Chicago, IL - Comcast - Page 363 - AVS Forum
post #10861 of 10870 Old 10-15-2014, 05:19 PM
kezug's Avatar
I have Comcast Chicago HD and lately, especially ABC HD and some other channels, the bass is so boomy and prevelant, that it is exhausting on the ears to listen. I am finding myself having to turn DOWN my bass volume. Other channels are fine.
I have a pioneer receiver, all hooked up via HDMI, and have changed from Pure Direct, Direct, to Auto Surround, to ACL...nothing helps. It is definitely in the mix being transmitted by either the studio or Comcast.
Anyone else hearing this boomy bass?
Edit: I have also found this thread of other mentioning same occurrence. http://forums.comcast.com/t5/Channel...2353813#M54729
kezug is offline
post #10862 of 10870 Old 10-16-2014, 06:12 AM
retromzc's Avatar
It's the same via Directv. I have to switch the Directv receiver to PCM sound to get rid of the much too loud bass. Other channels are fine with Dolby turned on. Seems to point to a problem from either WLS-TV or ABC.
R. B.
retromzc is offline
post #10863 of 10870 Old 10-16-2014, 02:18 PM
andyross63's Avatar
Quoted: 21 Post(s)
Liked: 34
I've noticed some weird issue with WLS-HD, too. I didn't seem to notice it yesterday, but I do remember a noticeable rumbling during many shows like "The Middle" and similar.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #10864 of 10870 Old 10-16-2014, 02:34 PM
andyross63's Avatar
Quoted: 21 Post(s)
Liked: 34
I also asked this on the OTA forum, just to verify it's a WLS issue:
Chicago, IL - OTA
post #10865 of 10870 Old 10-17-2014, 04:58 AM
kezug's Avatar
kezug is offline
post #10866 of 10870 Old 10-18-2014, 06:35 AM
andyross63's Avatar
Quoted: 21 Post(s)
Liked: 34
FXX HD is supposed to be on channel 337. It's on the box, but there is no signal. History HD, Animal Planet HD and Velocity are on the same frequency (489MHz, RF 68), and they work. Is this really going to be a 4:1 HD, or is there a mixup?
post #10867 of 10870 Old 10-18-2014, 06:55 AM
FSugino's Avatar
I called Comcast a few days ago about the blank screen on FXX HD 337. A guy with a heavy Indian accent named "Fernando" told me they were working on it and it should go active shortly. It's still dead this morning. It's Comtastic!
Flicks? Here's my collection. And I've seen a lot, too.
FSugino is offline
post #10868 of 10870 Old 10-20-2014, 09:21 AM
anthony ippolito's Avatar
Hello just a note channel 337 FXX HD is up and running
anthony ippolito is offline
post #10869 of 10870 Old 10-20-2014, 02:20 PM
andyross63's Avatar
Quoted: 21 Post(s)
Liked: 34
Working here, too. And yes, that is now FOUR HD's on one frequency.
post #10870 of 10870 Old Yesterday, 02:05 PM
kezug's Avatar
Chicago, IL - OTA
A response has been posted here
Comcast Forum - ABC Sound - Overpowering Bass Rumble
kezug is offline
User Tag List
