Seattle, WA - OTA - Page 340 - AVS | Home Theater Discussions And Reviews
 8Likes
post #10171 of 10182 Old 02-01-2015, 08:56 PM
seatacboy's Avatar
Quoted: 24 Post(s)
Originally Posted by jtostenr View Post
Anyone know why I can get KIRO 7-1 just fine, but cannot get KING at all? I live in Marysville and am using an Antennas Direct 91XG mounted in the attic. No matter where I point it, I cannot get KING (or KOMO for that matter). Can't post my tv fool results yet since I don't have 5 posts. Jeff
KIRO-TV has a low-power translator for Everett/Marysville. It transmits on a different frequency than the main Seattle transmitter, but it maps out to channel 7.1 (the RF channel is 17).
http://www.kirotv.com/news/entertain...slators/nDqkh/
Additionally, Everett has a low-power translator for KZJO which maps out to channel 22.1 (the RF channel is 29). Besides KIRO and KZJO, which other stations are you able to receive? If you are using a highly-directional XG91 Yagi, it might be worth checking your TV Fool mapping and tinkering around with things.
If you can find a post by DanKurts, send him a PM. Although he specializes in custom A/V installations, he is very knowlegeable about the performance of TV antennas in specific neighborhoods and specific types of houses.
seatacboy is offline
post #10172 of 10182 Old 02-01-2015, 09:02 PM
seatacboy's Avatar
Quoted: 24 Post(s)
Originally Posted by eiger View Post
Thanks. Do any of you guys know of local shops in the greater Seattle/Lynwood/Puget Sound area that sell good antennas? Not looking at the best buys of the world, more of the specialty shops.
Fry's Electronics in Renton carries some RCA, Channel Master and Antennas Direct models. I recall that McLendon's Hardware carries a couple of RCA antennas. You might want to PM DanKurts on this thread, he performs a lot of custom A/V installs and could point you in the right direction as well as offer his opinions on specific antennas.
post #10173 of 10182 Old 02-02-2015, 11:58 AM
jtostenr's Avatar
Liked: 0
Here are the channels that I am getting right now. Many are at the same azimuth as KING at similar tx power I believe.
4.1
4.2
4.3
7.1
7.2
11.1
12.1
12.2
12.3
13.1
20.1
20.2
20.3
20.4
20.5
22.1
22.2
22.3
24.1
24.2
28.1
28.2
28.3
51.1
51.2
jtostenr is offline
post #10174 of 10182 Old 02-03-2015, 08:42 PM
weebling1's Avatar
jtostenr, King is touchy way the heck up here (snohomish). I had to add a signal booster and theres a rather narrow aim for me sometimes. (wonder if my antenna rotor 'walks')
weebling1 is offline
post #10175 of 10182 Old 02-06-2015, 07:11 PM
AZFats's Avatar
Everything has changed... all the channel numbers that is. Seemingly as I type... I'm confused...
I came here hoping someone knew what was up. Is it storm related or some kind of upgrade or channel swap?
Getting the network channels on 48 now if I'm not mistaken. I don't remember that existing before.
Using rabbit ears in Edmonds
AZFats is offline
post #10176 of 10182 Old 02-08-2015, 10:55 AM
KING transmits 5.1 and 5.2 on channels 48.1 and 48.2. Your TV should remap the channels to 5.1 and 5.2 based on the PSIP information in the broadcast stream.
Try re-scanning channels on your TV. In most cases, that should clear things up.
I've seen a couple of receivers over the years that had a really difficult time recovering from corrupt PSIP data. The fix for those was to disconnect the antenna and do a full scan (clearing everything), then reconnecting the antenna and doing another full scan (re-adding everything.)
Good luck!
pastiche is offline
post #10177 of 10182 Old 02-12-2015, 04:47 PM
girbabe's Avatar
Lost local SD channels
Hopefully I'm in the right forum.
I just realized this week (I'm in the Bellevue area), that I've lost several of the local SD channels - Komo 4, King 5, Kong 6, KCTS 9, KZJO 10, and KSTW 11. The screen message just show no TV signal detected. Surprisingly, CBS 7 and FOX 13 aren't affected. I can get them in HD however (channels 104, 105, etc).
