Springfield / Joplin, MO - HDTV - Page 190 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #5671 of 5695 Old 06-08-2017, 06:10 AM
dbsstephen's Avatar
Quoted: 22 Post(s)
Liked: 0
But if that's the case then why is KYCW coming in better than KY3 is because I don't even get KY3 anymore since they changed everything around the only stations I get his channel 25 now which carries the CW WeatherNation Cozi TV and antenna TV I don't get none I don't get ABC or NBC anymore over the air here
Sent from my SAMSUNG-SM-N910A using Tapatalk
dbsstephen is offline
post #5672 of 5695 Old 06-08-2017, 07:04 AM
Ozarks's Avatar
Liked: 0
Originally Posted by Trip in VA View Post
FCC ownership rules do not allow a company to own or operate two of the top four stations in a market without using questionably legal maneuvers. Gray bought KYTV and with it came the agreement to run KSPR. Gray couldn't own KSPR outright, and the previous administration's rules made the agreement attributable, so it was as if Gray owned KSPR as well.
Gray kept KYTV and turned in the license for KSPR. However, since LPTV stations do not count toward the ownership limit, they moved KYCW-LD, an LPTV license they bought, to the KSPR facility, and turned the power down to make it into an LPTV license.
- Trip
Odd. The ABC affiliate is still calling themselves "KSPR 33" on their logos, etc. The whole thing has left viewers wondering WTF? And my OTA TiVO is completely FUBAR.
Ozarks is offline
post #5673 of 5695 Old 06-08-2017, 05:34 PM
scottmo2020's Avatar
Quoted: 16 Post(s)
You've got other problems then. RF-44 is still full power and carries ABC, NBC, and standard def CW. I am 50 miles farther away than you and it blows the doors off of RF-19. "Channel 25" is RF-19 and on a low power transmitter. In Lebanon you should get both. So maybe your receiver isn't handling the various PSIP overlap/combination/cluster that they have going on.
scottmo2020 is offline
post #5674 of 5695 Old 06-08-2017, 06:04 PM
dbsstephen's Avatar
Quoted: 22 Post(s)
Liked: 0
I can't even pick up 49 they have a tower just 10 miles north of town
post #5675 of 5695 Old 06-08-2017, 06:26 PM
unclehonkey's Avatar
Quoted: 366 Post(s)
Liked: 73
Because the station is legally still KSPR...but its now KSPR-LD (low powered digital station) versus the former KSPR-DT (full powered station). The copy on KYTV is for folks who liver outside of Springfield proper.
unclehonkey is offline
post #5676 of 5695 Old 06-08-2017, 06:27 PM
Quoted: 366 Post(s)
Liked: 73
as noted right above
post #5677 of 5695 Old 06-08-2017, 06:34 PM
Quoted: 366 Post(s)
Liked: 73
If you dont mind me asking how bad is it? At least when they used Tribune (zap2it, screener) I could see what the call sign is. Tvguide they just list the station numbers
It doesnt help when Gray is playing "wheel of stations" all the time
post #5678 of 5695 Old 06-09-2017, 07:09 AM
Ozarks's Avatar
Liked: 0
On my OTA TiVO, 33-1 is labeled "KYTVDT2"
See screenshot attached.
There are other errors besides this station ever since Gray threw all the channels into the blender.
Ozarks is offline
post #5679 of 5695 Old 06-10-2017, 12:50 PM
Quoted: 366 Post(s)
Liked: 73
Yeesh! Just that screenshot looks bad when trying to record shows
Hate to see the whole list
You could submit a lineup change to Tivo
https://www.tivo.com/lineup.html
I always remember to be thorough. Use RF numbers and the PSIP numbers. So as example KYCW-LD (33-2) I assume is coming from RF44? If so then just explain that to them. Something like
"On June 1st a couple stations changed RF stations and call signs. Here are the errors
RF19 should have the following programming
25-1 CW (KYCW-LD)
3-2 Weather Nation
25-3 CoziTv
33-3 AntennaTV"
It may take some work going through the RF numbers to verify. Do you how to check that?
Unfortunately I've learned that Tivo doesnt seem to change things unless they are reported by the end user
post #5680 of 5695 Old 06-11-2017, 05:16 AM
Ozarks's Avatar
Liked: 0
The "25s" are just as bad. See attached pic.
25-1 CW (KYCW-LD)
3-2 Weather Nation
25-3 CoziTv
33-3 AntennaTV"
Thanks for the detailed suggestion, but yes, I've done all that; included the correct call signs, RF & virtual ch #s , network names and even a station engineer contact email. Eventually, TiVO sends me an email saying it's been fixed, but no dice, even after reconnecting to the TiVO network and re-downloading the guide info, rescanning, rebooting, etc.
Ozarks is offline
post #5681 of 5695 Old 06-11-2017, 01:30 PM
Quoted: 366 Post(s)
Liked: 73
bummer. Wonder if sending another lineup change would possibly make them relook at the issue.
post #5682 of 5695 Old 06-12-2017, 07:42 AM
Ozarks's Avatar
Liked: 0
I'll eventually look up the channel mapping for the channels I watch on RF 17, 19 & 44; and report the missing guide data again to Tivo and also KYTV/KSPR/KGHZ/KYCW (or whatever they're calling themselves this week).
