Cincinnati, OH - HDTV - Page 490 - AVS Forum | Home Theater Discussions And Reviews
 63Likes
post #14671 of 14684 Old 08-16-2015, 12:30 PM
Balloonfanatic's Avatar
Quoted: 43 Post(s)
Liked: 24
just put up a new "stellar labs quad bay antenna" from mcm electronics.
dayton ch. 26 and 45 are coming in around 36 percent here in sharonville while all the other dayton channels are around 70 percent + .
just curious if its on my end or are they still doing transmitter work and operating at reduced power.
Balloonfanatic is offline
post #14672 of 14684 Old 08-17-2015, 04:40 PM
WILWRadio's Avatar
Quoted: 13 Post(s)
How does this compare to your previous antenna in terms of performance? Better or worse on some channels?
WILWRadio is offline
post #14673 of 14684 Old 08-17-2015, 07:54 PM
513Tech's Avatar
Heard SBG currently own Ch. 12, 64 and 25 is it true?
513Tech is offline
post #14674 of 14684 Old 08-17-2015, 08:06 PM
microbob's Avatar
Quoted: 24 Post(s)
They don't own WBQC 25 but you're right they do own 12, 12.2, 64, 64.2
Robert
microbob is online now
post #14675 of 14684 Old 08-17-2015, 08:40 PM
Quoted: 43 Post(s)
Liked: 24
I like the unit - get all cincy and dayton channls (including 25, 20, 54) except 36. mcm electronics has the dual bay on sale for $29.99 and the single bay for $15.99 (source code A50774). I tried pointing both bays towards dayton then tried towards cincy. that doesnt work you loose some channels. when you point each antenna towards each cities towers it works great. I scanned in 53 channels here in sharonville.
I lost all my dayton channels this evening except 22. dont know if they powered down or I have water in one of the cheap rg59 wires that came with the unit after todays thunderstorms 1.25".
will replacing the antennas cheap rg59 cables combining the 2 antennas with rg6 cables improve the reception?
post #14676 of 14684 Old 08-18-2015, 05:04 AM
WILWRadio's Avatar
Quoted: 13 Post(s)
I usually use RG6 and try to find Quad Shield when I am in a urban or suburban area. Better shielding. RG11 when I am in a Fringe or Deep Fringe situation.
Which antenna were you using previously?
post #14677 of 14684 Old 08-18-2015, 06:19 AM
Quoted: 43 Post(s)
Liked: 24
2 radio shack vu90 antennas one towards dayton and 1 towards cincy and an a/b switch.
new antenna update. all the dayton stations were back by 8am at previous signal levels.
does this mean I dont have water in the connections or was this a trippo night.
post #14678 of 14684 Old 08-18-2015, 04:13 PM
513Tech's Avatar
Thanks Bob for clearing it up
513Tech is offline
post #14679 of 14684 Old 08-18-2015, 05:03 PM
WILWRadio's Avatar
Quoted: 13 Post(s)
Those RS antennas must have been 20 years old or older. I recall they were being made back in the 1970's!
Tropo. Not sure. I have signals that come in and out from time to time. Most likely if they are 2 edge signals (which is the case for me at my home in Covington with the Dayton stations) then they bounce off things before hitting the antenna at your home. That being the case sometimes they won't come in at all and other times they do.
Check the signal strength meter on your TV for each channel from time to time to see how strong they are. If they are weak then chances are they are 2 edge.
post #14680 of 14684 Old 08-20-2015, 05:23 PM
Quoted: 43 Post(s)
Liked: 24
anyone else having reception issues with daytons fox45. I barely receive it at 36-39 percent in sharonville.
since ch. 22 changed channels both ch. 2 and 22 have much stronger signal strengths. I wonder if ch. 19 (29) much stronger signal is causing the signal attinuation on fox45 (30).
post #14681 of 14684 Old Yesterday, 03:03 AM
Bubster's Avatar
Strong as usual here in Fairfield with my attic antenna, 30db and full bars according to my 5 yr old Sammy LCD. I have terrain issues here near the golf course and only get WSTR from Cincy, but I get all the main Dayton stations except 16 (PBS).
Bubster is offline
post #14682 of 14684 Unread Today, 07:01 PM
RobLee's Avatar
Quoted: 94 Post(s)
Liked: 149
Suddenly tonite I'm getting SyFy (TWC channel 1224) at 720p... I could have sworn it always used to be 1080i... I've switched channels back and forth and Spike, BBC, TNT etc are all still 1080, but SyFy is 720. Am I going nuts?
Polk RtiA9's, Denon 4520 & Emo XPA-5, CsiA6, RtiA7 surrounds, FxiA6 rears, twin Klipsch Synergy Sub-12's. Family room: RtiA3's & Rti4 surrounds, Csi3, Klipsch SW-450, Yamaha 565... Bedroom: Lsi9's on an Onkyo TX-8050
RobLee is online now
post #14683 of 14684 Unread Today, 07:26 PM
microbob's Avatar
Quoted: 24 Post(s)
TWC must be doing something with some of there HD channels lately. Here where I live in Northern KY Discovery ID has been in 480i for about a month. They don't care that it's broken either. I've contacted them about many times and it never gets fixed and they give the standard reboot your DVR by unplugging the power cord magic fix that does nothing.
Robert
post #14684 of 14684 Unread Today, 07:30 PM
RobLee's Avatar
Quoted: 94 Post(s)
Liked: 149
I got it "fixed" sort of. If I switch to a 480 channel then SyFy is 1080 when I switch back. Seems to only be affecting SyFy for some reason. Must be a quirk of the DVR box.
