CBS-HD on Directv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-09-2003, 02:25 PM - Thread Starter
outlanderbz's Avatar
Quoted: 14 Post(s)
I just ordered Directv with a HD reciever and all the bells and wistles. I also ordered the clip on antenna that is recommended for local HD channels. Does anyone have any info if they can recieve CBS-HD with the clip on antenna in the chicago market?
thank you
outlanderbz is offline
post #2 of 11 Old 09-09-2003, 02:31 PM
sregener's Avatar
This is getting real old. The number of newbie posts is growing exponentially and the quality of poster (i.e. how much research did they do before posting) is dropping like the stock market in panic mode.
Clip-on antennas are about the worst designed antenna out there. They might work. They probably will not. A brief search of this forum with a keyword of "Terk" or "clip-on" should tell you more than you ever needed to know in order to determine that you wasted your money.
Another cursory check of this forum will reveal that a great deal of posting is going on about WBBM's digital tower and the numerous problems they've had getting it up to full power. Also, the thread documents the insane amount of trouble people have reported getting it "in the Chicago market." But the Chicago market is a very large geographic area (shoot - Chicago ain't small, either) and your specific location will make a big difference in whether or not you stand a chance.
Read those threads. Educate yourself. Then post.
Please.
sregener is offline
post #3 of 11 Old 09-09-2003, 02:43 PM
Ken Erickson's Avatar
outlanderbz,
Visit www.antennaweb.org to determine where the local stations in your area are located. Then look at the direction your "clip-on" antenna is pointed. The dish is going to be pointed some where to the south - depending on your location (update your profile to include locale). Most probably, the clip-on is not going to work. For best results - install a roof-top antenna. If you are relatively close to the transmitters you could get away with a small indoor antenna. And, www.antennaweb.org will help you determine what you would need. As for receiving CBS-HD, that depends on whether your local CBS affiliate is broadcasting the digital signal. And, update your locale and we can answer more directly.
Ken Erickson is offline
post #4 of 11 Old 09-09-2003, 03:11 PM - Thread Starter
Quoted: 14 Post(s)
sregener, your from se minnesota. i am asking if anyone in the chicago market has used the clip on antenna with success not you.
post #5 of 11 Old 09-09-2003, 03:14 PM - Thread Starter
Quoted: 14 Post(s)
i am still amazed at your loooong post to rip me. i cant believe you didnt see my question. i may be new to this forum but i am not new to forums.
post #6 of 11 Old 09-09-2003, 03:34 PM - Thread Starter
Quoted: 14 Post(s)
thank you Ken Erickson, i used the antenna website you said to and it says that all the stations are a code yellow. Which according to yellow i can use my clip on dish antenna or the one i currently have (zenith indoor v-shaped) not sure of exact model number. If i didnt have a townhouse i would put up a rooftop but i can not. I am in hainesville, IL 60073
post #7 of 11 Old 09-09-2003, 05:57 PM
UncD2000's Avatar
Hainesville is about 38 miles from the Hancock, and in addition you are on an azimuth with reduced WBBM-DT3 field strength in deference to the analog Ch. 3 station in Madison, WI. Still, after the WBBM-DT powerup to 100% next Monday (9/15), your clip-on might have a shot if it happens to be in a sweet spot. The Silver Sensor is great for the UHF channels, but it isn't designed for the 93.4" half-wavelength of Ch. 3.
UncD2000
UncD2000 is offline
post #8 of 11 Old 09-09-2003, 07:32 PM
bytes2u's Avatar
Don't sweat the small stuff outlanderbz, these forums are for everyone new and old.
Hang loose till CBS goes full power on the 15th. The worse thing to happen is you get an amplified antenna from rat shack for $25.
Good luck.
Brian
bytes2u is offline
post #9 of 11 Old 09-09-2003, 08:05 PM
j.leone's Avatar
After doing a exhausting antenna installation in Round Lake beach on Alma Ct. Wbbm would not lock in . I used the largest Winegard combo aerial . Also a Winegard low noise pre-amp. and aimed the antenna precisely with a field strength meter. I just gave up. I know how frustrating it is to hear post after post on WBBM issues and I hope it gets fixed real soon. You know that other low band DT stations run 25 to 46 kw. Erp. It will never happen in Chicago. You can receive Milwaukee from Hainesville and it is worth a try.
j.leone is offline
post #10 of 11 Old 09-10-2003, 02:15 AM
brvheart's Avatar
Wow sregener, that was a nice welcoome. Why not just ignore it if it bothers you so much. Searching doesn't answer every question out there.
brvheart is offline
post #11 of 11 Old 09-10-2003, 08:28 AM
sregener's Avatar
Yes, I'm from SE Minnesota. As far as I know, the laws of physics (which is essentially what we're dealing with WRT antenna reception) don't change very much from one state to the next. Antenna design is antenna design and what works in one market is just as likely to work under similar circumstances is another market. So your question about whether clip-ons work in Chicago is a bit like asking if an FM radio works in Chicago.
The Terk "clip-on" design ignores most of the laws of physics. Now you can take a piece of coax cable and strip the insulation to a certain length and you'll have an "antenna." It will receive certain frequencies and will exhibit certain directional aspects based on how you position the "antenna" relative to the receiving signal. So the Terk will work, but sadly not much better than stripped coax (and sometimes worse.) Is it possible that you could buy one, hook it up, and get reception of all your desired digitals? Yes. But as antenna reception depends on many factors that cannot be accurately predicted in advance, it's best to buy the best design rather than the slickest marketing package unless you're prepared to be disappointed.
But none of the above paragraph is really "new" information. Those of us who've been here for a while have posted and posted and posted about these things. Yet none of it stops people from popping up on the forum and asking questions that have already been answered a thousand times.
Your question is no different from somebody saying "I just bought antenna brand X, model Y. Will it work for me?" Nobody knows for sure because of all the potential factors that can impact reception. 1) Distance to antenna. 2) Relative height of your location to surrounding terrain. 3) Presence of trees or tall buildings. 4) Large obstacles between you and broadcasting antenna. 5) Presence of objects that will reflect signals. Now we can tell you that WBBM is low-powered (and lower in your direction, apparently) and low-VHF, but we can't tell you with 100% certainty what will or won't work. I've seen people do everything wrong (Terks in basements in high-multipath areas) and get solid reception. I've also seen people do everything right (great antenna, great location) and get nothing. Those local factors are a killer and nothing is a sure thing. In at least one case on this forum, a guy has the identical setup to his neighbor's - same antenna, same amplifier, everything - but one gets the digitals and one doesn't.
I was a little harsh in my first post, and I apologize for that.
sregener is offline
Closed Thread Local HDTV Info and Reception
