New York, NY - OTA - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #871 of 18555 Old 11-29-2003, 12:28 PM
kschonha's Avatar
Note to festivalman:
I am also located in New Hyde Park and WNBC-DT comes in fairly strong. I would highly recommend that you have a rotor mounted on your antenna.
kschonha is offline
post #872 of 18555 Old 11-29-2003, 02:16 PM
festivalman's Avatar
I've got one of these little radio shack antennas that's propped up next to the upstairs window where my home theater is. It took about 20 minutes to finally get it positioned correctly so that the other 3 major channels come in very strongly, so I dread moving it again to try and get NBC. Alas, I'm sure I'll mess with it anyway just to see what I'm missing. Renting an apartment and not being able to put up a big outdoor antenna is annoying at times.
festivalman is offline
post #873 of 18555 Old 11-29-2003, 02:22 PM
seldenpat's Avatar
Going off of WNBC for a second...
Anyone else having problems with WLIW (21.1)? I have great signal strength, but no picture on either of the subchannels. Has been this way since last night.
"The truth is you're the weak. And I'm the tyranny of evil men. But I'm tryin', Ringo. I'm tryin' real hard to be the shepherd."
seldenpat is offline
post #874 of 18555 Old 11-29-2003, 04:03 PM
Ed Barclay's Avatar
WLIW is good on both my Hipix and Dish 6000. What receiver do you have and have you tried a channel rescan?
Ed Barclay is offline
post #875 of 18555 Old 11-29-2003, 04:24 PM
seldenpat's Avatar
Thanks, Ed.
I have a Sony HD200 and the integrated tuner on my Sony KDP-65XBR2. Same thing with both. Locked signal, no Audio or Video. I'll try a re-scan.
post #876 of 18555 Old 11-29-2003, 10:48 PM
seldenpat's Avatar
I have WLIW again. Just came back on. Same signal strength as before, I just have Audio and Video now.
post #877 of 18555 Old 11-30-2003, 01:21 PM
feloniousmonkey's Avatar
I dont get WLIW, I wish I could I like PBS. For now CV gets my doe. I have heard we wont get PBS (in the metro area) till they actually b'cast in NYC. The WB which I do get has a Christina Aguilera Stripped in London tonight, I think its a re-peat not sure but does anyone have info. that it *could* be in HD? thank you
f
feloniousmonkey is offline
post #878 of 18555 Old 11-30-2003, 03:06 PM
Ed Barclay's Avatar
Maybe Cablevision is different in your area but I get PBS HD on Long Island Cablevision. Channel 713 is WNET-DT with the same HD programming that is on WLIW-DT OTA.
post #879 of 18555 Old 11-30-2003, 03:21 PM
Thanks Ed, but it was the FREE OTA I was speaking of. I am sorry I wasn't more specific. I give CV my money b'cause I want PBS, of course MSG*FS-HD for me. If I could get PBS FREE OTA 1 more reason to loose CV if the pickins get slim.
f
post #880 of 18555 Old 12-01-2003, 04:28 AM
Trip in VA's Avatar
Quoted: 594 Post(s)
Liked: 162
Send a message via AIM to Trip in VA
Well, after being told I should have very good reception, I return from New Jersey. Time for a reception report from Fair Lawn on my Zenith HDV420 w/ a Zenith Silver Sensor and a CM7777. Remember that Normal (abbreviated NRML) is required for a picture/sound, and that is between 33%-66% signal. Good is above that and bad is below it.
56 CBS WCBS-DT GOOD (few breakups)
28 NBC WNBC-DT NRML (but only for a few minutes)
44 FOX WNYW-DT GOOD (few breakups)
45 ABC WABC-DT GOOD (few breakups)
12 TWB WPIX-DT BAD- (Got it up to about 10%, but jumped to 30% every so often... probably multipath)
61 PBS WNET-DT NONE
30 PAX WPXN-DT NONE
40 UNI WXTV-DT NRML (but only for a few seconds)
51 PBS WNJN-DT BAD- (It would go up to about 10% and then jump to GOOD for a second... methinks it was multipath)
27 TBN WTBY-DT NONE
48 INF WRNN-DT BAD- (Got to about 15%)
29 REL WFME-DT BAD- (Barely got above zero)
53 TFT WFUT-DT BAD- (Got to about 30%)
At my cousins house they actually HAVE an HDTV, and the only channel I could get at all was WCBS-DT and it was breaking up horribly. Plus their Sony HDTV wouldn't allow a manual focus so it was way the heck off.
