Los Angeles, CA - TWC - Page 300 - AVS Forum | Home Theater Discussions And Reviews
 458Likes
post #8971 of 9912 Old 07-01-2014, 05:09 PM
henhowc's Avatar
Quoted: 65 Post(s)
Liked: 24
nevermind...
henhowc is offline
post #8972 of 9912 Old 07-03-2014, 07:35 AM
Arvy's Avatar
Quoted: 94 Post(s)
Liked: 84
Mod's edit: Personal advertising removed.
Arvy
Arvy is offline
post #8973 of 9912 Old 07-03-2014, 10:43 AM
fastsvo's Avatar
Quoted: 31 Post(s)
Which modem should I be looking to buy in order to accommodate the next generation of technology for TWC?
phildaant likes this.
fastsvo is offline
post #8974 of 9912 Old 07-03-2014, 10:47 AM
phildaant's Avatar
Quoted: 874 Post(s)
Liked: 316
Lightbulb
You should ask this in http://forums.timewarnercable.com/t5...p/twc_internet and http://www.dslreports.com/forum/twc ...
phildaant is offline
post #8975 of 9912 Old 07-03-2014, 10:57 AM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
Check out the TWC "acceptable equipment" page, for the ethernet speed service plan you have.
Note that it seems they still have not rolled out the new TWC MAXX speeds citywide, although they are available now in just a few selected areas. However the new DOCSIS 3.0 modems shown on that page are compatible with current service speeds as well, so getting one now for the eventual MAXX speed you will have is fine.
There's another TWC document that also shows the acceptable equipment for the new TWC MAXX environment. Slightly different presentation, but the same info.
DSperber is offline
post #8976 of 9912 Old 07-03-2014, 12:39 PM
johnw248's Avatar
Quoted: 45 Post(s)
Liked: 32
Part of the upgrade appears to have started here (system 0196--Northridge, West Hills, et al) on Tuesday. I had a signal problem starting after midnight that killed many of the lower frequency channels and went through several phone calls (and they scheduled a service call for July 8th) but by the afternoon my SNR of 21db when back up to 37db and decrypting and tuning returned on those channel. Later that evening I tried tuning KCET on a clearQAM HD Homerun and not "No Video" it was recording on another machine with a Ceton and I checked the logs and it was showing as CA with no CCI.
I also noticed in scanning around that I was getting the same widescreen feed on 444 and 209 so it appears they have started consolidating HD on channels that used to carry down converted trimmed content. I noticed that the 503 HBO channel that used to be 3x4 is now widescreen as well.
I would imagine that they want to get these conversions made so they can service people that "cant tune anymore" with DTAs before they do the line-up switch.
I don't know if they have started the MAXX services yet, but it looks like they have cleared a lot of bandwidth necessary for it.
johnw248 is offline
post #8977 of 9912 Old 07-03-2014, 01:25 PM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
None. Just rent the latest and greatest for $5.99/month. SB6183 which is the only retail modem TWC authorizes over 100mbps is selling for $150 or more on ebay. At that price it will take almost 2 years to recoup your money and by the Docsis 3.1 will be out making your modem obsolete with little resale value.
nyctveng is offline
post #8978 of 9912 Old 07-03-2014, 01:39 PM
phildaant's Avatar
Quoted: 874 Post(s)
Liked: 316
Question
Does TWC stores even let you pick which cable modems to get? I thought they just give you whatever they have in stocks.
post #8979 of 9912 Old 07-03-2014, 02:23 PM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
They give the appropriate modem for your level of service. For those on tiers 100mbps or lower do not get the newest 16 channel bonding modems.
nyctveng is offline
post #8980 of 9912 Old 07-03-2014, 02:28 PM
phildaant's Avatar
Quoted: 874 Post(s)
Liked: 316
Question
Right, but do they let you pick which exact model to get like SB6183 if you have that Internet package.
post #8981 of 9912 Old 07-03-2014, 02:33 PM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
I noticed that TitanTV has already applied the channel lineup change (as if it were scheduled to have been completed by now) for TWC. So I can't conveniently make any further adjustments to my own "Favorites" lineup (which is based on TWC's complete set of available channels) for TitanTV.
