Seattle, WA - OTA - Page 339 - AVS Forum
 8Likes
post #10141 of 10165 Old 12-06-2014, 09:18 PM
SteveCS's Avatar
So much for that theory. In what is probably a weather-related issue, I have not been able to get video for KUSE for 2 days. Audio is fine. Very disappointing. I've been OTA for 3 months, and this is the first break in service I've had on KUSE (other than the temporary Russian language programming).
SteveCS is offline
post #10142 of 10165 Old 12-10-2014, 09:13 AM
SteveCS's Avatar
KUSE subchannel 46.5 came back again on Monday morning. Very strange that the issue would clear up when it did, with the weather still bad. Makes me wonder if there was some kind of transmission issue going on. Hoping for a problem-free weekend.
SteveCS is offline
post #10143 of 10165 Old 12-10-2014, 09:48 PM
Does anyone else here use a portable receiver that tunes ATSC M/H (mobile)?
My tuner's recently lost 4.2 (no data), 7.1 (no signal), and 11.1 (no signal). 4.1, 5.1, and 9.1 are still fine.
I've rescanned in more than one location with no luck.
I'm trying to figure out if stations are pulling the plug since the technology never really took off, or if my WiFi tuner's gone kaput and needs to be replaced.
pastiche is offline
post #10144 of 10165 Old 12-11-2014, 12:55 PM
Lee Wood's Avatar
ATSC-M/H 4.2 has been discontinued, but thanks for letting us know who the M/H viewer is.
Lee Wood is offline
post #10145 of 10165 Old 12-11-2014, 04:03 PM
seatacboy's Avatar
Quoted: 13 Post(s)
Tonight the National Weather Service is issuing a High Wind Warning for Puget Sound. Hopefully, those of you on this forum who use outdoor antennas of people have a properly secured install.
Has anyone here used the rather expensive HD Frequency Cable Cutter antenna? Information is at http://www.hdfrequency.com/best_indo..._antennas.html This probably is just another over-hyped antenna design but I did want to ask my fellow Seattleites if they had experience with this $100 indoor/outdoor design.
The CM 4228HD on our roof is pointed towards the major-league Seattle channels. We periodically watch KWPX/Ion and KUSE/Retro TV. Those stations are at a sideways angle from the 4228's positioning, and the 4228 is specifically designed to reject signal from the sides. We do have a rooftop installed generic 4-bay pointed east towards West Tiger, but I haven't been able to find the cable connections to receive its signal in our house. I do have a simple A-B switchbox to go between two different antennas. A Silver Sensor placed indoors is fairly good but still gets occasional breakups on KWPX, and the KUSE-LD signal remains very weak even though it's just 9 miles away and supposedly line-of-sight.
seatacboy is offline
post #10146 of 10165 Old 12-11-2014, 07:23 PM
I guess I should thank you for keeping 4.1 and 9.1 running for me, then.
My Dyle tuner's in my backpack everywhere I go, and it gets a lot of use. Not sure why that technology didn't take off!
pastiche is offline
post #10147 of 10165 Old 12-19-2014, 05:24 PM
rdiotte's Avatar
regarding 11.1 M/H signal...our mobile multiplexer lost it's mind back in late november.....we may or may not get it working again.
R Diotte
CE, KSTW
pastiche likes this.
rdiotte is offline
post #10148 of 10165 Old 12-19-2014, 06:32 PM
Thanks for the info. FWIW, I appreciated that Channel 11 always had guide data on their M/H signal. The other stations seemed to have lost theirs altogether in early to mid 2014.
pastiche is offline
post #10149 of 10165 Old 12-31-2014, 06:55 PM
Liked: 0
Just scanned in Grit TV on KOMO 4.3. 480i, PSIP reads "Grit TV".
KFFV PSIP appears updated today as well, correcting old channel names (i.e., 44.4 - "KBS"; 44.5 - "COZITV")
I think we're expecting something new on channel 5.2 shortly as well (to replace LiveWell).
Vengabus (Richard) is offline
post #10150 of 10165 Old 12-31-2014, 10:29 PM
thefalcon2k's Avatar
Grit TV is now broadcasting. Must have been a brand new network for 2015!
thefalcon2k is offline
post #10151 of 10165 Old 01-01-2015, 09:22 AM
rdvegas's Avatar
Quoted: 45 Post(s)
Liked: 29
GRIT launched as a network in August, but many more affiliates are coming on line this month or later.
