Chicago, IL - Comcast - Page 340 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #10171 of 11246 Old 10-10-2011, 11:06 AM
Spiderman865's Avatar
Been that way the last few weeks for College Football.
Spiderman865 is offline
post #10172 of 11246 Old 10-10-2011, 03:09 PM
Joe The Dragon's Avatar
Quoted: 30 Post(s)
Now when will comcast add CLTV HD?
Joe The Dragon is offline
post #10173 of 11246 Old 10-10-2011, 04:29 PM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
Does it exist anymore? I don't even see the HD logo they had for awhile. Given the Trib is still in bankruptcy (but still has tons of money to 'retain' their executives), I'm surprised it still exists.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #10174 of 11246 Old 10-10-2011, 08:49 PM
Quoted: 30 Post(s)
likely in house also there is no more WGN SD anyways. Other then the down res ver's the cable co pushers out.
post #10175 of 11246 Old 10-14-2011, 08:08 AM
Is there a reason other than Comcast management in this area being clueless, why when the Chicago area went through digital migration, the channel lineup could not have been re-aligned? If Comcast could do it in New Jersey, SE Pennsylvania, and the Boston area to name a few, why not here? Attached is Ocean County NJ's new HD line up where you can see HD channels all grouped in one location. C'mon Comcast, get with the program out here, one of your largest markets.
Ocean-HD-channel-lineup.pdf 105.76171875k . file
post #10176 of 11246 Old 10-14-2011, 11:09 AM
zzzzz's Avatar
That lineup is somewhat better than what we have here but there are still gaps. I see 300's, 800's, 1200's, 1300's, 1500's and 1600's. Plus there's 3D channels mixed between the HD channels.
Also 4 digit channel numbers are an annoyance; there's no need for them if they utilized the numbering more efficiently:
2 - 499: SD channels and music
500-899: HD channels
900-999: All those stupid on-demand link channels (honestly I wish they'd just drop these, but they do make it easier for advertisers to promote a quick way to get to their on-demand ads)
1000+: 3D channels (assuming they don't completely flop)
Even if every last scrap of bandwidth was used for HD -- with 3 HD channels per actual 6 Mhz cable channel -- on a 135 channel system, the most HD they could possibly have would be 405 virtual channels. In reality, they would never have that many since they still need room for on-demand, Internet, phone and SD channels. So a single bank of just HD from 500-899 should work fine.
Edit: And while they're at it, channel+ and channel- should automatically skip channels that you're not subscribed to.
zzzzz is offline
post #10177 of 11246 Old 10-14-2011, 11:58 AM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
Don't hold your breath.  The idea is to tempt you to subscribe by giving you hints at what you're missing.
dattier is offline
post #10178 of 11246 Old 10-14-2011, 03:40 PM
dishrich's Avatar
Quoted: 56 Post(s)
Liked: 39
Be thankful you were NOT an ex-Insight system - we have it WAY worse than anyone else! Insight did a "theme-based" lineup on all their systems back several years ago, which the way they did it, meant that they had duplicate channel#'s for every channel# in the expanded basic lineup.
(see this link for an example - as you can see they just shoved all HD in the 900 block, & are now all but out of room for new HD channels)
http://www.myinsight.com/documents/C...eupCardKEN.pdf
However, when CC took over 2 years ago, they left ALL the existing channel numbering as is, but everytime CC added new channels (including all those new HD's in our WOM conversion) they did NOT conform these new channels to the existing theme-based lineup, which they still have NOT touched. So, we have (new) HD scattered in the 600's & 900's, & (new) SD scattered everywhere, with NO rhyme or reason! What is even MORE ignorant, is that we did & still DO have plenty of empty slots in the 900's they could have shoved most, if not all those new HD channels in - & at least kept it somewhat consistent!
Totally agree! Here's a system that did it like you are suggesting:
http://www.secv.com/cdocs/channel_birds.pdf
If you notice, all you have to do to find the HD version of an SD channel, is simply add "5" onto the first digit of the SD channel; of course, channels 2-99 would be 5xx in the HD range.
Simple & efficient...
Unfortunately, as others have pointed out - good luck getting THAT to happen with a cable provider...
dishrich is online now
post #10179 of 11246 Old 10-15-2011, 07:44 PM
Quoted: 30 Post(s)
there are comcast systems that have Comcast Info Channel HD / CSN Chi + HD on 285 even when all other HD is in the 600, 700, 800. 900 range.
Out side of the Chicago area but still in the CSN Chicago zone.
also you think after all this time you rename Comcast Info Channel HD (old mojo HD) to Comcast Sports Net + plus on the on line channel list. The box guide list CN+HD for channel name.
post #10180 of 11246 Old 10-17-2011, 10:11 AM
Seems like Comcast needs a better management team in place out here. The channel lineup is sub-par compared to other Comcast systems.
post #10181 of 11246 Old 10-23-2011, 10:43 AM
scottsol's Avatar
Quoted: 22 Post(s)
Liked: 24
For the past few days my TCMHD reception has ranged from awful to nonexistent, with variable signal strenth that is never higher than 55. Has anyone else had this problem?
scottsol is offline
post #10182 of 11246 Old 10-25-2011, 06:06 PM
FSugino's Avatar
Quoted: 20 Post(s)
When did NBC Chicago Nonstop (252/341) start broadcasting in HD? I don't usually watch it but I was clicking through the channels and was surprised to see the rebroadcast of the 6 PM news filling the screen.
Flicks? Here's my collection. And I've seen a lot, too.