I also don't understand why the Netgear CMD31T modem (which I own) is not acceptable for speeds up to 100 or so. It's rated at 150Mbps by Netgear, and it's "approved" by Comcast in Chicago for their own 105 speed tier. So why it should be shown as only good up to 50 by TWC is unclear. I still haven't opened the Motorola SB6141 I rushed to buy to replace my CMD31T when told it would not be usable for the Ultimate 200, but if the CMD31T is actually usable up to 100 then I'd go forward with my plan to drop back one service level (to Ultimate 100) and save $10/month, plus return the SB6141 if the CMD31T will work at 100 speeds as the manufacturer says it should.
Anyway... none of this is happening now anyway, and if you call to ask "when will it happen" the answer is always TBD, TBA, or 2015-2016. None of this makes sense. It would be a good follow-up article for the LA Times to write after all the hype and bally-hoo that TWC put out about NYC and LA being first in the nation, and the fantastic Internet speed upgrades which were going to be made available with TWC MAXX, not to mention the multiple physical paper mailings that went out providing what appeared to be a date-certain for the national channel lineup change.
Oh well. Back to work.
DSperber is offline
post #8982 of 9912 Old 07-03-2014, 02:37 PM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
SB6183 is the only retail model for 16 channels and I don't think TWC has those. TWC has 2 different Arris models: 1 with MTA (phone) http://www.arrisi.com/products/product.asp?id=687
and 1 without http://www.arrisi.com/products/product.asp?id=684
nyctveng is offline
post #8983 of 9912 Old 07-03-2014, 02:39 PM
phildaant's Avatar
Quoted: 874 Post(s)
Liked: 316
Unhappy
Originally Posted by DSperber View Post
... Anyway... none of this is happening now anyway, and if you call to ask "when will it happen" the answer is always TBD, TBA, or 2015-2016...
Same on http://www.timewarnercable.com/en/tv/my-channels.html ... Still no new dates. Argh!
post #8984 of 9912 Old 07-04-2014, 06:47 AM
Arvy's Avatar
Quoted: 94 Post(s)
Liked: 84
150Mbps is based on the theoretical maximum of ~39Mbps that each channel of the modem can receive. If you go 150/39, it's a 4 channel downstream modem and probably 1 channel upstream. TWC is capping each channel at 20Mbps to avoid bottlenecks so the CMD31T's limit will be 80Mbps which is not quite 100. TWC then limits the modem's allocation to 50. This is all exactly like my Arris/Motorola 6121 which I bought about a year ago to avoid the rental fee increase hoping to break even in under a year. As it turns out, I'm screwed because I got a promo deal for TV/Internet/Phone including Turbo speeds which translated to 100/10Mbps and is currently active. In other words, my connectivity is 100/10 but the modem I own can only receive 50/5 (for another 10-11 months). My options are to stay put with a user owned modem on a promo deal and not get full service or rent a 100/10 8X4 modem and eat the cost of the SB6121 or sell the 6121 then rent or buy (which I'm finding hard to do) an 8X4.
DSperber likes this.
Arvy
Arvy is offline
post #8985 of 9912 Old 07-04-2014, 09:18 AM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
no they are not. You may have read this on another website or even be the one spreading this false information.
nyctveng is offline
post #8986 of 9912 Old 07-04-2014, 10:12 AM
Arvy's Avatar
Quoted: 94 Post(s)
Liked: 84
Why then does this SB6121 not receive the 100/10 my connection is allotted and instead stays at 50/5? or should i even care?
