Orange County, CA - Cox - Page 247 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 04-02-2014, 08:33 PM
teague's Avatar
1063 Guide is good for me on my Roamio.
teague is offline
Old 04-02-2014, 08:56 PM
moyekj's Avatar
What callsign do you see for that channel? Is it PRIMHD or PRIMEHD?
TiVo 6 tuner Roamio Pro, Elite & Premiere + MoCA networking.
kmttg - Tivo To Go and Advanced Remote Control
moyekj is offline
Old 04-02-2014, 09:08 PM
moyekj's Avatar
Well, here's an interesting one - my Elite and Premiere have the proper PRIMHD callsign and correct listings. It's only my Roamio Pro that is incorrect. Guess I'll have to redo guided setup to see if it fixes it.
moyekj is offline
Old 04-02-2014, 09:20 PM
teague's Avatar
PRIMHD
teague is offline
Old 04-02-2014, 10:35 PM
moyekj's Avatar
OK thanks. A net connect tonight just fixed the problem on my Roamio Pro. Strange, as I think the problem has been there for a few days now...
moyekj is offline
Old 04-04-2014, 09:07 AM
twarren's Avatar
Quoted: 26 Post(s)
For those with TiVos can you check if you are getting proper guide listings for channel 1063? I have a wishlist for Clippers games and was wondering recently why no Clippers games were getting recording. On my Roamio Pro when I check channel 1063 the callsign is PRIMEHD and all the guide listings are "OFF AIR". When I look at zap2it.com I see the callsign is PRIMHD (without the E) and there are proper listings there. So it looks to me like the TiVo lineup is messed up for that channel.
(EDIT: I did submit a lineup change request with TiVo BTW but wanted to check here if others are seeing same problem)
TIVO guide shows PRIMHD for 1063 and program listings appear to be ok.
twarren is offline
Old 04-23-2014, 06:43 PM
Whitearrow's Avatar
Quoted: 58 Post(s)
Liked: 68
Anyone else have any weirdness last night? I had two recordings between 9 and 10 record only partials. 1005 and 1010. It happened on two TiVos so it was either the cable, or something that wasn't an individual TiVo hardware gltch.
Whitearrow is offline
Old 04-26-2014, 09:33 AM
tvmaster's Avatar
Yes - the last two nights we've had at least one of our Tivo's go into hang-up mode, so that the only way to regain control again was to pull the power from the Cox Tuning Adapter, which makes me think it's a Cox problem and not a Tivo problem.
Both nights, when we went to use the Tivo at around 10:30pm, it was frozen, so the problem occurred each day between 4pm and 10pm
tvmaster is offline
Old 05-03-2014, 12:17 PM
moyekj's Avatar
So I finally replaced my Arris DOCSIS 2 Telephony modem with a DOCSIS 3 Cisco DPQ3212 telephony modem this morning (just picked it up for free at Cox store). Seems to be working fine, but speeds are no better than I was getting with my DOCSIS 2 modem, both up and down. Another things that sucks is the modem info page (192.168.100.1) seems to be locked down and just has a single page with modem name, MAC, firmware info and some power levels on the 8 downstream channels & 3 upstream channels being used. But access to more information seems to be blocked/locked out. Anyone know if there is a login that provides access to more tabs than the locked down one?
moyekj is offline
Old 06-18-2014, 07:17 AM
twarren's Avatar
Quoted: 26 Post(s)
Channel 68 analog
I have a tv set connected through cable only (no STB) so it gets just analog signals. Yesterday morning channel 68 stopped working , seemed to just freeze up. All other channels are fine and of course 68 and 1068 via STB are fine.
Just wondering if anyone else is having this problem.
twarren is offline
Old 06-18-2014, 08:44 AM
Dong-Kinh's Avatar
Same problem with channel 68. The picture is frozen on Marlon Brando in an Air Force uniform having dinner with a geisha.
