New York, NY - TWC - Page 891 - AVS | Home Theater Discussions And Reviews
 8Likes
post #26701 of 26715 Old 03-19-2015, 05:25 PM
Berk32's Avatar
The previously announced change effecting WGN America will now occur on or about March 27, 2015. As a reminder WGN America will change from our Starter TV service offering to our Standard TV service offering.
On or about April 30, 2015 we may cease carriage of TWC Movie Pass on Demand. Please note that Disney Family Movies will still be available through Disney Family Movies on Demand on ch. 267. Also on that date Movies! will change from our Starter TV service offering to our Standard TV service offering.
Berk32 is offline
post #26702 of 26715 Old 04-01-2015, 06:23 AM
Berk32's Avatar
On or about May 15, 2015 we will launch Peace TV on ch. 1534. Peace TV will be part of our Starter TV service offering.
Berk32 is offline
post #26703 of 26715 Old 04-16-2015, 05:58 AM
Berk32's Avatar
On or about May 20, 2015 we will cease carriage of Smithsonian HD on Demand (ch. 1019) and all its programming content will be moved to Nature & Knowledge on Demand (ch. 1008). Also on that date, we will cease carriage of TWC Sports Pass on Demand (ch. 1010) and Pro Sports on Demand (ch. 1011) and all their programming content will be moved to Sports & Fitness on Demand (ch. 1009).
On or about June 3, 2015 we will launch Estrella HD on chs. 811 and 1236. Estrella HD will be part of our Starter TV service offering.
On or about June 30, 2015 we will launch Foro TV on ch. 847. Foro TV will be part of our Variety Lite Español service offering.
Berk32 is offline
post #26704 of 26715 Old 04-19-2015, 06:32 AM
tamanaco's Avatar
The picture from my 8640HDC is cutting out about every half hour. The only way to get the picture back is to reset the box. If this issue persist... I'll have to get a new DVR soon. What's the best DVR one can get from TWC NY these days?
tamanaco is offline
post #26705 of 26715 Old 04-19-2015, 12:52 PM
adrman's Avatar
Wondering that myself as my 8640 is getting a bit long in the tooth. I've had to perform several hard resets recently.
adrman is offline
post #26706 of 26715 Old 04-20-2015, 08:12 PM
ILW
ILW's Avatar
I can recommend what TWC calls its "Enhanced DVR," the Arris DCX3600-M, which I got at the end of 2014. It's responsive, rarely has any hiccups, and has six(!) tuners and a huge storage capacity (1 terabyte or about 150 hours of HD).
adrman likes this.
ILW is offline
post #26707 of 26715 Old 04-21-2015, 11:33 AM
ajabrams's Avatar
Originally Posted by Berk32 View Post
April 1, 2015
Re; "Peace TV"
http://www.multichannel.com/banned-i...-twc-ny/389891
ajabrams is offline
post #26708 of 26715 Old 04-21-2015, 11:36 AM
Berk32's Avatar
Originally Posted by ajabrams View Post
wkob-ld 42.3
Berk32 is offline
post #26709 of 26715 Old 05-01-2015, 05:32 PM
Berk32's Avatar
Just noticed we have a full 2 weeks of program guide data now.
Berk32 is offline
post #26710 of 26715 Old 05-06-2015, 04:47 AM
Berk32's Avatar
The previously announced change regarding TWC Movie Pass will now occur on June 1, 2015. As a reminder, we may cease carriage of TWC Movie Pass on Demand. Please note that Disney Family Movies will still be available through Disney Family Movies on Demand on ch. 267.
The previously announced launch of Estrella HD will now occur on June 16, 2015. As a reminder Estrella HD will be part of Starter TV service offering.
On or about June 9, 2015, the following overflow channels will require two-way capable digital cable ready equipment, such as a Time Warner Cable-provided set-top box or a CableCARD-equipped Unidirectional Digital Cable Product (UDCP) used in conjunction with a a Tuning Adapter. Other UDCPs may not be able to access these services without additional equipment, such as a set-top box: MSG 2, MSG Plus 2, Sports Extra 1 and Sports Extra 2.
Berk32 is offline
post #26711 of 26715 Old 05-09-2015, 11:52 AM
nony's Avatar
I have picked up two DCX3600's and am satisfied-
Nony-DCX3600-Diagnostic-Invocation
Quick Tips On Reboot and Diagnostics -
1. Press and hold the power key on the remote for 10 seconds to force a reboot
2. During the countdown (L-10 ,L-9 ,L-8,etc), power on and hit select for a detailed display of the components as they are being loaded
3. During the countdown or later, power on, press and hold select for 10 seconds, then hit Up for the OCAP diagnostics
4. After the load completes, press and hold select for 10 seconds, and hit Down for the ODN diagnostics
5. With the STB on, hit power, then select, for quick access to the Motorola STB diagnostics
6. With the STB on, hit A, B, C, Settings, power off, power on, Settings, Left, to access the Field Tools menu.
7. To enable device ports/functionality (eSATA, MoCA, USB), requires a little more button pressing and will not be covered in this post, for obvious reasons.
Multichannel Trick Play: (this section should be visible)
The DCX3600 can actively buffer 4 to 6 hours of TSB (up to 1 hour per tuner). The buffering kicks in after power on, and is reset at power off. Specifically, the last 60 minutes of the first 6 channels that you tune to will be buffered, and 4 of the 6 will continue to be buffered, even if you channel surfed to many other channels, after the initial 6.
Here's what you do:
1)Power Off -->Frees up the tuner assignments
2 )Power On --> Assigns tuner[0] to its default
3) Select any channel as a filler -->Assigns a channel to tuner[1]
4) Successively select the 4 channels that you want to buffer.-->Assigns tuners[2,3,4,5]
Note that tuners[0,1] will lose their buffering as you channel surf.
(You can watch the assignments in real-time from p.8 of the ODN diagnostics)
Comes in very handy for Sunday morning talk shows.
Bonus:
To stream unprotected, recorded content to any device over Ethernet to an MPEG-2 capable player, see this thread-
http://www.dslreports.com/forum/r299...tions~start=35
-nony
adrman likes this.
nony is offline
post #26712 of 26715 Old 05-10-2015, 04:48 PM
nony's Avatar
DCX3600 MultiChannel Trick Play
Additions to DCX3600 Tips and Tricks will be posted in a more appropriate section-
Not Another Official DCX3600-M Provider Agnostic Thread
-nony
nony is offline
post #26713 of 26715 Old 05-25-2015, 09:30 PM
Berk32's Avatar
The previously announced launch of Peace TV will now occur on June 15, 2015. As a reminder, Peace TV will be part of our Starter TV service offering.
On or about July 7, 2015 we will cease carriage of Pay-Per-View Previews.
Berk32 is offline
post #26714 of 26715 Old Yesterday, 07:08 AM
Quoted: 112 Post(s)
Liked: 7
Man wtc gives us this channels no one wants to watch, peace TV, I deleted that channel on ota sub 42-3. Wtc is really stretching there. Is it any wonder why they don't get any new subscribers. Lol
uhfyagi is online now
post #26715 of 26715 Unread Today, 05:30 AM
nyctveng's Avatar
Quoted: 97 Post(s)
Liked: 65
your post makes absolutely no sense
nyctveng is online now
