South Bend, IN - HDTV - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #1171 of 3909 Old 09-14-2007, 02:53 PM - Thread Starter
justalurker's Avatar
The reboot helped!
Other OTA DTs at my location:
"16" - 70 but breaking up (bad encoder or multipath?)
"22" - 92
"28" - 85
"34" - 74
"46" - 79
BTW: I have RS's cheapest UHF antenna ... U-75R ... Catalog #: 15-2160
justalurker is offline
post #1172 of 3909 Old 09-14-2007, 02:54 PM
Kirby Baker's Avatar
Between White Pigeon and Sturgis MI, 34.7 miles away, towers at 254 degrees, and it looks like I am a bit too far away.
25.1 = peak 63, bouncing between 0 and 58, breakups
57.1 = bouncing signal from 0 to 58, had a peak of 63
69.1 = signal is more stable, 50-53%, still has lots of breakups
By comparison:
16.1 = 88
22.1 = 70
28.1 = 63
46.1 = 83
34.1 = 89
Now I may be able to tweak my antenna, as I was peaking it on 34.1 previously as that was my only channel I was trying for in HD, but now I can get PBS HD over cable, so hopefully I can peak my antenna on CW HD!
Kirby Baker is offline
post #1173 of 3909 Old 09-14-2007, 02:55 PM
Dakanez's Avatar
Originally Posted by hvs10trk View Post
Location, approx mileage from towers?
Bypass US20 and US 31 (michigain street) about where the new walmart/ chick fila is my location...
Dakanez is offline
post #1174 of 3909 Old 09-14-2007, 02:57 PM
nikitangc's Avatar
Originally Posted by cobby View Post
25.1 signal level good, but picture is breaking up
57.1 is perfect
69.1 signal level and video good, but no audio
I am in Bristol with a 30 foot tower
I'm in South Bend, not far from the tower and my tuner in the tv can't even pick up 69.1 with bunny ears.
nikitangc is offline
post #1175 of 3909 Old 09-14-2007, 02:59 PM
Dakanez's Avatar
channel- 25 100% signal
57 87% signal
69 92% signal
Dakanez is offline
post #1176 of 3909 Old 09-14-2007, 03:12 PM
eilros's Avatar
I'm able to get two of the signals: 25.1 @ 70-75 strength and 57.1 @ 60-65 strength using my DISH ViP622. I'll have to play with the antenna this evening to see if that helps.
eilros is offline
post #1177 of 3909 Old 09-14-2007, 03:14 PM
hd10rox's Avatar
25 - 60% signal, perfect picture/audio
57 - 100% signal, perfect picture/audio
69 - 75% signal, perfect picture, NO audio
I am located in Dunlap, just off of US 33.
hd10rox is offline
post #1178 of 3909 Old 09-14-2007, 03:59 PM
mxd
mxd's Avatar
16 and 22 perfect
Get nothing for 57. What is the chance for a waiver. Located near North Webster, over 30 miles SE.
mxd is offline
post #1179 of 3909 Old 09-14-2007, 04:07 PM
goldrich's Avatar
Quoted: 23 Post(s)
If anybody can please post your signal strength and town compared to other stations. Keep in mind we're only Low Power.
Compared to some of the DTV stations operating under STAs, your three LD stations are actually rather High Power... :-) Line of sight reception seems to be the key to good DTV reception. With your transmit antennas @ over 900 ft., reception in the area should be quite good.
Up until just over a year ago, the local CW affiliate station, WTTV-DT-48 (4-1) was operating with only 4 kW @ a little over 950 feet (HAAT) from its tower south of Indy in Trafalgar, IN. I live 37 miles north of the tower on the far north side of Indy and using a good high-gain antenna (CM 4221 or 4228, or Antennas Direct 91XG) @ 20-25 feet AGL, plus a preamp, I had a signal reading of 85-90%.
BTW, congratulations in getting the new LDs on the air!
Steve
goldrich is offline
post #1180 of 3909 Old 09-14-2007, 04:25 PM
Trowbridge's Avatar
I'm northwest of Elkhart, about 13 miles from the towers, with a Channel Master 4-bow antenna, and things are looking terrific here:
57.1 (UHF-49): 86%
69.1 (UHF-23): 81% (occasionally bouncing down to 72%)
25.1 (UHF-27): 85%
Time for the happy-dance!