Dong-Kinh is offline
Old 06-18-2014, 09:04 AM
twarren's Avatar
Quoted: 26 Post(s)
that's what I'm seeing also; the movie is "Sayonara" and was on yesterday morning from 8:30am to 11:15am
Edited: I reported this problem to Cox; response was that they had no prior reports of this problem so would have to send out a technician to check the signal at the pole going into my house. I told them that it is more likely a problem further upline but they said that was all they could do. Technician is scheduled for tomorrow morning. So, if others are having same problem it would probably help to report to Cox also if possible so they might get a clue that its more widespread.
Edited again: Channel 68 is working again, after about 24 hours.
twarren is offline
Old 06-19-2014, 02:47 AM
ajwees41's Avatar
Quoted: 20 Post(s)
Has Cox moved 68 to the digital space? I know Omaha's Analog channels now stop at channel 67.
ajwees41 is offline
Old 06-19-2014, 05:17 AM
twarren's Avatar
Quoted: 26 Post(s)
No, currently analog still includes 68 (goes up to 72); don't know how long they will continue with analog.
twarren is offline
Old 06-19-2014, 09:53 AM
ajwees41's Avatar
Quoted: 20 Post(s)
what speeds are you paying for? If you aren't on a D3 plan you will not see any increase in speeds just less dropping the signal.
ajwees41 is offline
Old 06-19-2014, 10:23 AM
moyekj's Avatar
Preferred (25/5 Mbps). Some others posted here they got increased speeds just switching to DOCSIS 3. Didn't make any difference for me.
moyekj is offline
Old 07-09-2014, 07:04 PM
twarren's Avatar
Quoted: 26 Post(s)
this has probably been discussed before, but simple search doesn't find appropriate results:
using the Cisco stb with contour, there are various settings for CC; however changing them (e.g. text color, background, etc) doesn't seem to affect many of the channels (e.g. SYFY) but does affect most. I guess its related to how the CC signal is included, but is there a way to change the appearance for all channels?
thanks for any response
Never mind; I guess the settings can only affect digital CC; analog signals are just analog?
twarren is offline
Old 09-15-2014, 03:37 PM
Whitearrow's Avatar
Quoted: 58 Post(s)
Liked: 68
I know that 90+ percent of what we talk about here is problems, so here's the 10 percent. I had Cox out on Friday to install their security system (for which I'll be paying $40 a month for their much improved system instead of the $48+ I was paying for ADT, locked in for 3 years). The three guys they sent (one of whom was a trainee) were all nice, knowledgeable, and easy to deal with. Before they finished they checked my cable wiring, replaced some cables and connectors, and improved my overall speed considerably.
So at least for this moment I am a happy customer. And I have cameras and can spy on my cats
Old 09-30-2014, 11:59 AM
Whitearrow's Avatar
Quoted: 58 Post(s)
Liked: 68
Does anyone know the cost to get a static IP on Cox?
Old 09-30-2014, 01:09 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
IIRC, you must get a business account.
domino92024 is offline
Old 10-03-2014, 01:14 PM
Ray Lucca's Avatar
Quoted: 58 Post(s)
Liked: 56
Back to basics. Video quality or lack thereof...
TBS, Ch. 1027 has a lot of the Baseball Play-offs. Picture is horrible and breaks up as soon as the Camera moves. Checked 2 Boxes on 2 different sets. Same on both. Looks bit-starved to me. Checked the Direc feed, rock solid, clear, dramatically better, and the Audio is louder. Haven't checked the FS1 feed yet as I'm in the Office and it isn't available without a Box. My Tv has video up to Ch. 72, and FS1 is Ch. 73, I think.
Ray Lucca is offline
Old 10-06-2014, 11:26 AM
Ray Lucca's Avatar
Quoted: 58 Post(s)
Liked: 56
Checked FS1 over the week-end. Same as TBS HD, poor picture, bit starved. It seems simple to me, Sports need more band-width. Please adjust Cox.
NBC SN All of the NBC Ch's look poor
CBS Sports
Velocity [Worst culprit]
NFL Ch
NHL Ch
TNT and TBS
MLB Ch
FS1
Discovery
Pac 12
SEC
ALL the Pay Movie Channels
etc...