Arvy
Arvy is offline
post #8987 of 9912 Old 07-04-2014, 10:22 AM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
TWC proactively manages bandwith by capping modems, not their QAMs. Your modem is a 4 channel model. If they allowed that model to go to 100, you alone would easily eat up almost 3 38meg QAM channels. By capping you at 50, you would only use 1.5QAM worth of bandwith. Same theory for 8 channel models like the SB6141, they allow up to 100 meg even though in a lab the modem can do over 300. They have been doing this type of "capping" for some time even before MAXX. Docsis 2 modems can do single channel bonding up to 38meg but TWC never allowed D2 modems for tiers above 20.
nyctveng is offline
post #8988 of 9912 Old 07-04-2014, 06:10 PM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 780 Post(s)
Liked: 709
Can anyone on Time Warner Cable in the San Fernando Valley point me to where to find out what channels are on SDV. I've been searching TWC's site and not having a lot of luck. I thinking about using cable cards with Tivo's but I need to know if what I want still needs tuning adaptors.
Gracias.
"Oooh a puzzle box, I love puzzles"/ "Are you familiar with 'The Lament Configuration"/ "Actually I'm lousy at puzzles..."
tenthplanet is online now
post #8989 of 9912 Old 07-04-2014, 08:03 PM
johnw248's Avatar
Quoted: 45 Post(s)
Liked: 32
Gracias.
I can't find a list of SDV channels on the TWC website anymore. There used to be a page with channels unavailable to cableCARD and it's "gone" for Southern California as best I can tell.
Here is the status as of today:
CLIENT
Authorized: Yes
Service Gp: 21621
RF Ip Addr: 10.200.149.79
SDV Channels: 489
SERVER
Status: Ready
TUNING ADAPTER
Authorized: Yes
OpStatus: Ready
ChanTblLoadTime: 07/04@03:01:17
HmacKeyGenTime: 07/04@06:08:07
TA CONFIG FILE
LoadTime: 07/04@03:01:13
Version: 06/30@22:39:45
NumChan/Split/Desc: 846/0/3
So there are a total of 846 channels and 489 are switched which means you'd get 357 channels without a TA right now. But remember they are in the midst of a change with total encryption and until it's complete there is no way to know what the final score card will be. Any you should be aware that they do move channels from broadcast to switched so something could just go away or just come on. So a listing today isn't really set in cement.
johnw248 is offline
post #8990 of 9912 Old 07-04-2014, 11:50 PM
kevin120's Avatar
Quoted: 31 Post(s)
Liked: 36
CLIENT
Authorized: Yes
Service Gp: 21621
SDV Channels: 489
SERVER
Status: Ready
TUNING ADAPTER
Authorized: Yes
OpStatus: Ready
TA CONFIG FILE
encryption should have no effect on which channels are SDV only thing that changes is that clear QAM tuners no longer can tune channels.
kevin120 is offline
post #8991 of 9912 Old 07-05-2014, 10:22 AM
johnw248's Avatar
Quoted: 45 Post(s)
Liked: 32
True, the point being once TWC goes to full encryption nothing will be received by a clearQAM tuner. Non-switched channels will be received with a cableCARD only OCUR but for full reception a TA will be required. Still two-way interactive will not work and such as video on demand are not available with cableCARD and TA set-ups.
Things to consider for someone that is looking to go away from the TWC STB and into Tivo or Media Center.
johnw248 is offline
post #8992 of 9912 Old 07-05-2014, 04:43 PM
Quoted: 780 Post(s)
Liked: 709
CLIENT
Authorized: Yes
Service Gp: 21621
SDV Channels: 489
SERVER
Status: Ready
TUNING ADAPTER
Authorized: Yes
OpStatus: Ready
TA CONFIG FILE
That missing page is what I was looking for. Thanks for the info
post #8993 of 9912 Old 07-08-2014, 10:39 PM
Mastaclocksetta's Avatar
Liked: 26
Well, in 90024, analog doomsday has arrived (at least for Standard TV). Only Starter TV is still available in analog. Digital Starter TV (e.g. HD versions of local channels, digital SD versions of shopping channels) has not been encrypted as of now. Where else did analog Standard TV go bye-bye today? Any word on when our clearQAM tuners will become useless?
