New York, NY - OTA - Page 612 - AVS Forum | Home Theater Discussions And Reviews
 70Likes
post #18331 of 18360 Old 12-10-2015, 08:26 AM
ALP
ALP's Avatar
Quoted: 56 Post(s)
Originally Posted by dvdchance View Post
Looks like it will be on WABC TV7. http://www.giants.com/broadcast-info.html
Thank you, some how my search for who would carry it missed what you found. ABC has nothing on this Monday that interest me so there will be no conflict if I decide to watch the game. Thanks again!
Tony Plachy
ALP is offline
post #18332 of 18360 Old 12-10-2015, 11:22 AM
Quoted: 12 Post(s)
Liked: 0
i did some research on some antennas including the ones mentioned here. can someone please help me understand these details such as bandwidth, gain, front to back ratio, return loss etc... in the table below.
this is what i understood of gain and dB, the more gain means the more signal the antenna provides to the tv/catches more signal from air.
negative dB is bad, positive is good, the higher the numbers, the more signal the antenna will provide?
here is the table.
if you have any other antenna recommendations, please let me know. so far based on research, i think either a Clearstream C2v or a RCA 751R or Winegard 7694p are my choices.
text table was all mixed up after posting, so i am posting pictures of it instead.
ID:	1111066   Click image for larger version
ID:	1111074   Click image for larger version
ID:	1111082   Click image for larger version
dell2015 is offline
post #18333 of 18360 Old 12-10-2015, 12:06 PM
dstoffa's Avatar
Quoted: 51 Post(s)
Liked: 24
Bandwidth corresponds to the frequencies the antenna is designed to receive. A 6 MHz block of spectrum corresponds to one TV "Channel".
VHF-Lo occupies 54 MHz to 88 MHz
VHF-Hi occupies 174 MHz to 216 MHz
UHF occupies frequencies above 460 MHz
In NYC, CBS, NBC, Fox, and WWOR broadcast in the UHF band, no matter how they brand themselves.
ABC, WPIX, and WNET are in the VHF-Hi band.
WJLP (MeTV) broadcasts in teh VHF-Lo band.
Front-to-Back Ratio - Don't worry about it. It really only comes into play when you need to reject interference from a broadcast antenna in the opposite direction.
Yes. But a negative dB is not necesarily bad, depending on the strength of the broadcast signal at your location, and it's typically an number compared to a standard folded dipole.
the hdtvprimer web site has a lot of information and a detailed glossary.
dstoffa is offline
post #18334 of 18360 Old 12-10-2015, 12:27 PM
ALP
ALP's Avatar
Quoted: 56 Post(s)
here is the table.
This first website will help with gain and dB's
http://www.hdtvprimer.com/antennas/basics.html
this one will help with front-to-back ratio
https://www.tselectronic.com/tech_no...tenna_spec.php
All TV antennas have the same bandwidth, do not worry about it.
How far from the ESB are you?
Tony Plachy
ALP is offline
post #18335 of 18360 Old 12-10-2015, 01:04 PM
Quoted: 12 Post(s)
Liked: 0
i guess maybe 35-40 miles?
I am in plainview, long island, NY 11801
i have posted my tvfool some posts back. here is the link as well:
http://www.tvfool.com/?option=com_wr...b97da9846ada0f
dell2015 is offline
post #18336 of 18360 Old 12-11-2015, 08:23 AM
Quoted: 12 Post(s)
Liked: 0
thanks for the links, learned quite a lot about the terminology.
dell2015 is offline
post #18337 of 18360 Old 12-11-2015, 12:52 PM
Quoted: 12 Post(s)
Liked: 0
homedepot is selling a Winegard freevision antenna in store. i think i am going to pick one up and install it to see how it works out.
how do these three antennas compare? Freevision vs the RCA 751R vs Channel master Stealthtenna 50?
http://www.winegard.com/freevision
http://www.channelmaster.com/STEALTH.../cm-3010hd.htm
http://www.rcaantennas.net/outdoor/?sku=ANT751R
dell2015 is offline
post #18338 of 18360 Old 12-11-2015, 01:31 PM
Wappingers.dx's Avatar
Liked: 0
Hi Dell, from your location I would run the Winegard HD7694P
But if you really wanna gild the lily, slap a rotor and a preamp under this sucker Winegard HD7084
I'm kinda old school when it comes with antennas and don't mind how they look up on my roof.
Cheers
Wappingers.dx is offline
post #18339 of 18360 Old 12-12-2015, 07:51 AM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 196 Post(s)
Liked: 189
The answer
Is probably what your real life experience is. Often opinions are helpful but actually installing it and seeing what the results are is more important. Make sure wherever you buy it that they have a return policy so that if you are not happy you can return it!
There are websites that review antennas and I am sure you went to the site that tells you what you need for your location! I would not put a rotor or preamp on it unless you really need it. Less is sometimes better than more when it comes to OTA reception.
