Fresno, CA - HDTV - Page 21 - AVS Forum | Home Theater Discussions And Reviews
Old 10-03-2005, 02:20 PM
maxpower2078's Avatar
DiCecco said:
You will need a vhf antenna to recieve ABC Fresno and Bakersfield , UPN Fresno and
Telemondo Fresno. WB Fresno,you will need a pre amp it is weak in our area.
With the proper antenna setup you can recieve many digtial stations in our area. You will also need a rotor to recieve all the stations.
I kind of see why I am not getting these channels now. So I have the Terk HDTVi, is there any hope for me. I have the Dvico fusion 3 something something and that antenna and I get nbc,fox,pbs, and cbs well, but what should I do to pick up the rest.
maxpower2078 is offline
Old 10-07-2005, 04:17 PM
videoaddikt's Avatar
Quoted: 32 Post(s)
Personally, I think a Silver Sensor is a better start than a Terk, but neither one will replace a good outside antenna..
Now, is anyone on this thread signed up with Comcast Digital, with a PVR, and can you tell me about your likes or dislikes. Thanks, always.
Samsung PN51F8500, Emotiva UMC200, Emotiva XPA-5, Samsung BD-H5900 BluRay, Dish Hopper, Furman Elite pf-15 conditioner, Dali Ikon (Ikon6, Vokal2, OnWalls) Outlaw Audio LFM-EX subwoofer.
videoaddikt is offline
Old 10-07-2005, 05:29 PM
sarasdad's Avatar
will a inside amp work like a outside pre-amp and what is the difference
sarasdad is offline
Old 10-16-2005, 09:23 AM
DogsFan's Avatar
Hey all - just picked up my first HDTV yesterday. I'm currently using an indoor antenna but planning to switch to DishHD soon.
Question - this morning (sunday am) i'm not getting many channels at all (only 30.1). Does this mean there is no content? My set shows a decent signal on some channels, but content.
DogsFan is offline
Old 10-16-2005, 10:07 AM
DogsFan's Avatar
Nevermind - figured out my set was set to "cable" not "ant". Fox showed up right away...
OH-MY-GOD - this loook awesome.
DogsFan is offline
Old 10-16-2005, 11:24 AM
DogsFan's Avatar
What's up with the fox audio on 5.1? 47 seems fine, fox is super low and very inconsistent. I thought it might be the output of my set, but 47 has been fine.
anyone else notice this?
DogsFan is offline
Old 10-16-2005, 11:31 AM
richeydog's Avatar
Originally Posted by DogsFan View Post
Hey all - just picked up my first HDTVyesterday.
Hey Dogsfan, what television did you buy? I'm using a Phillips 34pw8402 that we got from Costco. Love it. Although i wish it were a larger screen size.
richeydog is offline
Old 10-16-2005, 11:36 AM
DogsFan's Avatar
I got the Philips 30PW9110D from walmart. So far i love it. I read a few negative comments on another thread about SD content, but haven't had much chance to use it for my Dish yet.
I'm going to do some side-by-side with my previous set to compare my standard Dish feed.
the HD content is amazing though.
I would LOVE a larger set, but this is the biggest that will fit in my cabinet without going plasma/lcd, and the finance department won't approve that purchase ;-)
DogsFan is offline
Old 10-24-2005, 12:30 AM
Malo83's Avatar
Is it just me or is CBS not showing the games in HD, using a OTA antenna for HD viewing and the last two weeks both games were in SD. Fox games are in HD as well as ABC and NBC
Malo83 is offline
Old 11-04-2005, 02:22 PM
I am having trouble getting quite a few stations. The only ones I get are CBS 47, Fox 26, NBC 24 and PBS. I am using the Terk HDTVi indoor antenna. Anyone have any hints? I would like to have UPN, WB and ABC. I know you can get some of these outdoor antennas for pretty cheap now like the TV55 but didn't know if it would make that much of a difference because some of these stations are listed at the same spot as the channels I get fine by antennaweb, so I am guessing it is something else.
Old 11-07-2005, 10:11 AM
DrewM's Avatar
Get a real antenna for outdoors. Sparky's on Blacktone has quite a selection.
DrewM is offline
Old 11-11-2005, 08:25 PM
Steve S's Avatar
Liked: 46
Anyone else having problems with 30.1 the last coupla days?? Lost broke up intermittently Wed. night and by this morning (Friday) it was totally unwatchable. I'm getting it OTA via a HDTivo box, and it's been rock solid before this latest problem. All my other local digitals are fine, even those that show considerably lower signal strength than KFSN-DT.
Steve S.
Steve S is offline
Old 11-15-2005, 08:25 PM
fresnohd's Avatar
to me it seems like 26-1 is having a better picture the last few weeks. The 49ers games, House and OC look much better. I wonder if they did any upgrades.
Also anyone find a WB or UPN HD in Fresno?
fresnohd is offline
Old 11-17-2005, 09:44 AM
I don't know if I just noticed this or if it changed, but I see FOX coming in at 5.1 now. Has this been a new thing or am I crazy? I still notice all the other channels at 2 channel still. When is this going to be upgraded?
Old 11-17-2005, 01:25 PM
David Ortiz's Avatar
KFSN and KMPH are passing 5.1 audio when present.
