Cincinnati, OH - HDTV - Page 480 - AVS Forum | Home Theater Discussions And Reviews
 129Likes
post #14371 of 14895 Old 08-26-2014, 08:33 AM
Paul Hovey's Avatar
Here’s my TVFool http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3dec2f385689757 b
With Dayton and Cincy at about 200° apart I had 2 antenna A/B to try to get everything. I started with just a 71” from Radio Shack that did one or the other pretty well, but not both. It would pick up Cincy off of the back, but not well enough. I added an RCA ANT751R for Cincy, but still had dropouts and weak signals. After searching for a bi-directional antenna, I ended up making the Stealth Hawk. It was an easy build and pretty much free (already had everything I needed) and does as well if not better than the 2 antenna combined. I get pretty much 80% or better on everything I had before. And now Iget channel 25.1 (broadcast on 47) at about 30%. WDYC (36) WKOI (39) & WCVN(24) are 0-10%. But, I don’t get WOTH (20), WBQC (25) or WRGT (30).
Looking at the TVFool it seems I should be getting these(and better reception on 47), but can’t seem to bring them in regardless of where I’m aiming. I never got any of them with the other antenna either (or even knew they existed) so maybe it’s something between me and the broadcasts that’s keeping them out, but I get 9 & 12 @ 100% and it seems at least 47, 25 & 36 are in the same place.
Any suggestions would be helpful.
Paul Hovey is offline
post #14372 of 14895 Old 08-27-2014, 11:33 AM
luvmyhdtv's Avatar
Looks like you're close enough to the Cincy stations that they should be fairly easy to get. I'm guessing you're using the antenna indoors, not outdoors?
Dayton stations probably aren't going to be possible with any antenna used indoors. I've got an old style CM4228 and a 91XG antenna mounted on the roof. With either antenna pointed SW I get
Cincy channels fine and Dayton off the back side. I only have the #4228 hooked up now here in Clermont County. Long story short.....get the antenna outside if at all possible.
KU 36" dish / C band 8' dish no longer hooked up, 47" Vizio 3D Tv with Philips 3D Dvd player, Gateway 3.6Ghz - 2Tb computer for home theatre setup
Old style CM4228 and 91XG antennas for OTA.
luvmyhdtv is offline
post #14373 of 14895 Old 08-27-2014, 01:29 PM
Paul Hovey's Avatar
Antenna's outside. About 30' high.
I get all the Dayton fine (80%+). It's just those few Cincy channels that give me trouble. I might be Clear Channel (now in kenwood) has transmitters or something on the roof that's messing with my signal.
I was pretty amazed when I put the little antenna up and get better signal than my 71".
luvmyhdtv likes this.
post #14374 of 14895 Old 08-27-2014, 04:36 PM
ThoraX695's Avatar
Quoted: 25 Post(s)
Liked: 32
How else is the WEBN frog going to control the fireworks on Sunday? Seriously, I don't think that's the issue unless you have obstacles directly in your line-of-sight path like trees. You could also be dealing with multi-path, which is difficult to diagnose in the digital era. (In the analog era, you would see ghosting in the picture.) From your location, you should get everything from Cincinnati and perhaps only have issues with WKOI (RF 39, virtual 43) because it's off-axis.
Are you using an amplifier (installed at the TV) or pre-amplifier (installed at the antenna, but powered close to the TV)? That may cause overloading and wash out your weaker channels. Are you using new RG-59 cable from the antennas to your TV? If you're using old and weathered cable, it could be losing signal. Or there could be a short in it. There's also a chance that your homemade antenna has a problem, especially if you also have a homemade balun.
P.S. WBQC is RF 47, virtual 25, so you're already getting that weakly. WRGT from Dayton can be tough to get in our general area because their transmitting antenna doesn't radiate a lot of power south. (See this link from TV Fool.) Nobody can get WOTH (RF 20, physical 38) because it's not broadcasting at the moment. Although there was an article in the Enquirer hinting that the new transmitting antenna for RF 20 was installed a few weeks ago...
ThoraX695 is offline
post #14375 of 14895 Old 08-28-2014, 06:42 AM
Paul Hovey's Avatar
OK. So it sounds like I’m actually getting everything I should. I didn’t realize WBQC was listed twice. (once as LD (47) and as LP(25)) I get WRGT, but didn’t realize it was virtual 45. So the only thing I’m really missing is a stronger WCVN which @ ~14 miles it seems I should have. (I have 48, 14 & 16, but we do like our PBS )
I have RG-6 running about 35’ straight to the TV (which I thought was better than 59?). I have a distribution amp to feed other TVs, but I’m bypassing it right now. I’m using a commercial balun since I had a few lying around.