Also if you are 35-40 miles out you might need bigger antennas than the ones you are looking at to get strong and quality reception.
LenL is offline
post #18340 of 18360 Old 12-15-2015, 04:03 PM
reddice's Avatar
Quoted: 498 Post(s)
Liked: 104
Originally Posted by Aero 1 View Post
FYI, a local football team MUST always be shown on a broadcast network in their local market when its on a cable channel. I might be wrong in this, but i think the Jets have a deal with CBS and WPIX and the Giants have one with WWOR and WABC.
WWOR should have all the local simulcasted sports games as there is never anything worth watching on myNetwork TV (cop TV2 ION is cop tv1). Never should it be on a major network station.
EarthLink Extreme powered by Time Warner Cable Brooklyn.
Netgear R7000 - DD-WRT v3.0-r29020M (02/04/16) using OpenDNS.
Toshiba 39L2300U - Apple TV 4 (2015), Fire TV (2015), PS4 (2013), Roku 3 (2013).
Cats are the best pets.
reddice is offline
post #18341 of 18360 Old 12-16-2015, 05:09 PM
Liked: 0
As a frustrated Giants fan and seeing as I can pick up WWOR no mater which way my antenna is pointing... I agree with you 100%
That WABC 7 just doesn't make the trip up here in Wappingers to well
post #18342 of 18360 Old 12-17-2015, 10:09 PM
unsmiley's Avatar
Quoted: 22 Post(s)
Originally Posted by p0tsm0ke View Post
OTA is running great here in Murray hill , getting everything and have not had any down time for a bit now.
doing a rescan now to see if anything has been added.
just finished scanning and picked up 2 more channels
RETRO TV : 32.5
WXNY-LD : 32.6 - : https://en.wikipedia.org/wiki/WXNY-LD
- MY TV CHANNEL LIST AS OF NOV 30 2015 MURRAY HILL NY 10016 ENGLISH ONLY -
- ALSO I DO NOT ADD NON CHANNELS THAT HAVE NOTHING BUT COMMERCIALS -
2.1 / 2.2 / 4.1 / 4.2 / 5.1 / 5.2 / 7.1 / 7.2 / 7.3 / 9.1 / 9.3 / 11.1 / 11.2 / 11.3 / 13.1 / 13.2 / 21.1 / 21.2 / 21.3 / 31.1 / 31.2 / 32.5 / 33.1 / 33.2 / 33.3 / 41.3 / 41.4 / 58.1 / 68.3 / 68.4
You mean you are getting WLIW in Manhattan? I thought that was impossible (according to many in this forum). How do you do it? I wish I could could get WLIW and Channel 55.
unsmiley is offline
post #18343 of 18360 Old 12-17-2015, 10:15 PM
unsmiley's Avatar
Quoted: 22 Post(s)
Originally Posted by roseha View Post
For what it's worth, I've just added the VHF Retrofit Kit, https://www.antennasdirect.com/store/VHF-Antenna-Kit.html
from Antennas Direct. I've connected it to a ClearStream Micron Indoor HDTV Antenna. The idea is that you connect your antenna cable from the TV to the VHF kit, and the cable to the UHF antenna on another connection. They provide an extra cable for this, but since the Micron had the cable attached I just used that one, which is working fine. It's only been one day, but after I situated the VHF kit in the right spot in the window with some plastic stick on hooks, I'm getting Me-TV in fine again. Anyway, just a suggestion, it's a cheap enough solution.
I'm also using a shorter antenna cable from the TV to the window, probably less interference this way.
I think that is useful for antennas that do not have VHF ability. I *think* my cheapo rabbit ears has both - it has a pair of rabbit ears as well as a circular antenna (I believe) to pick up both UHF and VHF. Correct me if I am wrong.
unsmiley is offline
post #18344 of 18360 Old 12-28-2015, 11:13 PM
roseha's Avatar
Quoted: 16 Post(s)
Yes, the rabbit ears do pick up both UHF and VHF, I had an RCA model that did both. However, now that I'm using the VHF attachment I mentioned above I'm getting many more channels consistently, at least most of the time. I can get MeTV over Channel 3/33-1, along with Channels 7-1, 11-1 (and Antenna TV on 11-2), 13-1, all VHF, (and as of today ION on 31-1 which was breaking up over the weekend, is fine as well). I also get the usual NYC UHF channels over the air, CBS, NBC etc. I think it was worth the small investment. Before I couldn't get all of these at the same time. I even get Retro on 42-7 though I don't know what's playing on it since my Tivo has no information.
roseha is offline
post #18345 of 18360 Old 12-29-2015, 08:35 AM
ALP
ALP's Avatar
Quoted: 56 Post(s)
Does anyone here have any insight into why all of the major college football bowl games are being carried in ESPN instead of the national broadcast networks (ABC, CBS, NBC and Fox)? Did ESPN out bid the networks or what??
