Boston, MA - OTA - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #451 of 11403 Old 10-26-2001, 12:54 PM
SUTTONHT's Avatar
Does anyone know which shows Bob is referring to? Will this be for all WBZ programming which is not HD from CBS? Which shows are the upconverts?
Sorry, but I'm still pretty green with my new HDTV and I tend to only watch the HD stuff OTA and go upstairs to watch non HD on cable with old 27 incher.
SuttonHT
To experience it this fully... is to have spent a lot of money !!!
SUTTONHT is offline
post #452 of 11403 Old 10-26-2001, 01:01 PM
jdkulp's Avatar
Originally posted by Bob Hess
At the risk of having lightning strike me, I am going to again raise the subject of 4:3 vs 14:9 vs 16:9 images for our upconverted progamming.
Well, I'll go on record and say I refuse to watch anything in the 14:9 format. It just plain looks aweful. If it is presented in that format, I'll switch over to the analog signal or the locals on dish.
If you're concered about burn in, I suggest one of:
1) Change the black sides to gray
2) Change the sides to logos much like you do for various sports. Have different logos for various programs so the logos don't get burned in.
3) Change to 480p broadcast for them so the user can do what they want.
That's my vote.
Daniel Kulp
jdkulp is offline
post #453 of 11403 Old 10-26-2001, 01:19 PM
steverobertson's Avatar
I am for keeping the way it was I have RPTV and the way the shows were comming in I had no concerns about burn in. My Toshiba TV allows me to switch the modes if need be to fill in the screen. I think that all of us want the best pq available and absoulutley don't want 14.9
steverobertson is offline
post #454 of 11403 Old 10-26-2001, 02:42 PM
Doug G's Avatar
Bob - I for one would like to see the OAR retained for upconverted programming, at least for now. Truth be told I only really have the hidef receiver on when I know there's some HD content on I want to watch, but I will watch the occassional upconverted program (like when my wife forces me to watch "Survivor!" before CSI on Thursday nights.)
IMO the whole stretch thing just plain stinks. The only kind of stretching I can even tolerate is the non-linear ("natural wide" as my Elite 510 calls it) where the middle 60% of the screen retains OAR and the remaining 20% of each side is gradually stretched to fill the screen with increasing scale. It does take some getting used to, and swapping between OAR and this format will quickly make anyone realize its not perfect, but it is watchable and avoids the "burn-in" issue. Matter of fact, this is how I watch all my analog source 4:3 programming (mostly cable) to avoid burn in. Others may disagree, but I think this is the only way to go if you want to do any kind of stretch. Other than that I'd really just prefer 4:3 with side bars. Unless someone's watching 80% of their content like this than I think the need to go to grey sidebars isn't really warranted, as they are a bit more distracting than black. (My TU-HDS20 uses grey bars when set to display 4:3 material on a 16:9, this is partially the reason I went with the "natural wide" mode.)
Also, I was partially incorrect on my previous post about 'BZ-DT. Although it does map to 4-1 and identify the station call letters properly, there's no actual programming info. So maybe the PSIP is only partially working. Glad to see you got one of these, hopefully it means things may get better for me soon!
Doug G is offline
post #455 of 11403 Old 10-26-2001, 02:49 PM
Benji's Avatar
Bob Hess: I've had my Mits 65" since last December and continually watch WBZ and WCVB digital (w/black bars) and when I am watching other non-HD stations I use the normal format (4:3 w/gray bars). I have no evidence of burn-in on what is considered one of the more notorious 'burn-in' models. I watch as much HD as I can, so the breakdown is roughly 50/50 between sidebars (black/gray) and HD. My vote is to leave WBZ as is. Thanks Bob!
Benji is offline
post #456 of 11403 Old 10-26-2001, 03:46 PM
mkingman's Avatar
The problem with 14:9 is that it not only distorts the OAR, it doesn't really fix the burn-in issue. There are still, albeit smaller, black bars on the sides. It's the worst of all potential "solutions".
The only way to "solve" the burn-in issue AND keep the OAR is to either:
a) broadcast 4:3 content inserted into a 16x9 frame w/ gray sidebars, like most RPTV's, set-top boxes, and video processors support.
OR
b) broadcast 4:3 content in 480i and put the control in the hands of the viewers. (480p doesn't work because many TVs incorrectly assume that 480p is 16:9 and lock into full mode).
I almost never watch 4:3 content via WBZ-DT. I switch to my cable feed and watch it analog so I can have gray bars (and my TiVo).
/Matt
mkingman is offline
post #457 of 11403 Old 10-26-2001, 03:53 PM
SPel699187@aol.com's Avatar
Bob:
I am so used to adjusting the aspect ratio every time I go to watch something now days, I have no opinion to offer.