Trowbridge is offline
post #1181 of 3909 Old 09-14-2007, 04:27 PM - Thread Starter
I upgraded my antenna to an amplified version. (Radio Shack DA-5200 Catalog #: 15-2186)
Still using my ViP-211 and ViP-622 DVR receivers. 12 miles out to the East.
23 (69.1) ... 66-67 (of 100)
27 (25.1) ... 74-75
49 (57.1) ... 0
42 (16.x) ... 0-69-73 (bad encoder?)
30 (22.x) ... 85-86
58 (28.1) ... 75-77
35 (34.x) ... 66-68
48 (46.x) ... 70-71
Seeing the other results for 57.1 (49) I'll try again later.
I'll also pull out my old DT tuner some time.
Oh yeah, I forgot to say THANKS! (and congratulations)
post #1182 of 3909 Old 09-14-2007, 04:56 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
As I feared, there is no guide data available from TiVo and I can't even tune to them with the Directv HR20 because Directv has never heard of these channels. For now, I can only view them live on the TiVos and can't see them at all on the HR20.
Mike Lang, Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Forum Club and help support the site. Help Support AVS Forum Sponsors.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
post #1183 of 3909 Old 09-14-2007, 04:57 PM
Trowbridge's Avatar
Those signal strengths seem awfully low for being just twelve miles from the towers with an amplified antenna -- even if it's a Radio Shack (which, sorry to say, I think is mostly overpriced garbage).
Is it possible you have a cabling problem? Or is the amplifier adjustable?
post #1184 of 3909 Old 09-14-2007, 05:00 PM
nikitangc's Avatar
I'm glad I'm not the only one going crazy! I was on hold with DirecTV and ended up hanging up. Did DirecTV give you any kind of timeframe as to when those channels will show up in the guide?
post #1185 of 3909 Old 09-14-2007, 05:05 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
I didn't call. I asked about this a while back...
http://www.avsforum.com/avs-vb/showt...8#post11129078
post #1186 of 3909 Old 09-14-2007, 05:16 PM
nikitangc's Avatar
O.k., so you didn't call DirecTV about it today. I'd like to be able to record these HD channels through the HR20 when the new seasons start in the next few weeks. I am doubting calling DirecTV is gonna change anything, but thought I'd at least call and see...
post #1187 of 3909 Old 09-14-2007, 05:18 PM
eilros's Avatar
I'm not getting the guide either and I have DISH.
eilros is offline
post #1188 of 3909 Old 09-14-2007, 05:33 PM - Thread Starter
Loser - get a real satellite service!
(Just kidding my fellow DBSTalk mod.)
In the past guide data has appeared the next day when I've added new OTA HD channels (this was true even when I managed to tune in 21.1 WPTA, 24 digital, out of Fort Wayne). Perhaps tomorrow we'll have EPG for 25.1 and 57.1.
I don't expect EPG for 69.1 since E* does not carry that channel.
Mike, are you getting EPG for 46.1 and 46.2? How about the other .2/.3 channels? E* customers in the SB market get all EPG for the old channels.
49 (57.1) ... 0
I realized that my home distribution has a channel on 50 ... when I turned that off I got 49 (57.1) with a 65 signal level. It keeps dropping out. I expect there is interference from 48 (46.1) ... perhaps the ViP tuner can't do side by side channels?
post #1189 of 3909 Old 09-14-2007, 05:47 PM
cobby's Avatar
Lost video on 25.1, signal level still good
cobby is offline
post #1190 of 3909 Old 09-14-2007, 06:06 PM - Thread Starter
57.1 ... Irish Rewind at 7:30pm (6:30pm CT) had some letterboxing issues ... very skinny tall football players with double width side panels.
post #1191 of 3909 Old 09-14-2007, 06:19 PM
NoToLowPower's Avatar
Just tried the new signals 30 miles north of Fort Wayne (well outside the coverage area for the LDs, but South Bend stations have never been particularly difficult to receive here, the main exception being 69). XG91 antenna, no amp. Signals are as follows:
WBND: steady 70, perfectly watchable
WCWW: 40s-50s, occasional drops to 0, no picture or sound
WMYS: 0 (IIRC, it's directional, so that's a given)
(UPDATE just before 9pm: WBND has just started jumping from the 40s to 70 with dropouts, largely unwatchable.)