Tony Plachy
ALP is offline
post #18346 of 18360 Old 12-30-2015, 01:15 AM
StudioTech's Avatar
3 years ago.
http://www.si.com/si-wire/2012/11/21...otball-playoff
http://www.cbssports.com/collegefoot...tball-playoffs
StudioTech is offline
post #18347 of 18360 Old 12-30-2015, 07:17 AM
ALP
ALP's Avatar
Quoted: 56 Post(s)
Thanks for the input, this really sucks for OTA viewers. I guess the major networks just weren't willing to pony up that kind of money.
Tony Plachy
ALP is offline
post #18348 of 18360 Old 12-31-2015, 02:11 PM
Liked: 0
Out of curiosity how many 720p subchannels could you fit on one UHF channel?
post #18349 of 18360 Old 01-14-2016, 07:30 AM
Liked: 0
WCBS-TV Moving to 1 World Trade Center
Looks like WCBS-TV will be moving over to 1 World Trade Center.
Broadcasting 1702 feet above ground should really help improve reception, unless you're in Connecticut of course
http://fccinfo.com/CMDProEngine.php?...Number=1250423
post #18350 of 18360 Old 01-14-2016, 04:48 PM
reddice's Avatar
Quoted: 498 Post(s)
Liked: 104
About time. It is a start. I really hope channel 31 and 41 move to 1WTC. Right now channel 31 on the ESB has a horrible signal. I can get LP stations stronger.
reddice is offline
post #18351 of 18360 Old 01-15-2016, 04:24 PM
roseha's Avatar
Quoted: 16 Post(s)
I read the link, thanks but did it say anywhere when CBS would make the move? For some reason it occasionally starts to break up on me, which is strange, since it's a major network and I live in midtown Manhattan.
roseha is offline
post #18352 of 18360 Old 01-16-2016, 07:22 AM
LenL's Avatar
Quoted: 196 Post(s)
Liked: 189
I think you are way too optimistic and are reading much too much into this. Doing an internet search I could not find anything supporting any plans to broadcast from 1WTC anytime in the future by any TV Station.
Besides that there is no way of knowing if this would improve or impact your current TV viewing. It is naïve to assume the move would improve reception.
LenL is offline
post #18353 of 18360 Old 01-24-2016, 07:31 AM
LenL's Avatar
Quoted: 196 Post(s)
Liked: 189
I may have been the exception but I was amazed at how good reception was during the storm on Sat. No issues at all.
LenL is offline
post #18354 of 18360 Old 01-24-2016, 08:32 PM
unsmiley's Avatar
Quoted: 22 Post(s)
Same here -- no reception problems during the storm.
unsmiley is offline
post #18355 of 18360 Old 01-24-2016, 08:34 PM
unsmiley's Avatar
Quoted: 22 Post(s)
unsmiley is offline
post #18356 of 18360 Old 01-28-2016, 01:13 PM
cnsf's Avatar
I live out in Northern Westchester and am pulling in all the UHF channels with no problem (WCBS, WNBC, WNYW, WWOR). I tried various VHF antennas with no luck at all to get the other three big networks (WABC, WPIX and WNET).
Any idea if/when the VHF-Hi networks in NYC will move to UHF?
cnsf is offline
post #18357 of 18360 Old 01-28-2016, 02:18 PM
mets18's Avatar
It's actually more likely that you will see UHF stations move to VHF after the spectrum auctions. The UHF frequencies are more valuable to the wireless companies.
mets18 is offline
post #18358 of 18360 Old 02-01-2016, 12:43 PM
Quoted: 131 Post(s)
Liked: 8
most if not all vhf hi channel space is allready taken.
I dont see any uhf station auctioning off here in nyc.
uhfyagi is offline
post #18359 of 18360 Old 02-06-2016, 03:18 PM
NYC10033's Avatar
I'm in Manhattan by the George Washington Bridge and I also no longer get WABC, WPIX or WNET. But I do get WOR. 9-* with an indoor gold bowtie antenna. I lost WABC/WPIC/WNET 1+ years ago.
Anyone know if channel 4 or other stations drop their transmit power after 12AM??? Can't blame the leaves. I also notice that if the picture freezes, sometimes I hear a plane/helicopter flying nearby. When it's gone, the picture returns.
Several times I'm watching a show on 4-2 after 12AM and all of a sudden the picture freezes and goes blank - going in and out.
NYC10033 is offline
post #18360 of 18360 Old Today, 03:09 PM
nyctveng's Avatar
Quoted: 103 Post(s)
Liked: 65
There is regular maintenance at ESB from various stations that have transmitters that occur after 12am. Some reduce power or transmit from a backup site. I believe WNBC has a backup in West Orange, NJ.
nyctveng is online now
