Springfield / Joplin, MO - HDTV - Page 182 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #5431 of 5683 Old 01-05-2014, 11:08 AM
mulliganman's Avatar
Well I have been officially "blocked" from KRBK's facebook page after pressing them as to why their signal is consistently the lowest by far and why it is that all other channels still come in for me when we get winter weather but theirs doesn't. LOL!
mulliganman is offline
post #5432 of 5683 Old 01-05-2014, 11:20 AM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
You don't give your location. Are you getting your signal from the SFN in and around Springfield,
or from the KWBM signal south of Springfield?
Chuck44 is offline
post #5433 of 5683 Old 01-05-2014, 11:21 AM
The installer I had do my work for me said he was aiming toward Bolivar.
post #5434 of 5683 Old 01-05-2014, 11:23 AM
located in Ozark. My signal strength is now around 37% or so. Absolutely no issues picking up any other channels despite the snow.
post #5435 of 5683 Old 01-05-2014, 01:18 PM
It's absolutely ridiculous I can't pick this up ALL the time with a separate antenna + preamp+ distribution amp.
post #5436 of 5683 Old 01-05-2014, 01:37 PM
ProjectSHO89's Avatar
Quoted: 279 Post(s)
Liked: 130
It's not their fault that you are on the back side of a hill facing away from their broadcast tower.
Edit. You realize that Bolivar is about 180° from where an antenna for KWBM needs to be aimed...
ProjectSHO89 is offline
post #5437 of 5683 Old 01-05-2014, 01:52 PM
Chuck,
What signal strength are you getting for KRBK off KWBM's transmitter in Branson?
post #5438 of 5683 Old 01-05-2014, 02:16 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
Originally Posted by mulliganman View Post
Chuck,
I'm about 10 miles southwest of Ava, and with my outside antenna pointed north
towards Fordland, KRBK \ KWBM comes in at 75 to 80 on my Pal DVR's signal meter.
I'm close enough to the KWBM tower that it comes in strong even though my antenna
is actually pointed away from it.
Chuck44 is offline
post #5439 of 5683 Old 01-05-2014, 08:45 PM
OK so I realized the coordinates I had given earlier were wrong. Google maps was mixing it up with another street name with the same name in Ozark. A much closer representation at my situation would be: 37.0316027 -93.19952269999999
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b940f11af42d0
With that being said, do you all think I can pick up KRBK vis KWBM stronger than how I am currently aimed?
post #5440 of 5683 Old 01-06-2014, 05:57 AM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
If you're in Ozark, everything except the new KRBK SFN is east of you.
Chuck44 is offline
post #5441 of 5683 Old 01-06-2014, 06:33 PM
bearfan4's Avatar
Is anyone getting KRBK 49.2 ME TV? I have rescanned and cannot get it. I am getting 49.1 just fine.
bearfan4 is offline
post #5442 of 5683 Old 01-06-2014, 07:05 PM
motorhead0922's Avatar
Yes, been receiving METV for a couple of weeks on all TV's. No rescans.
motorhead0922 is offline
post #5443 of 5683 Old 01-06-2014, 07:17 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
So far its only being broadcast through the Springfield KRBK SFN on 49.2.
It remains to be seen whether it will also be available through the KWBM signal for those of us south of Springfield.
Chuck44 is offline
post #5444 of 5683 Old 01-13-2014, 07:34 PM
JOHNTEDLOCK's Avatar
krbk towers are in bolivar and none can pick it up im 10 miles away and only picked it up when snow was on as soon as it melted it went off
JOHNTEDLOCK is offline
post #5445 of 5683 Old 01-14-2014, 04:16 AM
Quoted: 279 Post(s)
Liked: 130
KRBK has a total of 5 towers of their own (plus a piggyback sub-channel on a station down near Branson), one of which is in Bolivar.
You have to know where the "best" signal is likely to come from for any given location then aim your UHF antenna appropriately while avoiding the other signals.
Map of KRBK transmitters: http://www.rabbitears.info/contour.php?appid=1495755
post #5446 of 5683 Old 02-16-2014, 01:46 PM
scottmo2020's Avatar
New place!
I'm thinking about putting up an antenna and working toward re-cutting the cord at some point. Here's my Tvfool
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b94c2c7bb574b
Looks like I have a better shot at Springfield than I do Columbia stations. Some are 2edge so that's where I am concerned. Thanks for your advice!
scottmo2020 is offline
post #5447 of 5683 Old 02-16-2014, 06:52 PM
Quoted: 279 Post(s)
Liked: 130
Well, the good news is that KRBK won't be an issue...
A long as you aren't behind trees, you should be able to get it to work. Many Lake locations are pretty much SOL when it comes to antenna usage. Something like a 7698 and LNA200 should do the job.
post #5448 of 5683 Old 04-23-2014, 11:06 AM
I am looking for someone with the means/ability/tools to help trouble shoot a problem I am having.
