New York, NY - OTA - Page 625 - AVS Forum | Home Theater Discussions And Reviews
 107Likes
post #18721 of 18744 Old 09-27-2017, 05:39 PM
ALP
ALP's Avatar
Quoted: 86 Post(s)
Liked: 27
Originally Posted by dreamingned View Post
_______
Thank you, I will use only a winegard LNA-200. I misunderstood the purpose of the distribution amp. I live at the bottom of a sheer 50' rock cliff so my 70' antenna is only 20' over the top of the cliff despite being on top of a 5 story Bldg. I'm in the South Bronx.
I realize I am probably misunderstanding what you are posting, but are you telling us you have a 70' mast for you antenna?
Tony Plachy
ALP is offline
post #18722 of 18744 Old 09-27-2017, 11:25 PM
foxycat's Avatar
Quoted: 12 Post(s)
I'll swap my WPIX (ch 11) and my WNYW (ch 5) for a WLIW from anyone on Long Island. I'll throw in
WWORD(ch 9) as a freebie.
I'm just checking in after a while away. Will reception from the WTC be better than from ESB?
foxycat is offline
post #18723 of 18744 Old 09-28-2017, 08:10 AM
d3193's Avatar
Quoted: 61 Post(s)
Liked: 49
For some people, yes. For some people, no.
d3193 is offline
post #18724 of 18744 Old 09-28-2017, 05:56 PM
Liked: 0
No. I live in 5 story walk-up. Bldg is 65' tall and my antenna is about 10' off the roof. It also holds my ham radio antenna 5BTV with two 67' dipole/radials.
I find conflicting input voltage reported for the Winegard LNA-200. If the later models are power from a USB powered injector it's only 4vdc but the older ones are 15-18vdc. Any way to distinguish between them ?
dreamingned is offline
post #18725 of 18744 Old 09-29-2017, 05:47 AM
ProjectSHO89's Avatar
Quoted: 288 Post(s)
Liked: 131
The LNA200 has ALWAYS used a USB power supply, it has never used anything else since it came out a few years ago (mid 2013?).
ProjectSHO89 is offline
post #18726 of 18744 Old 09-30-2017, 06:36 AM
Liked: 0
I just found the reviews on TVfool (http://forum.tvfool.com/showthread.php?t=13530) that show the RCA TVPRAMP1R performs better than the LNA200. Mr. Higgins' review was thorough and convinced me to go with the RCA instead. I hope he is a real person and not fictitious shill working for RCA.
Thank you for your replies gentlemen. I learned a lot about TV antennas from the many Posted write-ups here. Nice website.
neil
post #18727 of 18744 Old 10-07-2017, 05:24 PM
garence's Avatar
Has anyone here ever run into a situation where some channel signals became weak all of the sudden, for no apparent reason?
This just happened with me, affecting WWOR-TV (channel 9.1) and H&I Heroes & Icons (channel 9.4). Yesterday, my Sony TV tuner (1080p) was unable to pick up anything from those stations. Signal strength 0. However, my DVR tuner could pick up the stations (it is unfortunately limited to 480p). Most other stations were fine on my TV. I swapped antennas and no difference. However, I then tried a 3rd antenna small and convenient enough to operate by hand and move around. Fiddling with the dial on it I was able to get 9.1 and 9.4, but at about 50% weaker and only from a very specific position.
So my conclusion was that some very weird problem happened with my TV tuner and since it's an older TV, it's not fixable.
But then the next day (today), I discovered the stations were back!
I don't watch a lot of OTA TV, but I'm wondering if periodically stations may momentarily significantly reduce the signal for a while.
garence is offline
post #18728 of 18744 Old 10-08-2017, 01:56 AM
Trip in VA's Avatar
Quoted: 860 Post(s)
Liked: 255
Send a message via AIM to Trip in VA
If a station has an equipment problem, they might reduce power or move to a backup facility for a short time. And, indeed, my auto-scanner indicates something was up with the WWOR signal recently and is now back to normal.
https://www.rabbitears.info/tvdx/sig...tuner1/WWOR-TV
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #18729 of 18744 Old 10-08-2017, 02:06 PM
garence's Avatar
- Trip
Thank you very much, Trip. I didn't know about RabbitEars.info -- terrific resource!
I do realize weather can be a factor in signal strength, but I hadn't seen anything dramatic. I'm happy to know it was likely their transmitter.
I've browsed the site a bit... and have a question. What menu pathway do you follow in order to get the signal graphs for any station?
DrDon likes this.
garence is offline
post #18730 of 18744 Old 10-10-2017, 12:08 PM
Quoted: 283 Post(s)
Liked: 276
Speaking of wwor
https://www.tmonews.com/2017/10/t-mo...york-city/amp/
Tmo pushing to get their 600mhz up.
reddice likes this.
