Springfield / Joplin, MO - HDTV - Page 188 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
Old 05-06-2017, 05:05 AM
scottmo2020's Avatar
Quoted: 13 Post(s)
Originally Posted by Trip in VA View Post
The cell companies had nothing to do with it. Gray has been turning in station licenses as they buy up the non-license assets of stations they can't legally own the licenses to. (See WFXS.)
- Trip
KY3 is telling the public it is because of the historic spectrum auction, which is for the cell phone companies.
http://www.ky3.com/spectrum/
Whatever the convoluted reasoning is or how it ends up happening operationally, we OTA viewers in the rural areas lose 3 pretty popular channels. The station is telling people some of these will be available but neglect to tell anyone that people greater than 20 miles from Springfield are out of luck. Just "Springfield and surrounding communities..."
If they were smart, they would be honest and get in front of this because people are going to call when they lose their channels. I guess they really don't care about the few rural OTA viewers at the end of the day anyway.
scottmo2020 is offline
Old 05-06-2017, 10:00 AM
unclehonkey's Avatar
Quoted: 320 Post(s)
Liked: 65
They didnt list the reason but Trip already laid it out and I have posted info on it before. It had to do with the Gray/Schurz buyout. Here are some of the links in this thread
unclehonkey is offline
Old 05-06-2017, 12:34 PM
MGOMRJSURF's Avatar
Quoted: 23 Post(s)
Another like DTV America could pick them and solve OTA problem.
MGOMRJSURF is offline
Old 05-06-2017, 01:37 PM
Quoted: 320 Post(s)
Liked: 65
considering DTV America mainly puts their stations right in the heart of a city it would be no better than the existing setup (probably worse as DTV America uses shorter towers in a lot of cases)
Old 05-06-2017, 04:14 PM
Ingersoll's Avatar
There are three problems with O.T.A. T.V. in the United States:
  1. Not enough power (especially on the VHF band). VHF channels need to go back to broadcasting with 316 kilowatts of effective radiated power.
  2. Masts which are not tall enough. Taller masts equal greater reach.
  3. The use of A.T.S.C. DVBT2 is superior as it does not have as much of a "digital cliff" DVBT2 has a middle ground between signal and no signal where you get a degraded signal.
Ingersoll is offline
Old 05-07-2017, 03:40 AM
ProjectSHO89's Avatar
Quoted: 271 Post(s)
Liked: 129
1. The 316 kw maximum ERP you quoted on VHF was concentrated in the vertical sync pulse of the NTSC signal. Digital uses an average of the whole channel bandwidth. Not the same thing at all. In any event, if VHF stations were permitted to go that high of power, the interference in locations between major cities would be so strong as the make it impossible to receive due to interference. There is a reason for the existing power levels. FWIW, UHF broadcasters were allowed up to 5 MW ERP with NTSC!
2. Home owners, too often, look for the easy/cheap way out when it comes to installing an antenna. There are hardly any local businesses that still install towers or tall antenna installations since most of those guys have either died, retired, or moved on to other business lines.
3. Water under the bridge for ATSC, those decisions were made over 20 years ago. The evolution to ATSC 3, which uses an ODFM format, will greatly improve reception in multi-path-prone areas.
ProjectSHO89 is offline
Old 05-07-2017, 05:57 PM
Ingersoll's Avatar
The reason I don't get reception on VHF is not because of multi-path it's because the VHF signal is too weak due to ridiculous power reduction. Homeowners should not have to go to expensive and elaborate means to get over the air signals. http://www.tvnewscheck.com/article/3...-a-power-boost
Old 05-08-2017, 04:56 AM
Quoted: 271 Post(s)
Liked: 129
Guess again. Old-timer remember having to have towers and very large antennas installed if they wanted reliable analog reception back in the day.
Since that article was written in 2009, many VHF stations either did increase power or moved to UHF. Other stations either didn't care or were constrained by the realities of what they were allowed to do. We're seven years down the road. and you're beating a long-dead horse. Let it rot and go away. Analog and its power levels on VHF are dead and still misunderstood if you do not understand the difference between peak and average power levels as well as the implications for adjacent market interference.
Old 05-11-2017, 06:03 PM
Ingersoll's Avatar
Adjacent market interference? There are no markets around broadcasting on channels 7 or 14.
Old 05-22-2017, 04:54 AM
Quoted: 13 Post(s)
So will KSPR-LD be on RF 15 at their downtown Springfield facility, and KYCW-LD will be on RF-19 at Fordland with reduced power? I was wondering because RF 15 might interfere with KMOS, but since RF 15 will be low power and far away I don't think it will be an issue for me. When KYTV moves to 19, what will happen to KYCW-LD?
Old 05-22-2017, 02:07 PM
Quoted: 320 Post(s)
Liked: 65
sounds right
Low powered stations will have a time frame next year to file with the FCC for open stations in an area (if they are getting bumped by a full powered station). This one is unique as Gray owns both stations (most cases the station being bumped for another station are not co-owned)
Old Today, 09:50 AM
dbsstephen's Avatar
Quoted: 12 Post(s)
Liked: 0
I'm getting channel 15 in Lebanon Missouri did they change something or did they just up the power someone channel 15 so it reach farther
Sent from my SAMSUNG-SM-N910A using Tapatalk
dbsstephen is online now
Old Today, 11:57 AM
Super Moderator
DrDon's Avatar
Quoted: 1079 Post(s)
Liked: 2142
Probably just atmospheric conditions. You do have a front moving through.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
