Jacksonville, FL - HDTV - Page 150 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #4471 of 4526 Old 10-17-2012, 11:09 AM
scolumbo's Avatar
Liked: 36
Originally Posted by bubbaprog View Post
I am leaving Jacksonville for St. Petersburg, and I only note that I've been waiting years for WAWS to join the 1990s and buy a 5.1 Dolby Digital encoder. They never did. Good luck to everybody in this forum.
I'll bet you won't have that experience in St. Pete. Jacksonville can certainly be backwards in a lot of ways. Good luck on the west coast.
scolumbo is offline
post #4472 of 4526 Old 10-20-2012, 01:02 PM
wmsbrum's Avatar
I have a Philips (not RCA) MANT-940 antenna. It does have a "power injector" but I do not have it plugged in.
wmsbrum is offline
post #4473 of 4526 Old 10-20-2012, 01:57 PM
tylerSC's Avatar
Quoted: 766 Post(s)
Liked: 171
You probably don't need amplification with a strong signal. That could overload and disrupt the signal. But sometimes amped antennas won't work unless they are plugged in. Try plugging it in but leave it turned off.
tylerSC is offline
post #4474 of 4526 Old 10-20-2012, 04:30 PM
Mister B's Avatar
Quoted: 17 Post(s)
It does not appear that antenna has an on/off switch or any method of adjusting the amount of amplification. When an amplified antenna is not plugged in or the power injector is not used, very little signal passes from the antenna to the tuner. I have over the years opened up several amplified antennas and removed the amplifier and wired around it. If you are up to that kind of work, it may improve reception, but of course will permanently alter the device.
The Radio Shack budget "rabbit ear and loop" antenna is often recommended on this forum for very strong signal areas such as described in Jacksonville. It looks like many low cost antennas that can be found at drug stores, etc. but has a larger UHF loop which is more in tune to the lower UHF frequencies used nowadays. One would lower the rods to the horizontal position and only extend them about half ways. The loop would be perpendicular to the broadcast towers.
http://www.radioshack.com/product/index.jsp?productId=2103077&znt_campaign=Category_CMS&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2032189#
Mister B is offline
post #4475 of 4526 Old 12-21-2012, 08:45 AM
Gator99's Avatar
Quoted: 72 Post(s)
Happy Holiday's Jax Metro area people - our thread really has slown down over the years.....
Jeff
Gator99 is offline
post #4476 of 4526 Old 01-07-2013, 12:18 PM
reds75's Avatar
Quoted: 86 Post(s)
Liked: 106
It really has slowed down.I can remember when we early HD adapters met at the Waffle House to discuss the start up of the local stations broadcasting in HD. I think there were about ten of us.
Gator99 likes this.
reds75 is online now
post #4477 of 4526 Old 01-07-2013, 02:18 PM
WTEV-JD's Avatar
And a few of us from the TV stations. You guys helped us and we tried to help you.
Gator99 likes this.
WTEV-JD is offline
post #4478 of 4526 Old 01-12-2013, 09:13 PM
rak56's Avatar
Well.. Giving this OTA thing a shot. Sick of a high cable bill. Between an OTA antenna and a jailbroken Apple TV, I'll hopefully have plenty of ways to watch some TV.
Got the antenna today and set-up it up in the garage earlier to give it a go and see if it works.. Picture of the NFL games looked perfect. The girlfriend was impressed. Which is good, since she's been the biggest skeptic of this.
Now gotta do the hard part and run the cable in the attic. Blown insulation definitely makes this a bit harder, but shouldn't be too bad. Was originally planning on hooking up the antenna to the pre-installed cable, but since I still need internet through Comcast, I decided to not touch any of that.
My first time running cable, but only running for one tv at the moment so this should be pretty simple.. Hopefully!
RC83 likes this.
rak56 is offline
post #4479 of 4526 Old 01-13-2013, 07:07 AM
Mister B's Avatar
Quoted: 17 Post(s)
You made a good decision to not involve the separate Comcast cable as the signals from the antenna can not be combined with those. Make sure you point your antenna toward the majority of the broadcast towers, east of the St. John's river and south of downtown. If you have any more questions there are many knowledgeable members on this forum in terms of OTA reception.