I also used my digital tuner on the road and took screenshots, but that's not for here, although I almost locked WNJT-DT on I-78.
- Trip
Bitstream Admin
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #881 of 18555 Old 12-01-2003, 05:24 AM
chap's Avatar
Quoted: 64 Post(s)
Liked: 35
I find that odd since I am in hawethorne, but get fairly good signals on some of those channels that you got bad signals from, but at the same token I can't pick up wpix at all.
chap is offline
post #882 of 18555 Old 12-01-2003, 06:16 AM
I havent touched my antenna in 2 years. I receive CBS,NBC, ABC, FOX, UPN (analog) WB DT
F
Originally posted by John Chu
I can't imagine having a roof top and having to go up there every few days....:-)
post #883 of 18555 Old 12-01-2003, 06:16 AM
To the guy who mentioned that he's getting good NBC reception in New Hyde Park, I seem to be out of luck. I went all out in terms of putting my antenna in all different positions, including holding it out the window with my arm. Even though I was getting 90% on cbs/abc/fox, and now even 50-60 on wliw which i wasn't getting at all up until then, nbc never once went above 5%. An almost totally dead signal. I tried it on 28.1, 2 and 3 subchannels.. never above 5%. Not sure what the deal is.
post #884 of 18555 Old 12-01-2003, 06:55 AM
MLM
MLM's Avatar
Does anyone know the power with which the local stations are broadcasting? If so, could you post it.
I have the most trouble with WCBS but I thought it had the most power. If it does, can I conclude that the problem is with interference from bouncing signals? Sometimes I can actually improve the reception by cutting power to the antenna amplifier.
MLM is offline
post #885 of 18555 Old 12-01-2003, 07:10 AM
sjf99's Avatar
Are any PBS-DT in the NY area broadcasting 24/7?
I'd like to try to get some of the PBS stations in my area (Morris Cty, NJ). Before I start playing with the rotor I want to be sure they are broadcasting at the time. Stations in my area include:
WNETD PBS 13-1-2 (may not be live)
WLIWD PSB 21-1-2
WNYED PBS 25-1-2-3 (may not be live)
WEDWD ? 49-1-2-3-4
WNJND PBS 51-1-2-3-4-5
WLNYD ? 55-1
WFTYD ? 67-1
Does anyone have any information on these as well as any others besides 2-4-5-7-9-11?
Steve
sjf99 is offline
post #886 of 18555 Old 12-01-2003, 10:05 AM
wward's Avatar
Quoted: 13 Post(s)
MLM
WCBS-DT is at full power considering that you are located in the NYC area you may need to turn down the gain on the pre-amp to pick it up.
wward is offline
post #887 of 18555 Old 12-01-2003, 10:49 AM
wward's Avatar
Quoted: 13 Post(s)
sjf99
WLIW-DT PBS 21-1-2 Operates 24 /7
WNET-DT PBS 13-1-2 Operates 24/7 at very low power 125 watts
WNJN-DT PBS 51-1-2-3-4-5 Operates 24/7 at full power
Also check out WNJU-DT 43-1,2,3,4
wward is offline
post #888 of 18555 Old 12-01-2003, 12:04 PM
joev's Avatar
Is anyone on the west side of midtown manhattan receiving ANY pbs station and /or wb? If so, tell me how your doing it....please .
i currently have ABC, CBS, FOX, NBC and UPN. would love to complete the package with a pbs.
Joe
joev is offline
post #889 of 18555 Old 12-01-2003, 12:11 PM
Paperboy2003's Avatar
SJF aside from the PBS stations, what else do you get and with what equipment. I'm in Randolph and I can only get 2.1, 5.1, 5.2 and 7.1. WHat about you??