Someone on the DIgitalhome forum suggested I build one of the slightly more complex versions of the antenna to get a little better gain and range. I built this version http://clients.teksavvy.com/~nickm/sh/sh_U_3_9.html in about 10 minutes and it does as well as any commercial antenna I’ve had and being bi-directional, is ideal for this area. It seems to have much better range than any of the omni-directionals I’ve tried. I’ll try making the “Super” version this weekend and report back.
Thanks for the input.
post #14376 of 14895 Old 08-28-2014, 07:45 AM
jim tressler's Avatar
Quoted: 16 Post(s)
its the FBI thats jamming you
from the map, you appear to have direct line of site to 5,9, and 12 - Clear channel is not in your way.
jim tressler is online now
post #14377 of 14895 Old 08-29-2014, 03:38 PM
ThoraX695's Avatar
Quoted: 25 Post(s)
Liked: 32
Everyone gets confused about the digital channel mappings. It's both a blessing (stations can keep their original analog channel number and can tell everyone to "just rescan" when they move frequencies) and a curse (keeping everything straight, plus possible conflicts when distant stations come in during tropospheric ducting events).
I guess the only other issue could be with your homebrew antenna itself. You should be OK if you follow the directions very carefully, including building the feed lines to the balun properly, but things could go awry if something is off and affect the weaker signals. You could also try building two of them and hook them together into an array. (It's a three-day weekend for most of us anyway, might as well put it to good use!)
post #14378 of 14895 Old 08-31-2014, 06:06 AM
WILWRadio's Avatar
If you run into issues with the home made antennas not being able to withstand inclement weather I recommend the HDX 1000 from Antennacraft.
http://antennacraft.net/Antennas/AntennasAmplified.html
I have tested this at my home in Covington, KY which is very close to several TV towers. Despite this I got perfect reception on every Cincy channel with no overload from the low power pre amp. I did not get any Dayton stations but that is because I had the antenna mounted at ground level and I am surrounded by some taller brick structures nearby. Hope to try to roof mount an antenna and get it above the roof line of the home that blocks signals from Dayton to see what this will do as well as other antennas.
WILWRadio is offline
post #14379 of 14895 Old 09-04-2014, 06:10 AM
Paul Hovey's Avatar
I made the “Super Stealth Hawk” (no reflectors) and I’m getting a stronger CVN (30-40%) and BQC about the same (is it just really weak?).
The HDX 1000 is similar to what I used to have and being directional, would do one or the other well, but not both. The home made antenna is getting me as good a signal from both directions at the same time.
I’ll try a preamp to see if it makes any difference, but I don’t know that there’s anything more I can pull in. Hopefully it’ll bump up a couple of the weaker stations a bit.
post #14380 of 14895 Old 10-02-2014, 07:39 AM
Bubster's Avatar
Quoted: 17 Post(s)
I may be the only one left using a HD Homerun to grab clear QAM channels off of TWC, but in case there are others out there they apparently were laying new cables in the area (big thick mofos) and my cable went down yesterday for most of the day hours. When it came back up all my local clear QAM channels had changed, and the once reliable Silicon Dust web page no longer lists the cable channels, only the OTA digital channels.
So, if it hasn't gotten to you yet it will, and you'll find this listing of the new channels handy in case you add them manually like I do:
5.1-- WLWTDT -- 102.563
5.2 -- WLWDT2 -- 102.564
9.1-- WCPODT -- 104.556
12.1-- WKRC-DT -- 104.559
12.2-- WKRCDT2 -- 104.560
19.1-- WXIX-HD -- 74.571
19.2-- WXIXDT2 -- 74.572
48.1-- WCETDT -- 75.549
64.1-- WSTRDT -- 74.570
64.2-- WSTRDT2 -- 74.573
//Current as of 10/02/2014
I live in Fairfield, I guess these could differ in other areas of the city?
Bubster is offline
post #14381 of 14895 Old 10-18-2014, 02:41 PM
DaveA28's Avatar
I'm using an HDHR also, with MythTV, on TWC in Maineville (old Amelia system). I'm not recording a whole lot, but I did miss an SNL episode a couple weeks ago because the freq was wrong. My recordings on 9, 12 and 19 worked fine. I just updated the settings for WLWT, WSTR and pbs.
Thanks for the heads up!