Mister B is offline
post #4480 of 4526 Old 01-21-2013, 04:26 PM
lookatthemonkeys's Avatar
So I was running comcast basic (just local stations) to my HTPC digital tuner and my QAM signal is officially gone starting last Saturday or Sunday (it recorded Fringe on Friday night) 01/19/13 or 01/20/13. I haven't been keeping up with this thread and have been ignoring any notifications from Comcast because I assumed they would continue to support QAM but I guess not. All of a sudden my HTPC running WMC says no signal at all no matter what I do. Unless it is a driver problem or something, but I doubt it because I havent changed anything. I switched to a backup antenna that I have in my attic for emergencies for now.....Anyone else?
EDIT: So doing some research it is definitely an odd issue and I would love to hear from others in Jax with this set-up. Even though Comcast's website claims you can get limited basic cable service through QAM, many people are suddenly having issues with it not working.
lookatthemonkeys is offline
post #4481 of 4526 Old 01-21-2013, 06:58 PM
iforgit's Avatar
Just dropped cable and went with Roku and an antenna. I have a wineguard ss-3000. Set up was good and get nearly all channels and sub channels in just fine but WJCT is no where to be found.
Here is the tv fool and although it's not top on the list I'm getting NBC and ABC http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda5a47a73140
Also, this is basically the trial run because we are close to breaking ground on a new house. I plan on dropping cable completely and adding an HDHomerun to the package and networking the house. Any additional tips or tricks would be greatly appreciated on that as well. Just not sure where to start, willing to do the research and homework, but need to be pointed in the right direction.
edit: forgot to mention current house is on the Northside near yellowbluff and new house will be at the beaches.
edit #2: Also should mention I live in a townhome and my neighbor has done the same thing, so we were talking about channels and he can't get PBS either.
iforgit is offline
post #4482 of 4526 Old 01-22-2013, 05:08 AM
ozite's Avatar
I have Comcast, but not the basic level, and haven't had any recent issues with QAM and a pchdtv5500 tuner and MythTV.
If you have a TV with a digital tuner, you could connect it and see if the TV can get the QAM signal. If so, then it is likely a problem (hardware or software) on the HTPC side. You may need to scan for channels again, in case Comcast changed the configuration.
MythTV backend server to frontends to each of the following
ozite is offline
post #4483 of 4526 Old 01-22-2013, 07:56 PM
Gator99's Avatar
Quoted: 72 Post(s)
Regarding QAM - it is best to always check (weekly) Silicon Dust's website to see if channels are added/changed/deleted - which can certainly happen:
http://www.silicondust.com/support/channels/
Keep in mind their list is not always 100% accurate but they can be helpful.
If you have any specific question regarding HDHomerun let me know I have been running their tuners (QAM and Cable card variety) in my house since January 2010 and just really think Windows Media Center and these tuners are incredible (as long as you get your setup right, which I have (Twice now))
Jeff
Gator99 is offline
post #4484 of 4526 Old 01-23-2013, 12:42 AM
OK I think I got it figured out. It freaked me out for a few hours, but my QAM and limited basic cable is still working with Comcast. For whatever reason I guess the QAM channels moved and my WMC no longer recognized them. Typically when I scanned QAM it would give me a giant list of digital channels and I would sort through them using Silcon dusts website. Now for whatever reason when I scan it says "No channels found" and makes it seems like nothing is there, but when I go to edit channels anyways I get my list of channels, although it seems now most of them are locked (they were always locked before but not as many) and now really only the 100.1+ and up work.
post #4485 of 4526 Old 01-29-2013, 10:27 AM
reds75's Avatar
Quoted: 86 Post(s)
Liked: 106
I have a large yagi antenna about 20 ' up. All the locals come in clean except abc25-1 and pbs 7-1. Been this way for12 years. The ota picture is so much better than cable or dish and direct tv.I live in southen st.johns county by the way.
