South Bend, IN - HDTV - Page 123 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #3661 of 3911 Old 06-09-2011, 08:25 PM
morphinapg's Avatar
Quoted: 482 Post(s)
Liked: 237
I'm using Windows 7 Media Center with two Hauppauge HVR-1250's. I also can't use an outdoor antenna so I got the Terk HDTVi and after I positioned it towards the broadcast antennas (they're mostly all in the same direction) I haven't once dropped my signal, when I used to drop it all the time, so I highly recommend that antenna if you have to use an indoor antenna.
Sony XBR65X930D, Sony HTCT780, PS4 Pro, Philips BDP7501
Panasonic TC-P50UT50, Denon AVR-1911, Base PS4
Check out my video game movie edits
morphinapg is online now
post #3662 of 3911 Old 06-10-2011, 08:14 AM
whachano's Avatar
Thanks for the suggestions guy's!! You all are a big help. Once I get everything I'll probably be back with a few more questions.
whachano is offline
post #3663 of 3911 Old 06-12-2011, 09:00 PM
Phoenixfury's Avatar
Quoted: 17 Post(s)
I'd also like to add that if you have an Xbox 360, you can use that as a Mediacenter extender. This is a better solution than hooking the computer to the tv in my opinion. This also allows you to leave your computer setup in another room as well. this also cuts down on the distraction of fan noise your computer may produce. If you use a 360 for this purpose, make sure you enable "wake on LAN" in the pc's bios. This allows the 360 to wake your pc up from sleep mode when it's needed.
I'd also like to add that wake on LAN is also handy for the Apple TV (2nd gen) if you have an iOS 4.x device and the remote app. Your Apple TV won't wake your pc from sleep mode (at least not as of yet) but the remote app will wake your pc if you use it to access iTunes. I think it's odd that Apple doesn't allow an Apple TV to wake a pc, but the remote app does on any other iOS device. I think of this as a work around I discovered that should have been enabled on the Apple TV in the first place.
Phoenixfury is offline
post #3664 of 3911 Old 06-17-2011, 05:35 AM
mbkeller's Avatar
57.2 has been added to Comcast, channel 244, clearQAM 121-5. It's on the little DTA's as well as the main boxes, unlike 25.2 (just on the main box).
Is there a programming guide online for 57.2?
mbkeller is offline
post #3665 of 3911 Old 06-17-2011, 11:08 AM
alesch1's Avatar
TitanTV and Zap2it both have listings for 57.2.
alesch1 is offline
post #3666 of 3911 Old 06-18-2011, 12:56 PM
JGTech's Avatar
I wonder how many boaters on Lake Michigan between New Buffalo and St. Joseph, MI can see the Special Marine Warning on ABC 57.1. I could be wrong, but I don't recall any other local station ever disrupting national programming for marine warnings.
JGTech is offline
post #3667 of 3911 Old 07-05-2011, 12:01 PM
rmcdonough's Avatar
Anyone else getting test pattern on 28-1???
rmcdonough is offline
post #3668 of 3911 Old 07-05-2011, 12:02 PM
rmcdonough's Avatar
Sorry, I meant 28-2
post #3669 of 3911 Old 07-05-2011, 12:10 PM
Trip in VA's Avatar
Quoted: 608 Post(s)
Liked: 166
Send a message via AIM to Trip in VA
Looks like ABC's Live Well network is coming soon to 28-2.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #3670 of 3911 Old 07-05-2011, 03:03 PM - Thread Starter
justalurker's Avatar
Yep. They have text over the screen confirming that. (There is an infomercial playing at the moment.)