DaveA28 is offline
post #14382 of 14895 Old 10-20-2014, 11:05 AM
luvmyhdtv's Avatar
Me TV in Dayton Soon
I read on a broadcasting forum today that Dayton is going to get ME Tv on WHIO around December. Not sure if it will replace the weather channel on 7.2 or not. According to FCC contour map WLWT covers most of Dayton, personally I didn't see much point of it being on WHIO. Maybe those in the north part of Dayton don't see WLWT.
post #14383 of 14895 Old 10-20-2014, 11:47 PM
Paul210's Avatar
Quoted: 23 Post(s)
Liked: 31
WHIO's pq is pretty decent right now. I'd hate to see them eat into the bitrate to add another redundant sub. I live NW of Dayton (near Englewood) and WLWT is very strong here ota. Cable subscribers are a different story though. WLWT isn't carried Dayton northward on TWC.
Panny Plasma Junkie: TC-P50VT20, TC-P50G15, TH-42PX60U
Paul210 is offline
post #14384 of 14895 Old 10-29-2014, 07:09 PM
Magick's Avatar
Is anyone else having problems receiving 19.1 WXIX on TWC via clear QAM? It seems to have disappeared for me on Thursday last week.
Magick is offline
post #14385 of 14895 Old 10-29-2014, 07:42 PM
Bubster's Avatar
Quoted: 17 Post(s)
Working as usual here. I've noticed, however, since the realignment, WCPOHD is very poor quality.
Bubster is offline
post #14386 of 14895 Old 11-01-2014, 03:55 PM - Thread Starter
Nitewatchman's Avatar
Quoted: 33 Post(s)
Liked: 25
Noticed the other day WDYC-LD now has Daystar HD ... They're running 720p on 36.1, and 480i 16x9 on 36.2 - which is improperly flagged as 4x3 - which seems to be a common occurance these days - WDTN for example has been doing that for months and months on 2.2, WBQC-LD has been doing it on 25.5/A1 recently, etc/etc ....
Oddly enough, WLWD-LD 20 (Daystar) Dayton/Springfield is also running HD now, but it's 1080i, with no additional subchannels .... They didn't have audio when I checked it several days ago, but audio is there now ... They only squirt a few watts in my direction per their DA pattern, so I have to aim XG91 right at it to get it ....
As long as I'm posting, also noticed WWRD-LP 32 Dayton (analog only at this point, and the last analog station currently still on air in the area) managed to get some actual programming up rather than just dead air (which is how it's been for maybe a year or so -- transmitter up -- but only video black, or similar present) ....I found Some of their local, "WWRD" originated programming actually pretty interesting, too bad only (some, presumably) Dayton area cable viewers have been able to see it for quite some time.....
Jeff
Nitewatchman is offline
post #14387 of 14895 Old 11-01-2014, 08:24 PM
ThoraX695's Avatar
Quoted: 25 Post(s)
Liked: 32
But WDYC-LD still doesn't have any programming guide information. It's been "TBD" 24/7 since they went on the air. At least they're putting their channel's bandwidth to better use!
Maybe we can still count WOTH-CD as analog still on RF 38? If they installed a new antenna for RF 20 a few months back, then we should see it on the air relatively soon... right?
post #14388 of 14895 Old 11-12-2014, 09:56 PM
Balloonfanatic's Avatar
Quoted: 55 Post(s)
Liked: 40
Live well channel 9-3 is going away jan.1. What is going to replace that channel. I'm guessing it's going to be a 24 hr. headline news channel similar to their 4pm newscast.
Balloonfanatic is offline
post #14389 of 14895 Old 11-12-2014, 11:01 PM
Bond 007's Avatar
Quoted: 2370 Post(s)
Liked: 1906
As if there aren't enough 24 hour news channels already. Wonder if it will be Republican or Democrat.
Bond 007 is online now
post #14390 of 14895 Old 11-13-2014, 09:01 AM
microbob's Avatar
Quoted: 35 Post(s)
Liked: 26
How bout just non biased news and no opinion or yelling at one another. I know, It will never work. Here's hoping it will be Antenna TV or Movies!