Wanting a strong FCC to say no to the Wireless lobby. Keep the tv broadcast band for ota television broadcasters.
rdvegas is offline
post #10152 of 10165 Old 01-01-2015, 09:23 AM
rdvegas's Avatar
Quoted: 45 Post(s)
Liked: 29
King is adding the Justice Network soon.
rdvegas is offline
post #10153 of 10165 Old 01-01-2015, 11:03 AM
Liked: 0
KBCB is running Sonlife Broadcast Network on 24.1 & 24.2 right now. I don't usually get to tune in this time of day, but I've never seen them deviate from the ShopHQ programming. Is this a programming change?
post #10154 of 10165 Old 01-02-2015, 03:47 PM
Is the aspect Grit TV is using intentional? The programming is stretched; the commercials are pillar-boxed.
It looks that way. ShopHQ is on 44.1 instead of 24.1, now.
pastiche is offline
post #10155 of 10165 Old 01-06-2015, 12:28 PM
leszek1's Avatar
After a failed handoff of KBCB to Fox (http://licensing.fcc.gov/cgi-bin/ws....ion_id=1651610) it looks like it was given to SBN instead.
leszek1 is online now
post #10156 of 10165 Old 01-07-2015, 10:48 AM
Flambe's Avatar
Quoted: 37 Post(s)
Liked: 58
Anyone else having 7.1 (KIRO) occasionally dropping off? My PC (equipped with Hauppage USB tuners) occasionally can't find the show. Not always, just sometimes. I'm in Fremont. Am I just unlucky or are they doing something?
Flambe is online now
post #10157 of 10165 Old 01-13-2015, 03:11 PM
happy2Lurk's Avatar
7.1 (kiro) & 4.3 grit
RE: 7.1 (KIRO) occasionally dropping off - I haven't noticed anything today - haven't had it on much though. Days or maybe weeks ago, I remember 7.1 (KIRO) was gone for hours - could not get a signal with anything I have. When it did come back, it started with a weaker than normal signal. By prime-time it was back to normal.
Anyone using windows media center and have guide data for 4.3 GRIT TV? My DTVpal DVR picked-up 4.3 so I rescanned in media center - got 4.3 but no guide data.
happy2Lurk is offline
post #10158 of 10165 Old 01-14-2015, 04:43 PM
tkreyche's Avatar
Liked: 0
KIRO Issaquah translator Problems
I've experienced flakey behavior the past couple weeks with the KIRO Issaquah translator on Tiger Mtn on channel 51 - it has worked fine for me for quite awhile, then for some reason my TV couldn't lock onto the signal. Last night I checked and the signal was gone completely. I'm receiving other signals on Tiger Mtn just fine so it's not my TV or antenna.
tkreyche is offline
post #10159 of 10165 Old 01-19-2015, 03:34 PM
houman's Avatar
I used to have an Amazon Basics TV antenna which was OK, then recently swapped it with the amp model (Amazon did that no questions asked). It's just connected behind the TV on the wall (facing N) and I am in Bellevue. Yesterday during the game I had drops in all channels (a friend took the antenna and put it on the wood floor and I had better reception!)
Not sure if it is because of the bad weather we were having.
Does anyone recommend any place that would install rooftop antennas in the area(s) ?
houman is offline
post #10160 of 10165 Old 01-20-2015, 11:35 AM
Lee Wood's Avatar
Annnd, now we're not. Decided to give the bits back to the main programs with the addition of 4.3.
Lee Wood is offline
post #10161 of 10165 Old 01-20-2015, 03:30 PM
Jiminkirkland's Avatar
Experts,
As a number of folks have noted--KIRO (Ch-7) has fluctuated recently. On occasion it's unwatchable and at other times it's merely annoying. For me it's been happening for the past month (approx). No changes in my set-up or antenna (downtown Kirkland). I imagine that it's weather connected (wind?). But still, for years they were steady. Have they made changes to their antenna location?
Jiminkirkland is offline
post #10162 of 10165 Old 01-20-2015, 06:46 PM
Liked: 0
KING-TV 5.2 appears to be running Justice now.
PSIP: KING-SD
Resolution: 480i
post #10163 of 10165 Old 01-20-2015, 06:54 PM
Liked: 0
The KIRO-TV translator on West Tiger appears to be off air right now-- if you're able to re-scan for Channel 39, it might fix your problem. I suspect when 51 scans in on some receivers it supercedes 39 and erases 39. RF Channel 39 is the main KIRO-TV transmitter from Queen Anne.
post #10164 of 10165 Old 01-20-2015, 10:38 PM
Probably not a bad decision if I was the only one using that stream. Thanks for letting me know though!
pastiche is offline
post #10165 of 10165 Old Yesterday, 09:22 PM
rdn
rdn's Avatar
PSIP: KING-SD
Resolution: 480i
I wish KING or KONG would add NWCN.
Bob
rdn is offline
post #10166 of 10165 Unread Today, 02:26 PM
leszek1's Avatar
MCE uses zap2it service. Once they have it so will MCE
http://www.zap2it.com/tvlistings/loc...d=USA-OTA98034
