Chicago, IL - Comcast - Page 371 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #11101 of 11111 Old 01-22-2016, 09:41 AM
LUND's Avatar
Tivo said it won't work, that is why they have this deal for series 3 tivo owners.
JIM
LUND is offline
post #11102 of 11111 Old 01-22-2016, 05:32 PM
cherry ghost's Avatar
Quoted: 18 Post(s)
Whoever you talked to at TiVo gave you bad info. The software update started going out today.
http://www.tivocommunity.com/tivo-vb...d.php?t=536450
cherry ghost is offline
post #11103 of 11111 Old 01-22-2016, 06:46 PM
LUND's Avatar
Hope I get it back to normal with my HD channels.But I'm keeping the Roamio.Let you know if anything happens.
JIM
LUND is offline
post #11104 of 11111 Old 01-23-2016, 08:46 AM
LUND's Avatar
You were right all I can say ,I can't say it or will banned.They Tivo said it won't work,two CC tech's, Tivo people.I talked to so many people even called me to help in the evening.In the end all I needed was the update not a new machine.Should give me it free.
Thanks for your help JIM
LUND is offline
post #11105 of 11111 Old 01-23-2016, 02:42 PM
dattier's Avatar
Quoted: 88 Post(s)
Liked: 47
Lately on some channels (all of them HD; there hasn't been anything recently that I've wanted to watch on the channels that are available only in SD here, so if it affects any SD channels, I wouldn't have noticed), when I skip forward or skip back on the DCX 3501, the audio catches up to the new point immediately but it takes a noticeable fraction of a second before the video at the new point replaces the video from the start of the skip, and it's more noticeable in skipping forward than in skipping back.
Is that an indication that the channel is in MP4?
dattier is offline
post #11106 of 11111 Old 01-29-2016, 08:04 AM
anthony ippolito's Avatar
HELLO Just a note I heard something yesterday on the news that next month the fcc is considering that you subscribe to cable will stop paying a monthly fee to rent a set top box from their provider.
anthony ippolito is online now
post #11107 of 11111 Old 01-29-2016, 03:19 PM
andyross63's Avatar
Quoted: 121 Post(s)
Liked: 48
The FCC is pushing to get an OPEN standard to allow devices to connect to cable/satellite without being forced to rent a box or CableCard. It will probably be a few years at best, and most likely never as the companies are already complaining how it will hurt innovation and other hilarious excuses.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is online now
post #11108 of 11111 Old 01-29-2016, 03:20 PM
andyross63's Avatar
Quoted: 121 Post(s)
Liked: 48
I did get my new cable box yesterday. I plan on replacing the old DVR Saturday morning when I get caught up on everything. Hopefully, it will go cleanly. Box (DCX-3400M) looks new or fully refurbished. It has the protective film over the front panel.
post #11109 of 11111 Old Yesterday, 03:17 PM
andyross63's Avatar
Quoted: 121 Post(s)
Liked: 48
Anyone have something odd happen early this morning? The box worked, but the only key that worked was INFO, and that would pop up something about entering a parental control PID. Nothing entered actually worked. Just before 7AM, the box seemed to do a soft boot and started loading the menus and other stuff.
post #11110 of 11111 Old Yesterday, 04:52 PM
FSugino's Avatar
I lost DVR functionality on my box. I called support and they said there was a system problem reported this morning, and they're sending hits to all boxes trying to get things back in order.
FSugino is offline
post #11111 of 11111 Old Today, 03:24 PM
andyross63's Avatar
Quoted: 121 Post(s)
Liked: 48
They had something odd happen Tuesday morning. I found my box mostly unusable. I could change channels, but the only key that really worked was INFO, and that popped up some PIN entry window. Just before 7AM, the box seemed to do a soft boot and started reloading the menus and guide data.
