New York, NY - OTA - Page 571 - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #17101 of 18551 Old 03-14-2014, 04:52 AM
ProjectSHO89's Avatar
Quoted: 210 Post(s)
Liked: 110
none of the 114 stations I get carry more than 36 hours of data.
You don't get 114 stations, you likely can get no more than about 35-45 or so stations, at most. However, with digital broadcasting, each station can multi-cast additional sub-channels. Some operators cram as many as 10 subs of sub-par quality into a single station while most have up to two or three subs in addition to their primary channel.
ProjectSHO89 is online now
post #17102 of 18551 Old 03-14-2014, 05:03 AM
Theducksfan2010's Avatar
Liked: 57
My mistake, I meant 114 channels, off of 43 stations (not including inversion channels). I simply meant that even with that large of a number, culled between 4 markets (most all of them from 2), that like @LenL PSIP program data rarely extends more than 24 hours (if it does it is only by a few), and receiving a large number of LPTV stations, I get no PSIP guide data on those.
Josh
Theducksfan2010 is offline
post #17103 of 18551 Old 03-30-2014, 02:45 AM
NYC10033's Avatar
Me-TV has a good lineup of shows but I wish one of these Retro TV channels would start broadcasting "The Wild Wild West" series in NYC metro area.
NYC10033 is offline
post #17104 of 18551 Old 04-07-2014, 10:20 PM
Giacomo Siffredi's Avatar
Quoted: 74 Post(s)
Liked: 31
PMCM TV LLC. still does not have a construction permit for KVNV, the Middletown Township television station. In fact, a revised application specifying minimally reduced ERP and a minimally higher antenna was recently submitted to the FCC. Both applications are still outstanding.
As most of you are aware, KJWP Wilmington, in the Philadelphia, PA. market, is also owned by PMCM TV LLC. It is therefore likely that when KVNV signs on in Manhattan, NY. to serve Middletown Township, New Jersey, its programming will be nearly identical to KJWP, given that both stations are intended to serve as primary affiliates of the Me TV Network.
But here is a heads up for those who wonder what the programming will be like. According to another discussion forum, and specifically a sub-forum which discusses television in the Philadelphia market, "Paid Programming" was observed at 6AM ET. on KJWP Wilmington. So I checked the programming listings for that market. Sure enough, a four-hour block of paid programming airs weekdays from 5AM - 9AM, Saturday from 5AM - 8AM followed by mandatory E/I programming from 8AM - 11AM, and Sunday from 6AM - 9AM followed by additional mandatory E/I programming from 9AM - 11AM. It should be noted that the block of E/I programming carried by Me TV includes a Canadian television series, Edgemont, which aired from 2001 to 2005 on CBC Television.
What this all comes down to is that when KVNV signs-on, the overwhelming majority of New York City market viewers will finally have access to the Chicago-based classic television network Me TV. It has been long-awaited. So long, in fact, that about two months ago, some overly eager individuals twice went over to the KVNV Wikipedia page and vandalized it to reflect that the station was now airing in the NYC market. Apparently they felt, "so let it be written, so let it be done" But, unlike the direct feed that is presently enjoyed by the lucky bastards hooked up to the Time Warner Cable Manhattan system, the PMCM TV local affiliates will apparently not be providing an uninterrupted 24/7 feed from the Windy City. But despite the early morning interruption, viewers should still embrace this new programming service. KVNV will, after all, provide more hours of coverage than the Bridgeport, CT. affiliate did and be available to a significantly larger viewing population.
Giacomo Siffredi is offline
post #17105 of 18551 Old 04-11-2014, 08:46 AM
AloEuro's Avatar
I have opened 46- 3 EEE Spanish Christian broadcasting
46- 1 was running, now color bars
46- 2 I see only commercials
46- 4 color bars
AloEuro is offline
post #17106 of 18551 Old 04-16-2014, 07:19 PM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
WZME-DT has added an additional stream.
WZME-DT (43.1) is still Me-TV
WZMD-DT2 (43.2) is now "the Works", while
RetroTV (43.3) has moved to WZME-DT3
The lineup change has yet to be picked up by zap2it et al.
Cheers!
-Doug
dstoffa is offline
post #17107 of 18551 Old 04-19-2014, 08:22 PM
unsmiley's Avatar
Quoted: 26 Post(s)
I am not getting any of the channel 43's; I am in Manhattan.
unsmiley is offline
post #17108 of 18551 Old 04-22-2014, 03:10 PM
Quoted: 74 Post(s)
Liked: 31
Hey unsmiley,
You should try manually entering in channel 42; that is the RF channel WZME Bridgeport transmits over.
