Seattle, WA - OTA - Page 310 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #9271 of 10372 Old 11-14-2011, 10:35 PM
DanKurts's Avatar
Liked: 24
Originally Posted by trode View Post
Turns out my problem ended up being a bad network switch and a firewire tuner that wasn't able to tune well.
I started from scratch and tested all available tuners including the LCD tv. It was able to get all channels without issue. The tip I would share with network attached tuners is to try directly connecting them to a computer via ethernet port and test them that way. That is how I determined that it had to be a network issue when they worked properly that way. I swapped out a 8 port netgear switch with an older 5 port one and now everything works. The switch was failing is such a way that normal tests like ping did not show any problems..
What really confused me was the old firewire tuner was failing in a similar way on the same channels. I have retired the EyeTV 500 and now am using 2 HDHomeRun's to get 4 tuners via the network.
Thanks for the help Jim/Dan and the rest of the posters!
trode
You're welcome. Thanks for the challenge. I had no idea your Mac tuner devices were streaming. Learned another one!
By the way, the ping is very low on the OSI stack. My old laptop I use for programming on site fails a ping, but works fine otherwise. Not worth repairing.
Your basic instinct and troubleshooting methods were right on. If you have another failure, try the Linksys/Cisco hardware. I don't like callbacks, and have been bitten with a variety of hardware and software issues with D-link, Netgear, ASUS and others. There probably are others out there with great reliabilty, but my luck has held well using Linksys/Cisco, and the 24/7 free support is decent, and their tier2 support is great.
After all this, you have the cleanest antenna install around !
Dan
DanKurts is offline
post #9272 of 10372 Old 11-14-2011, 11:08 PM
DanKurts's Avatar
Liked: 24
Originally Posted by rbico View Post
Okay, I went out with a compass and tried my best to move the antenna towards 162º which is what that OTA website said the bulk of the stations I want are located. Because I already had the mast installed, I wasn't able to get it exactly where I wanted it, but as close as possible. I swiveled the antenna a little but I still get random pixilation on most of the mainstream networks (kiro,komo,king and fox). Sometime it will go an hour fine, but sometimes it will go a minutes, then pixels, then a message from my TV saying there is no or a weak signal - or something to that effect. Then it will pop back on for a minute, then it starts all over. It might be worth noting that when the station is on, it is clear as a bell - better than my previous HD cable.
I forgot to mention that when I was originally hooking up the antenna, I split the coax so I could have a TV in my basement. I have the cable run, but it is not hooked up to the 2nd TV yet or the splitter yet. So I have a 2-way splitter with one cable going to my main TV and the other ready but not hooked up to anything yet.
With that in mind, I called channel master to ask for some advice. They said do not get a bigger antenna; that the 4220 may be too big since I am less than 20 miles from the towers and that if anything my problem might be that I my antenna is over-shooting the Seattle towers. They suggested hooking up the second TV so that it will weaken the signal and possible clear up the pixilation. If that doesn't work they suggest bypassing the splitter and going directly from the antenna to the TV. If neither of those work, they suggested moving the antenna to the peak of my roof (another 4') and trying that.
I could move the antenna another 4' up to the exact peak of my roof. this would put the antenna a little higher and I would at that point be able to position the mast exactly where I want it.
What do you think?
here is my tvfool info in it helps:
http://www.tvfool.com/?option=com_wr...ec12baa4201296
rbico
Your antenna is waaaaaaaay to small.
Aiming with it is not going to be that critical, won't make much difference.
Whomever you spoke with at Channelmaster hasn't a clue about your terrain problems, so he thinks you're line of sight, which you aren't.
TVFool doesn't account for terrain. Good for finding the directions, though.
The 4228 is not too much for your location.
Going higher usually helps, sure won't cost much to try.
Remove the splitter temporarily. If it solves your problems, you could try a preamplifier, but not recommended. Spend the money on more antenna, no preamp. You'll get a better signal to noise ratio, which digital tuners like.
