Flint, MI - HDTV - Page 38 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1111 of 1131 Old 09-22-2015, 06:20 PM
Primestar31's Avatar
Quoted: 76 Post(s)
Liked: 46
WBSF Channel 46-3 "Grit".
Can anybody tell for SURE what aspect ratio they are actually transmitting on this channel? Everything on it is old 4:3 stuff, but my tv set wants to set it to 16:9, which makes it "stretch-O-vision" which I HATE.
I'd rather it default to 4:3 mode with black bars on the side. However, I'm unsure whether the issue is because they are broadcasting the 4:3 material overscanned to 16:9, OR if there's an issue with my tv's aspect ratio on this channel.
If I FORCE set the channel to 4:3, it looks fine, but it automatically wants to be 16:9...
They are broadcasting this as 16x9 480i. So, it is stretch-O-vision. I prefer original 4x3 material to be broadcast as 4x3, even if it has black bars at the sides. That's the format it was filmed in, and should stay in.
I complained to the station engineer, but he hasn't made any change as of yet.
NOTE: They finally got this fixed on October 1st!
Primestar31 is online now
post #1112 of 1131 Old 10-16-2015, 04:28 AM
Quoted: 13 Post(s)
Liked: 1
Comet TV on WSMH
Looks like the new sci-fi channel Comet TV is replacing ZUUS Country on 66.3 on Oct. 31st.
thebeeguy is offline
post #1113 of 1131 Old 10-16-2015, 12:13 PM
Quoted: 76 Post(s)
Liked: 46
Yeah, and I can't WAIT! October 31'st it should go live.
http://comettv.com/
post #1114 of 1131 Old 10-19-2015, 04:36 AM
Quoted: 13 Post(s)
Liked: 1
I've been using a homemade 4-bay McClapp up in my attic now for about a year and a half. I could get channel 5, 12, 19, 25, 28, 49 & 66 pretty good most of the time. But sometimes 12 & 5 would mess up. So I decided to make another on out of PVC to put it on the roof. I painted it black so it doesn't stand out. I put it up and have added 4, 6, 7, 20, 56 & 62 all with awesome signals. Weird thing is I had this set up at ground level in the front yard to test it before I put it on the roof and was able to pick up 2 & 31. I always thought the higher the better for antenna placement.
post #1115 of 1131 Old 11-19-2015, 08:29 PM
Quoted: 76 Post(s)
Liked: 46
Well, Comet Tv got turned on WSMH 66.3 several weeks ago.
Now on 1/1/2016, WSMH 66.2 Get Tv will be leaving us, AND will replaced by AntennaTv ( http://antennatv.tv/ )
http://www.tvnewscheck.com/article/9...6-new-stations
I wish Get Tv was also staying, but I'm happy we are finally getting AntennaTv channel in mid-Michigan!
post #1116 of 1131 Old 11-24-2015, 04:54 AM
Quoted: 13 Post(s)
Liked: 1
This is good news. I wonder why they didn't add it to 66.4.
I'm also wondering if this is why I'm having problems with my Magnavox DVR. 66.2 is now blank on it but shows up when going through the TV. Weird.
post #1117 of 1131 Old 11-24-2015, 11:56 AM
Quoted: 76 Post(s)
Liked: 46
Try re-scanning your channels for 66.2, as it's still live as Get tv and works fine.
post #1118 of 1131 Old 11-24-2015, 03:22 PM
Quoted: 13 Post(s)
Liked: 1
I tried that and it's still the same. Weird thing is that 66.1 & 66.3 come in just fine. It also comes in fine through the TV, just not the DVR.
post #1119 of 1131 Old 11-24-2015, 03:25 PM
Quoted: 76 Post(s)
Liked: 46
Ok, try THIS little trick:
1: Disconnect the antenna coax from your DVR.
2: Re-scan for channels without the antenna. It should clear the signal matrix completely.
3: Hook the antenna coax back up. Re-scan for channels again, and it should scan them all back in as normal, hopefully including 66.2 once again.
post #1120 of 1131 Old 11-25-2015, 03:33 AM
Quoted: 13 Post(s)
Liked: 1
I did that and it's still the same. 66.2 is there but the screen is black with no sound. I can also hit the info button on the remote and it even says what show is currently being broadcasted.
post #1121 of 1131 Old 11-25-2015, 07:29 PM
Quoted: 76 Post(s)
Liked: 46
Well, guess what? 66.2 does NOT work on my Tivo (black screen like yours) BUT, it DOES work on my tv set!
So, I have the same issue. They must have something wrong in their broadcast to cause this.