post #4486 of 4526 Old 01-30-2013, 10:40 AM
iforgit's Avatar
Thanks so it sounds like PBS is just tough to get for most? I couldn't read through the entire 150 pages. I just found this surprising because it seems so much more centrally located to my house in comparison.
iforgit is offline
post #4487 of 4526 Old 01-30-2013, 10:54 AM
Gator99's Avatar
Quoted: 72 Post(s)
It has been quite a while but both PBS ABC here are VHF and that does create reception issues if you are not using the proper equipment
Jeff
Gator99 is offline
post #4488 of 4526 Old 02-09-2013, 11:50 PM
trackavsforum's Avatar
Correct. For example, I was using a Winegard SS1000 ch.14-69 (UHF-only) (the 4" flat grey box) which worked fine during the various digital transitions. But I had to switch to a Winegard GS1100 ch.2-69 (UHF&VHF) (the small metro antenna) after the digital transition was complete, because those two stations' "true" frequencies moved back down to RF Channels 7 and 10. WTLV-DT 12.1 NBC was close enough at RF channel 13 that I could get it even with the UHF-only antenna. Antennas marketed at the start of transition were called "digital" or "HD", but all it meant was "UHF" in a world where plenty of folks still had VHF-only antennas.
Well, yagi doesn't necessarily mean anything about frequency range. For example, a Winegard HD 9075P "HD-Platinum" antenna is a yagi, but UHF-only -- so it won't receive those two stations. Versus an AntennaCraft Y5-7-13 which is also called a "yagi" but is actually VHF, for channels 7-13 only -- so it will receive those, but won't receive any of the rest of the digital stations! I'd look up your antenna model and see if you've been unintentionally shooting yourself in the foot all these years. You definitely need both UHF *and* upper-VHF reception here.
trackavsforum is offline
post #4489 of 4526 Old 02-15-2013, 12:35 PM
reds75's Avatar
Quoted: 86 Post(s)
Liked: 106
Thanks for the info .My antenna is about 6' long and is combination uhf/vhf. 47-1 and 30-1 have always been the strongest signal 90plus. 12-1 about 70 and 25-1 and 7-1 around 60.I also have a booster on it.I believe ABC and PBS just send out a weaker signal then the other stations perhaps.
post #4490 of 4526 Old 02-15-2013, 09:18 PM
Oops, don't want to mislead anyone. Though what I said was true about UHF/VHF, @reds75's relative signal strength estimates are also correct: Channel 7, WJCT (PBS) really is pretty weak in the southeast fringe.
post #4491 of 4526 Old 04-15-2013, 10:25 PM
http://www.engadget.com/2013/04/15/comcast-encrypt-basic-cable/#comments
Does anyone know how the new Comcast rules will affect current QAM users?
I am currently running a HTPC with WMC and have the limited basic Comcast cable to obtain my QAM channels. I have been threatened before that I will require a box, but I have always ignored them and my setup has always worked. I obviously can not use a box with my HTPC and I am not going to get a cable card just for local channels. Does anyone know any additional info? Thanks
post #4492 of 4526 Old 04-16-2013, 05:49 AM
Gator99's Avatar
Quoted: 72 Post(s)
If/when this happens you will have to have cable card or STB, OR use your tuners for OTA ATSC broadcasts. Sucks that FCC allowed this
Jeff
Gator99 is offline
post #4493 of 4526 Old 05-30-2013, 01:30 PM
snevensmores's Avatar
Can anyone recommend an antenna for me? I have a mast I made out of metal fence top bars (about 2" in diameter, I'd say). It's placed next to my house, braced to my roof eave. It's probably about 22-25' AGL. I have a cheapo $30 antenna up there right now that's mostly plastic and poorly made, and I'm not getting all the Jacksonville channels that I want. Most of them come in OK, but it's struggling with VHF, and my Vizio TV is only detecting 25 channels, half of which are watchable. I'm on a limited budget, so I'd like to do this relatively cheap. Here's my TVFool report.