NoToLowPower is offline
post #1192 of 3909 Old 09-14-2007, 06:19 PM
tvmicrowave2002's Avatar
Irish Rewind is a local show. Likely an issue with the program (editing) itself. What you see on the DTV is what has fed the analog since 12/05. The analog feed of 25 and 57 is a 4:3 crop of the HD.
All: Guide data on the OTA will come soon. 30 days or less. No time to configure right now. Programming will contact DirecTV and Dish so they will fix the guide issue on sat.
Really curious to hear general comments of signal strength and pic quality of all over the weekend. Thanks for all who have posted so far. Keep in mind that unfortunately these are FCC LP-DTV stations. We'd go full power tonight if we could. Hopefully we can get some waivers in the not to distant future to do so.
tvmicrowave2002 is offline
post #1193 of 3909 Old 09-14-2007, 06:28 PM
South Side MC's Avatar
~4 miles west of tower.
16-1 90
16-2 91
22-1 84
22-2 85
22-3 84
25-1 78 no audio or video now, had it ~5pm
28-1 87
34-1 85 (requires antenna adjustment)
34-2 83
46-1 85
46-2 85
57-1 29 to 54 jumping all over but have video and sound
69-1 80 great video but no audio
getting there, but looks like a few bugs are left
South Side MC is offline
post #1194 of 3909 Old 09-14-2007, 06:46 PM
jhs33's Avatar
I rescanned my local channels on my HR20-700 and 25.1 now shows in the guide the other two don't.
jhs33 is offline
post #1195 of 3909 Old 09-14-2007, 06:53 PM - Thread Starter
I have not seen any problems on 25.1 or 69.1 ... I have audio and video and have closed captioning on both. (It would be good to note the receiver if you're having problems.)
Hopefully E* will add the 69.1 data - even though they don't carry that channel via satellite. The other two are simple maps and could be easily done.
post #1196 of 3909 Old 09-14-2007, 08:37 PM
eilros's Avatar
It's been much better this evening. I've got 25, 57 & 69 in the 70-85 signal strength range but I do get a few dropouts on 57.
eilros is offline
post #1197 of 3909 Old 09-14-2007, 08:55 PM
cpferris's Avatar
I also have the HR20 issue. When I reset the antenna settings and re-scan, I still don't see them. But if I just plug some standard rabbit ears into my actual TV and bypass the HR20, I see them on my TV.
That being said, my HD antenna is currently fed into the back of the HR20. Can I run a splitter off of the antenna and feed both the HR20 and the tuner in my actual TV without and significant signal loss? That way I can still have the guide stuff for other OTA locals, but still have the good antenna feed the TV so that I get a good signal for watching 57-1 until it shows up on the HR20?
Also, I know how to check the signal strength of OTA HD channels with the HR20, but can you also do that through your actual HD TV itself? How are you guys that aren't running Dish or Direct reporting your signal strength?
Thanks for all the hard work on getting these up and running!
cpferris is offline
post #1198 of 3909 Old 09-15-2007, 04:02 AM
nikitangc's Avatar
I just rescanned this morning on my HR20 for the new channels and it doesn't pull up any of the new channels. I wonder why yours did and mine didn't. You just went through initial setup again, right?
post #1199 of 3909 Old 09-15-2007, 06:33 AM
seacrest's Avatar
Also trying to get 25.1 and 57.1. Do not show up in HR20 menu, I'm also going to try and call Directv and see if we can get enough pressure on them to update their guide.
seacrest is offline
post #1200 of 3909 Old 09-15-2007, 09:26 AM
Ralph43's Avatar
I have tried and tweeked my antenna and I can not pick up the signals. I receive 16-1 and all the earlier stations just fine. I live 15 miles ne near 6 span bridge in Elkhart.
Ralph43 is offline
