Washington, DC / Baltimore, MD - HDTV - Page 172 - AVS Forum | Home Theater Discussions And Reviews
post #5131 of 8537 Old 09-23-2004, 02:22 PM
steeler's Avatar
Originally posted by jamesavery22
Doh yeah dont own my roof...
Do have a deck I can mount it on though...
roof- no
deck-yes
Are there any trees or buildings blocking your view of 110-120 degrees from your deck? If so you might be in trouble.
steeler is offline
post #5132 of 8537 Old 09-23-2004, 02:23 PM - Thread Starter
CycloneGT's Avatar
Quoted: 69 Post(s)
Liked: 45
You can get UPN24? Did they do HD last year for enterprise? I think UPN20 did, but I'm not sure about that either.
CycloneGT is offline
post #5133 of 8537 Old 09-23-2004, 02:26 PM
jamesavery22's Avatar
Originally posted by steeler
roof- no
deck-yes
Is there any trees or buildings blocking your view of 110-120 degrees from you deck? If so you might be in trouble.
Actually I might be the luckiest guy in the world. From looking at that map and from just seeing the back of my building there is a straight shot from the back of my deck all the way down 7 (East = down). Its the only unobstructed view I have. I'll get a compass and double check.
jamesavery22 is offline
post #5134 of 8537 Old 09-23-2004, 02:29 PM
AcuraCL's Avatar
I get 24.1 loud and clear (one of my few Baltimores).
Enterprise was not HD when I watched it last season, but it was a wee bit better Pic quality than WWOR over Dish Network.
Edit: HD Schedule here:
http://www.avsforum.com/avs-vb/showt...hreadid=450005
AcuraCL is offline
post #5135 of 8537 Old 09-23-2004, 02:30 PM
Scott R. Scherr's Avatar
Channel 24 is not HD yet. I have been able to get 24 since they went on the air digitally without a problem, but there is nothing to watch. They use a channel 11 type stretch mode.
Scott
Scott R. Scherr is offline
post #5136 of 8537 Old 09-23-2004, 02:39 PM
steeler's Avatar
Originally posted by Philip Hamm
jamesavery22,
Check at www.antennaweb.org before calling Fairfax Antenna to see what you can get. You may be in a good strong reception area. You may get locals with a rabbit ears.
I'm in Loudoun County also and with a big Channel Master 4221A
I doubt rabbit ears are going to work from Sterling.....A (not that big) 4221 would probably be a much better choice.
steeler is offline
post #5137 of 8537 Old 09-23-2004, 03:58 PM
mikepinkerton's Avatar
I get locals just fine with a Silver Sensor on top of my a/v rack in my basement from Ashburn. Those in sterling should be able to do well without a full antenna mast
-Mike
mikepinkerton is offline
post #5138 of 8537 Old 09-23-2004, 04:22 PM
LarryC's Avatar
....You may get locals with a rabbit ears....
Rabbit ears (as the telescoping metal pole antennas are called) are typically associated with VHF reception, not UHF. Unless you use the circular UHF piece associated with the rabbit ears, it is unlikely that you would pick up any OTA UHF signals.
LarryC is offline
post #5139 of 8537 Old 09-23-2004, 04:30 PM
Stuggs's Avatar
TedE
Stuggs is offline
post #5140 of 8537 Old 09-23-2004, 04:32 PM
Stuggs's Avatar
TedE
Thhanks for the information about the seemingly widespread HD problem with Comcast. Did they give any timeline on fixing it?
I gradually lost channels as you did - they went in groups, getting worse over time until I lost all HD. Its taken place over the past month
Stuggs is offline
post #5141 of 8537 Old 09-23-2004, 05:13 PM
Hrmmm well I have a straight shot out about 400 - 500 yards in the right direction but then all I can see is trees =(
So am I SOL?
post #5142 of 8537 Old 09-23-2004, 06:06 PM
steeler's Avatar
So am I SOL?
Maybe, maybe not. You have two choices.