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1ddab040d79cb6
I'm looking at this antenna right now. Would this be suitable for me, or could I get a better deal on something else?
http://www.solidsignal.com/pview.asp?p=hd7694p&d=winegard-hd-7694p-high-definition-vhf/uhf-hd769-series-tv-antenna-%28hd7694p%29
Thanks everyone in advance!
snevensmores is offline
post #4494 of 4526 Old 05-31-2013, 08:06 PM
Mister B's Avatar
Quoted: 17 Post(s)
You are going to need one of the larger Winegard High VHF/UHF antennas. They do cost a bit more but are very well made. You have a good selection of many stations to receive but from several directions. If you are looking to save some money in the short term, you could do what I did as a kid in Northern Florida and go out and turn the antenna pole by hand.
Mister B is offline
post #4495 of 4526 Old 06-01-2013, 08:33 AM
tylerSC's Avatar
Quoted: 766 Post(s)
Liked: 171
Winegard 7698 would be a good choice. Or the Antennacraft HBU55 is a bit cheaper and also performs well. But not as good build quality.
tylerSC is offline
post #4496 of 4526 Old 06-01-2013, 01:27 PM
Mister B's Avatar
Quoted: 17 Post(s)
Here is another scenario to consider. Get a Winegard YA 1713 High VHF antenna and point it at Jacksonville for PBS on RF7, ABC on 10 and NBC on channel 13. This is widely considered to be the best high band VHF antenna available and I can personally attest to the fact that it made a huge difference when I was in a difficult reception situation. If it will not pull in the VHF from Jacksonville, nothing within reason will. It would be about $40 from the same vendor mentioned above.
Add to that the Antennas Direct DB4e for UHF directed at your CBS affiliate on channel 28. That would also give you FOX on RF 31, slightly off target but you are LOS to it as well as a secondary ABC on channel 16 and possibly an alternate PBS on channel 36. The DB4e is $50.
Tie the two antennas together with a Pico Macom UVSJ for $10. The UHF/VHF joiner allows you to point the two different band antennas in different directions, something you can not do with two antennas designed for the same band and one can not simply use a two way splitter backwards. The whole project would cost just slightly less than the Winegard 7698 and would not require a rotor or turning the pole. It would also have the advantage of giving you news and weather from both Jacksonville and I would assume the more relevant Gainesville market. As I said, something else to consider.
Mister B is offline
post #4497 of 4526 Old 07-17-2013, 08:35 AM
RC83's Avatar
I live in Fleming island and am doing the exact same thing, got the jail broken apple tv... and am not about to buy an antenna... any suggestions as to which antenna works best in Fleming Island? Thanks!
RC83 is offline
post #4498 of 4526 Old 08-08-2013, 08:26 AM
iforgit's Avatar
What did you end up with? I'm building a house in Jax Beach and having someone install a home network and he had a big blank look on his face when I described my antenna and hdhomerun setup. Someone else in his store piped up with the website for antennasdirect but wasn't sure if that was the best appliation. We spray foamed the attic ceiling so I think I'll need an exterior one and it needs to withstand some stronger winds (they already ran a RG-6 through the eves to the west side of the home).
Any help would be appreciated
iforgit is offline
post #4499 of 4526 Old 08-08-2013, 01:53 PM
I ended up with the Winegard 7694P mounted on a tripod on my roof. It's about 25' above ground level. I also added a Winegard 8700 pre-amp. It works pretty well for me, as I'm about 47 miles from the Jacksonville transmitters. I will say that I wish I would have bought a bigger Winegard antenna. I should have followed others' advice on here and spent a little more. That being said, my setup still works pretty darn well most of the time. Your first stop should be tvfool.com to do some research on your location and your needs!
post #4500 of 4526 Old 08-09-2013, 01:49 PM
wmsbrum's Avatar
Yep, it works with the power injector...don't see why I'd need it, but it wont pick up CBS without it!
wmsbrum is offline