Always terminate a cable run if you're not using it. RatShack has 75ohm terminators. The open coax run on a splitter can act like a trap and cause all kinds of wierd problems. In strong signal areas it can actually work like an antenna and add more problems as well.
Last, digital will always look perfect when you get a channel to lock on. Not like the old analog days of ghosting, snow, etc when a signal gets weak. When you get right on the minimum amount of digital signal, or the noise level gets to high, comparatively, breakups and pixelation can occur.
Let us know what happens with the mast.
Dan
DanKurts is offline
post #9273 of 10372 Old 11-15-2011, 11:42 AM
rbico's Avatar
Originally Posted by Jim in Seattle View Post
Rbico,
Per your TVFOOL report it looks to me that you are well east of Lynnwood, so I'd like to know the altitude above sea level where you live and a closer physical location.
I setup a friend in Lynnwood who's TVFOOL looks nothing like yours and he gets over 30 clear channels.
Jim
Thanks for the replies Jim and Dan.
I am on the west end of Lynnwood, but definitely in Lynnwood, about 6 blocks west of 99. i don't know about 30 channels but we my TV said over 30, although some don't come in. I would say we have about 20 channels - counting the foreign stuff. What antenna does your friend have?
I hooked up the second TV via the splitter and immediately had no pixelation on KIRO, KOMO and KING5. Fox was still half frozen, looked like it was made out of legos. I then removed the splitter and added a coupler connecting my antenna directly to ONE TV, and Fox came in clear as a bell, as did the others. This was last night. This morning, with the same connection, Fox is back to legloland but the other stations are great.
TVFool says the Fox tower is 30.8 miles from me, so you are probably right Dan. I took the CM tech guy's information with a grain of salt, but what he said did made sense to me. But I know very little.
I guess I will put the 4228 on the Christmas list, that is if my wife can't live without Fox. I don't care, personally - I just watch Hulu and movies and the news for the weather (which is inaccurate anyway).
rbico is offline
post #9274 of 10372 Old 11-15-2011, 07:28 PM
DanKurts's Avatar
Liked: 24
rbico
Progress. Good job!
Fox owns both ch13 and ch22. Fox comes in on ch22-2 in standard definition.
Frys in Renton has the 4228.
Merry Christmas, either way !
Dan
DanKurts is offline
post #9275 of 10372 Old 11-15-2011, 09:58 PM
Dave_in_MV's Avatar
Hi all,
I've been thinking about cutting the cable and have been reading a lot from this thread. I'm in Maple Valley about 25-30 miles from most of the local channels. I picked up a CM-4221HD from Fry's to see what I might expect.
TV Fool report
www dot tvfool dot com/?option=com_wrapper&Itemid=29&q=id%3d8d1705e8c82a33
says I should get the major stations (KOMO, KING, KIRO), Fox, ION, etc. and generally I get a good picture but with random drop outs. I cannot get KCTS at all. I do have a large stand of tall trees in the direction of the transmitters.
I also have a CM-7777 since our house is wired with 4 outlets.
A couple of questions:
I assume the dropouts are due to low signal strength so a larger antenna, like a 8 bay e.g., a CM-4228. Is the 4221 too small for my location? Should I try for more height before I swap antennas?
Is Channel 9 (KCTS) too low of a channel for the 4221? Would it make more sense to add a dedicated VHF antenna or just use a larger antenna for both? For example, the 4228 claims to get channels 7-13 out to 45 miles.
Fry's website lists the 4228 at $95, and a Winegard 8 bay (HD-8800) for $40. Is there that much difference in performance and quality to justify the price difference?
Would adding terminators to the unused cable outlets make a significant difference?
Thanks for any input.
Dave
Dave_in_MV is offline
post #9276 of 10372 Old 11-15-2011, 10:50 PM
be236's Avatar
Must be tropo-like conditions today, freezing cold and all... DXing...