1) Buy an antenna and try hooking it up yourself. The only way to know what channels you can get is to try)
2) Write a check
steeler is offline
post #5143 of 8537 Old 09-23-2004, 07:47 PM
quik_2_win's Avatar
Hi- new to the forums here. I had many of the same concerns about reception when I considered going to OTA HDTV that many people seem to have. To consider the cost of the hardware and the possibility of poor reception is troubling. I will share my experience here in that others might find it helpful and/or encouraging. I live in Prince William county, approx 22-24 miles from most of the transmission towers in the area (according to antennaweb.org). This past Mon. (Sept 20), I installed a Samsung t351 with a Terk TV55. The Terk is mounted indoors on the second floor, attached via wall-mount, facing nearly due-North (NNE would have been ideal..). Without any antenna manipulation I can receive:
4.1
5.1
7.1/.2
9.1/.2
26.1/.2/.3/.4
30.1/.2/.3/,4
50.1
54.1/54.2 were both working last night, both are down at this time
Needless to say, that's alot of content and we are all very pleased! We won't even watch Comcast cable anymore- can't stand the IQ
quik_2_win is offline
post #5144 of 8537 Old 09-23-2004, 08:23 PM
Flyer1's Avatar
I use a pair of rabbit ears to pick up UHF OTA HD. It has both the telescoping poles and a circular piece, so for some they do work. Although the best would be an antenna on the roof. However, the rabbit ears will be going away shortly, I got a outdoor antenna (thanks to Bruce!!!) and will be having someone come out an install it soon.
Flyer1 is offline
post #5145 of 8537 Old 09-23-2004, 08:44 PM
llogan's Avatar
Originally posted by sasha_j
"Lost" on WMAR-DT, BLEW US AWAY! Amazing pic, amazing 5.1. This is what quality OTA HD is all about! I will be recording and probably archiving the entire series. Very impressive. Thanks ABC!
I wish Tivo already had that 'share your recording with 9 of your friends' functionality set up. I could really use it as I MISSED last night's premiere of Lost. Girlfriend was supposed to set up the Season Pass...and didn't. DAMN. Of course I'll never see that functionality since I only have DirecTivos and DirecTV will never go for the whole sharing thing. Anybody record it to a VCR for me? I'll pay ya $20 :)
5 Pioneer 50" Plasmas
20 LCDs
3 Motorized Plasma Mounts - K2 X-ARM
10+ HD DirecTV DVRs
7 Xboxes and 6 Xbox 360s
2 Buttkickers
4 Sling Boxes (2 Pros, 2 Classics)
1 Roku Netflix unit
llogan is offline
post #5146 of 8537 Old 09-23-2004, 09:01 PM
UHD Addict
aaronwt's Avatar
Quoted: 6049 Post(s)
Liked: 3750
What's a VCR?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #5147 of 8537 Old 09-23-2004, 09:02 PM - Thread Starter
CycloneGT's Avatar
Quoted: 69 Post(s)
Liked: 45
Welcome Quik, Looks like you are in good shape.
You got me with that 4.2. The rest look like the entire DC lineup.
post #5148 of 8537 Old 09-23-2004, 09:10 PM
UHD Addict
aaronwt's Avatar
Liked: 3750
I just read that for those who missed Ep1 &2, Saturday Oct.2 they will be running Ep1 & Ep2 from 8-10pm on ABC.
I think I'll fire up my HiPix to archive it.
aaronwt is offline
post #5149 of 8537 Old 09-23-2004, 09:18 PM
quik_2_win's Avatar
Welcome...You got me with that 4.2.
