Hartford, CT - OTA - Page 238 - AVS Forum
post #7111 of 7115 Old 08-14-2014, 05:53 PM
lucasland's Avatar
Originally Posted by lucasland View Post
according to the amazon page it is a VHF/UHF antenna. http://www.amazon.com/Esky-Controlle...dp/B00D74GRGM/
I think next time I would like to try a omni/multi directional antenna. know a top of the line one to get or what company makes good ones? I wasn't too impressed with this Esky antenna
i'm interested in the following 2 antennas. anyone have any experience with them?
Winegard MS-2002 HDTV Antenna
http://www.amazon.com/Winegard-MS-20.../ref=pd_cp_e_3
LAVA OmniPro HD-8008 omni-directional HDTV Antenna
http://www.amazon.com/LAVA-OmniPro-H.../dp/B00EPP5ZSS
lucasland is offline
post #7112 of 7115 Old 08-15-2014, 06:11 AM
sgbroimp's Avatar
Quoted: 39 Post(s)
You should plug your location into TV fool and have a look at what that shows in terms of pulling in CH8 from your exact location. As for the antenna, sadly a lot of that is trial and error, but if you have no amp on it, this might be worth a try (buy at Rat Shack and don't make a mess of the package, keep your slip etc.). It may well be you need to spend $90 or so like I did for a deep fringe UHF/VHF and an $20 amp. Also be aware terrain can play a role. From the shoreline, most if not all of us can not pull in Ch3 Hartford because of some hilly terrain in the way and that could be a killer for you on Ch8 also. Unless and until they bulldose that (ha-ha), no antenna available will help unless it is on a 300 ft tower. Do be sure you have your antenna oriented also, as a few degrees can matter. Rotator is of course the ideal on that.
sgbroimp is offline
post #7113 of 7115 Old 08-15-2014, 08:12 AM
lucasland's Avatar
can you link the antenna and amp you're talking about?
post #7114 of 7115 Old 08-15-2014, 08:42 AM
sgbroimp's Avatar
Quoted: 39 Post(s)
Boy, it was quite a while back, but I know the brand was Antennacraft for the antenna. Not sure about the amp, but I think it was something like a 20 db gain. It is powered so one end gets hooked into the coax at the TV and right there needs to get AC also. Other part goes on the antenna. The RS dealer ought to be able to show you all this and, again, if you don't mess up the packing too bad and keep your slips, you can test and take back if NG. I did not buy the deepest fringe antenna and in fact it is installed in the attic of my garage as we do not like the look outdoors and only use it as emergency back up to cable. Can you perhaps walk your neighborhood and see if someone has an antenna up and ask if they pull CH8? A little gutsy, but might help.
sgbroimp is offline
post #7115 of 7115 Old 08-15-2014, 05:21 PM
100/40's Avatar
Here's where I'm at. My son lives in Stratford. No Cable. This is on the house with amp.
http://www.solidsignal.com/pview.asp...ce=google_base
Came with the house and they don't want cable. NYC stations with CH 8 coming in from the back, probably due to location.Well it quit. Probably the amp. On the peak of a colonial. Son says I'm too old, perhaps true, and he doesn't like heights. I ordered this
http://www.amazon.com/RCA-ANT751-Dur...ds=rca+antenna
Tried it a home, south Wethersfield, replacing a double bow tie. The bow tie gave me locals plus Springfield, no CH 8. The RCA picked up CH 8 from the side (VHF) which I never got before. No CH 59 which I suspect is on the same tower. My antenna location about 1.5 feet above gutter on a ranch. So off to Stratford. Mounted on an old satellite mount on the chimney. Height about second floor level. Fair reception. 8 OK off the back, probably due to location. Picked up CH 7 (ABC) since this antenna has VHF. Most other channels OK but CH 4 (NBC) in and out. Found out they are on Empire State building as is CH 2, but with less power. Will try to get CH4 solid with this.
http://www.amazon.com/RCA-TVPRAMP1R-...rca+amplifrier
Ordered today.
So you see it's not too cut and dried. If this works out at my son's I plan on getting the RCA antenna for myself. I have cable but use the antenna for emergencies and CH 57 Springfield, which cable does not have in HD, and I like to fool around with this stuff. Good luck.
100/40 is offline
User Tag List