Mastaclocksetta is online now
post #8994 of 9912 Old 07-08-2014, 11:39 PM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
Received a letter from TWC yesterday seemingly announcing August 26 as the start of all-digital, and advising about getting an adapter if needed, and that it would be free through Jan 1 2016 after which it would be $1.50/month. 90292.
I don't know how this ties into the postponed channel lineup changes, or the TWC MAXX internet speed upgrades.
DSperber is offline
post #8995 of 9912 Old 07-09-2014, 07:14 AM
johnw248's Avatar
Quoted: 45 Post(s)
Liked: 32
Last Tuesday, July 1 2014 they started pulling some clearQAM in 91324 (Northridge) which I discovered when I tried to watch Death In Paradise on KCET via a HD HomeRun. I had to change MC to only use cableCARD for KCET and KOCE. I think KCBS, KNBC, and KABC were still available but I started trimming out clearQAM from various machines then.
No letter as yet, but hopefully they're well underway in getting the head end in line for the change.
Nothing has changed so far on the page I marked for the upgrade notices. http://www.timewarnercable.com/en/tv/my-channels.html
still all "coming soon"
johnw248 is offline
post #8996 of 9912 Old 07-09-2014, 09:01 AM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
The lineup changes can be done at anytime with no impact to MAXX rollout or analog removal/DTA rollout. It can be done before or after or not at all. It's all back office stuff and call centers having to handle tons of calls.
The MAXX upgrades require 8 additional channels adjacent to their current 8 downstream channels. Analog channel removal and DTA rollout will need to be completed so that the headend/hubs can rework the RF combining.
nyctveng is offline
post #8997 of 9912 Old 07-09-2014, 10:24 PM
Drewdawg's Avatar
I'm in Anaheim 92806 and I get the following NTSC channels with the "Get your TV picture back" screen.
2, 4, 5, 7, 8, 9, 11, 12, 13, 14, 25, 26, 27, 29, 30, 32, 33, 34, 35, 36, 38, 40, 41, 42, 43, 44, 47, 48, 49, 50, 51, 53, 55, 56, 58, 59, 60, 61, 62, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77
Channels 3, 97 & 98 have a black screen but there are channels there.
I get TV from OTA and shows from the net. I'm hoping they turn these analog channels to digital so my Standard 15/1 goes up. I don't know who's watching these analog "title card" channels but I'm sure they got the message by now.
Drewdawg is offline
post #8998 of 9912 Old 07-10-2014, 06:39 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 512 Post(s)
Liked: 772
My mother-in-law and also a friend in Mar Vista (90066) just got the same letter with the same August 26 date, but what's funny is that their neighborhood doesn't get cable straight from the wall in the first place and never has. I've tried scanning channels on a number of flat panel TVs there over the years and i get nothing. My mother lived in the same neighborhood/zip and also couldn't get cable from the wall. Same thing at my sister-in-law's house nearby in Palms (90034). They've all had to use boxes there.
At my house in El Segundo (90245) and all my friends in town, we have always gotten cable straight from the wall as have some friends in Torrance, but i have not yet gotten a letter that we're going all-digital, just the ones about the channel lineup change (that's been delayed twice here now). Not looking forward to having to use a digital adapter on my bedroom TV from the wall since the tuning adapter on my Tivo in the man-room is so unreliable. Maybe i'll just switch that bedroom TV to antenna when digital arrives.....
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8999 of 9912 Old 07-10-2014, 11:43 AM
Blasst's Avatar
Quoted: 68 Post(s)
Liked: 65
Just set up with the new TW modem. Will report my findings and thoughts in a few days.
Blasst is online now
post #9000 of 9912 Old 07-10-2014, 12:26 PM
holl_ands's Avatar
Quoted: 464 Post(s)
Liked: 191
I would be curious as to what the Down/Up-Load Speeds are to Servers at different locations in the U.S. [e.g. NYC, Silicon Valley, Portland, Seattle & where are Netflix, et.al. Servers????] as well as overseas, such as various countries in Europe and same distance as Electronics Support sites in Japan, Taiwan and Hong Kong.
holl_ands is online now