Doug
Paperboy2003 is offline
post #890 of 18555 Old 12-01-2003, 09:22 PM
Mattdoc's Avatar
Does anyone in Manhattan use indoor antennas? I live on East 30th off 1st ave, and have an unobstructed path (north exposure) to the ESB. Would I be able to get any channels without using a roof antennae?
Mattdoc is offline
post #891 of 18555 Old 12-02-2003, 02:15 AM
clsgman's Avatar
Can anyone recommend a good preamp? Like alot of members, NBC-DT is the weakest signal although I have been receiving it with minimal breakups. ABC-DT is a little stronger 4-5 bars on my SAmsung 161 and CS with 9-10 is strongest. I'm in Roslyn Heights off exit 28 of the NSP.
clsgman is offline
post #892 of 18555 Old 12-02-2003, 07:20 AM
sjf99's Avatar
Doug
Doug,
I get:
2-1
4-1
5-1
5-2 (9)
7-1
11-1
53-1
29-1
I have to work on WLIW-DT
I have the following equipment:
CM 4228 - Attic mounted (for UHF)
RS VU-90 XR Antenna (for VHF & FM)
CM 7777 Pre amp (powered by one of my DTV receivers)
CM 9521A Rotor
Hughes HTL-HD receiver (recently replaced the RCA DTC-100)
HTH
Steve
sjf99 is offline
post #893 of 18555 Old 12-02-2003, 07:21 AM
Ed Barclay's Avatar
Channel Master 7775 for UHF only. The model 7777 adds VHF capability if needed.
post #894 of 18555 Old 12-02-2003, 07:26 AM
Calabs's Avatar
Originally posted by sjf99
Doug,
I get:
2-1
4-1
5-1
5-2 (9)
7-1
11-1
53-1
29-1
CM 9521A Rotor
HTH
Steve
Steve -
I assume that in order to get 53 and 29, you need to turn your rotor toward Philly? How can you pick up 11-1 from where you are?
Calabs is offline
post #895 of 18555 Old 12-02-2003, 12:39 PM
Try it, you cant loose. Radio Shack will give you your money back good luck, Let us know.
f
post #896 of 18555 Old 12-02-2003, 01:32 PM
Doug,
I get:
2-1
4-1
5-1
5-2 (9)
7-1
11-1
53-1
29-1
CM 9521A Rotor
HTH
Steve
Are you getting 4 and 11 without drop outs? It's hard to believe, but a testament to the CM4228 that you get all those stations with an attic mounted antennae. I have a (crappy) turk, but it's on top of two masts on top of my house! All told, it's got to be around 900 feet asl!
post #897 of 18555 Old 12-02-2003, 03:37 PM
AudioJosh's Avatar
Quoted: 249 Post(s)
Liked: 234
I am pretty much screwed where I am. I only get the WPIX channels, that's it. Analog channels come in really really poorly. I refuse to pay $50 for cable that I hardly ever watch.
I have the following:
Samsung SIR-T165
CM Stealthtenna & amp upgrade.
...but unfortunately I face north in on the 10th floor of an apt high-rise. My CM is out on the patio and facing west but I can't face it SW (towards ESB) as the building is in the way.
Maybe it is my setup, I dunno, but I get one piss-poor channel.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
post #898 of 18555 Old 12-02-2003, 03:42 PM
trekkerj's Avatar
Try different orientations and try to pick up multipath off another building, or try a simple indoor antenna pointed in the proper direction.
trekkerj is offline
post #899 of 18555 Old 12-02-2003, 04:29 PM
AudioJosh's Avatar
Quoted: 249 Post(s)
Liked: 234
I have tried just about every orientation that I could think of that made sense. It doesn't really help.
However, made if I tried a UHF only antenna that would work better, or an indoor pointed in the right direction. I think I will purchase a couple of rat shack ant's and give them a try and take back what doesn't work.
post #900 of 18555 Old 12-02-2003, 09:30 PM
TAKKL's Avatar
Is anyone else having this problem? As of 11:25 PM, I am not receiving any signal from wnbc-dt (4-1).
TAKKL is offline
