Hartford, CT - OTA - Page 240 - AVS Forum | Home Theater Discussions And Reviews
post #7171 of 7194 Old 01-12-2015, 01:50 PM
Liked: 0
Help in Waterbury
#4
mackz1960 is offline
post #7172 of 7194 Old 01-12-2015, 01:51 PM
Liked: 0
Help in Waterbury
#5
post #7173 of 7194 Old 01-12-2015, 01:59 PM
Liked: 0
Help in Waterbury
By my count, this is post 6. As I said in my original post, I live in Waterbury and am looking for some help and or advice on antenna selection so that I may cut the Cable from Comcast. Here is my TVFool plot
http://www.tvfool.com/?option=com_wr...2c15d0f9630058
As previously stated, unfortunately, in the attic is the best that I will be able to do, and that is not 100% certain, as I have to get the landlords permission. I watch a Panny 55ST60 plasma, and the picture is great ! I'd like to keep it that way, without Comcast.
Mackz
post #7174 of 7194 Old 01-12-2015, 02:16 PM
Liked: 0
Help in Waterbury
Some additional details. The building I live in is a standard frame structure with typical shingle roofing (only one layer of shingles as the roof was stripped down 2 years ago). Walls are drywall with wood frame studs. If I can get into the attic, I will be 20-25 feet above ground level. My apartment runs approximately N-S, with windows facing both directions on both floors. Thanks for your attention .
Mackz
post #7175 of 7194 Old 01-13-2015, 06:32 AM
sgbroimp's Avatar
Quoted: 185 Post(s)
Originally Posted by BiggAW View Post
Yeah, WVIT must be more then. There's no way a person can see 3ms vs. 0ms. Maybe 50-100ms. I usually adjust increments of 10 or 20ms, and even then I can't see one or two increments.
Last night the synch issue on NBC Evening News was a good deal better, perhaps not perfect, but now I need to adjust my end back to zero and maybe that will do it. They had something goofy going on there for sure.
sgbroimp is offline
post #7176 of 7194 Old 01-13-2015, 09:44 AM
ctdish's Avatar
Quoted: 39 Post(s)
Liked: 25
Makz, your best bet is to get a small antenna with high VHF coverage for WTNH. You could use this http://www.walmart.com/ip/10828410?w...872274&veh=sem or http://www.solidsignal.com/pview.asp...u=716079000987 . It should be aimed at New Haven 148 Deg.
A mid sized UHF antenna aimed at the Hartford channels possibly with a preamp should get the rest of the network stations. Possibilities include http://www.solidsignal.com/pview.asp...0Antennas&sku= or http://www.solidsignal.com/pview.asp...0Antennas&sku=
The signals from the two antennas can be combined with http://www.solidsignal.com/pview.asp?p=UVSJ&ss=420115
John
ctdish is online now
post #7177 of 7194 Old 01-13-2015, 02:56 PM
BiggAW's Avatar
Quoted: 247 Post(s)
Liked: 63
AntennasDirect is known for their OTA stuff. Not that SolidSignal is bad, but they are just a reseller. AntennasDirect designs their own stuff.
BiggAW is offline
post #7178 of 7194 Old 01-13-2015, 03:14 PM
ctdish's Avatar
Quoted: 39 Post(s)
Liked: 25
I provided the links to give a sample model and some info on the antennas. Other similar antennas would probably work as well and the same model can be bought any dealer the person wishes.
John
post #7179 of 7194 Old 01-16-2015, 05:16 AM
lucasland's Avatar
Quoted: 12 Post(s)
WRNT ch. 48
I discovered some new info. I always thought it was showing Retrotv, but apparently its AMGTV. If you want to see clearly what the channel is showing just go to their website, which shows the broadcast online for free. http://www.amgtv.tv. I also came across some other persons comments regarding WRNT on another site. they said :
"WRNT used to be a Retro TV affiliate years ago, but in the last several years it has carried the AMGTV network. Retro TV's national website still (wrongly) lists WRNT as its Connecticut affiliate. While WRNT is still on the air as of this writing, its new owner, Landover 5 LLC, plans eventually to cease broadcasting and use Channel 48's frequency for wireless broadband. Landover 5 has purchased many low-power TV stations across the U.S. to use the channels' frequencies for this national broadband venture. "
Here are some links of interest about landover
http://www.landoverwireless.com
http://rbr.com/lptv-fan-landover-5-strikes-again/
lucasland is offline
post #7180 of 7194 Old 01-27-2015, 01:41 PM
lucasland's Avatar
Quoted: 12 Post(s)
new winegard automatic antenna
what you people think of this new automatic antenna?
http://www.winegard.com/rayzarauto/
post #7181 of 7194 Old 01-27-2015, 02:02 PM
100/40's Avatar
I would like to see some real reviews. I have seen it priced at about $350. It better be really special.
100/40 is offline
post #7182 of 7194 Old 01-29-2015, 01:59 PM
BiggAW's Avatar
Quoted: 247 Post(s)
Liked: 63
That looks pretty cool. For an RV.
BiggAW is offline
post #7183 of 7194 Old 03-20-2015, 06:10 PM
WHNB's Avatar
Laff and Escape Coming To WFSB Sub-Channels
News broke today on tvnewscheck.com that the comedy network Laff will be carried on Channel 3.3 and Escape, a movie network geared toward women, will be on Channel 3.2. No specific launch dates were mentioned, but Laff will debut nationally on April 15th.