Extended Channel Name: Live Well
Elementary Stream PID 65 (0x0041) MPEG-2 Video
MPEG Video: Bitrate 2.800 Mbps Resolution 720 x 480i
MPEG Video: Framerate 29.97 fps Aspect Ratio 4:3 Chroma Format 4:2:0
Elementary Stream PID 68 (0x0044) AC-3 Audio
AC3: Bitrate 192 Kbps Sample Rate 48 KHz
AC3: Mode complete main Coding 2/0 L, R
AC3: Dolby Surround Mode Not Dolby Surround
AC3: LFE Mode Off Dialogue normalization -27 dB
At least it is SD ...
justalurker is offline
post #3671 of 3911 Old 07-05-2011, 03:37 PM
Trip in VA's Avatar
Quoted: 608 Post(s)
Liked: 166
I gleaned the information from this image: http://img.lineupui.silicondust.com/...t_29814757.jpg
- Trip
N4MJC
RabbitEars
post #3672 of 3911 Old 07-05-2011, 08:47 PM
Quoted: 17 Post(s)
- Trip
Someone at Fox 28 must really miss having that ABC affiliation. LOL! Now they'll get it back.. Well only partially. :-)
post #3673 of 3911 Old 07-05-2011, 09:10 PM
LithOTA's Avatar
At least it's not HD, which would do to WSJV what it did to WLS- make it look like dog snot.
LithOTA is offline
post #3674 of 3911 Old 07-08-2011, 01:20 PM
Maxdout38's Avatar
I re-scanned my TV to pick up 28.2 and I found 2 extra channels. 006-01 & 006-02 WITI in Milwaukee (FOX6) were scanned into my TV from the South Side of South Bend. I have no signal at this time. Must of been an atmospheric thing going on!!! Wierd!!!
Maxdout38 is offline
post #3675 of 3911 Old 07-08-2011, 01:51 PM
morphinapg's Avatar
Quoted: 482 Post(s)
Liked: 237
Happens sometimes. One time I picked up signals from Ohio. This was before DTV but still it was pretty clear and that was pretty far away.
post #3676 of 3911 Old 07-08-2011, 02:47 PM
sebenste's Avatar
Quoted: 23 Post(s)
Yep....tropospheric ducting, or "skip" was happening. Check out the Chicago OTA thread, and you'll see that we were even locking Weigel's low power stations from the northwest suburbs of Chicago! That, and even channel 5, 7 and 11 from Grand Rapids (stomping on WLS-DT 7 in Chicago!).
Gilbert
sebenste is offline
post #3677 of 3911 Old 07-08-2011, 02:48 PM
LithOTA's Avatar
Uh, for the last 2 nights ALL of your South Bend stations were coming in strong into Northern Illinois- including LPs WBND and WMYS. Lots of Grand Rapids and Cadillac stations from Michigan too. Wonderful stuff, that tropospheric enhancement.
Edit: D'oh! Gilbert beat me to it!
LithOTA is offline
post #3678 of 3911 Old 07-16-2011, 01:11 PM
mbkeller's Avatar
Is 28.2 live? I reset my Media Center machine and the guide data for 28.2 exists (I pull off of Comcast, who still thinks that .1 is on .2)...
mbkeller is offline
post #3679 of 3911 Old 07-17-2011, 12:23 PM - Thread Starter
The "coming soon" banner is gone from 28.2 ... currently airing a "Paid Program".
(Oddly enough, at the moment 28.1 PSIP is empty and 28.2 is populated.)
post #3680 of 3911 Old 07-27-2011, 07:26 AM
Quoted: 17 Post(s)
Do you guys see something like this happening in our area? I guess this would be better than slicing off pieces of existing broadcasts for mobile internet. However I don't see this white spaces internet being the be all end all solution for mobile internet. I don't see phones taking advantage of this because if my phone has to send and receive to a tower that's even within 30 miles, my battery is going to be dead in like two seconds.. (Not to mention my hand is probably going to feel rather toasty among other things..) I think this would have to be a more stationary solution like DSL or cable.
I know this white spaces thing has been a very controversial topic among broadcasters. So what's your take HVS? Would you rather use white spaces, slice off some precious data from existing bandwidth, or cut off your arm? LOL!