I have been having reception issues on my local ABC and its sub-channel. My setup is a two antenna setup. I have an Antennas Direct C2V pointed toward all towers except Fox (it is in a completely different direction). I am using an Antennas Direct 91XG to pull in Fox. I just recently had both antennas combined using this custom combiner: http://www.tinlee.com/PDF/AC7-customer%20general%20hookup%20Info.pdf
The combined output ran to a Channel Master 3414: http://www.channelmasterstore.com/Antenna_Cable_TV_Amplifier_p/cm-3414.htm
That is then ran out to 3 television sets. I had experienced some trouble with the new Channel Master DVR+ that I was hoping the Tinlee AC7 combiner would solve. But, unfortunately it didn't. The Tivo Roamio I have hooked up was not having any of the same problems the DVR+ has with the same setup. I began problem-solving to make sure that the tuners on the Channel Master DVR+ weren't being overpowered (which they weren't). I knew I couldn't add a preamp to the Antennas Direct C2V (that's where the ABC stations are coming from) because when I ordered the custom AC7 combiner I only had DC pass built in for the Fox station from the Antennas Direct 91XG (because according to my TVFool report it is my weakest station). I had this amp laying around from an earlier setup: http://www.solidsignal.com/pview.asp?p=sky38323
I decided then to run the combined output from both antennas into the Skywalker amp (it has a nob to control amount of amplification; I did not turn it up all the way), then from there to the Channel Master 3414 amp and split to the 3 TV's. Then voila. The ABC channels stabilized and my Fox station signal quality has jumped up to 84% signal strength and mid 90's signal quality. Unfortunately, the stabilization of ABC and its sub-channel (33.2) only lasted a couple of days.
So, I am looking for help with this situation. One TV only connected to a coaxial line doesn't have the problem. Another set connected to a Tivo Roamio hasn't had the problem. I'm not sure what to make of it. I'm wondering if there is an issue that the DVR+ is detecting because it is more sensitive but don't know what it could be.
Here's my TV Fool report if it helps: http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3D5b940f11af42d0
If more additional information is needed, please ask.
post #5449 of 5683 Old 04-28-2014, 01:49 PM
bvinson's Avatar
Did anyone else lose all of the Springfield OTA UHF channels today (around noon), or it it just me?
I still get KOLR-10 (VHF), but nothing else.
bvinson is offline
post #5450 of 5683 Old 04-28-2014, 02:43 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
Just you. If you use an outdoor antenna, it may have gotten moved during the storms.
Chuck44 is offline
post #5451 of 5683 Old 04-29-2014, 07:07 AM
bvinson's Avatar
I don't know what happened. It was clear and sunny when they went out.
Came back on around 4:30pm.
Must be a loose connection somewhere.
bvinson is offline
post #5452 of 5683 Old 06-18-2014, 12:04 PM
tch
tch's Avatar
I give up on FOX. Used to be I could "split the difference" between pointing at Fordland and KWBM and get both fairly well. Now it appears that something has happened to the KWBM coverage... I noticed when a FOX show failed to record the other day. Now the best I get is broken and pixelated. I'm sick of chasing this network's marginal signal and their screwed-up toy antenna. I just pointed my antenna at Fordland and said GOODBYE FOX.
tch is offline
post #5453 of 5683 Old 09-26-2014, 07:58 AM
JopMan3305's Avatar
Message Problem
Help! The last post I have in this Springfield/Joplin, MO - HDTV reception forum is 5454 by tch at 06-18-2014 reference reception of Fox from KWBM. He's giving up, he said. What have I done, or am I not doing, to cause this problem?
jopman3305
JopMan3305 is offline
post #5454 of 5683 Old 09-26-2014, 08:28 AM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
What problem? That is the most recent post in this thread.
Chuck44 is offline
post #5455 of 5683 Old 09-28-2014, 01:28 PM
JopMan3305's Avatar
Thanks, Chuck. I thought I could count on you to come through with an explanation, that is, if you were still with us! I guess it's my age, but I still don't understand why all traffic ended with that thread under discussion, just as though everybody shut up shop all of a sudden, no one chipping in with reception, problems or otherwise. I saw somewhere recently that KSPR will begin airing Antenna TV on 33-03 on Oct. 1. Joplin had it on 49-1 until recently. It's been off the air for a couple of weeks now for the third time since its initial airing this summer. An Antenna TV spokeswoman checked for me and said the other times were due to vandals damaging equipment. No reason for this last off-the-air disappointment. We still have Retro TV here, but still in analog and off the back side of my outdoor antenna pointed toward the big network transmitters. Again, thanks for your reply.
Warner2Bruce likes this.
jopman3305
post #5456 of 5683 Old 09-28-2014, 02:53 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
(...)I saw somewhere recently that KSPR will begin airing Antenna TV on 33-03 on Oct. 1...
I hadn't heard that. I know KRBK was trying to add Me-TV to their south (KWBM) signal, but I guess that fell through.
So, what is Antenna TV?
Edit:
I looked it up, and you are right:
http://antennatv.tv/interactive-affiliate-map/
Chuck44 is offline
post #5457 of 5683 Old 09-29-2014, 04:53 PM
Quoted: 256 Post(s)
Liked: 41
I saw today on KYTV that they are adding Cozi Tv 3-3.
JopMan3305 likes this.
Warner2Bruce is offline
post #5458 of 5683 Old 09-29-2014, 04:56 PM
Quoted: 256 Post(s)
Liked: 41
I have a reception question for this forum. Anyone having trouble with Fox KRBK in the Ozark area. I'm aimed toward the Springfield tower and haven't had any trouble with it since putting up an Antennas Direct 91xg. But, yesterday I completely lost the signal. I was told on their web page to contact their engineers, which I did but I haven't heard anything back.
post #5459 of 5683 Old 09-29-2014, 05:15 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
Also on October 1st KSPR is adding Antenna TV on channel 33.3.
Chuck44 is offline
post #5460 of 5683 Old 09-29-2014, 05:20 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
First, I'd double check the cable(s) for tightness and damage.
Then I might try aiming the antenna towards Forsythe \ Tanyville to try to get their signal via KWBM (displays as 49.1 but is actually on RF 31.2).
Chuck44 is offline