Ozarks is offline
post #5683 of 5695 Old 06-12-2017, 03:17 PM
Quoted: 366 Post(s)
Liked: 73
It doesn't help when apparently 25-1 is mapped from THREE different spots (according to rabbitears)
RF17 PSIP 25-1 (the one near Branson that has WXNation and the tourist station)
RF19 PSIP 25-1 (the tower in Fordland that USE to be used for ABC)
RF15 PSIP 25-1 (the short stick in downtown Springfield)
Best thing to do is go through your list via the signal meter and see what RF station those stations are mapping to then submit a update to Tivo.
post #5684 of 5695 Old 09-10-2017, 05:36 PM
21hawk's Avatar
KRBK engineering, on July 20th, replied to a post on their Facebook page, stating that they were going to a single full power tower in Fordland, that the process was underway. presumably in conjunction with their move to RF22
21hawk is offline
post #5685 of 5695 Old 09-11-2017, 07:03 AM
Ozarks's Avatar
Liked: 0
So it's likely that Carroll County, Ark. still won't be able to pick them up, due to interference from LP station K22HS on RF22, in the same DMA & coverage area.
Ozarks is offline
post #5686 of 5695 Old 09-11-2017, 03:10 PM
ProjectSHO89's Avatar
Quoted: 288 Post(s)
Liked: 131
There's absolutely nothing in the FCC's LMS that indicates such a change has been requested. KRBK applied for the repack changes for their DTS system on 22 as well as filing for a couple of million dollars in repack expenses.
Couldn't find zip on KRBK or their engineering department's FB feeds that would substantiate the above. FWIW, the engineering dept doesn't even have any posts after June...
ProjectSHO89 is online now
post #5687 of 5695 Old 09-11-2017, 05:35 PM
Trip in VA's Avatar
Quoted: 863 Post(s)
Liked: 255
Send a message via AIM to Trip in VA
They can't have applied for it yet anyway since the filing window for that type of change has yet to open for KRBK.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #5688 of 5695 Old 09-11-2017, 07:18 PM
Quoted: 288 Post(s)
Liked: 131
Any idea when that filing window will open?
So, if they did go to a single "big stick" full power facility at the Fordland site, would they likely displace the channel 22 translator mentioned by 'Ozarks'?
post #5689 of 5695 Old 09-12-2017, 02:29 AM
Trip in VA's Avatar
Quoted: 863 Post(s)
Liked: 255
It's not yet been announced.
And I believe so, though I would have to look into it.
- Trip
N4MJC
RabbitEars
post #5690 of 5695 Old 09-12-2017, 04:33 AM
Ozarks's Avatar
Liked: 0
...I believe so, though I would have to look into it.
K22HS used to be on RF 18 (and had different call letters). When KFSM, (CBS Ft Smith/Fayetteville) moved from analog RF 5 to digital RF 18, KFSM forced them to move from RF 18 to RF 22. I remember it well because no one around here could receive KFSM until the LP station moved to 22.
So, if full power still has bumping rights, K22HS will have to move again, if KRBK ever goes full power at Fordland.
K22HS Application history: https://licensing.fcc.gov/cgi-bin/ws...ility_id=11137
Displacement: http://licensing.fcc.gov/cgi-bin/ws....ion_id=1153272
Ozarks is offline
post #5691 of 5695 Old 09-12-2017, 04:35 AM
21hawk's Avatar
Gentlemen, please allow me to enter this into the inquisition
21hawk is offline
post #5692 of 5695 Old 09-13-2017, 03:59 AM
Quoted: 288 Post(s)
Liked: 131
21hawk,
Thanks for posting that. For the life of me, I still cannot find it in their FB feed.
post #5693 of 5695 Old 09-13-2017, 05:52 AM
Ozarks's Avatar
Liked: 0
Originally Posted by ProjectSHO89 View Post
21hawk,
It's there, in a nested reply posted on 20 July.
Ozarks is offline
post #5694 of 5695 Old 09-13-2017, 09:06 AM
Ozarks's Avatar
Liked: 0
From KBRK:
...we will displace channel 22 [K22HS] at Eureka Springs when we moved to channel 22...
Good to know, since so far, we've never been able to watch KBRK at all. And more often than not, all that's on K22HS is a placeholder showing that their satellite feed to the holy land is down.
Ozarks is offline
post #5695 of 5695 Old 09-13-2017, 10:13 AM
Ingersoll's Avatar
Quoted: 12 Post(s)
Originally Posted by scottmo2020 View Post
OTA stations get paid per subscriber from the subscription services. They get to double-dip in ad revenue AND subscriber fees. They WANT subscribers to these services rather than giving it away over the air.
Running a transmitter must cost a fortune, just in electrical costs. Add on maintenance, liability insurance, whatever else, and you can see the advantage of shutting these transmitters down. Consolidation was in the cards even before the spectrum auction as a way for TV stations to save money. Why run a megawatt transmitter when you can fiber uplink to a cable or satellite head end at a fraction of the cost?
And that's why KRBK runs several transmitters, right? KOAM asked for 55kw of E.R.P. That's 3.7x the amount of power they have.
http://www.rabbitears.info/static.ph...vhf_nightmares
The broadcaster and viewer are both getting screwed over.
Ingersoll is offline