Steve Pelchat
SPel699187@aol.com is offline
post #458 of 11403 Old 10-26-2001, 03:53 PM
Benji's Avatar
OR
/Matt
There is a third way: broadcast your local programming in 1080i HD! Then there is no problem. In all seriousness, I've viewed the new 'improved' WBZ-DT and still vote for 4:3 w/sidebars.
Benji is offline
post #459 of 11403 Old 10-26-2001, 04:18 PM
atmosfera's Avatar
Hello ! Can anybody suggest GOOD dish/OTA antenna installer/dealer in BOSTON ?
Thank you !
Andrey
(ex-systems engineer)
atmosfera is offline
post #460 of 11403 Old 10-26-2001, 04:22 PM
Benji's Avatar
Thank you !
Radio Shack
Benji is offline
post #461 of 11403 Old 10-26-2001, 08:02 PM
rudolpht's Avatar
At the risk of having lightning strike ....
Bob,
They are spinning up the lightning machine at the Museum of Science....
I went away to Florida for a few days and came back to Bizzaro world.
Hope we don't mess with success.
Tim
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #462 of 11403 Old 10-27-2001, 06:36 AM
Mike Emery's Avatar
Bob,
Re: broadcast AR of 4:3 material
Please please please.... Keep 4:3 as 4:3. Like has already been said, these in-between stetch modes are just pointless.
Anyone who is really concerned can change black fillers to grey in the menu of their receiver. My Dish 6000 does this, I believe the RCA does also.
Mike Emery is offline
post #463 of 11403 Old 10-27-2001, 06:52 AM
Soycrema's Avatar
Quoted: 117 Post(s)
Liked: 62
My vote goes to 4:3 in 16:9 mode, like NBC does here in Boston.
By the way Bob, I sent you a private message about CBS, did you get it?
Soycrema is offline
post #464 of 11403 Old 10-27-2001, 07:00 AM
JSteinberg's Avatar
I just tested my reception of Fox and received a signal of 25-47. Very eratic. Not consistent enough to maintain a picture.
They're not quite there yet.
JSteinberg is offline
post #465 of 11403 Old 10-27-2001, 07:10 AM
SteveV's Avatar
Bob,
PLEASE no 14:9! I vote for OAR--if I want to stretch the image I can do it myself.
Thanks -- Steve
SteveV is offline
post #466 of 11403 Old 10-27-2001, 07:14 AM
SteveV's Avatar
Same thing here. I was hoping to watch Dark Angel in 720P(????) last night but my 6000 refused to lock in the signal. Like you, my signal was bouncing all over the place.
What would be really COOL is if FOX could give us an update regarding what the hell is going on. And yes, I'm still waiting for a reply to the emails I sent them nearly 3 weeks ago
-- Steve
SteveV is offline
post #467 of 11403 Old 10-27-2001, 07:14 AM
JSteinberg's Avatar
Bob,
I vote for 4:3 in a 16:9 frame with gray bars or logos on the side. I am very concerned about burn-in on my Toshiba 56H80 projection TV, however, I can't stand watching the distorted images.
This is all about the best quality picture.
post #468 of 11403 Old 10-27-2001, 07:57 AM
MikeD's Avatar
WBZ has long been a proponent of retaining the 4:3 aspect ratio for our upconverted programming. As you also know, we can only do it in a 16:9 frame.
Bob,
It would be nice to send 4:3 in a 4:3 frame but it looks like you can only send a 16:9 frame.
In this case I prefer 14:9 in the 19:9 frame. I have a 16:9 direct view TV. 4:3 just looks so ugly after 19:9. The 14:9 is a good compromise with little clipping on top/bottom. The black border looks nice on my Sony 34xbr2 but if people are concern about burn-in, maybe you should try gray border so people can judge what it look like.
Thanks for all the hdtv. :-)
MikeD is offline
post #469 of 11403 Old 10-27-2001, 08:18 AM
MikeD's Avatar
My receiver can not change the black border. It can not change the view size when it is sent in a 16:9 frame.
I like the 14:9 frame because it is a good compromise. The 4:3 aspect ratio is retain and their is little clipping of the top/bottom.
Maybe wbz can try sending gray borders with with the 14:9.