Sony A1E OLED 4K Ultra H
FS Gen2 Nvidia shield TV 2017 version
EF9500 is offline
post #18731 of 18744 Old 10-10-2017, 03:19 PM
reddice's Avatar
Quoted: 604 Post(s)
Liked: 118
Good. WWOR is a waste anyway.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-140 K26ARM USB VPN-64K.
My Primary Streaming Devices: Apple TV (2015), Roku Premiere.
Cats are the best pets.
reddice is offline
post #18732 of 18744 Old 10-13-2017, 06:14 AM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 298 Post(s)
Liked: 251
LenL is offline
post #18733 of 18744 Old 10-13-2017, 06:24 AM
ALP
ALP's Avatar
Quoted: 86 Post(s)
Liked: 27
Is anyone having extremely intermittent signal strength problems with CBS? In the last few days channel 2.1 has been dropping out even though the weather has been basically good (heavy rain will cause some channels to drop out for me). I also notice slight intermittent reception on WPIX (Channel 11) but the main problem is CBS.
Tony Plachy
ALP is offline
post #18734 of 18744 Old 10-13-2017, 10:59 AM
Quoted: 34 Post(s)
Liked: 9
Well I get cbs on Long Island from the antenna out here and yesterday i couldn't get a signal at all in the daytime. Something must have been up.
Jay Stone is offline
post #18735 of 18744 Old 10-13-2017, 04:14 PM
ALP
ALP's Avatar
Quoted: 86 Post(s)
Liked: 27
Can anyone suggest how I (or we) can find out what is going on with CBS?:
Tony Plachy
ALP is offline
post #18736 of 18744 Old 10-14-2017, 05:53 AM
LenL's Avatar
Quoted: 298 Post(s)
Liked: 251
Alp,
You best bet is to send a private message to TRIP if he doesn't see your comments and respond on this forum.
LenL is offline
post #18737 of 18744 Old 10-14-2017, 06:05 AM
Trip in VA's Avatar
Quoted: 860 Post(s)
Liked: 255
I didn't realize the message was directed at me. The auto-scanner doesn't say anything's up with WCBS, but then, it only scans long enough to log the signal strength and then moves on, so tiny drops are unlikely to be caught.
- Trip
N4MJC
RabbitEars
post #18738 of 18744 Old 10-14-2017, 07:19 AM
ALP
ALP's Avatar
Quoted: 86 Post(s)
Liked: 27
- Trip
Trip and Len, Thanks for the input. Whatever is going on at CBS is very erratic. Yesterday it was almost unwatchable, this morning it is crystal clear.
Tony Plachy
ALP is offline
post #18739 of 18744 Old 10-14-2017, 10:25 AM
LenL's Avatar
Quoted: 298 Post(s)
Liked: 251
- Trip
Actually it was not directed at you but I know you are monitoring the NY broadcasters from your aunts and you have the equipment to let us know if there is an issue impacting us. Well maybe not all the time but you have helped us with blips that have occurred now and then.
LenL is offline
post #18740 of 18744 Old 10-14-2017, 10:27 AM
LenL's Avatar
Quoted: 298 Post(s)
Liked: 251
I typically watch a lot of CBS but mostly recorded on my DVR+ so if there is a problem I may not see it for a week or more later!
LenL is offline
post #18741 of 18744 Old 10-14-2017, 10:30 AM
LenL's Avatar
Quoted: 298 Post(s)
Liked: 251
I have a spare used CM4228 outdoor antenna that I am willing to part with dirt cheap. It does a great job for NY reception. Anyone interested just send me a private message. Do not post a reply on this forum.
LenL is offline
post #18742 of 18744 Old 10-14-2017, 04:04 PM
Trip in VA's Avatar
Quoted: 860 Post(s)
Liked: 255
Here's the link, so anyone who doesn't already have it can see it: https://m.rabbitears.info/index.php?...10343612&tno=1
Clicking the callsign will show the signal graph.
- Trip
N4MJC
RabbitEars
post #18743 of 18744 Old 10-15-2017, 12:18 PM
LenL's Avatar
Quoted: 298 Post(s)
Liked: 251
- Trip
I have to ask. Curr SS is for current signal strength?
What is Curr MER? I could not figure that one out and why is was so different from Curr SS.
LenL is offline
post #18744 of 18744 Old 10-15-2017, 12:39 PM
Trip in VA's Avatar
Quoted: 860 Post(s)
Liked: 255
Yes (re: curr SS).
MER = Modulation Error Ratio. It's another term for SNR. In many places, you'll find it called "signal quality."
- Trip
N4MJC
RabbitEars