Using home-built M4, able to get RF 22, 20 and 43 from up north! Yeah!
be236 is offline
post #9277 of 10372 Old 11-15-2011, 11:49 PM
be236's Avatar
Yeah, KCTS is on VHF, and your CM 4221 wasn't designed for VHF that low (channel 9).. I guess it can reach down to channel 13 FOX since you seem to be able to get it, unless you're picking it from RF 25.
Some websites claim HD-8800 has better gain than CM 4228HD, while others say the reverse.
If you prefer a signal antenna solution to get KCTS 9, then a CM 4228HD should do the trick for you, or you can add a 2nd VHF antenna and combine it with your CM 4221 (though this can get tricky to combine two antennas).
be236 is offline
post #9278 of 10372 Old 11-16-2011, 06:06 AM
rbico's Avatar
Originally Posted by DanKurts View Post
rbico
Progress. Good job!
Dan
Thanks for the tips, Dan. Frys is where I got my 4220.
Fox 13 (HD) seems to come in great at night, just not during the day. Seems odd, but whatever. I will try channel 22 until I get the 4228.
Do you know if the 4228 will work with the mast from the 4220mhd?
rbico is offline
post #9279 of 10372 Old 11-16-2011, 03:45 PM
PeggyD's Avatar
Dave,
Maple Valley is very difficult. We used to live just north of Shadow Lake Elementary & could only get OTA from the West Tiger Mountain transmitters. TVFool's signal locator is worthless & AntennaWeb isn't much better. Neither considers the terrain. Use the Google Maps links on TVFool for much more accurate results.
We moved to Kent last year & now get all the OTA signals.
PeggyD is offline
post #9280 of 10372 Old 11-16-2011, 05:56 PM
DanKurts's Avatar
Liked: 24
Originally Posted by Dave_in_MV View Post
Hi all,
TV Fool report
Dave
Dave
What's your nearest cross streets?
Dan
DanKurts is offline
post #9281 of 10372 Old 11-16-2011, 06:19 PM
DanKurts's Avatar
Liked: 24
rbico
The 4228 is about 30" high, so it won't work with the foot and mast on yours.
Depending on where you mount it, a fairly strong bracket needs to be used. There's a lot wind load with the 4228. If possible, an eave mount would work without having to go into the roof,
http://www.dennysantennaservice.com/image/21022193.jpg
or a chimney mount
http://www.rfwiz.com/images/AustinAn...House200pm.jpg
Make sure you have about 15" to 20" above the roof peak or chimney top. Just enough so they won't affect the antenna reception. You also don't want to allow the antenna to have too much leverage over the mount, like a 10' mast anchored at the bottom and 3' up, with 7' left above hanging in the wind. Sure disaster.
Dan
DanKurts is offline
post #9282 of 10372 Old 11-16-2011, 07:53 PM
Dave_in_MV's Avatar
Dan,
Nearest cross streets: 234th Ave. S.E. and S.E. 253rd Pl.
I'm toward the northern end of 234th.
Dave
post #9283 of 10372 Old 11-16-2011, 10:13 PM
DanKurts's Avatar
Liked: 24
Hi all,
TV Fool report
Dave
Dave
Good news, your at 570ft elevation.
Bad news, 3 miles of trees before you clear the hill at SE Lake Youngs Road and 190th. TVFool doesn't see trees.
Dropouts aren't always from low signal level. Your preamp has lots of power and can make up for that if you get enough coming in above minimums for it to work.
The main problem is the trees. They tend to really chop up the signal. Makes it very hard for the tuner to lock on. A 4228 would be better than a 4221, specially for the VHF. It's not designed for VHF, but works somewhat.
A yagi style UHF, though, usually works better in these situations. Think of it as helping you to pick your way through the trees, ignoring some of the other ugly signals.
Frys has the CM2020 for about $70. It also has the hi-band VHF for ch's 9-11-13. Combined with your 7777 preamp, that's a pretty good start. You could go for more antenna, but since you're doing pretty well with the 4221, it should work.
The biggest thing is finding the sweet spot. Patience will win out. Make a chart with the main channels and the "strength" numbers you see for each. Sight down the antenna and pick a spot in the distance. Move the antenna a bit one way, identify another spot and note it and numbers, and then do it again. By a bit, like having the nose of the antenna move about four inches.
