Wilmington, NC - HDTV - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
Old 01-09-2007, 09:29 AM
Daryl L's Avatar
Quoted: 354 Post(s)
Liked: 232
Originally Posted by jspENC View Post
What happened to 'TheTube' on 26.2 ? It is now gone on my set and 26 has been renamed
WSFX-DT
It's a shame to see the music videos have been taken off all the Sinclair channels including 28.2 in RDU and now we lose them also.........
It just stopped being remapped. It was on their physical channel 30.4 this morning.
LG OLED55E6P UHD TV
Samsung UBD-K8500 UHD BD Player
Denon AVR-S710W Atmos AV Receiver
Samsung SMT-H3272 HDC DVR Cable Box
Roku 2 Streaming Media Box
Daryl L is offline
Old 01-15-2007, 03:23 PM
jdncsu's Avatar
greetings guys!
i have direct tv hd.. but im also looking for some OTA. any recommendations on the best antenna in the hampstead area? i have been comparing for a while but im just not sure which will work best.
i have looked at the terk hdtvs, the square shooter, the db2 and the lacrosse. dont really want a big nasty antenna but i will if i have to. thanks in advance!
* yellow - uhf WWAY-DT 3.1 ABC WILMINGTONNC 248° 34.4 46
* yellow - uhf WUNJ-DT 39.1 PBS WILMINGTONNC 271° 32.1 29
* red - uhf WECT-DT 6.1 NBC WILMINGTONNC 271° 32.1 44
* red - uhf WPXU-DT 35.1 MNT JACKSONVILLENC 63° 15.7 34
* blue - uhf WCTI-DT 12.1 ABC NEW BERNNC 30° 53.1 48
* violet - uhf WUNM-DT 19.1 PBS JACKSONVILLENC 30° 53.1 18
jdncsu is offline
Old 01-15-2007, 04:01 PM
incus's Avatar
I just asissted a friend who lives in Pelican Reef (Hampstead area) put up a Channel Master 4228, pre amp and a rotator. He is pulling in all the Wilmington HD's and also 35.1...(not sure of the station).
The antenna is mounted on his roof, about 30' high. He couldn't pull everything in until he used the rotator. Amazing what a few degrees can do.
Good Luck,
Incus
incus is offline
Old 01-15-2007, 04:34 PM
jspENC's Avatar
Quoted: 97 Post(s)
Originally Posted by jdncsu View Post
greetings guys!
I would suggest a CM 4221 or 4228. You should be able to get WITN-DT 32 from there also. You will need a rotor. If you want CBS & CW WNCT-10 VHF, I would suggest a high band http://www.solidsignal.com/prod_display.asp?PROD=YA1713 added onto that via a CM 7777.
jspENC is offline
Old 01-15-2007, 07:37 PM
jdncsu's Avatar
thanks guys... any difference in the 4221 or 4228 for the price?
jdncsu is offline
Old 01-17-2007, 09:48 AM
jdncsu's Avatar
how bout this from radio shack?
40" Boom Length, 17 Elements Outdoor Antenna for UHF-Only
Model: U-75R | Catalog #: 15-2160
jdncsu is offline
Old 01-17-2007, 10:44 AM
jspENC's Avatar
Quoted: 97 Post(s)
CM 4221 is about $25 online, but S&H is more. The Channel masters are better than the RS, but that one is good also. I picked up both WWAY and WSFX with it 60 miles away, and it picked up UNC at 55 miles when they were low power with no problem.
Good luck! It's all trial and error at first to see where the best spot is to get everything usually.
jspENC is offline
Old 01-17-2007, 10:51 AM
jdncsu's Avatar
attic installation worth a crap or do i have to get it outside?
jdncsu is offline
Old 01-18-2007, 01:34 PM
foxeng's Avatar
Quoted: 166 Post(s)
Liked: 66
The FCC has announced it has accepted for filing WILM's companion DTV channel 40.
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers. "Arguing with an engineer is like mud wrestling with a pig. After a couple of hours, you realize the pig likes it"
foxeng is offline
Old 01-18-2007, 02:41 PM
jspENC's Avatar
Quoted: 97 Post(s)
Channel 40? That is the same as the Charleston FOX affiliates frequency. WTAT 24.1
jspENC is offline
Old 01-18-2007, 05:21 PM
Daryl L's Avatar
Quoted: 354 Post(s)
Liked: 232
What's that mean? What's that gonna be?
LG OLED55E6P UHD TV
Daryl L is offline
Old 01-18-2007, 05:44 PM
foxeng's Avatar
Quoted: 166 Post(s)
Liked: 66
It means that the FCC has accepted an application for channel 40 for WILM-LP and if approved, WILM can build a digital station on channel 40.
foxeng is offline
Old 01-18-2007, 06:15 PM
jspENC's Avatar
Quoted: 97 Post(s)
If they go with 40, there is bound to be a lot of interference. I pick up Fox from Charleston regularly in the evenings and mornings.
jspENC is offline
Old 01-18-2007, 07:40 PM
MarcS's Avatar
Very, very interesting............ that should open up some more OTA recording options for sure...
Time to give Connie a call to get some more info.......(assuming she's still the station manager...)
Aw crap! I got excited too soon...
http://www.fcc.gov/fcc-bin/tvq?list=0&facid=167819
Only 7,500 watts... and antenna about 170' above ground...
Oh well, it's a start...
Looks like the antenna will be within about 4-5 miles of my house at worst... but then again, the initial WSFX antenna was that close also, and I couldn't pick up squat. But I think WILM will be much higher...