FSugino is offline
post #10183 of 11246 Old 10-26-2011, 10:44 AM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
It hasn't.  It's still in 704×480i.  Are you sure it wasn't in widescreen SD, or that your own tuner or display wasn't adjusting it?
dattier is offline
post #10184 of 11246 Old 10-26-2011, 11:58 AM
FSugino's Avatar
Quoted: 20 Post(s)
Hmmm. I got curious so I recorded a sample to my computer. The picture is 704x480 (853x480 anamorphic) and is displayed fullscreen. Neither my tuner nor TV is set to stretch or zoom, so it's coming through as widescreen SD, not HD.
It's definitely soft but the picture quality is much better than the ABC Live stuff that's 16:9 squashed into the 4:3 safe area.
FSugino is offline
post #10185 of 11246 Old 10-26-2011, 01:04 PM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
It hit me after posting that this was the Chicago Comcast thread, not the Chicago OTA thread; I checked the OTA reception of 5.2 and shot my mouth off about that.
I can't imagine that Comcast would have or bother distributing an HD source of an OTA channel broadcast only in SD; I'll try to check a QAM tuner's opinion and will post if it's anything other than 704×480i.
dattier is offline
post #10186 of 11246 Old 10-26-2011, 01:25 PM
SycamoreSeej's Avatar
Comcast *should* be broadcasting local 16:9 as 16:9. The only channels I recall that Comcast zooms 16:9 to 4:3 is CBS, ABC and NBC, even when broadcasting national feeds. Craig Ferguson jokes all the time about people not watching in 16:9 and does visual jokes to rile them up.
Now in NE Tucson, AZ with a cheap rabbit ears antenna. Got everything except KTTU (MyNetwork).
SycamoreSeej is offline
post #10187 of 11246 Old 10-26-2011, 04:59 PM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
I think Comcast just passes it on. On ClearQAM, it shows up as anamorphically stretched on my Samsung TV (which doesn't auto-change.) It does say 16:9 on the info screen. The top and bottom seem to be a bit cut off, though.
The DTA is a bit confused. It looks like it recognizes the 16:9 and stretches it horizontally, but then chops off the sides since it's only a 4:3 device.
The cable box is sending it as HD in 16:9. The diagnostics show it as 704x480i, but 16:9. Nice way to handle it, but shows that Comcast could do fake HD by sending 16:9 SD!!
OTA, the DTT901 seems to work properly.
post #10188 of 11246 Old 10-26-2011, 07:25 PM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
Yes, and indeed they are relaying Nonstop in 16:9, but it's the same 16:9 SD that WMAQ sends; it's not HD.
dattier is offline
post #10189 of 11246 Old 10-27-2011, 11:19 AM
Yeah, that's what I meant. OAR should be presented as such, but Comcast won't listen cos it's math and that's reaaaaaalllly harrrrd.
post #10190 of 11246 Old 10-27-2011, 01:15 PM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
Except through the DTA, I'm receiving Nonstop from Comcast in 16:9 over QAM and through the [rented] DVR, and that's the new OAR for Nonstop, isn't it?
dattier is offline
post #10191 of 11246 Old 10-30-2011, 10:04 AM
metropole's Avatar
Quoted: 39 Post(s)
Any Hawks fans here? Watching a game on WGN is almost impossible for me at this point. Things are rather blurry. Games on on the 200 comcast channel are fine.
metropole is offline
post #10192 of 11246 Old 10-30-2011, 05:14 PM
JTH182's Avatar
That's weird, game was fine for me
JTH182 is offline
post #10193 of 11246 Old 10-30-2011, 05:47 PM
Rammitinski's Avatar
I had it in HD OTA-only, but I thought that the Wolves game, which was on WPWR at the same time, actually looked better.
Rammitinski is offline
post #10194 of 11246 Old 10-31-2011, 06:30 PM
mogulos's Avatar
Not getting any center channel audio on CBS (Comcast channel 189). All other channels are fine. Anyone else have the same problem?
mogulos is offline
post #10195 of 11246 Old 11-01-2011, 06:52 PM
Quoted: 30 Post(s)
WPWR games look like 16:9 SD
WGN 9 HD looks real good on directv.
What is with your HD OTA antenna hook up?
You can get WGN 9 HD OTA in places like Kenosha, WI
post #10196 of 11246 Old 11-01-2011, 10:56 PM
The games were 16:9 SD up until this year - this season they're definitely HD, at least OTA.
I'm not the only one by far to complain about WGN OTA - people on the Chicago OTA thread do it all the time. Not about lack of fine detail - it's the "blurring" and microblocking during fast scenes. Smallville used to look terrible at times.
post #10197 of 11246 Old 11-02-2011, 09:05 PM
Quoted: 30 Post(s)
WGN is 1080i
WPWR is 720P
post #10198 of 11246 Old 11-03-2011, 01:44 AM
720p is HD.
post #10199 of 11246 Old 11-04-2011, 01:38 PM
pqfan's Avatar
Okay, this is my understanding:
720p tends to give better results with fast moving images. Hence it is was selected by ESPN to give best image quality for sports programming.
1080i shows more detail, which should look better with slower images that contain more detail. This would include most movies.
Obviously, no one choice is best for all content. Ideally a network would change their broadcast method to match each show but no one does that and it is probably not practical.
pqfan is offline
post #10200 of 11246 Old 11-05-2011, 12:23 AM
Other than a contrast difference in the Hawks game's favor, I felt that the Wolves game looked a bit overall better that particular night (aside from any 720p or 1080i difference).
As far as the condition or "quality" of my antenna system, that, of course, wouldn't have anything to do with any picture quality differences, as long as both stations were coming in solidly, which they were.