It takes about 10 to 30 seconds for a tuner to lock on, so you can't whip it around like an old analog antenna and get instant results. After a while you'll see some channels are more sensitive than others. Concentrate on those to shorten the process. Also moving it higher or lower than 8" can make a difference, too. Even moving the mast a bit to a different location just 8" can make it.
The numbers you're seeing aren't really strength, but more like signal quality. You could be very weak, or strong in actual level, and still see the same numbers. If the signal is not good, as viewed on a scope, it won't lock. That's what makes this a real challenge with out test equipment.
Check out the basic direction on a map, or use Google Earth to draw a line from your house to QA Hill and that should get you close.
Also, ch13 comes from much more to the west, so worry about that last. If it doesn't come in, you can use a separate antenna if needed.
Last, I hope you installed the 4way split after the preamp power supply, not between it and the preamp. Definitely use terminators on unused splitter ports, or at the end of the unused cable run.
Keep us informed on your progress!
Dan
DanKurts is offline
post #9284 of 10372 Old 11-17-2011, 10:49 PM
Dave_in_MV's Avatar
Dan,
Thanks for the detailed reply. I had assumed that I needed a more signal capturing capacity, but I understand your point about trees affecting signal quality. I have my 4221 oriented toward the Queen Anne transmitters using a compass heading and it pointed right at a large stand of trees. I do notice more dropouts when its windy, so I think your analysis is right on.
With a yagi, would it be better to aim for gaps in the trees even if the direction isn't exactly toward the transmitters? Or is it just a matter of experimentation?
The splitters in my house are all hidden in the walls so I have the amp connected between the antenna and a cable outlet. The intent is to drive the signal to all the outlets. Is there a better method?
I think a trip to Fry's is in my future for a CM-2020 and some cable terminators. Hopefully the weather will allow some installation work.
Thanks again.
Dave
post #9285 of 10372 Old 11-18-2011, 12:24 AM
DanKurts's Avatar
Liked: 24
Dan,
Thanks again.
Dave
Dave
Aiming an antenna is not that exact. In your case, misaiming can actually work to your advantage. With a yagi, it may be as much as 20 degrees either side of perfect. You will see a noticeable difference, though, with very small movements. The 4221 is very wide, and can be turned far more without much change, not very directional. Yes, it's going to take some playing around with direction and location to find that one good spot. If you keep a chart, it will help you narrow down the better gaps in the trees.
All your cable connections are in a daisy chain? Do you know which one is the first one?
The normal way of splitting is to have each run go to one location, and connect to one splitter. That way each run has the same amount, give or take because of cable lengths. A 4way split connected that way would lower the signal level 7db to each TV. When you split it once, and then feed the next splitter, and then the next, and then the last one, the loss to each TV, from beginning to end would be 3.5db, 7db, 10.5db and the last one would be down 14db. There are other considerations, but the main result is far more loss. Your preamp can make up for a lot of that, but if your signal is weak coming in, you can have a lot of signal level, but also a lot more noise. Digital hates noise, makes it hard to figure what's real and what isn't.
If possible, try to figure out where the cable company hooked up their signal. That's where you want the output of the amp to go. Cable companies don't usually configure cabling runs like yours. They get too many problems and callbacks. If you are using a secondary set of runs that someone else did, bail and use the cable company runs.
What I meant with the preamp connection is the preamp is on the roof at the antenna, and the power supply for it is in the house. After the power supply is where you start your run to the rest of the house. If you install a splitter between the preamp and the power supply, it will short out the power and not work. Occasionally, when there's a lot of signal to begin with, some signal will still get through, but it's not reliable. Eventually you'll fry the power supply.
It sounds like you probably have it connected correctly, though, as you are getting a fair amount of channels. Just making sure we're all set up right.
Let us know what happens.
