Hartford, CT - OTA - Page 243 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #7261 of 7270 Old 08-30-2016, 05:20 AM
fred9's Avatar
Originally Posted by fred9 View Post
update The plot thickens Channel 3 came in perfectly this morning from 7 to 9:30 AM when I the house. But now at 1:28 PM back to freezing and "no signal" briefly like yesterday afternoon..
Channel 3, WFSB, CBS is now choppy, breaking up often.
I'm in Simsbury and a few weeks ago I put up a Winegard Free Vision Model FVHD30H on the north side of my house facing north at about the gutter level on a 2 story house. I get great reception of the MA stations NBC 22, PBS on 57, ABC on 40.1 and FOX on 40.2. Attached is the listing of the local stations. It shows Channel 3 is the closest to my location but about 180 degrees opposite.
Does this antenna do poorly for stations on the back side?
The antenna is at the east corner. Should I try to turn it to face more towards the east?
Any other ideas?
Let me know if I should move this to the technical forum http://www.avsforum.com/forum/25-hdtv-technical/
This is my first try at "cutting the cord".
All stations are ok now that I turned the antenna 180 degrees. I now even get Channel 8 out of New Haven (Hamden).
fred9 is offline
post #7262 of 7270 Old 08-30-2016, 07:35 AM
KEVINL71's Avatar
Quoted: 27 Post(s)
You should also be getting channel 59 (MY), since they transmit from the same area as channel 8...Madmere Mountain in Hamden.
Did your reception of the Springfield, MA stations change much? I don't get them here in New Britain...although I did get channel 40 to pop in a time or two in either late spring or early summer.
KEVINL71 is online now
post #7263 of 7270 Old 08-31-2016, 06:18 AM
fred9's Avatar
KEVINL,
I do not get 59.
The stations from MA seem to be coming in very good. But as I type this at 9:15 am Channel 30, NBC here in CT is breaking up a little. And over on Highdef I was told to wait to see how good my reception is in bad weather. So maybe I'm not "all set".
fred9 is offline
post #7264 of 7270 Old 08-31-2016, 06:30 AM
KEVINL71's Avatar
Quoted: 27 Post(s)
Channel 30 breaking up? WOW! Simsbury isn't that far from Rattlesnake Mountain in Farmington! My New Britain address gets listed as 4.5 miles from their site. If I don't get them, CW 20, PBS 24 and FOX 61, I'm in some serious doo-doo!
Sometimes, in my struggles to get channel ABC 8 to come in stable, I'll get a blip of WEDN-TV (PBS) channel 53 from Norwich. They use VHF channel 9, of course.
As for matching stations like WEDH and WEDN, I often get WPXQ-TV (ION) channel 69 from Block Island/Providence. Of course it's the exact same thing as channel 26 of New London, minus the tiny print top-of-hour legal ID.
post #7265 of 7270 Old 09-06-2016, 05:11 PM
OTAzak's Avatar
Originally Posted by WHNB View Post
Around last Thursday, Hartford's WRNT moved from channel 48 to channel 32. The station's website confirms the new channel number. Channel 48 is now a black screen. Here's the owner's link:
http://www.intriguemusic.com/info
Has anyone been ale to receive real channel 32 ? I have a variable attenuator to suppress channel 33 (virtual 3-1 through 3-4), which might be affecting RC32 as well.
@ fred9 and at least one other recent poster, I think you are suffering from too much signal. When this happens you will lose all but the strongest one or two signals. Try pointing your antenna away from nearby towers, and if you have the capability in your TV check your signal to noise ratio for each channel.
OTAzak is offline
post #7266 of 7270 Old 09-07-2016, 05:10 AM
KEVINL71's Avatar
Quoted: 27 Post(s)
Not seeing anything from these channels in the south end of New Britain. Of course I'm using an indoor antenna on the second flood, near the bottom of Walnut Hill.
post #7267 of 7270 Old 09-07-2016, 02:58 PM
WHNB's Avatar
Originally Posted by OTAzak View Post
Has anyone been able to receive the real channel 32?
My Channel Master off-air tuner/DVR automatically found this channel on August 11th and added it to the tuner's channel line-up. I'm in East Windsor with an indoor antenna that is next to a west-facing window on the second floor, but the antenna is facing northeast so that I can receive the Springfield PBS station in addition to most of the Connecticut stations.