But I wouldn't be surprised if you ultimately cannot receive this station. Receiving New York City stations can be a challenge in Manhattan, and I would guess it could be even harder to receive rimshot signals from Connecticut.
post #17109 of 18551 Old 04-23-2014, 07:23 AM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
Don't count on getting WZME unless you're on the northern tip of Manhattan with an outdoor antenna.
nyctveng is offline
post #17110 of 18551 Old 04-23-2014, 12:16 PM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
I receive it on the South Shore of long Island, less than 5 miles from JFK (I am south of the Southern State Pkwy) with an outdoor antenna that isn't even facing the right way....
dstoffa is offline
post #17111 of 18551 Old 04-23-2014, 04:04 PM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
Sorry I should have been more clear on my post. I was replying to user unsmiley from an unspecified Manhattan location.
nyctveng is offline
post #17112 of 18551 Old 04-23-2014, 04:11 PM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
WLIW will be going HD by end of summer
After much delay, it's finally going to happen in the next 30 days!
rothe likes this.
nyctveng is offline
post #17113 of 18551 Old 04-23-2014, 05:43 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
About time. This day and age a full power TV station should not be in 480i.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is offline
post #17114 of 18551 Old 04-23-2014, 06:20 PM
rothe's Avatar
Well, yay! I can actually receive that at the Jersey shore, even though it's not a line-of-sight signal for me. Since WNET is VHF, and arguably a bit underpowered, I can't get it. This will fill that need.
James Rothe
Monmouth County, NJ
(37 miles due S of the ESB)
My Own OTA HDTV Experience: http://www.jimrothe.com/hdtv_ota/
rothe is offline
post #17115 of 18551 Old 04-24-2014, 09:35 AM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
I can barely receive WLIW OTA but I know Dish Network will carry it in HD eventually as they have all the local stations in HD except ION channel 31.
reddice is offline
post #17116 of 18551 Old 04-24-2014, 10:06 PM
unsmiley's Avatar
Quoted: 26 Post(s)
I am on the Upper East Side of Manhattan.  For Channel 42 I get "weak signal" message but no picture or sound; same thing for Channel 43.
unsmiley is offline
post #17117 of 18551 Old 04-24-2014, 10:08 PM
unsmiley's Avatar
Quoted: 26 Post(s)
This may be a stupid question, but going HD won't make it any easier to receive in WLIW 21 in Manhattan, correct?  I cannot get WLIW OTA now with my unamplified rabbit ears.
unsmiley is offline
post #17118 of 18551 Old 04-25-2014, 04:40 AM
Quoted: 210 Post(s)
Liked: 110
It will make no difference.
post #17119 of 18551 Old 04-29-2014, 05:48 PM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
Looks like Thursday May 1 st
dm145 is offline
post #17120 of 18551 Old 05-07-2014, 06:21 AM
flatronic's Avatar
WLIW is in HD now on FiOS – not sure about OTA.
flatronic is offline
post #17121 of 18551 Old 05-07-2014, 07:33 PM
dturturro's Avatar
OTA up and running too.
dturturro is offline
post #17122 of 18551 Old 05-08-2014, 07:42 AM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
720p or 1080i ?
dm145 is offline
post #17123 of 18551 Old 05-08-2014, 09:55 AM
mikepier's Avatar
Quoted: 16 Post(s)
I think I remember seeing 1080i OTA.
As a sidenote, Cablevision has it in HD on 721, but on Ch 21 it shows it in SD.
It does not appear they have mapped the SD channes to the HD channel, like they do with the other channels ( ex, if you tune to Ch 2 or 702, the HD picture is shown)
mikepier is offline
post #17124 of 18551 Old 05-08-2014, 11:58 AM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
Disk Network still does not have it yet but it will come soon as they have all the other networks even channel 31 now in HD.
reddice is offline
post #17125 of 18551 Old 05-09-2014, 08:56 AM
AloEuro's Avatar
Lately WABC ch.7 signal breaks, showing pixelation
AloEuro is offline
post #17126 of 18551 Old 05-09-2014, 06:50 PM
dturturro's Avatar
Originally Posted by dm145 View Post
720p or 1080i ?
Yes, it's broadcasting at 1080i.
post #17127 of 18551 Old 05-11-2014, 09:30 PM
unsmiley's Avatar
Quoted: 26 Post(s)
Yes I have been getting the same thing (in Manhattan), with both WABC 7 and WNET 13 for about the last month.  Never had any problems for about a year before.  Now I have to move my rabbit ears around and that is a pain.  What could be the cause and how to remedy it?
unsmiley is offline
post #17128 of 18551 Old 05-12-2014, 09:17 AM
AloEuro's Avatar
Unsmiley, You in Manhattan me in Brooklyn having the same problem means to me that moving Antenna would not solve the problem, I blame the studio WABC 7. maybe Trip knows
AloEuro is offline
post #17129 of 18551 Old 05-12-2014, 09:20 AM
Aero 1's Avatar
Quoted: 333 Post(s)
Liked: 167
ABC working perfectly for me 18 miles away in NJ.
Cord Cutter | OTA - NYC DMA - 6 TB TiVo Roamio - 3 TiVo Mini's | Plex Pass | Netflix | Hulu | Amazon Prime | MLB.tv & MLS Live with No Blackouts!
Aero 1 is online now
post #17130 of 18551 Old 05-12-2014, 07:01 PM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
Cheers!
-Doug
It would seem that as of the time of this posting, WZME has dumped all three streams above and is now sending:
43-1 CCTV News
43-2 CCTV4
43-3 CCTV Spanish
I wonder if they flipped the switch at midnight this morning. My DVR recording "The Rockford Files" yesterday (5/11) afternoon, but failed to record "The Saint" this morning (5/12) at 4am. Can anyone else confirm the change in programming?
Cheers!
-Doug
dstoffa is offline