Dan
DanKurts is offline
post #9286 of 10372 Old 11-20-2011, 11:07 AM
Taperwood's Avatar
I'm down by the water in Bremerton and hardly ever get KING. Today, Sunday, the 20th, it's booming. My signal quality meter is in the 70's. I've never seen it that high. Usually it's under 30 and unwatchable. I checked here to see if KING had made any changes but don't see any mention. I'm hoping it's not just the weather.
Originally Posted by allen98311 View Post
I was reading over on the DBSTalk forums that KING has been dropping their broadcast power levels over the past few weeks. I have noticed that it has been harder to get the signal over the last few days, and they have been the easiest to get for a long time! Does anyone here know anything about this?
Taperwood is offline
post #9287 of 10372 Old 11-20-2011, 11:43 AM
Jim in Seattle's Avatar
Location: In one of Seattle's most difficult areas for OTA reception
Taperwood,
I'm on QA Hill and I receive KING via a reflection off of a downtown skyscraper and its signal 'strength' has not changed for me. On occasion I can receive it when I aim my CM-4221 at their tower, but not this morning.
Every once in a while I point my 4221 toward Victoria and rescan to see if by chance any Canadian stations are making the trip and for the first time on this antenna at its current height, my tuner 'discovered' The Shopping Channels. My guess is both of our reception changes are being caused/allowed by the current weather/atmospherics.
Jim
Jim in Seattle is offline
post #9288 of 10372 Old 11-20-2011, 04:45 PM
Taperwood's Avatar
Jim,
Thanks. I guess I got my hopes up for nothing. Another thing I just thought of is that the city is doing work on the sewer line on my street and a couple of days ago they parked two big cranes across the street and up a house or two in the general direction of my Seattle signal. I don't watch much TV so today was the first chance I had to notice any changes. I'm wondering if all that steel sitting there has something to do with it. Whatever the case, I'll enjoy it while I can.
post #9289 of 10372 Old 11-21-2011, 10:42 AM
Ricky Mac's Avatar
I doubt KCTS is flagging Masterpiece but I thought I just ask really quick.
I haven't been able to record a whole show in sometime. I usually just get a few minutes. Once I got an hour of a 2 hour program.
I've only tried other stations once, and it did work.
I suspect it's a MCE problem. Nothing seems the same after a failed SageTV install.
Ricky Mac is offline
post #9290 of 10372 Old 11-23-2011, 02:06 PM
rdn
rdn's Avatar
I haven't had any such issues with an EyeTV hybrid tuner and EyeTV 3.5.3 software.
Bob
rdn is offline
post #9291 of 10372 Old 11-23-2011, 03:24 PM
KR7L's Avatar
I regularly record Masterpiece but recently I had to change my record time from 1.5 hours to 2 hours to fit the longer shows. No problemo.
KR7L is offline
post #9292 of 10372 Old 11-23-2011, 09:26 PM
be236's Avatar
Jim, I thought you said you already get KVOS from Bellingham (Orcas Island) already... if so, it shouldnt be a suprise you get the "Shopping" channels (RF 19), since they're on the same Mt on Orcas Island..?
be236 is offline
post #9293 of 10372 Old 11-25-2011, 03:42 AM
be236,
KVOS has an ERP of 580 kW which makes the trip but KBCB has only 165 kW ERP and the only time I received them (not dependibly) was this past summer when testing a Terrestrial Digital DB-2 at about 36 feet above ground level. My tuner 'sensed' the KBTC translator in Grays Harbor/LeBam at the same crazy height.
Jim
post #9294 of 10372 Old 11-25-2011, 08:40 AM
be236's Avatar
Hi Jim,
Yeah, I knew KBCB (RF 19) had a lower ERP than KVOS, but I just assumed you'd still be able to pick it up still. It must have a lower NM value than KVOS.
I'm about 15 miles closer to KBCB (listed about 62 miles away) and I can get KBCB just fine using an old RS VU-160 or CM 4221 or home built M4 antenna. Its NM is about 9 dB or so for me. (heh).
Also, I can get RF 24 from Orcas as well with its super low ERP. Using M4 or CM 4221, I have it about 15 feet AGL just barely (about 60% signal on my Sony to get picture lock).