MarcS is offline
Old 01-19-2007, 05:13 AM
foxeng's Avatar
Quoted: 166 Post(s)
Liked: 66
Remember that LP stations have a fraction of the area that full power stations do. They are basically to cover a specific area where full power stations cover large regions. I am kind of surprised they didn't try to upgrade the status to a low end full power station with the new channels open but then they may not be able to until post transition when the old analog channels open up.
The proposed coverage doesn't look to bad though for what they are trying to cover.
foxeng is offline
Old 01-19-2007, 07:02 AM
MarcS's Avatar
The proof will be in the reception... I don't put too much stock in the proposed coverage diagram. We only need to go back and look at WSFX before they moved their antenna (and upped the power), and we could take a look at WECT's service contour map and see that it radiates out over the ocean... but as many of us here in Wilmington know, the signal has real problems stretching to the East...
The first WSFX antenna, mounted at their studio, was about 125' up at 5kW, WILM's is proposed to be about 180' at 7.5kW...
So really, I am encouraged by the developments, especially if the signal gets cleaned up a bit compared to the feed coming from TimeWarner cable, and if we can finally get DD5.1 instead of 2.0. Wait, hold on!! Maybe they'll devote the entire bandwidth to just the single broadcast!! We can hope...
I left a message with Connie this morning, hopefully she'll call back soon and I'll try to get more info.......
BTW, foxeng--thanks for posting the FCC approval, and in general, it's nice to have someone with your experience and knowledge posting...
MarcS is offline
Old 01-19-2007, 07:15 AM
MarcS's Avatar
Uh oh... it's a side mount antenna...
http://svartifoss2.fcc.gov/prod/cdbs...ibit_id=441215
MarcS is offline
Old 01-19-2007, 09:14 AM
MarcS's Avatar
WILM digital... budgeted for 2008.......... maybe we'll get FiOS by then too.....
MarcS is offline
Old 01-25-2007, 08:42 AM
jdncsu's Avatar
hey guys... one more possibly dumb question.. if i put up a 30' mast now with a 4228 or equivalent can i add the rotor/preamp later? or do i need to put those on when i install the mast?
jdncsu is offline
Old 01-27-2007, 09:29 AM - Thread Starter
nc88keyz's Avatar
Quoted: 154 Post(s)
Liked: 78
Funny that you mention FIOS,
I have heard that AT&T and verizon are trading some territories. and wilmington will become a VZW landline market. Keep your ears to the wall. I know VZW wants this really bad
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NUC i5/KODI, ChromeBox/KODI, ShieldTV
HT2: LC80LE844U, AVR: AVR4311CI, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2
STORAGE: DS1812, DX513 x 2 - 4TBx18 Hybrid Raid, (It Just Works!!) R/C: HarmonyOneX2, Harmony880x1
nc88keyz is offline
Old 01-27-2007, 02:57 PM
MarcS's Avatar
We do have a large call center here... hmmm...
Funny thing was, Verizon builds a call center in Wilmington, but no one can get their service for a couple of years...
MarcS is offline
Old 01-27-2007, 02:59 PM
MarcS's Avatar
I'm sure you can add it later, but it would probably be easier to do it all at once... you know, only one trip to the roof...
Of course, you won't know if you need it until you put it up without those items...
MarcS is offline
Old 01-31-2007, 08:42 AM
bdfox18doe's Avatar
Quoted: 215 Post(s)
Liked: 118
Those of you in Wilmington may want to try receiving WFXB-DT on channel 18, now that we're at full power from our new transmitter in Mullins SC..
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
Old 01-31-2007, 09:44 AM
jspENC's Avatar
Quoted: 97 Post(s)
I doubt I will pull in WFXB... Our PBS station between New Bern and Jacksonville is on 18. Yesterday morning I noticed I couldn't get PBS on 19.1, so maybe I was picking up both signals! I don't care about PBS on 18 anyway, since I get them on 29 (39.1) also. I think in 2009 the Jacksonville PBS will move to 19, so maybe then...
jspENC is offline
Old 01-31-2007, 09:10 PM
MarcS's Avatar
The contour map doesn't include the Wilmington area, but it's possible my antenna stack could still pull it in:
Yeah, just kidding!
MarcS is offline
Old 02-05-2007, 12:33 PM
TorontoNewb's Avatar
how long do you think it will take for CBS to start showing up on Channel 40 weeks months a few more years?
last night I was trying to watch CBS from Florence for the superbowl and it sucked it was all shakey
TorontoNewb is offline
Old 02-05-2007, 12:47 PM
MarcS's Avatar
It's budgeted for 2008... as they say... "you do the math"...
That said, just because it's budgeted for 2008, doesn't mean it will be operational in 2008... so I wouldn't hold your breath for OTA WILM...
Who do you have for cable? TW has CBS in HD...
MarcS is offline
Old 02-05-2007, 12:51 PM
wow junk that lol
I have Charter for Cable
who does TW use for CBS in HD? what station and why isn't Charter offering it with their current HD Lineup
Old 02-05-2007, 01:26 PM
jspENC's Avatar
Quoted: 97 Post(s)
Antenna sweet spots can be a pain in the arse. Does the CBS ever come in steady?
jspENC is offline
Old 02-05-2007, 01:36 PM
ya it comes in pretty steady but only at night and only when it is clear outside
I don't know what was causing the problem last night but the audio was dropping so bad we just put it on wilm which on our tv is streched and all blurry