MikeD
MikeD is offline
post #470 of 11403 Old 10-27-2001, 08:25 AM
eags's Avatar
I have had my RPTV HDTV for about a month now and while I believe the "Burn in" issue is a bit overstated (If you properly calibrate your set and avoid 4:3 images 100% of the time, there should be no concern about burn in), I nonetheless prefer the 16:9 stretch mode that WHDH employs. I know its not perfect but I just can't get used to seeing black or gray side bars. 14:9 looks terrible.
eags is offline
post #471 of 11403 Old 10-27-2001, 10:17 AM
CoffeeBreath's Avatar
I'm watching WFXT right now in Westford, and it's pretty stable at 57-60% signal strength. IIRC, I was getting about 70-75% a few weeks ago.
Dish 6000, attic-mounted antenna (previous owners left it!), WBZ is at about 85-90% right now.
BTW, is there any way to ask the Dish 6000 what format the current signal is in? I don't have an HD display yet, just using the svideo out (and even that is terrific!)...
CoffeeBreath is offline
post #472 of 11403 Old 10-27-2001, 04:26 PM
jeff43's Avatar
Quoted: 205 Post(s)
Liked: 111
Bob:
I was one of the few that wanted 14:9 during round one but later switched to agreeing on 4:3.
For side bars, can you place something similar to what CBS does during half time of college HD football games? I suppose huge CBS letters would be distracting to most but placing something, even a gray background, would help with the burn in issue.
It does seem to be kind of a waste to transmit black.
jeff43 is offline
post #473 of 11403 Old 10-27-2001, 06:40 PM
JOtteman's Avatar
Hi Guys,
Bob Hess
Director, Broadcast Operations/Engineering
WBZ-TV/WSBK-TV/WLWC-TV/WBZ-AM/WODS-FM
Bob! ! !
Please go back to 4:3. I always watch 4.1 when watching CBS even if it is not HD because the picture quality is much better than my satelite or antenna feed of analog 4. I don't worry about burn in on my Elite510 because I watch enough full screen to offset it. Please go back to 4:3 for all non-HD programing! The 14:9 is awful in my opion.
Thank you,
Jay
JOtteman is offline
post #474 of 11403 Old 10-27-2001, 06:45 PM
JOtteman's Avatar
-- Steve
Dark Angel was broadcast in 4:3 mode last night as was Pasadena after it. Fox must not be done with their upgrade or have changed their policy because usually these would be in 480P widescreen. I am getting a steady signal here in Framingham.
Jay
JOtteman is offline
post #475 of 11403 Old 10-28-2001, 05:45 AM
JSteinberg's Avatar
Success! With a little movement of my indoor antenna, I was able to watch the World Series last night with a strong signal. Signal range with my new antenna position was 75-87. Strong enough with my Toshiba receiver to have an uninterrupted picture.
post #476 of 11403 Old 10-28-2001, 06:45 AM
Bob Cupka's Avatar
Bob,
I too much prefer broadcasts be done in their OAR. Please go back to 4:3.
Bob Cupka is offline
post #477 of 11403 Old 10-28-2001, 08:29 AM
ismeltitudeltit's Avatar
Hi Guys,
Have at it......
Bob Hess
Bob, I think the best way to address the burn in problem is to use gray bars. I prefer the 4:3 image. I can always use either my receiver or TV to size the image the way I want (although you do a better job of it) but I can't get back to the original.
thanks.
ismeltitudeltit is offline
post #478 of 11403 Old 10-28-2001, 03:00 PM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
Bob:
Here in Pawtucket, I get Providence's CBS affiliate perfectly from the same antenna I have in my attic for the Boston digitals. Today I watched the Jets (and am now watching the Pats)on that station instead of WBZ. Until you go back to OAR, I will watch all the 4:3 stuff on Channel 12 in Providence.
SMK
RoyGBiv is offline
post #479 of 11403 Old 10-28-2001, 04:20 PM
Richard_P_Harvey's Avatar
O.K. Bob no lightning but please dump this nasty format now. Why take a step backwards...? Please remember you were instrumental in getting WCVB to dump the aweful 14:9 format they started with. I have had my Mit's RPTV for near two years now and the black bars with the 4:3 in a 16:9 frame made me nervous at first but I can say that so far there is NO screen burn at all. I find that normal viewing provides enough balance of full screen, black bars, gray bars etc. so that screen burn is not a problem.
I said many times that WBZ should consider gray bars OR ever changing colored logo bars to fill the space. I have never received a response to these repeated suggestions.
OAR is the only way to go and is all I will watch .... period
Hopelessly addicted to HDTV and lost deep in the woods of Charlton, MA - Rich
rharvey@at-com.com
Richard_P_Harvey is offline
post #480 of 11403 Old 10-28-2001, 04:53 PM
MikeD's Avatar
I'm new to this. What is OAR? It is not in the FAQ.
MikeD is offline
Displays