I'll assume you can't get RF 24 at all?
Also, we talked a few months back about me trying to get those BC channels. Well, update with a pre-amp (KT200) and M4 (similar to CM4221), I can occasionally now get RF 22 (CHAN), and RF20 (OMNI) with NMs at -8db and 13dB.. amazing , huh? Yes, might be due to tropo conditions, but it's just good to know I can get this. I think I just need a bigger antenna, (maybe CM 4228 or HD-8800) or gang two up to 2.5dB gain.
CHAN is amazing in HD! :-)
be236 is offline
post #9295 of 10372 Old 11-26-2011, 12:33 PM
be236,
The only way I have been able to receive KBCB is with a DB-2 shoved WAY up in the sky, but it wasn't dependable reception. I checked the REC Networks website and their antenna height above sea level is 42 meters lower than KVOS, so for me its a combination of their lower height and lower ERP.
I'm convinced the DB-2 is undersized and designed for channels at the top of the current UHF band, but if I built a cut-to-channel multi-bar Yagi or a stacked pair, I bet I could capture them. Lucky for me, I don't need to receive that channel!
Jim
post #9296 of 10372 Old 11-26-2011, 01:04 PM
be236's Avatar
Yea, I think those DB-2s are like the CM 4221s... they're designed for high UHF, so I made an M4 design (similar to CM 4221) for low UHF... that allowed me to pick up RF 20 and 22 sometimes. heh.
My next project is to build basic SBGH since it might have slightly higher gain ...
If that doesnt work, I'm thinking of getting two HD-8800s and ganging them up.
Oh, Friday 11/25, I went to Fry's and they just had one CM 4220 left.. I dont think they sell CM 4228s (or out of stock and I didnt see).. and I saw they have Channel Master 7000 there.. about $349.. ouch.
be236 is offline
post #9297 of 10372 Old 11-26-2011, 01:20 PM
be236,
The DB-2 has 6.5" whiskers compared to EV's Kosmic SuperQuad with 10" whiskers. If I get a chance this winter I want to build a 2-bay version of the KSQ. By the way, my friend in Lynnwood lives a couple blocks west of Harvey's Tavern and currently he has a pair of old-style CM-4228's vertically stacked. What a kite!
When you were at Fry's was the OTA TV section poorly stocked? The last two times I was there it was wiped out. You wrote they have a CM-7000 (converter box) for $349 - I hope you meant a CM-7000 PAL DVR!
Jim
post #9298 of 10372 Old 11-26-2011, 01:29 PM
ProjectSHO89's Avatar
Quoted: 279 Post(s)
Liked: 130
That's probably the reason it was redesigned and replaced.
ProjectSHO89 is online now
post #9299 of 10372 Old 11-26-2011, 01:32 PM
be236's Avatar
Yeah, the shorter whiskers are better for high UHF channels. For me the highest UHF channel from BC is RF 43 (CBUT).. while most of their channels are low UHF (17 to 26,32) that I want.
Do you know if ganged CM 4228s are better than ganged HD-8800s (since those HD-8800s are half the price of CM 4228s). I get conflicting reports of one being better than the others.
Yes, I was in the OTA section yesterday and their selection, they had lots of Yagi types left... and one of those bay types... But I was hoping to see and look at a 4228s, but couldnt find any.
I wish they had more different bays, like HD-8800 or DB4s, etc... or diffferent Yagis, like CM 3023 or MXU59 or 91XG. (heh).
And yes, I mean CM-7000 PAL DVR. That is so expensive for a OTA DVR!? Geez.. It shouldnt be more than a regular DTV box, say around $100-$150 at most?
be236 is offline
post #9300 of 10372 Old 11-26-2011, 03:03 PM
ProjectSHO89,
I have a copy of the early version DB-2 that uses a standard balun and a copy of the second generation DB-2 that has an integral balun. What are the characteristics of the replacement 'newest' DB-2?
Thanks in advance,
Jim