WHNB is offline
post #7184 of 7194 Old 03-22-2015, 07:05 AM
BiggAW's Avatar
Quoted: 247 Post(s)
Liked: 63
Great. Even more over-compression on WFSB-DT. How many subchannels are they running now and how many will be carried after this?
BiggAW is offline
post #7185 of 7194 Old 03-23-2015, 09:05 AM
OTAzak's Avatar
First thanks for this news about WFSB and Laff, I was about to scrounge up and modify a Y10-7-13 to try to get Laff off the Empire State building which would probably only work where I'm at (a little north of Hartford in the CT river valley) during summer evenings (tropo) .
Escape on 3.2 will replace the weather side channel they have there now not clear if they will move that to 3.5
Laff will replace the 3.3 which is currently a 480i repeat of WFSB
About to move my indoor setup (DB4E + C2V dipole in second floor closet, old school CM 7778, old Digiwave 4 bay in attic cut in with Jointenna for ION only) outside and up high (5 feet above the roof, 34 feet AGL), will post a comparison with outdoor vs. indoor reception. My goal is to greatly improve reliability of 59.1, pickup 57.X MA PBS reliably from the DB4E backside, get WZME RC 42 (can only occasionally get PSIP info inside or hanging below gutter) and possibly pull in RC 23 WFTY out of Smithtown (GetTV, and Escape on sideband channels) along with all the other HD and sideband channels I now get (+/- 30 when there isn't 2 feet of snow on the roof)
All of this in preparation for telling Frontier/Uverse/Cox thanks but no thanks anymore.
OTAzak is offline
post #7186 of 7194 Old 03-23-2015, 02:30 PM
BiggAW's Avatar
Quoted: 247 Post(s)
Liked: 63
So how many subchannels is WFSB running in total? All this makes me want DirecTV, they are the only provider getting direct uncompressed feeds of the locals and compressing them themselves...
BiggAW is offline
post #7187 of 7194 Old 03-23-2015, 06:50 PM
OTAzak's Avatar
Its kind of tricky, some of the 3.X subchannels actually come from WSHM RC21 out of the Springfield area (same owner, only the morning/evening newsfeeds are different).
According to Rabbitears.info, 3-1, -2, -3 and -4 are off WFSB's tower, and 3-5, 6 are from WSHM's tower.
Given that 3-1 is 1080i, I would think 3-2 as Escape and 3-3 as Laff would not compress things too much as long as they shut 3-4 off.
ION has a half dozen subchannels on their 720i primary carrier . . .
OTAzak is offline
post #7188 of 7194 Old 03-24-2015, 03:24 PM
BiggAW's Avatar
Quoted: 247 Post(s)
Liked: 63
Interesting. 2 subchannels, while obviously not the ideal situation of a single 1080i channel, isn't actually that bad, at least in theory.
BiggAW is offline
post #7189 of 7194 Old 04-09-2015, 09:19 AM
mickinct's Avatar
Quoted: 87 Post(s)
Liked: 619
Hello members, does anyone know the reason for WVIT or NBC when recording OTA the VOICE live is recording in the 4:3 aspect ratio, the commercials are ok, the show is 4:3. When viewing this live on monitors it is 16:9 , is this the cause? something called Active Format Description (AFD),signals . The show Chicago Fire following was ok 16:9
MickinCT
mickinct is online now
post #7190 of 7194 Old 04-15-2015, 06:55 PM
pauldow's Avatar
Now We Can Laff
It looks like WFSB has changed over to Laff on 3.3 (33.3). It looks like a pretty good selection of movies, however it looks like they don't have many repeat series. With the frequency they're running them, they should burn out pretty fast. It would be nice if they could afford some original programming.
I still don't see anything on 3.2. It would be nice if they used a translucent bug like Cozi, or better yet, the short identification like Antenna does. But it's better than Now. Curiously, their Now channel never showed any weather warnings.
It's nice not having that Eyewitness News theme on the air all the time. When they first started their Now channel I could take it for about 10 seconds. It quickly got annoying after about 1/4 second. Another annoying thing about Now was that they changed the weather for the next day at about 4 PM. They didn't show the weather for that evening.
Now if they can just adjust their bit rate to get rid of the blockiness on their primary channel. Whenever there's a lot of motion like on the Price is Right, or if confetti is shown after a sporting event win, the picture is just gone.
Paul
pauldow is offline
post #7191 of 7194 Old 04-16-2015, 04:34 AM
AVS Club Gold
Scott Greczkowski's Avatar
Quoted: 17 Post(s)
You need to rescan to get 3.2. Everything is running now.
After rescanning last night on my Samsung HR8550 4K TV, I lost WVIT. It took 8 scans to finally get it back in which is strange since Newington is so close to the tower.
Scott
SatelliteGuys.US / MultiChannel News
Scott Greczkowski is offline
post #7192 of 7194 Old 04-16-2015, 08:09 AM
OTAzak's Avatar
3.2 is now Escape, no need to get it from 67.4 now (from Long Island).
OTAzak is offline
post #7193 of 7194 Old 04-18-2015, 03:06 PM
terminal_man's Avatar
Eh, I'd rather have ME-TV. WZME is outside my reach especially with a wall of trees to the south.
terminal_man is offline
post #7194 of 7194 Old 06-12-2015, 11:25 AM
MadMan400096's Avatar
WRNT ch. 48
As I said in the Springfield, MA thread, the owners found out about Landover's plans and shot them down, as I learned from a call to the owner. Now they're being sold to Tyche Broadcasting. All I know of Tyche is that they tried and failed to buy WPXT in Maine.
MadMan400096 is offline
