Seattle, WA - Comcast - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 03-05-2004, 10:20 AM
IssaquahHD's Avatar
Originally posted by Alex Wetmore
Both a new firmware and VOD. I tested VOD this morning while eating my cereal and it works just fine.
alex
I just called and the lady said they sent the message out to all of the boxes, even in areas where it isn't available yet. I guess they do their updates on Thursday so maybe next Thursday.
IssaquahHD is offline
Old 03-05-2004, 10:34 AM
wareagle's Avatar
My Bellevue 5100 did not receive any such message. Are updates always this wishy-washy?
wareagle is offline
Old 03-05-2004, 11:06 AM
Trevorsplace's Avatar
I just called also and the CSR was great... He was able to tell me that it had not been enabled in Auburn yet but will be in the next couple of days. Also set up an appointment for tomorrow to exchange both my 5100's for 6200's. Must admit was surprised on how much he knew about the subject matter. Cudo's to Comcast.
Trevorsplace is offline
Old 03-05-2004, 12:17 PM
churlock's Avatar
Originally posted by Trevorsplace
I just called also and the CSR was great... Must admit was surprised on how much he knew about the subject matter. Cudo's to Comcast.
That is a bit surprising. When the tech came out to exchange mine, the 6200 was the first one he'd ever seen. He asked why I wanted it (because of dvi). I guess with all the chatter here relating to the 6200, we tend to forget that the group on this forum represents probably an infinitesimal number of subscribers who care, or are even knowledgeable about the 6200.
churlock is offline
Old 03-05-2004, 04:54 PM
generationxwing's Avatar
You probably talked to Jeremyfr
Capre orbis Terrarum
generationxwing is offline
Old 03-05-2004, 05:01 PM
CoolCanuck's Avatar
Actually he works for the HSI division, not the cable portion. Kinda ironic that the only Comcast employees who know anything about HDTV work in unrelated departments.
Instead we get to deal with CSRs who talk about 'DHTV' (yes, I'm not kidding -- this CSR went on and on about how they could hook me up with DHTV).
Visit the Red-Meadow Theater!
CoolCanuck is offline
Old 03-05-2004, 06:37 PM
quarque's Avatar
DHTV - short for DuH-TV. Designed for those who heard something about a fancy TV somewhere but not quite sure what it is, but it must have been better than "reg'lar TV".
I've run out of witty sayings...
quarque is offline
Old 03-06-2004, 01:32 PM
Comcast just left after exchanging both my 5100's for 6200's. They both came loaded with 7.07 and on demand shows on the guide but I get a communications error message when I select it. So I guess VOD is not available in Auburn yet ?? Unless there is another issue. I do think the picture quality on the analog channels is better in 480 overide.
Old 03-06-2004, 02:36 PM
Jeremyfr's Avatar
Communications error typically means that there is something wrong with the return path and a tech would need to go out to look at it.
Jeremyfr is offline
Old 03-06-2004, 05:04 PM
Tom_Oliver's Avatar
On the cracking audio problem with the 6200 what kind of reciever does everyone have? I have an Onkyo TX-DS797.
Tom_Oliver is offline
Old 03-06-2004, 05:36 PM
Received a download about an hour ago and now the VOD choice is gone so I guess my S/W version rolled back. Just have to wait till it is released in Auburn, at least I know Firmware version is the latest.
On the PQ, what a difference with the 6200. The analog channels look great now on 480P overide. I could never use that on the 5100 as the PQ was crap.
Old 03-06-2004, 09:53 PM
ianken's Avatar
The upconvert this box does is noticably better than the 5100. Not as good as even a low end line doubler, but OK.
ianken is offline
Old 03-06-2004, 10:58 PM
patfaram's Avatar
Location: Sammamish, WA Mits WS-55613 Rear Proj TV Moto 6200 Cable Box v7.07 Mits HD1100U DVHS Recorder MyHD MDP-120 Card w/DVI Onkyo TX-NR801 AV Receiver DALI Evidence 5.1 Speakers
FYI - I'm using the OPTICAL audio output of my 6200 into my Onkyo TX-NR801 with NO audio popping.
However, I have to set my A/V Sync to +74 ms (which is the maximum setting). Otherwise people's mouths are ahead of their voices. Does anyone else have this issue?
Pat
HDTV - It's what's for dinner!
patfaram is offline
Old 03-06-2004, 11:26 PM
buddma's Avatar
After Comcast "turned on" Cinemax HD, i'm able to watch it but after a long "One moment please" message on my screen. I get the program guide bar along the bottom of the screen with what is currently showing. Is there anyway to fix this? I have the 5100 box. Thanks!
buddma is offline
Old 03-07-2004, 12:33 AM
Fredline's Avatar
I have a brand new 'Pioneer VSX-D912-K' thats working fine otherwise.
