Seattle, WA - Comcast - Page 538 - AVS | Home Theater Discussions And Reviews
 3Likes
post #16111 of 16120 Old 02-23-2015, 06:10 PM
rickeame's Avatar
X1 System is Bugging Me
I recently moved from DirecTV Genie to the X1 system as it saved me money, however....*sigh*
I'll look past losing the "pause on the bedroom tv" feature that my wife is peeved about. I'll look past the weird UX that requires a lot more clicks than I'm used to.
However, the one thing that is really getting to me is that I've missed a bunch of shows, particularly on ABC (105) due to massive pixilation and freezing. ABC Family is also doing it. It's maddening and I haven't yet seen it on other shows. Modern Family, Blackish, and my two Marvel shows -- all unwatchable.
So -- does anyone see this too? I don't know if it's a signal issue, a bad DVR, or ABC just bites. I loathe having to have a tech out yet again (they've been out a few times for security system issues...), but that's my last resort. I'm already hearing "why did we leave DirecTV again?"
rickeame is offline
post #16112 of 16120 Old 02-23-2015, 06:46 PM
olyteddy's Avatar
Quoted: 329 Post(s)
Liked: 394
What are the channel numbers involved? ABC is Ch 104, NBC 105. What channel is ABC Family? Does it happen on both the HD and SD channel? At any rate I'd check for loose connectors at the box and at any splitters. Quite often pixelated channels are the result of ingress.
olyteddy is offline
post #16113 of 16120 Old 02-23-2015, 06:50 PM
rickeame's Avatar
You are, of course, right -- I meant 104, not 105. 104 is having issues (and looking back in this thread, someone else had similar issues with 104). I haven't tried the SD channel as I'm auto-setup to immediately jump to HD, and I almost never watch that channel live, it's always recorded. I will look for loose wiring.
ABC Family is 678 for the HD feed (the one we record).
rickeame is offline
post #16114 of 16120 Old 02-24-2015, 07:34 AM
olyteddy's Avatar
Quoted: 329 Post(s)
Liked: 394
Here in Olympia 104 is on the 159MHz QAM and is therefore potentially subject to ingress from a number of terrestrial sources like business radios and pagers. We get 678 on a different carrier (417MHz) so at least down here there's no correlation. Here's a chart: http://www.ntia.doc.gov/files/ntia/p...3-allochrt.pdf
olyteddy is offline
post #16115 of 16120 Old 02-24-2015, 03:51 PM
jhachey's Avatar
I'm also in Sammamish and I also get some pixelation on KOMO. It's not bad enough to be unwatchable, but it's certainly an irritant. Of the channels I watch, it's the only one I can think of where pixelation is ever an issue. It seems like it must have started in the past couple of months. I don't watch a lot of KOMO (mostly Gray's Anatomy) and I don't recall having any problems with KOMO last fall before Gray's went on some sort of mid-season break.
jhachey is online now
post #16116 of 16120 Old 03-19-2015, 09:20 PM
levibluewa's Avatar
Last night I noticed 4.3 (327) -- GRIT tv
levibluewa is online now
post #16117 of 16120 Old 03-19-2015, 09:38 PM
levibluewa's Avatar
Does Comcast Seattle carry KUSE 46.1 & 46.5 ... Hot & Retro TV?
post #16118 of 16120 Old 04-11-2015, 11:38 PM
thefalcon2k's Avatar
We used to have Retro TV! I don't know why they got rid of it, but then again ... blame KIRO on that switch.
thefalcon2k is offline
post #16119 of 16120 Old 04-17-2015, 10:46 AM
levibluewa's Avatar
Re: 7.3
I'm guessing that 7.3 (LAFFtv) is now active OTA in Seattle. Anyone know if it is going to be added soon to Comcast...I'm guessing at 326.
post #16120 of 16120 Old Today, 11:57 AM
levibluewa's Avatar
7.3 (326) -- June 6!