KMPH started it at the same time they became HD capable.
If only KGPE would upgrade their equipment. (I watch many CBS shows.)
David Ortiz is offline
Old 11-17-2005, 02:17 PM
DrewM's Avatar
When you watch MNF do you get anything out of the rear channels? My amp shows DD 5.1 but nothing out the rears. Works just fine on the INHD DD 5.1 programs.
DrewM is offline
Old 11-17-2005, 03:38 PM
Ahh, that makes sense, I don't get KFSN yet, I am getting a better antenna.
Old 11-17-2005, 04:54 PM
snatch's Avatar
If any of you have D*, you can get ABCW HD in Fresno. It's been mentioned on this thread previously, but our local HD is owned and operated by ABC. All you have to do is call and get a waiver from D*. Might take 3 weeks or so, but you'll get it.
I get all of the digital stations pretty well except 30-1, one phone call and 3 weeks later I have no reception issues at all.
Never underestimate the predictability of stupidity
snatch is offline
Old 11-23-2005, 07:23 PM
Steve S's Avatar
Liked: 46
KMPH has been flawless for about a week now, the constant glitching is gone! I fought for months and finally got ABCW from DirecTV but they shut it off a coupla months ago, and I don't know why. I'm so PO'd at D anyway, only one new HD channel in the last year and it was another damn ESPN instead of TNT, STARZ, Cinemax HD, etc.
Steve S.
Steve S is offline
Old 11-29-2005, 05:17 PM
I talked to an engineer at KFREDT WB inquiring about when they are upgrading to be able to pass through the HD shows. He said they are planning to update their equipment in the 1st quarter of '06 and if they don't make that time, then the 2nd quarter. This is really good news.
Old 11-30-2005, 01:02 AM
snatch's Avatar
awesome, that is great news. So by 4th quarter it might actually be working right.
snatch is offline
Old 12-11-2005, 04:29 PM
Mach1_8's Avatar
Liked: 90
Hey...did anyone else lose 26.1 during the 49ers game? I still get analog, but the digital signal isn't there!?! Football in SD blows...
Dyin' ain't much of a living, boy...
Mach1_8 is offline
Old 12-21-2005, 01:43 PM
DrewM's Avatar
Does anyone hear watch MNF using their amps? If so do you get any sound out of the rear channel when your using DD 5.1? I called up ABC and asked them about this because crowd noise should be hear in the rear channel. I don't watch too many other ABC shows and I don't always use my amp so I don't know if its this way with all of there programming.
The engineer said he would hook up a 5.1 system and check this out.
And yes when I watch other DD 5.1 such as INHD I do get sound out of the rear channel.
DrewM is offline
Old 12-28-2005, 11:57 PM
MikeSM's Avatar
Hi. I'm from up the SF Bay Area, and just got a new Sony KDF-E42A10 for my mom in Fresno. I'm down here setting it up for her, and am trying to configure in the HDTV channels on Comcast Cable, since the set has a QAM tuner in it, and she doesn't want to deal with a STB. I have found ABC, CBS and PBS (and a few random others) that are being transmitted, but can't find Fox (KMPH) and NBC. Does anyone know what frequencies Comcast transmits these channels in Fresno?
Mike
MikeSM is offline
Old 12-29-2005, 05:13 PM
Try 80.1 and 80.2 for NBC and CBS. The others of interest are 109.1 and 109.3, ABC and PBS, respectively.
Comcast doesn't carry the HD version of KMPH.
Old 01-04-2006, 10:38 AM
Mach1_8's Avatar
Liked: 90
I've noticed the same, but was too lazy to do anything about it! My amp clearly indicates that I am receiving a 5.1 signal though. I'd be curious to hear what the engineer you spoke to says about it....
Mach1_8 is offline
Old 01-04-2006, 11:03 AM
DrewM's Avatar
I left message with the engineer Ron after the last MNF with no rear audio, he didn't call me back. However the last two bowl games had rear audio, so maybe they fixed it.
That was the reason I called with the Rose Bowl coming up and me having guest come over I wanted to have good sound, along with good picutre. We'll need to wait for ABC's playoff game to know for sure if they fixed it.
FWIW though no more NFL football on ABC and ESPN and NBC don't do 5.1.
DrewM is offline
Old 01-05-2006, 11:26 AM
sihawker's Avatar
Hello all I just got a new HDTV Samsung Slimfit and I am having a hard time picking up any HD stations. I am planning on installing an outdoor atenna but I am not sure which outdoor antenna to get and which direction to face it. I have checked antennaweb but I am still a little confused. Do antennas come with a compass and do I have to get up there and move it around all the time? Does the antenna pick up signals from all directions? Thanks for any help! I live just west of the 99 freeway near Central High.
sihawker is offline
Old 01-05-2006, 12:32 PM
DrewM's Avatar
The antenna that works well for me you can get at Sparky's on Blackstone. They are rectangle wire mesh with (2 or 4) bowtie elements. Face the bowties towards the east. You may have to move it a little north or south from there but once its set it in place "forget about it".
DrewM is offline
Old 01-05-2006, 01:37 PM
sihawker's Avatar
Will that atenna get all stations (UHF/VHF) OTA? Will a 5 ft pole be enough to get OTA stations?
sihawker is offline