I have a cable card and Silicondust Prime with Windows Media Center if that makes a difference. Have I missed some Comcast changes or does anyone know what could be causing this? Appreciate your help.
girbabe is offline
post #10178 of 10182 Old 02-13-2015, 06:53 PM
tmn1's Avatar
Quoted: 13 Post(s)
This would be the OTA (over the air forum) for Seattle. Come back if you cut the cable. What you want now is Seattle, WA - Comcast Good luck
tmn1 is offline
post #10179 of 10182 Old 03-12-2015, 07:02 PM
rdvegas's Avatar
Quoted: 56 Post(s)
Liked: 34
According to the KVOS Bellingham Facebook page, their sister station KFFV Seattle has added a new sub-channel being 44.6. It carries a simulcast of the KVOS METV service, extending METV's footprint further south than is possible from the KVOS Orcas transmitter. Expect some quirk remedy over the nest week or two, but it's now on the air.
Wanting a strong FCC to say no to the Wireless lobby. Keep the tv broadcast band for ota television broadcasters.
rdvegas is offline
post #10180 of 10182 Old 03-12-2015, 07:27 PM
seatacboy's Avatar
Quoted: 24 Post(s)
MeTV is live on 44.6!
MeTV is live on KFFV 44.6 today! Obviously KFFV is doing quite a bandwidth juggling act with six channels, although unlike KWPX (of which the .1 ION programming is supposedly HD), all of KFFV's channels are SD.
KVOS' transmitter up on Mt. Constitution, along with a blowtorch 580kw transmitter (quite high power given the HAAT) does have a huge geographic reach. However, given the limitations of digital TV combined with curvature of the earth, reception in the Seattle-Bellevue area is spotty. Their transmitter is almost 89 miles from my house as the crow flies, and on TV Fool the signal strength AGL is -8.7 dB, it only improves to about -8.0 db at 20 feet HAAT, so having the KVOS feed retransmitted on 44.6 is fantastic!
PQ on 44.6 is mid-def. There's some motion blur caused by the limited bitrate. This is typical when a station runs six subchannels. One thing I did notice, however, while watching M*A*S*H* during the past half-hour, is that the MeTV KVOS commercials are LOUD. I'm sure they have developed audio technology which manipulates the audio dB level, so that these LOUD MeTV commercials comply with the FCC'S CALM regulations governing the loudness of commercial advertising.
post #10181 of 10182 Old 03-14-2015, 07:24 AM
rdvegas's Avatar
Quoted: 56 Post(s)
Liked: 34
Cox has announced that KIRO will add a new sub-channel soon for the April launch of LAFF TV. This new diginet from ABC and Scripps will be formated to keep your laughing, and hopefully ABC and Scripps laughing all the way to the bank. The new service is set to launch mid-April across the US, and will most likely be aired on KIRO 7.3. The network has already launched a Facebook page: https://www.facebook.com/lafftvnetwork
rdvegas is offline
post #10182 of 10182 Unread Today, 01:50 PM
m9610172's Avatar
Quoted: 20 Post(s)
Hi, I’m planning to install antenna in attic but I’m not sure which one would be the best.
Here is the result from TVFool.
http://www.tvfool.com/?option=com_wr...f1f019dcd2f415
I want to pick up NBC, Fox, CBS and ABC. I don’t watch any other channels.
A few antennas I’m thinking are AntennaCraft HBU33, Winegard HD7694, Channel Master 4228 or Amazonbasics Outdoor 60 miles.
I prefer CH4228 or Amazonbasics, if they work, due to their smaller size. Or please let me know if there is a better one.
Thanks in advance
- Panny 65PS64 Plasma, Denon 3313, Panny BD35 Bluray, HTPC (XBMC), Energy RC-70, RC-LCR, RC-10 & V-mini (FH), 2 x Micro Marty Subwoofer
- Samsung 63" Plasma, Xbox 360, WiiU, Wii, PS2, Pioneer VSX-1018, Energy Micro 5.0 + LFM-EX
- Onkyo TX-8255, Infinity Primus P163
m9610172 is online now
