Toledo, OH - HDTV - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #571 of 1983 Old 01-04-2007, 08:15 PM
John Cage's Avatar
Originally Posted by myboat245x View Post
I was able to scan and found quite a few local HD channels. However the screen size is small. I can use the remote to change it the aspect to full/just, but it is kind of incovenient. Is there a way to keep a channel at the aspect size I want?
I have a Panny 50PX600U.
thanks
Take a look during prime time programs and make sure you are still geting a small picture. During most of the day, local HD channels will still have black bars on the left and right when they aren't showing HD content.
John Cage is offline
post #572 of 1983 Old 01-04-2007, 11:13 PM
Star56's Avatar
Location: In my armed redoubt deep in the mountains of northern Ohio
Quoted: 109 Post(s)
Liked: 73
Originally Posted by John Cage View Post
The firewire port on the box just puts out the audio and video from whatever the box it tuned to, and it encrypts most cable or pay channels so they can't be recorded (my quick search didn't yield any quick workaround for the encryption but it could exist)..
There is NO encryption applied to the signal coming out of the firewire port of the Moto 6412 or 6200.
This includes the "pay channels" e.g. HBOHD, ShowtimeHD.....StarzHD.
42" in the dining room.50" in the bedroom 80" in the living room 65" in the family room 70" in the family room 106" in the family room "There is another system" Video Modes: SDTV-EDTV-XGA-HDTV-4K
Star56 is offline
post #573 of 1983 Old 01-05-2007, 02:00 PM
myboat245x's Avatar
Thanks. I guess I will have to live with change the size size to zoom if I want to get rid of the bars.
Another question...do you know how I would enter channel 11-1 in my remote? 111 does not work.
Thanks again.
myboat245x is offline
post #574 of 1983 Old 01-06-2007, 07:42 AM
John Cage's Avatar
Wrong.
5C encryption is used for pay channels coming out of the firewire port. This is not an issue when connecting directly to a display, but if you attempt to record the stream onto a pc using something like capDVHS, it will not record from pay channels.
post #575 of 1983 Old 01-06-2007, 04:22 PM
daberning's Avatar
Originally Posted by KentStater72 View Post
Where are you? What equipment are you using?
I'm in Monclova and I'm using a Terk HDTVo. I have the antenna mounted on a chain link fence post 5 1/2' off the ground. I know it would be better to have it mounted up on the roof, but all of the channels were coming in very strong the day I was installing the antenna, and mounting it low to the ground worked better for running the coax.
Usually internal tuner 1 fluctuates between a signal strength of the 70s all the way down to the 40s on 24.1, 24.2, and 24.3 and tuner 2 will be in the mid 90s lately. A few days ago, both tuners were steady at 95, just like the rest of the channels. Today, tuner 1 is back to having low signal strength and tuner 2 is at 94. All of the other channels have strong and roughly identical signal strengths on tuner 1 and 2, so I don't think there's anything wrong with my HR10-250.
Just wondering if anyone else is having the same issue with one tuner having a much lower and fluctuating signal strength???
daberning is offline
post #576 of 1983 Old 01-07-2007, 04:58 PM
APorter's Avatar
Quoted: 73 Post(s)
Buckeye Cable has HD boxes back in stock.
Family Room - Samsung JS8000 Denon X1200 NHT SuperZero and SuperCenter Front Speaker Stage Athena Micra Back Surrounds and Front Heights (5.1.2)
Media/Bar Room - Epson Home Cinema 8100 102" Screen Denon 2310ci
APorter is offline
post #577 of 1983 Old 01-08-2007, 05:05 PM
nimchimpski20's Avatar
Hey, I've been having problems with my motorola 6412. I went today and traded it in and the guy at Buckeye gave me the new Motorola 3416.
It's just as wide and looks the same (without the inputs on the front) as the 6412, but it isn't as and fits much nicer on my A/V stand.
It has a larger hard drive, Buckeye said 30 hours standard or 10 hours HD programming.
It seems to work a little faster, not as long a pause when switching to VOD and between the tuners.
The remote also worked fine with it, I already had my B button reprogrammed for 30 sec. skip and it still worked with the new box.
They seemed to fix all the problems that I had with the old 6412 on this new 3416.
nimchimpski20 is offline
post #578 of 1983 Old 01-09-2007, 12:01 AM
Star56's Avatar
Quoted: 109 Post(s)
Liked: 73
Does the Moto 3416 have firewire ports? I assume it does.