I'm going to send them an email, but I've done this before, and they aren't very responsive. I would suggest YOU also send them and email. Just give them a short explanation of how it works on your tv, but not on your dvr, etc. I'm sending it to: promotions@wsmh.com and also filling out their "feedback" form at: http://www.wsmh.com/sections/station/
post #1122 of 1131 Old 11-27-2015, 07:24 PM
Quoted: 76 Post(s)
Liked: 46
Well, they fixed it after receiving my email. It's back to working on my Tivo Roamio. Can you check and see if you now also get 66.2 on your dvr again?
post #1123 of 1131 Old 11-30-2015, 03:53 PM
Quoted: 13 Post(s)
Liked: 1
Nope, still the same.
post #1124 of 1131 Old 11-30-2015, 07:42 PM
Quoted: 76 Post(s)
Liked: 46
Did you send an email like I did? The engineers name is Pete, and his email address is: PGlass AT sbgtv.com. Replace the "AT" with @
post #1125 of 1131 Old 12-01-2015, 05:37 AM
Quoted: 13 Post(s)
Liked: 1
I will, but am also wondering if it has to with them switching it to Antenna TV next month.
post #1126 of 1131 Old 12-01-2015, 07:25 PM
Quoted: 76 Post(s)
Liked: 46
No, I'm sure it is NOT anything to do with switching to Antenna TV.
You also might want to mention that 66.3 Comet, is being broadcast at the wrong Aspect ratio. It's 4:3 formatted as 16:9, but broadcast as 4:3, which makes it narrower than it should be. Set to "Full" or 16:9 (depending on your tv's format button) and it's then correct.
Send your email direct to the engineer, I gave his email address above.
post #1127 of 1131 Old 03-31-2017, 02:17 PM
Quoted: 76 Post(s)
Liked: 46
Well, this thread sure is dead. Isn't there anybody other than ME that's watching OTA tv in the mid-Michigan area?
paultrip likes this.
post #1128 of 1131 Old 04-04-2017, 09:31 AM
paultrip's Avatar
I'm still here even though I moved out of the Flint area. Moved up north in the thumb. I miss getting the Detroit stations and gained only one distant station besides the getting the usual Flint/TriCities market stations.
Through the years since this thread started I would say we have a gained decent amount of new networks available OTA.
Current stations in Flint/Tri Cities market
5-1 CBS
5-2 My Network
5-3 Cozy
12-1 ABC
12-2 MeTV
12-3 Weather Nation
19-1 PBS Network
19-2 PBS MHz Worldview
19-3 PBS Create
19-4 PBS Kids programming
25-1 NBC
25-2 CW
25-3 Bounce
46-1 CW
46-2 NBC
46-3 Grit
66-1 Fox
66-2 Antenna TV
66-3 Comet (used to have Get TV there)
Not bad of an OTA line up at all. We could gain a couple more if the duplication was eliminated on 25 & 46.
The only gain I had moving here was WBKB (on 11-1 CBS, 11-2 Fox and 11-3 ABC).
Which are just duplicates of what I already have.
This thread isn't dead...it just looks that way.
paultrip is offline
post #1129 of 1131 Old 04-04-2017, 09:05 PM
Matt L's Avatar
Quoted: 303 Post(s)
Liked: 270
I feel bad loosing ch.28. I get 56 from Detroit, but the programming differs. It's not worth rotating my antenna to pick up any of the other PBS stations. Not quite sure how things will shake out with the next round of channel reallocation. I don't even bother with Ch. 12 since it's VHF, too much trouble to deal with that, plus I much prefer the Detroit stations as they do a better job overall. It's been quite a while but I recall one or more of the Flint stations having their DD 5.1 totally hosed, I'm not going to put up with that.
Matt L is offline
post #1130 of 1131 Old 04-09-2017, 02:33 PM
Quoted: 76 Post(s)
Liked: 46
Is anybody seeing an odd very intermittent interference/flashing/pixelating/audio beeping issue on WSMH 66.3, specifically Comet tv? I'm not sure how many days or weeks it's been going on. I'm receiving this over an outdoor antenna.
It only seems to happen to the .3 subchannel, as when it's happened, I've flipped to 66.1 and 66.2, and they seem fine!
I'm watching Attack of the Puppet People right now, and it's continued having problems all through this movie. The most frequent I've seen. It happens on both my OTA tv tuner, and my Tivo Roamio.
Nobody has any input on this? Even though it can be pretty random, it does seem to happen for sure every night during the 9pm Stargate SG-1 airing starting around 9:20pm or so, and then happens every so many minutes until it's over.
post #1131 of 1131 Old Today, 02:57 PM
Quoted: 76 Post(s)
Liked: 46
WNEM tv5 just added the ION network on new subchannel 5.4.
Rescan your devices to pick it up.