Old 10-30-2014, 05:51 PM
rwb1921's Avatar
Just an FYI, looks like internet speed has at least doubled for me in Mission Viejo. Now getting 116.71 Mb/s on Chrome using Speedtest.net. So my speed has doubled at least, I am on Premier plan.
rwb1921 is offline
Old 10-30-2014, 06:55 PM
moyekj's Avatar
Yes, it was in the OC Register recently that starting Tuesday Cox doubled internet speeds. On Preferred plan I'm getting about 60 Mbps down, but still only 5 Mbps up. Also last I checked the data caps didn't change (still 250GB for Preferred which is very lousy).
moyekj is offline
Old 10-31-2014, 10:36 AM
Whitearrow's Avatar
Quoted: 58 Post(s)
Liked: 68
Yup, same for me.
One of the many reasons I do not look forward to a world where all TV is internet-based. We'll end up paying for bandwidth instead of cable. Well, that and the unskippable ads, which I find intolerable on any pay service.
Old 10-31-2014, 01:47 PM
rwb1921's Avatar
Yup, same for me.
Yea, I agree, the caps for data is not good. Would be easy to use it all up. That keeps me from using internet that much for TV watching. Hopefully that may change sometime, but until then we are stuck I guess with watching how much we use.
rwb1921 is offline
Old 11-22-2014, 02:12 PM
sharding's Avatar
Liked: 25
All 4 of my tuning adapters (all connected to TiVos of various versions) stopped working (in blinking amber mode) at some point recently. I've been too busy to watch tv for a couple of days, but it definitely happened within the last few days. Rebooting them fixed it. Annoying because it causes recordings to fail until I notice the problem. I wish TiVo would send an email alert or something when it can't tune to a channel it wants to record on. (Well, I wish we didn't have to use tuning adapters, or that they weren't so flaky, but I'm trying to be realistic).
sharding is offline
Old 01-11-2015, 11:23 AM
Whitearrow's Avatar
Quoted: 58 Post(s)
Liked: 68
So, this is a little weird.
On my old TiVo (HD) I got a lineup change a few days ago that History is changing to HistoryP (along with some other channel I didn't care about and can't remember).
I haven't gotten the lineup change for my Premiere (last connect was this morning), and I've verified the lineup change is correct for History (it's 3 hours off). Anyone else experience this? And what's the best way to approach TiVo about it, since it isn't the normal lineup change situation?
Old 01-22-2015, 05:20 PM
lnong's Avatar
Quoted: 57 Post(s)
Liked: 24
What HD digital antenna do you guys use in Irvine, CA?
I recently cut the Cox cable cord, and have been looking for a good digital HD indoor antenna so that I can just watch the OTA channels, but I'm running out of choices. I've tried several different ones, including ones that have good reviews. With all of them, I can get CBS (2), NBC (4) and KTLA (5). With none of them, except for the Winegard antennas, can I get ABC (7), KCAL (9), FOX (11) and KCOP (13). With the Winegards, I SOMETIMES can get ABC (7), KCAL (9), FOX (11) and KCOP (13) but only like one at a time, depending where I place the antenna around the room. Very sensitive. And on top of that the signal is very weak. Sometimes the I see pictures for a second or two and then the signal breaks apart. Very sad and frustrating.
The indoor HD antennas I've tried:
- RadioShack brand amped
- RCA brand nonAmped
- Winegard FL5500A
- Winegard FL55YR
- Some $90 amped antenna from RCA
I ended up having to return all of them. If any of you guys live in Irvine and use an indoor HD antenna that can pick up all the local OTA channels I've listed above, please share! I'm fine with any style of antenna (flat wave, rabbit ears, etc) as long as it's for indoors.
Here's the TV Signal Report I just ran at TVFool.com.
lnong is offline
Old 01-22-2015, 05:38 PM
moyekj's Avatar
Ever since the digital transition where the major networks moved to VHF range instead of UHF here in Mission Viejo the pre-amped indoor antenna I had in garage is now worthless. It worked great for UHF channels but doesn't work well at all for VHF channels (I don't remember name of antenna, but it has both UHF and VHF antennae). You would probably have to look to put antenna on your roof to get decent reception since the transmitters on Mt Wilson are probably about 60+ miles from you and it seems like the VHF signals are much harder to tune reliably from that distance.
moyekj is offline