Also...Nimchimpski......I assume you work in or are familiar with the field of experimental psychology? The name is a dead give away.
Star56 is offline
post #579 of 1983 Old 01-09-2007, 07:25 AM
The Moto 3416 has the following:
No - Cable Card Slot
No - RCA in (at all)
2 - Firewire ports
1 - USB (in back)
1 - SATA
1 - HDMI
1 - Component out
1 - S-video out
1 - Digital Optical out
1 - SPDIF
1 - RF in
1 - RF out
1 - Ethernet port
Still haven't figured out the size of the hard drive, but I hardly ever filled the 6412 up so I'm not really concerned with that. One other thing is I have it hooked to my tv via HDMI, then the tv is hooked to the receiver via Digital Optical, with the 3416 I have to have the volume set kind of a lot higher than with the 6412.
And I know less about psychology than just about anything. Why you ask?
post #580 of 1983 Old 01-09-2007, 08:56 AM
jubjub75's Avatar
Can you double check that? That's about half of what the 6412 does, which has a 120GB drive. I don't think anyone makes 60GB drives anymore...
jubjub75 is offline
post #581 of 1983 Old 01-09-2007, 10:15 AM
Let me rephrase that.
An additional 30 hours standard programming..or 10 hours HD programming.
It has 160 GB hard drive...40 gigs more than the 6412.
If you've had any problems with your 6412 I'd definitely go exchange for this smaller, nicer 3416.
post #582 of 1983 Old 01-09-2007, 10:33 AM
HDNLUVINIT's Avatar
Sorry if this question was already answered but...I have a new Panasonic that is capable of using a cablecard. Outside of spending $100 for a Buckeye guy to insert the card in the TV and pay about $3.50/month, what will this card get me?
Access to Buckeye's Digital Programming, HD Plus Pak, Premium channels if you are so inclined. I just bought a new Panasonic also and was adamant about not having a High Def cable box - which you can't get from Buckeye right now anyway due to a claimed nationwide shortage. I must admit that I was not real happy about the $100 CableCard installation charge - especially since it was something I could have done myself - and, actually ended up doing. I heard the installer on the phone with someone at Buckeye - it was obvious this was the first CableCard installation for both of them. He could not get it working and finally had to leave to move on to the next appointment. I got it working later that day via a phone conversation with a Buckeye tech person. So, what did I pay the $100 for??? And, for the record, the monthly CableCard fee is $6.35. Still beats having to deal with a cable box.
HDNLUVINIT is offline
post #583 of 1983 Old 01-09-2007, 10:44 AM
HDNLUVINIT's Avatar
Originally Posted by videditor View Post
INHD2 should be gone now. BCS TVGuide has refreshed and listings are gone as well as the channel.
Videditor, you appear to have substantial knowledge of BCS and the TV Guide feature. I hope you won't mind a question: I have a new Panasonic with a CableCard and the TV Guide service. It has been connected to Buckeye's system since 12-26-06. Everything is correct in the TV Guide setup but it still does not show some of the HD channels at the top end such as 660. Some of the lower channels are missing also. It is not a matter of having them turned "on" or "off" in the guide settings - they don't show up at all - anywhere. Any ideas?
post #584 of 1983 Old 01-09-2007, 11:16 AM
HDNLUVINIT's Avatar
Not according to Buckeye. I just called and was told a "guesstimate" is end of January.
post #585 of 1983 Old 01-09-2007, 03:44 PM
myboat245x's Avatar
I have basic cable and my Panny 50PX600U has the TV Guide feature. However, ever so often I look the guide as it say "no listing" and when I check the progress it says is is updating. Is this normal? Do you lose your TV Guide?
Jim
post #586 of 1983 Old 01-09-2007, 05:38 PM
Star56's Avatar
Quoted: 109 Post(s)
Liked: 73
Nimchimpsy was the name given by a famous psychologist to a chimp that was used in a set of experiments designed to test Noam Chomsky's theory regarding human language.
Nimchimpsky was a satiric version of Noam Chomsky.
Star56 is offline
post #587 of 1983 Old 01-09-2007, 06:12 PM
videditor's Avatar
I'll look into that one... I have no experience with the cable cards... but I know who to ask.