Here's the latest article about white spaces.
http://www.engadget.com/2011/07/27/i...e-almost-felt/
post #3681 of 3911 Old 07-28-2011, 03:32 AM - Thread Starter
I don't see white space working on handheld devices for several years. 4G will use the last bandwidth "surrendered" by OTA ... perhaps 5G or 6G phones will be able to use whitespace UHF channels. That leaves non-handheld portable usage and fixed location usage for the short term.
I expect that 5G/6G will be able to receive "whitespace" UHF as a high bandwidth return channel for data requested over existing frequencies or perhaps as a broadcast service. I'd also like to see those devices work with ATSC Mobile TV, but that might conflict with the content transmitted on whitespace. (Why allow free Mobile TV access when one can charge for IP delivered TV content? Eventually local TV stations will get their piece of the action and support IP delivered TV.
If the TV band is compressed to "free up" a large block of channels I wouldn't call that "white space". White space infers gaps between current licensed broadcasters - not new "wireless only" spectrum.
So at first I expect we'll see fixed location use ... then mobile use (RV, van and other portable devices that are bigger than handheld). I expect by the time "whitespace" gets to handheld devices it will be a wireless only band - especially two way usage. We might see transmit only "whitespace" to handheld before that.
post #3682 of 3911 Old 07-28-2011, 07:59 AM
mbkeller's Avatar
Channel *345* on Comcast, 117-3 for QAM. Really dumb place for it, especially since 246 is open (and would put 57.2, 25.2, 28.2, and 22.3 all together).
mbkeller is offline
post #3683 of 3911 Old 08-23-2011, 02:13 PM
swiat's Avatar
it could be worse... a tornado could hit the area...
Seriously though, LivWell is pure crap and a waste of bandwidth.
swiat is offline
post #3684 of 3911 Old 08-25-2011, 11:18 AM
mbkeller's Avatar
I was jumping ahead in my guides and found that ABC57 apparently will be doing a 7PM newscast starting 9/6.
Has there been any movement with WNDU and a different sub-channel? Kind of disappointed we don't have Universal Sports or a dedicated radar feed (again).
mbkeller is offline
post #3685 of 3911 Old 09-10-2011, 07:10 AM
JGTech's Avatar
On the subject of guides, Weigel stopped broadcasting PSIP guide data for all of the South Bend stations yesterday.
JGTech is offline
post #3686 of 3911 Old 09-12-2011, 03:04 PM
JGTech's Avatar
Guide data is back today with lots of programming changes on 57.2 (and 69.1 and 25.1).
JGTech is offline
post #3687 of 3911 Old 09-15-2011, 11:32 AM
mbkeller's Avatar
Universal Sports is getting dropped as a sub-channel
mbkeller is offline
post #3688 of 3911 Old 12-13-2011, 11:04 AM
Maxdout38's Avatar
I've noticed watching 25-01 OTA that the feed is never smooth. Someone told me the feed comes from Chicago. When WBND build their place, will they get the feeds from satellites like our other locals?
post #3689 of 3911 Old 12-13-2011, 11:15 AM
Quoted: 17 Post(s)
It's nice to see that WBND is shedding light on geocaching. I took up this hobby over the summer which is part of the reason I hadn't been on here as much.
I do want to comment on what Maxdout38 just said though. I wonder if his observation is what affects 25.2 ThisTV on my Windows Mediacenter. It's the only channel that is really choppy for me. Otherwise all of the other channels are fine for the most part. For some reason the only work around is to just tune into my Mediacenter PC through the Xbox 360 which seems to fix the choppiness. It's odd that my PC does this and my 360 doesn't. Perhaps it's the difference in graphics chipsets. My PC has an AMD (formally ATI) Radeon HD 5750 and the 360 has a custom ATI GPU in it. I've never see this issue with my Nvidia boards but this card I have now blows away any Nvidia board I've ever had.. Yet this video anomaly exists and drives me bonkers!
post #3690 of 3911 Old 01-19-2012, 05:43 AM
Maxdout38's Avatar
Anyone notice FOX28 News at 10PM was in HD!!!
About time!!!!