Thanks Cyclone! My mistake- there is no 4.2 :rolleyes:
I am new to this, so does anyone know how the NFL on FOX is being broadcast on 5.1? I saw the game last weekend (before the HD tuner) was stated as being 720p-
post #5150 of 8537 Old 09-23-2004, 11:03 PM - Thread Starter
CycloneGT's Avatar
Quoted: 69 Post(s)
Liked: 45
You'll find the HDTV NFL games on 5.1, 9.2, and 7.1. The 7.1 (Monday Night Football) won't be in DD5.1. WJLA-DT will be adding DD5.1 later this year.
post #5151 of 8537 Old 09-23-2004, 11:39 PM
Eh fine I'll just try it :D
What antenna should I get? Will get an amp also, any suggestions?
post #5152 of 8537 Old 09-24-2004, 04:51 AM
steeler's Avatar
Check this previous post for some suggestions.
steeler is offline
post #5153 of 8537 Old 09-24-2004, 06:09 AM
EricRobins's Avatar
I started watching ER on NBCE (D*) last night, but the lip synch issues were too much to handle. I was actually getting dizzy. So after about 30 mins, I switched to 4.1. However, I did not realize that 4.1 was NOT DD5.1. Any news about 4.1 going DD5.1? Anyone know anything about the "kungfu movie effect" on NBCE?
EricRobins is offline
post #5154 of 8537 Old 09-24-2004, 06:23 AM
UHD Addict
aaronwt's Avatar
Liked: 3750
It wasn't too bad for me, although I did have to adjust the delay on my receiver another 25ms to compensate.
aaronwt is offline
post #5155 of 8537 Old 09-24-2004, 06:26 AM
mallu2u's Avatar
But the game is in HD, right? In that case, I shall watch the game on 2.1, if they are showing it, since they might show in 5.1
mallu2u is offline
post #5156 of 8537 Old 09-24-2004, 07:21 AM
dg28's Avatar
WMARDT (2-1) broadcasts MNF in HD and DD5.1. Yes, nearly all the games on Fox this year will be HD. 2-3 per week on CBS.
dg28 is offline
post #5157 of 8537 Old 09-24-2004, 07:52 AM
sasha_j's Avatar
As others have pointed out, the pilot will be shown in a repeat coming up soon.
I think you also use a MyHD card right? If so, I have the pilot in ".ts" file format if you want to come by with a portable hard drive for a data dump. I "shudder..." don't use VHS anymore....
For those planning to record future episodes of "Lost", make sure to point your antennas to Baltimore.
In the DC/Balt area, anything on ABC worth watching in the first place should ALWAYS be viewed or recorded via WMAR-DT. WJLA-DT often "forgets" to throw the HD switch and does not bother to use a 5.1 encoder.
The difference is night and day. WMAR-DT has earned my respect and loyalty.
Sasha Jevtich
sasha_j is offline
post #5158 of 8537 Old 09-24-2004, 08:30 AM
UHD Addict
aaronwt's Avatar
Liked: 3750
WJLA has been pretty good lately with showing programs in HD. At least the few that I have watched over the last several weeks. Hopefully they will have DD5.1 soon though. I can't usually get WMAR unless it's raining.
aaronwt is offline
post #5159 of 8537 Old 09-24-2004, 08:50 AM
sasha_j's Avatar
From reading tons of sasha's posts Ive been persuaded to go OTA for TV.
Im in Sterling right off of Dranesville road.
Also from reading too many of his post's I believe I should just give Fairfax Antenna a call.
My question is what do I need to tell them?
They'll come out and figure out what channels I can get but minus what room I want them to route the cable to is there anything else I need to ask?
I just want it to go to one room so I dont need any distribution setup I dont believe. How much might all this cost me?
I live in a condo but am on the top floor so they can mount everything on my roof.
Hi and thanks for your kind words. You should know however that pretty much all of my comments regarding the benefits of OTA antenna installation and use were pretty much aimed at single family home and town home owners, folks that own their own roof, and thus, have great umbrella protection from OTARD.
Apartment and condo dwellers are in a totally different situation, as they typically don't own their roof and thus have more limits.
I would urge you to join your condo board and if applicable, have them consider hiring a pro like AltAntMike to design and install a master antenna system (MATV).
Otherwise you will probably be limited to placing an antenna on your balcony or using an indoor antenna.
Unfortunately, folks that own their own roofs have the most leeway and freedom with regards to antenna use and placement.
Sasha Jevtich
sasha_j is offline
post #5160 of 8537 Old 09-24-2004, 09:36 AM
EricRobins's Avatar
That is of course, unless they are married!! :p
Closed Thread Local HDTV Info and Reception
