrank% is offline