Robert
microbob is offline
post #14391 of 14895 Old 11-13-2014, 09:11 AM
Quoted: 55 Post(s)
Liked: 40
It would be nice to see antenna tv.
post #14392 of 14895 Old 11-16-2014, 07:03 PM
WILWRadio's Avatar
Second vote for Antenna TV. Great shows like All in the Family, It Takes a Thief, WKRP, I Dream on Jeannie, McHales Navy, Dennis the Menace, Barnaby Miller and more. Even though I don't watch it daily where I am at currently, I do enjoy it when I have the chance. BTW. If you buy Rabbit TV you can access the shows for free that way.
post #14393 of 14895 Old 11-19-2014, 03:58 PM
Quoted: 55 Post(s)
Liked: 40
With rabbit tv Can you buy a box that will stream antenna tv to the tv or are you limited to streaming to your computer?
post #14394 of 14895 Old 11-19-2014, 07:32 PM
WILWRadio's Avatar
Not sure. I just use it on my computer. I did read that the new version they are working on will work directly on a TV that has a USB connector. Not sure when it will be released. Might want to check the Rabbit TV website for more info.
post #14395 of 14895 Old 11-22-2014, 10:41 PM
robmadden1's Avatar
Anyone who lives in Delhi have issues recieving WLWT OTA. I live on the top of the hill by Neeb and Rapid Run. I have had this issue ever since they fixed the cut transmition line. It does nothing but break up with my Radio Shack 15-1892 indoor antenna. It was perfectly fine before the transmition line was cut and fixed. I nevrr had one single issue what so ever with the channel. It may somtimes not breakup but 99.9% of the time it does and makes me unable to watch anything on NBC. I have had no changes what so ever in my setup sice the transmition line was cut. I reported it to WLWT and they said there was no issue what so ever with the channel but I clearly have an issue with recieving it and it dont matter how good the signal strength is it still breaks up even at 80+% for signal strength. One other thing is I even get Indy via tropo sometimes and its comes in way better than WLWT does. One time via tropo i even gor Louisville and WLWT was still breaking up. Anyone know how I can fix this issue without having to get an outdoor antenna since I live in a condo? My room with the issue is on an outside wall facing west.
robmadden1 is offline
post #14396 of 14895 Old 11-24-2014, 09:31 PM
Quoted: 55 Post(s)
Liked: 40
if you are getting Indy stations indoors the front of your antenna might be pointing west instead of east. Also try lowering your vhf antenna rods to about half height (strange as it sounds it improved my reception).
post #14397 of 14895 Old 11-25-2014, 02:59 AM
robmadden1's Avatar
It has nothing to do with the rods (dipoles) those are for VHF not UHF. The UHF is the round thing in the center. It dont matter wat direction its set too it always breaks up.
post #14398 of 14895 Old 11-25-2014, 07:49 AM
Quoted: 55 Post(s)
Liked: 40
I understand the difference between vhf and uhf.I don't know why but with plaster walls lowering the rods allowed me to get more (uhf) stations with a combination antenna. I can move the antenna 1 foot to the left or the right and it's the difference between tv and no tv. I have never had any luck with radio shack indoor antennas or any antenna costing under $20.it . The direction that the uhf antenna is pointing is critical if the antenna has reflectors on the backside (you can't tell if it's enclosed in plastic) because it limits the signal from the back allowing more gain on the front.
post #14399 of 14895 Old 11-25-2014, 08:06 AM
robmadden1's Avatar
I don't know why but with plaster walls lowering the rods allowed me to get more stations. I can move the antenna 1 foot to the left or the right and it's the difference between tv and no tv. I have never had any luck with radio shack indoor antennas or any antenna costing under $20.
This one cost me $50 brand new in 2007. I do have a metal window frame in the room but it has never given me any trouble on my tv. WLWT is the only channel I have had issues with other than when WCPO was on 9 not 22 like they are now. I would love to know what they changed because my tv is from 2007. I even have issues when 64.2 Get TV lockes up my tv. I can watch the channel but to be able to change the channel I have to pull the plug to my tv from the wall so I can switch the channel. I never watch it because of that. I have a 26-27" SharpAquos from 2007. I am kind of wondering if what they changed when replacing the transmition line is not 100% compatable with my older digital tv. I had to help 25 fix there issues by calling them all the time to help them fix an audio issue when they first when digital. THe way they had it set up my tv could not decode it so I let them know when they finally had it set right so my tv could decode it. This might be a simular issue with codec or something that is causing my break up.
post #14400 of 14895 Old 11-25-2014, 08:17 AM
Quoted: 55 Post(s)
Liked: 40
The best indoor antenna I have tried is the Antennacraft antenna from radio shack $49. It allows me to get dayton indoors (except 2 uhf50) in sharonville but low power channels 25 or 36 can only be received here with an outdoor antenna.
