Charleston, WV - HDTV - Page 130 - AVS Forum | Home Theater Discussions And Reviews
post #3871 of 3883 Old 12-08-2013, 05:43 AM
Nohoch's Avatar
H
Nohoch is offline
post #3872 of 3883 Old 12-21-2013, 10:59 AM
Nohoch's Avatar
Anybody in Huntingon reccomend a good attic mount option for me to get 11.1 and 8.1 from charleston i will post my tvfool results
I am getting good signal from 13.1 and 3.1 on cheap rabbit ears behind tv looking for an option to get all of the locals from the attic and then routed to bedrooms from there im still going through this thread for answers
Nohoch is offline
post #3873 of 3883 Old 12-21-2013, 01:59 PM
Nohoch's Avatar
So, I have read a little bit, and was looking into getting something from this list.
http://hdtv-antenna-review.toptenreviews.com/
Maybe some of you have had previous experience with some of them or had some advice on a combination of antenna + amplifier to get the right signal and then split out to the rooms. I am more interested in just having the locals rather than go directtv, comcast, or dish route for the moment.
I would appreciate any help, I am pretty competent on electronics and such, just haven't done much research on antennas specific.
I am leaning towards the Channel Master CM-3020 as it has a range of quadruple (100 miles ~ 26.4 miles) the charleston stations so I figured that would work well or is that just overkill and also the fear that I can get it installed in the attic because of its size of 8x13
Nohoch is offline
post #3874 of 3883 Old 12-21-2013, 06:06 PM
ProjectSHO89's Avatar
Quoted: 279 Post(s)
Liked: 130
Probably none off that list except, perhaps the 9032 or the 91XG. The CM3020 is a huge antenna with unneeded VHF elements. A number of the rest have amps that will likely overload.
Try an outdoor-mounted DB4e aimed due east. Your Fox and ABC stations will the really difficult ones to get, so aim the antenna at them. The rest should come in off-axis since they are all strong, including the lone VHF channel.
ProjectSHO89 is offline
post #3875 of 3883 Old 12-22-2013, 11:58 PM
Nohoch's Avatar
Thanks for your reply, even though this is according to the description a UHF receiver it will still pull the VHF channel? I was reading through this thread a little more and saw the posts of people in hurricane having a problem due to angles of the towers, but i opened the .kmz file of the tvfool signal strength for the area, and have a straight line drawn from my roof to the abc and fox towers, wsaz, and cbs would be slightly off angle, so if I catch your drift, point it straight at the abc/fox towers and it should pull everything?
Thanks for the response, I seemed to think this thread was dead, I may try this in an attic see what happens and then go from there to improve signal quality.
Nohoch is offline
post #3876 of 3883 Old 12-23-2013, 12:05 AM
Nohoch's Avatar
Here is the location, big arrow is where i need to shoot to get 8.1/11.1 and the small arrow I am getting from indoor cheap antenna perfect now
Still open to any suggestions, my wifes not to keen on putting an antenna on top of the roof, so I am trying to avoid that at all costs, however Im trying to figure out if it will be absolutely necessary for a rooftop mount.
Again, I really appreciate the response, alot better priced for the antenna and mount
Nohoch is offline
post #3877 of 3883 Old 02-26-2014, 08:35 PM
SGRSBSKIER's Avatar
Does anyone know when our CW will air Arrow and the Tomorrow People. There was a basketball game instead and the my guide doesn't show anything until next weeks new episodes.
UPDATE: If anyone else cares.
I found out after calling the number from the website that does our local CW they gave me another number then that number transferred me finally getting it.
So the Tri State CW, WQCW will show the 2/26 episodes of Arrow and The Tomorrow People on Saturday 3/1 at 8:00pm and 9:00pm
There are basketball games much earlier in the day so that could affect the start time.
SGRSBSKIER is offline
post #3878 of 3883 Old 08-22-2014, 08:54 AM
Liked: 0
Why not make a listing in 1st post of all channels Available in this and all other dma's OTA ?
ALSO, This should be listed as Huntington - Charleston WV ?
CA_LLS is offline
post #3879 of 3883 Old 11-09-2015, 04:30 PM
mvcg66b3r's Avatar
Quoted: 109 Post(s)
WSAZ 'Charleston Split' question
Does WSAZ still do the "Charleston Split" or has all news production moved to Huntington? The "Charleston Split" is when the station produces separate newscasts for Charleston on W16CE and Suddenlink cable. W16CE still broadcasts in analog per RabbitEars, there was a CP to convert to digital, but it expired in September.
http://www.wsaz.com/home/misc/Charle..._18322959.html
http://www.rabbitears.info/market.ph...callsign=W16CE
Sister station WQCW had a translator in Charleston which was sold off to DTV America. What might happen to W16CE?
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is offline
post #3880 of 3883 Old 03-12-2017, 02:20 PM
mvcg66b3r's Avatar
Quoted: 109 Post(s)
West Virginia Public Broadcasting Tries to Stave Off Budget Ax
It was noncommercial media’s version of “Defending Your Life” as Scott Finn, general manager of West Virginia Public Broadcasting, told the state's House Finance Committee this week that if the legislature zeroes out funding to WVPB, as proposed, it could be the first state to ever lose its public broadcasting network, radio and TV. "That's a first that you might not want to have," he said.
The current proposal by the governor is to eliminate the $4.6 million in state funding that represents about 45% of WVPB's total budget. Finn said that would also mean losing various matching federal grants.
In his presentation to the committee, Finn said that funding cut, if it meant not enough money to stay on the air, could also mean FCC fines and eventually losing their station licenses.
"If you have a house and you abandon that house and it burns down, you lose the value of the house," he told the finance committee in a presentation. "The state of West Virginia has built this house over the last 50 years. We ask that you don't burn it down."
http://www.broadcastingcable.com/new...dget-ax/163976
Back to the Charleston Split, with W16CE still in analog, do you think it may go by the wayside with the repack?
post #3881 of 3883 Old 03-20-2017, 10:38 AM
Liked: 0
Buzzr tv now live on the zone 50.3
stevekent09 is offline
post #3882 of 3883 Old 03-21-2017, 09:05 PM
Liked: 0
GRIT TV now on Mountain Telephone channel 123
post #3883 of 3883 Old 05-16-2017, 01:35 PM
mvcg66b3r's Avatar
Quoted: 109 Post(s)
With the repack, WQCW is moving to RF 15, which was W16CE's assigned digital channel. No new channel is indicated for W16CE. If they can't find another channel, is this the end of the "Charleston Split" ?