BTW, I'm a bit of a cable box n00b. How do I get into the 'service menu' on my 6200 to check my settings(pic ratio, etc.)? I already found the user menu to change the Audio, Language, check Firmware, etc. but the pic ratio wasn't in there.
Fredline is offline
Old 03-07-2004, 07:40 AM
drewba's Avatar
On the 5100, you power the box off, then press the Menu button. Likely the 6200 is the same.
drewba is offline
Old 03-07-2004, 08:54 AM
brente's Avatar
Quoted: 21 Post(s)
do you see this on any of the inhd channels too? if so, may be a low signal level.
brente is offline
Old 03-07-2004, 09:48 AM
churlock's Avatar
I've been getting the "One moment Please" message too (6200) along with the guide bar for several days now (and I subscribe to Cinemax).
churlock is offline
Old 03-07-2004, 10:29 AM
buddma's Avatar
I get INHD just fine also sometimes CinemaxHD breaks up.
buddma is offline
Old 03-07-2004, 10:55 AM
churlock's Avatar
I've noticed that Voom (http://www.voom.com), the new sat provider (with 25 HD channels), carrys local KIRO-HD in their lineup. If they can, why can't Comcast reach some agreement?? I sure hope they get it before the next NFL season.
churlock is offline
Old 03-07-2004, 11:20 AM
wareagle's Avatar
The local channels on Voom are Over the Air, so no agreement is required.
wareagle is offline
Old 03-07-2004, 12:09 PM
jimre's Avatar
Right - VOOM doesn't actually broadast these channels. Their dish just has a built in OTA antenna, and it looks like they integrate OTA channels with their program guide. So even with VOOM, you're still SOL for KIRO-HD if you can't already receive KIRO's OTA signal.
jimre is offline
Old 03-07-2004, 02:34 PM
Andy Anderson's Avatar
Hey--for those of y'all getting appointments to switch out the 5100 with the 6200, is Comcast charging you for the visit? How much is it?
Xbox Live Gamertag: Anderpants
Andy Anderson is offline
Old 03-07-2004, 03:53 PM
bpdp379's Avatar
For anybody who may want one, I have two 2m DVI cables that I do not need. If you want one send me a PM.
Cables are gone. Thanks for the interest.
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a...
bpdp379 is offline
Old 03-07-2004, 05:32 PM
Andy,
No charge they do it for free...
Old 03-07-2004, 06:23 PM
Milt99's Avatar
Quoted: 236 Post(s)
Liked: 246
patfaram,
I've had my 6200 for a month now and have been using DVI to an HS-20.
I fired it about about 10 minutes ago and the audio sync is horrible on all channels!!
It has worked perfectly up to now.
I'm in the process of power cycling my box, if that doesn't work I'm giving Comcast a call asap.
With the Sopranos debut tonight, I am going to be royally pissed if it's f'd up.
I can't believe we're the only ones experiencing this.
UPDATE: Powered the 6200 off for about 15 minutes and powered back on.
Audio sync is now fine again. Odd.
Doug
It ain't ignorance causes so much trouble; it's folks knowing so much that ain't so
Milt99 is offline
Old 03-07-2004, 06:25 PM
Al Shing's Avatar
Comcast had my OMP (One Moment Please) appointment scheduled for Sunday, even though I asked for and we agreed on Saturday afternoon originally. Tech came and tried some things. He decided to swap out the box for a new one to see if it would fix it. New one is a DCT-6200, manufactured 02/2004. It was taking too long to download the microcode, so he took off for his next call and said he would check back on the status of the problem.
I'm still getting OMP on those new channels, but at least I got a DVI and firewire output now.
If anyone is getting OMP on those channels, I suggest you call it in so they know there is a problem. I think they are just starting to realize that there is something going on with these new channels in some areas, but not in others. The tech said he checked at the headend in Burien, and it is working there, but it isn't working in Auburn or at my house for some reason.
Al Shing is offline
Old 03-07-2004, 11:42 PM
ianken's Avatar
"Home Theater Access Fee"
$15 for a guy to hand me a box and I do all the work hooking it up? I guess it covers the cost of the guy driving out here and handing me the box. And it wasn't even a Comcast dude, rather a sub contractor who was monumentally clueless.
ianken is offline
Old 03-07-2004, 11:45 PM
ianken's Avatar
Yep. In other words there are no local channels on voom at all. But they don't try very hard to let consum,ers know that. A little asterix at the bottom of the marketing spam. IMHO it is a bit misleading. I wonder how many people picked it up thinking theywould get their locals in HD via satellite? Read the fine print I guess. :-)
ianken is offline
Old 03-08-2004, 11:44 AM
Fredline's Avatar
Now that I found the settings(16:9, 1080i, etc.) on my 6200, can someone recommend which settings to use for my setup?
I have Sony 50" LCD GWIII & have a DVI cable I've been meaning to hookup but currently using component.
Fredline is offline