The new owner of WRNT and WTXX also represents music artists. The primary channel is running a promo that it will soon be showing music videos in the morning along with weather forecasts. WRNT has already shown the first episode of a program done in Hartford (possibly in Bushnell Park) that features a psychic medium giving readings to people who walk up to her booth. The show is called "The Pop-Up Psychic". Another ongoing local show, "Just Eat It", visits Hartford restaurants. These programs look like that they have been produced in HD, but because channel 32 is broadcast in 480i, the shows are in standard definition with black bars on the top and bottom of the screen.
When these local shows aren't on, the station shows the AMGTV network - but then the audio is out of sync and the picture is not as sharp as it could be. The channel runs some well-produced top-of-the-hour computer animated station identifications. These IDs show the call letters and Hartford; no channel number is indicated.
On the secondary channel, 32-2, there is a network aimed toward natives of India - the DIYA network. There is no information in the electronic program guide for WRNT, so programs can't be time-shifted easily with the off-air DVR. In addition to the Hartford and Springfield stations, the company also owns a station in Providence, Rhode Island - WCRN, channel 25.1.
Here are the artists that Intrigue Music represents: http://www.intriguemusic.com/management/.
The Intrigue Group has worked with these artists: http://www.intriguemusic.com/publishing/.
WRNT on Facebook: http://facebook.com/IntrigueTV/.
The station is at 6 Central Row in Hartford. It broadcasts from the WCCC radio station tower on Albany Avenue in West Hartford, and the Springfield station broadcasts from the same tower that Meredith's WSHM (CBS 3) transmits from (in Wilbraham).
WHNB is offline
post #7268 of 7270 Old 09-24-2016, 10:38 AM
prashp1's Avatar
http://www.tvfool.com/?option=com_wr...e2cbd5fd2db729
Hi. I am in Danbury, CT. I get channels 20 (20.1) WCCT, 35 (30.1) WVIT, 42 (43.1) WZME clear all the time with no problems at all.
I have a LG 4K TV that is on a TV stand with swivel. If I move the TV swivel left or right, some times channels 33 (3.1) WFSB, 45 (24.1) WEDH, 49 (49.1) WEDW, and 31 (61.1) WTIC comes and goes. I have a Mohu Leaf Ultimate indoor antenna and Winegard 20 db amplifier.
I don't get channel 10 (8.1) WTNH at all. Any suggestions on getting the channels that comes and goes all the time? OR even WTNH? Thanks
prashp1 is offline
post #7269 of 7270 Old 09-24-2016, 03:55 PM
WHNB's Avatar
Originally Posted by prashp1 View Post
Hi. I am in Danbury, CT. I get channel 20 WCCT, 30 WVIT, 43 WZME clear all the time.
I have a TV that is on a swivel. If I move the TV left or right, some times channel 3 WFSB, 24 WEDH, 49 WEDW, and 61 WTIC comes and goes. I have a Mohu Leaf Ultimate indoor antenna and Winegard 20 db amplifier.
I don't get channel 8 WTNH at all. Any suggestions on getting the channels that comes and goes all the time? OR even WTNH? Thanks
Channels 20, 24, and 61 are on the same tower in Farmington, so I'm not sure why you are able to receive only WCCT. Channel 3's tower is in Avon and Channel 30 has its own tower in Farmington.
The gomohu website says that the Leaf antennas are multi-directional - able to pick up signals from all directions. But Channel 8 is VHF while the other stations are UHF. I looked at the FAQ section of www.gomohu.com and it mentioned that their antennas work really well with UHF, but some VHF signals are elusive. The Leaf Metro and the Leaf 30 may pick up a VHF station if it's in a 10 mile range from your residence. The Leaf 50 may pick up a VHF station if it's in a 20 mile range. According to www.distance-cities.com, the distance from Danbury to Hamden (where Channel 8's tower is located) is around 28 miles.
If you submit your street address and zip code to support@gomohu.com, they will do a detailed analysis of the stations that you should be able to receive with the Leaf antenna. They will help you trouble shoot reception problems. You can also phone them Monday through Friday from 8AM to 5PM at 855-446-6648. This information comes from their website. I hope this will help you.
WHNB is offline
post #7270 of 7270 Old 09-24-2016, 07:34 PM
KEVINL71's Avatar
Quoted: 27 Post(s)
How is your reception of either WEDW-TV (PBS) channel 49 of Bridgeport or WCTX-TV (MY) channel 59 of New Haven? I think channel 49 transmits from Booth Hill in Trumbull while channel 59 is on Madmere Mountain in Hamden with WTNH-TV (ABC) channel 8.
Any luck with WTBY-TV (TBN) channel 54 of Poughkeepsie, NY? I got that and grand total of once during the analog days in New Britain.