VE -
videditor is offline
post #588 of 1983 Old 01-10-2007, 03:27 AM
HDNLUVINIT's Avatar
VE -
Thank you!
post #589 of 1983 Old 01-10-2007, 09:44 AM
HDNLUVINIT's Avatar
Jim
Yes, I have experienced that also.
post #590 of 1983 Old 01-10-2007, 03:23 PM
MV400's Avatar
CES2007: Dish to Offer its HD DVR for Free
January 10, 2007
EchoStar Communications said this week its Dish Network will offer new satellite subscribers its HD ViP622 DVR receiver for free as part of Dish's Digital Home Advantage Program.
According to the DBS provider, the HD DVR is the first satellite set-top box to be offered with no upfront costs to new subscribers. The DVR receiver can support two TV sets in separate rooms.
The HD ViP622 DVR was awarded an Editor's Choice and ranked "best in class" in the DVR category by online network CNET for its features and design (including what EchoStar said is "the only true 30-second [commercial] skip feature in the industry").
Wonder how good it looks....
MV400 is offline
post #591 of 1983 Old 01-11-2007, 05:14 AM
spektator's Avatar
The hard drive sizes in the Motorola set tops in noted in the last two digits. The 6412 has a 120G drive, the 3416 has a 160G drive. The 6xxx series from Motorola includes an analog tuner, the 3xxx series is all digital.
Spek
2 - Firewire ports
1 - USB (in back)
1 - SATA
1 - HDMI
1 - Component out
1 - S-video out
1 - SPDIF
1 - RF in
1 - RF out
1 - Ethernet port
spektator is offline
post #592 of 1983 Old 01-11-2007, 01:25 PM
APorter's Avatar
Quoted: 73 Post(s)
My mom had a new one delivered to her on Tuesday of this week. When we went to pick one up before X-Mas they were out.
APorter is offline
post #593 of 1983 Old 01-11-2007, 05:01 PM
SlumLord1701's Avatar
I just installed a Channel Master 4228 OTA antenna and 7777 pre-amp. I am getting an average signal strength of 80-86 but can't seem to get WNWO at all. I have tried multiple times to scan channels but no 24 in HD. I have looked through all the scaned channels. WNWO in standard def comes in. All others channels come in great. My tv is a Pioneer PDP5070HD I am located in Northwood near Owens College. I see that WNWO going out has happend before I am wondering if it has happened again?
SlumLord1701 is offline
post #594 of 1983 Old 01-12-2007, 03:22 AM
fullwave2's Avatar
A couple questions. Where did you install the antenna and did you also install a rotator? These antennas are very directional. I', not far from you and when I want to bring in WNWO HD I have to rotate the antenna a bit from where it was to pick up WTOL & WTVG. If you don't have a rotator you may have to play with the orientation a bit to get the best far all. Some may be compromised.
Also, I hope you were able to install the antenna on your roof. Any antenna out side is better than the best antenna in an attic.
fullwave2 is offline
post #595 of 1983 Old 01-12-2007, 07:03 AM
It is on the roof on a ten foot pole. I have not installed a rotator. That was gonna be my next try. I have played with the orientation but never seem to get WNWO. I'll keep trying till I get the rotator. Thanks
post #596 of 1983 Old 01-12-2007, 08:12 AM
fullwave2's Avatar
I'm sure you'll find the rotator will make a world of difference. Good luck.
post #597 of 1983 Old 01-15-2007, 03:36 PM
Josh00Si's Avatar
Just so everyone knows, I justed picked up a Dual Tuner HD with HDMI box from Buckeye today. They said they were first come first served.
Josh00Si is offline
post #598 of 1983 Old 01-15-2007, 03:44 PM
Marky_Mark896's Avatar
What model was it?
It's not just a hobby, it's an obsession...
Marky_Mark896 is offline
post #599 of 1983 Old 01-16-2007, 07:06 AM
HDNLUVINIT's Avatar
That's interesting. Buckeye called me last evening (I was on the waiting list for a high def box) and informed me all they had to offer was a high def DVR - for another five bucks a month - and that they HAD to come out to install it. I politely said no thanks to both. The extra five bucks a month is not a big deal - I just don't have a need for a high def DVR right now nor do I need them to come out and install it. I can handle that myself thanks. Heck, they charged me $100 for their tech to come out and install the CableCard in my new set and it still wasn't working when he left. Which of their satellite offices did you pick the box up from?
post #600 of 1983 Old 01-17-2007, 08:23 PM
videditor's Avatar
VE -
Jerry,
Still no word, I know my contact is busy testing out the new PACE boxes. Have not forgotten about you.
VE
